  newest project (Page 8)
This topic is 78 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78
newest project by bubbajoexxx
Started on: 09-12-2003 06:18 PM
Replies: 3117 (378082 views)
Last post by: Phirewire on 07-03-2025 10:49 PM
crzyone
Total ratings: 176
Report this Post03-13-2004 07:09 PM Click Here to See the Profile for crzyoneSend a Private Message to crzyoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joe, you get a big + from me, that is awesome. Thanks for the info on the brake swap!
Master Tuner Akimoto
Total ratings: 271
Report this Post03-13-2004 08:06 PM Click Here to See the Profile for Master Tuner AkimotoClick Here to visit Master Tuner Akimoto's HomePageSend a Private Message to Master Tuner AkimotoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joe PM sent .
bubbajoexxx
Total ratings: 112
Report this Post03-13-2004 09:14 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
here are some of the sizes I will post the rest tomorrow
consentic rings front outside diam. 2.785 inside diam. 2.240
" " rear outside diam.2.785 inside diam. 2.255
drill spindels to 7/16
tap drill size 13/32 for use with the 12mm 1.75 x 30mm long cap screws
block diamentions 1"x 2.5' x 4.5' long 7/8" thick nothing less or the adapters are no good and caliper brackets will rub this uses no washers to line things up
bolt spacing tomorrow
ps: you can retain the stock hoses they bolt right up
[This message has been edited by bubbajoexxx (edited 03-13-2004).]
I Annoy
Report this Post03-13-2004 09:30 PM Click Here to See the Profile for I AnnoySend a Private Message to I AnnoyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joe, will this work on any year Fiero or is it just for 88's?
The Rebirth of 72vinman
bubbajoexxx
Total ratings: 112
Report this Post03-13-2004 09:43 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
this is for 84 to 87 only 88 not included
I Annoy
Report this Post03-13-2004 09:52 PM Click Here to See the Profile for I AnnoySend a Private Message to I AnnoyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joe you have a PM
Fierofreak00
Total ratings: 170
Report this Post03-14-2004 05:30 PM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bunp Don't want to loose this one. Bubba, do you have a write up for this?
A coward dies a thousand deaths..................A soldier dies but once.
Red 86 SE
Yellow 87 GT
Gold 86 SE (wrecked)
Red 84 2.5 Coupe
In the process of buying another 87 GT
Fierofreak00
Total ratings: 170
Report this Post03-15-2004 07:22 PM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump from page 3
stevenrossi
Total ratings: 126
Report this Post03-15-2004 07:39 PM Click Here to See the Profile for stevenrossiSend a Private Message to stevenrossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bub, you've got a bunch of e-mails at you @sprint account.
Thanx
Steve
bubbajoexxx
Total ratings: 112
Report this Post03-15-2004 07:42 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
where I just checked none My email is bubbajoexx@sprint.ca
bubbajoexxx
Total ratings: 112
Report this Post03-16-2004 09:48 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here you go boys the diamentions I promissed for the brake adapter
for a larger view use this link
http://groups.msn.com/FieroCaddySwapGroup/general.msnw?action=get_message&mview=0&ID_Message=5396&all_topics=0
[This message has been edited by bubbajoexxx (edited 03-16-2004).]
Fierofreak00
Total ratings: 170
Report this Post03-16-2004 10:21 PM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you sir! You wouldn't happen to have a drawing like that for the spacer would you ? If I could give you another + I would!
bubbajoexxx
Total ratings: 112
Report this Post03-16-2004 10:48 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
if you mean the consentric ring I wil lpost one found it
shop_rat45
Total ratings: 111
Report this Post03-16-2004 10:59 PM Click Here to See the Profile for shop_rat45Send a Private Message to shop_rat45Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info on the brake swap. A+ for you!! One dumb question though. Those are corvette calipers, right? What years?
Thanks,
Kris
bubbajoexxx
Total ratings: 112
Report this Post03-16-2004 11:06 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
85 to 87 corvette and vette caliper mounts same years
extra large versions are avalable at this link
http://www.fortunecity.com/skyscraper/switch/67/id213.htm
mattm
Total ratings: 60
Report this Post03-16-2004 11:10 PM Click Here to See the Profile for mattmSend a Private Message to mattmEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am going to try this with my 86. Can i use the stock master cylinder and proportioning valve? If not, where should i source the new ones.
Thanks, Matt
bubbajoexxx
Total ratings: 112
Report this Post03-16-2004 11:15 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
if you update the master use the 72 to 80 Vette master plenty of volume and it is made for 4 wheel disk dont use the s10 you are gaining nothing as it is the same bore as a Fiero and is for drum rear disk front not a good combo
shop_rat45
Total ratings: 111
Report this Post03-17-2004 12:08 AM Click Here to See the Profile for shop_rat45Send a Private Message to shop_rat45Edit/Delete MessageReply w/QuoteDirect Link to This Post
What about a master cylinder from a newer 4WD S-10. They have 4 wheel disc brakes. I would like to use one that has the plastic resivoir on it so the vehicle will look newer. I've also heard you can use one from a newer Tahoe. You need an adjustable proportioning valve though.
Kris
bubbajoexxx
Total ratings: 112
Report this Post03-17-2004 12:19 AM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
as i posted before the vette is the best the new cars are anti lock and rely on the system pump to make up the extra fluid so I would not use them they are also low volume
Fierofreak00
Total ratings: 170
Report this Post03-17-2004 07:16 AM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you that was just what I was looking for. Thanks for the link to your site it answered a few more questions I had.
hellfish87gt
Report this Post03-17-2004 12:34 PM Click Here to See the Profile for hellfish87gtClick Here to visit hellfish87gt's HomePageSend a Private Message to hellfish87gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
well my to do list just got a little longer thanks
jayguy
Report this Post03-17-2004 01:28 PM Click Here to See the Profile for jayguyClick Here to visit jayguy's HomePageSend a Private Message to jayguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info. I've been trying to figure out how to improve my brakes, looks like I'm gonna go this way!
Any more pictures of the car? Or have you spent the majority of your time on drivetain recently? Looking forward to the finished product.
Jay
'87 Fiero SE V6 5sp
Still all stock, with many many upgrades in the planning stages.
tesmith66
Total ratings: 135
Report this Post03-17-2004 01:53 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm assuming you have to turn the Fiero rotor down to make a hub like the Grand Am conversion?
1986 SE 350 V8
Fie Ro
Total ratings: 132
Report this Post03-17-2004 02:49 PM Click Here to See the Profile for Fie RoSend a Private Message to Fie RoEdit/Delete MessageReply w/QuoteDirect Link to This Post
1987 Pontiac Fiero GTR in progress
1969 Chevy Suburban
Mighty Mouse
Report this Post03-17-2004 04:17 PM Click Here to See the Profile for Mighty MouseSend a Private Message to Mighty MouseEdit/Delete MessageReply w/QuoteDirect Link to This Post
16 and up only 15's are a no go the 16 inch wheels clear by 3/4 of an inch on inside diam.
I'm not saying I don't beleive you, but it there is 3/4" of clearence to the inside od a 16" rim, a 15" rim is only 1/2" closer (clearence is on the radius not the diameter) doesn't that still leave a 1/4"? Or is the problem with 15s less in the diameter clearence and more in the inside face of the wheel? Yes, I realize I'm grasping here, but I want to keep my 15s for autocrossing so I don't have to by yet another set of rims, and this is definitely a sweet brake upgrade. + for you even if they don't fit inside the stock 15s
Thanks,
Troy
bubbajoexxx
Total ratings: 112
Report this Post03-17-2004 07:15 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
no the inside diamiter of the 15 inch wheel will rub the caliper it is much smaller than the 16 it is where tha taper startsthat will rub
mattm
Total ratings: 60
Report this Post03-17-2004 07:17 PM Click Here to See the Profile for mattmSend a Private Message to mattmEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, i am definately going to ry this. One more question: what do i do about the hubs? Do i cut down the stock ones?
Thank you, Matt
bubbajoexxx
Total ratings: 112
Report this Post03-17-2004 07:19 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
yup you can cut the rotor off with a mini grinder if you have an old spindle to mount it to
[This message has been edited by bubbajoexxx (edited 03-17-2004).]
bubbajoexxx
Total ratings: 112
Report this Post03-18-2004 10:32 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
hoping for nice weather tomorrow and will take step by step photos as I replace the spindle and brakes on the pass. side of the project car so you can see how easy it is .
bubbajoexxx
Total ratings: 112
Report this Post03-18-2004 10:36 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bubbajoexxx
Member since Aug 2003
I set the bakes up on a preped spindle and swap the new spindle for the old one
easer to set up off the car when you have te spare parts (ie) cleaning and drilling of the bolt holes
[This message has been edited by bubbajoexxx (edited 03-18-2004).]
OH10fiero
Report this Post03-19-2004 01:27 AM Click Here to See the Profile for OH10fieroSend a Private Message to OH10fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
bubbajoexxx, are the adaptors the same for front and back? Are you useing a e-break design for the rears on your car? since you did not say I was currious
crzyone
Total ratings: 176
Report this Post03-19-2004 02:27 AM Click Here to See the Profile for crzyoneSend a Private Message to crzyoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Joe! I would really appreciate step by step instructions with pictures, if I could give you more ++ I would.
Fierofreak00
Total ratings: 170
Report this Post03-19-2004 07:24 AM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah! I agree this would be a dandy idea!
PURPLE REIGN
From: Minnesnowta ------------------ Land of White Gold
Total ratings: 303
Report this Post03-19-2004 09:42 AM Click Here to See the Profile for PURPLE REIGNSend a Private Message to PURPLE REIGNEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, Matt
Or you find someone like myself who makes those hubs for $60 a pair
bubbajoexxx
Total ratings: 112
Report this Post03-19-2004 10:20 AM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
OH10fiero
the rear will be done as a multi caliper setup with a small mecanical rear caliper unless I can find a set of 95 to 2000 rear vette calipers as the rear upright must have the old brake setup completely remved and a new adapter that mounts under the wheel bearing installed to hold every thing will post pics of every aspect of the rear vette swap including the diagrams with diamentions
bubbajoexxx
Total ratings: 112
Report this Post03-19-2004 10:25 AM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bubbajoexxx
PURPLE REIGN
thats is a more than resonableprice to cut rotors down I would recomend you +
OH10fiero
Report this Post03-19-2004 05:05 PM Click Here to See the Profile for OH10fieroSend a Private Message to OH10fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Second question since I forgot to ask last post. On the concentric ring, did you fabricate that as well, or are you just useing something similar to a washer for this?
Looks more like you would have to make that ring than just find something like that happend to be in your tool box.
bubbajoexxx
Total ratings: 112
Report this Post03-19-2004 05:19 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
crzyone
the step by step is now being uploaded to my site I will also post it here with much smaller pics to save space lots of pics
http://www.fortunecity.com/skyscraper/switch/67/id214.htm this is the link
crzyone
Total ratings: 176
Report this Post03-19-2004 05:28 PM Click Here to See the Profile for crzyoneSend a Private Message to crzyoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Joe!
I have a question. What exactly is a cut down rotor? Is it a stock fiero rotor with the braking surface cut off and just the hub left? This is then placed inside the corvette rotor and new bolt holes must be drilled in the rotor for the fiero boltpattern? I think I just answered my own questions. Great pictures, where did you buy your rotors and calipers from?
Thanks Again
[This message has been edited by crzyone (edited 03-19-2004).]
bubbajoexxx
Total ratings: 112
Report this Post03-19-2004 05:28 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
OH10fiero
had them made $25.00for 4 2 front 2 rear as they are differant sizes
