Aurora 4.0l / Izuzu 5 speed swap into 88 coupe by cptsnoopy
Started on | : 04-27-2004 07:21 PM |
Replies | : 1016 (73534 views) |
Last post by | : Will on 01-15-2025 10:29 AM |
Aug 22nd, 2005
cptsnoopy Member Posts: 2587 From: phoenix, AZ, USA Registered: Jul 2003
| quote | Originally posted by Russ544: I'm anxious to see your solutions to the Isuzu hurdle as well. There's plenty of meat in the stock arm to machine the sides flat and drill/bolt on an extension but I'm curious how you'll mount the slave. are you still planning to use the pull slave? You'd better get a move on ...... I expect to be doing a final install on mine next weekend still no computer to update my build progress pics, but maybe by mid week. Cheers, Russ |
I have a lot on the burner right now but I would love to get this thing going. This darn cold I picked up yesterday is not helping much...
I am still planning to use the pull slave. It should be a fairly simple install. To keep the bleeder on the top side the slave body will be attached to the release arm and the slave piston rod will be attached to the trans. the slave will be at an angle and hopefully that will help the bleeding process. with luck the stock flexable tubing will work, if not a small extension will be used. The biggest problem now is that the tranny is buried behind the 88 while i battle getting the 86 engine back in. If I get this broken off thermostat housing bolt out of the intake manifold without destroying something then it should proceed normally again. I hope you are able to post some of your latest pics soon. your work is very inspiring!
12:43 PM
Russ544 Member Posts: 2136 From: S.W. Oregon Registered: Jun 2003
Oooooou summer colds really suck. btdt . As far as your broken stud: a little heat on the aluminum surounding the stud can really be your friend. get it plennty hot and work the stud back and forth if possible. never try to just force it out in one dirrection. Cheers, Russ
09:56 PM
ryan.hess Member Posts: 20784 From: Orlando, FL Registered: Dec 2002
You know, I had to look at the first post, and I realized you've been working on this for a year and 4 months now... Are you done yet!?
11:33 PM
Aug 23rd, 2005
GSXRBOBBY Member Posts: 3122 From: Southern Indiana USA Registered: Aug 2003
| quote | Originally posted by ryan.hess: You know, I had to look at the first post, and I realized you've been working on this for a year and 4 months now... Are you done yet!?  |
No hes like me, things have been put on hold....working in the heat sucks ass. But then again if he was out in the garage working on the car in the heat he may have not gotten sick?
11:42 AM
I think I get sick from work. some trips we work all night the first night and by the 3rd day we are back on a morning schedule... I had a trip like that followed two days later by one that started in the day time and then ended with all night flying. It's hard to convince the brain that it is time to sleep when you need it. funny how I seem to get sick after a few of the worst schedules back to back... I had hoped to get this thing running by last December but when I started thinking about using the GT body from the 86 it just threw that all out of whack. Russ, I was given an idea that I plan on trying. I will use my wire-feed welder to tack on an extension to the little bit of bolt that is sticking out. Like a 6" long 5/16" bolt. Then before it gets a chance to cool off too much, try to work it out like you describe. It should be interesting. But, a lot better than trying to drill it out and heli-coil what's left...
05:45 PM
Aug 24th, 2005
Well Russ, It worked great! not a gimmie as I was about to give up.... but on the third bolt I was able to get the broken bolt hot enough to stick and with a little massaging and a lot of PB blaster it came out and left clean threads.     [This message has been edited by cptsnoopy (edited 05-11-2012).]
06:36 PM
Don't ja' just love it when a plan comes together
08:48 PM
Sep 8th, 2005
just a quick update to keep the thread alive...  another bolt snapped when I tried to replace the water pump. that was just over a week ago and with the nice timing cover that PFF member "ditch" sent me the engine is almost ready to put back in the 86. when that is done then I can continue with the body swap... quite a bit got done in the last couple of days and if that continues, I should be working on the 88 in less than a month. the current plan is to finish making the 86 into a yellow coupe and have it drivable. then work on the mechanical part of the 88 until it is running. then finish putting the GT body on.
03:06 AM
So have you stopped working on the 4.0?
10:35 AM
Hi Ryan, I have stopped working on the 4.0 only because I wanted to put the 86 GT body on the 88. so I took the body off the 86 and while the body was off I decided to put the aluminum bushings in the cradle. while the engine was out, I thought I would change out the coolant and heater hoses. That last little idea has cost several hundred dollars and is just about finished. when the 86 is back together with the 88 coupe body then I will finish putting the aurora into the 88 and get it running. then finish putting the 86 GT body on. so in summary yes, for a short while...
01:09 PM
Sep 23rd, 2005
getting closer to getting back on track!  the 86 2.8 started last night and no leaks....yet..  now the body from the 88 starts coming off. must.. be.. careful..
03:43 PM
Nov 15th, 2005
finally back at it. the yellow front clip is off. the parts from the 88 are in much better shape than those from the 86GT. I don't suppose anyone knows how to remove the sail panels without breaking something?
03:35 AM
Dec 12th, 2005
Hey Snoopy, its been awhile since I have been on here and glad to see your getting back after it. I am still on hold for a while, I heard a razor blade and strong fishing string works when done right? ------------------ Bobby from NW Indiana 93 Northstar and 5 speed Getrag NEW e-mail address 219customs@sbcglobal.net My 86 GT build thread MY 88 Northstar build thread
01:06 PM
Dec 13th, 2005
Hey GSXRBOBBY, How goes it? I have been so busy playing with the wife and another hobby that has crept into my life... I just need to pull the interior out of the 88 to take the front roof cover off. Then those sail panels... I will try your suggestions as there is most likely some glue on the forward side.
01:54 PM
Dec 14th, 2005
I actually got something done this evening  the red roof w/sunroof is now sitting on the 88. whew...
06:00 AM
| quote | Originally posted by cptsnoopy: I have been so busy playing with the wife and another hobby that has crept into my life... |
Huummmm. that does sound like fun also curious about the "other hobbie". I just happened to think.. if you need anyhing from my "stash" for your project, my dad will be snowbirding to Scotsdale in a couple of weeks and could perhaps bring it down. let me know. Russ
10:53 AM
Dec 15th, 2005
How did you get them off?
02:08 PM
actually, I have not removed the sail panels yet. The rear notch-back part of the body is still on the 88. I just set the 86 roof panel on the car for now. when I was removing the interior pieces from the 88 I broke some of the trim that runs along the top of the window and down the a-pillars. It appears that the little metal clips held the plastic much better in 88.  after breaking some stuff, I decided to take a rest and do the sail panels when I am not in any hurry. I will need to do some research to find out how they really do come off. I don't want to break these two, they are in pretty good shape. hopefully there is more hope of getting these off in one piece compared to the fastback quarter windows...
02:18 PM
| quote | Originally posted by cptsnoopy: hopefully there is more hope of getting these off in one piece compared to the fastback quarter windows... |
OOOoooooooo. I thought you were asking about gt windows......... notchies I know abbout . Behind the arrow on the sailpanel is a stud. the nut on that stud is accessed inside the car after the interior trim is out of the way. once the nut is removed lift the sail panel enough for the stud to clear the body, then wile holding it out bump the sail panel towards the rear of the car with the palm of your hand to release the two clips on the rear edge. you'll want to place some tape on the paint berhind the sailpanel to protect it from scratching as the panel comes off. [thinking] if you meant how to get just the glass off the sail panel without it breaking....................... you can't. it's impossible  hope this helps, Russ
08:27 PM
Dec 16th, 2005
Hey Russ544, Thanks! That is exactly what I needed. now, no more excuses, I'll get to it asap.  (that is after I get some sleep... )
07:01 AM
Jan 5th, 2006
More progress, slow that it is. The rear body of the 88 is off and after cleaning will go onto the 86. Fastners look like the next hurdle...
12:26 AM
Feb 10th, 2006
Go big daddy go!!!
02:26 AM
Hey Bobby! things are going very slowly but the I got the rear of the 88 on the 86. I need to move the exhaust tips inward about a half inch to center them in the cutouts. I guess I may have to try bending them in as the clamps have recessed the tubes and I doubt if they would stay after being moved a tad. How are things in your neck of the woods?
08:28 AM
Well the newer place we are at has just a 1 car garage so room is tight, taken the car to a friend new polebarn in the spring. I am about to start doing a few smaller things on it to help pass the time until I go back to work in the spring, "interior stuff". Other than that just getting ready for the wedding, watching her spend way to much money! Still flying?
02:55 PM
Feb 12th, 2006
How are we gonna convince that young lady that the money is better off spent on a Fiero? maybe we ought not try that...  yup, still flying, the future is uncertain but time will tell one way or the other.
06:41 AM
| quote | Originally posted by cptsnoopy: yup, still flying, the future is uncertain but time will tell one way or the other.  |
Are you doing the Hi flight still? in the words of Glen Volk (a top comp HG pilot): "crossing unlandable terrain makes you a better pilot."
, Russ
[This message has been edited by Russ544 (edited 02-12-2006).]
11:11 AM
I went out to Estrella Sailport about a month ago and got current again. Now I have to do a couple of flights now and again to stay current and not have to fly solo for three laps. I took a couple of friends up for a ride. The lift was marginal as it seems to be this time of year but a couple of 45 minute flights were managed. If your in town and have half a day to spare, let me know so you can play with the other gliders. (I am sure it's not as thrilling as hanging out in the breeze but it is enjoyable.  ) As far as work goes, I am just keeping my fingers crossed. I am guessing that there are thousands of other folks out there doing the same about their job in whatever field they may work in. It just seems to be part of the "times". [This message has been edited by cptsnoopy (edited 02-12-2006).]
11:51 PM
Mar 6th, 2006
One issue I have found with swapping the bodys is that the exhaust tips are further out on the 86GT compared to the 88 coupe. I ended up loosening up the clamps and wrestling the tips off then cutting 1/2 inch off of the pipe from the muffler on each side of the car. Now the tips fit into the exhaust notches on the 88 coupe bumper pad. back to work.....
03:15 AM
Mar 19th, 2006
Are you done yet?  btw, I wanted to ask you... How much did you pay for your header parts? flanges, bends, etc?
10:40 PM
THE BEAST Member Posts: 1177 From: PORT SAINT LUCIE,FLORIDA,USA Registered: Dec 2000
ryan.hess You have a PM! JG
11:06 PM
Mar 20th, 2006
| quote | Originally posted by ryan.hess: Are you done yet?  btw, I wanted to ask you... How much did you pay for your header parts? flanges, bends, etc? |
Not yet, progress has been very slow getting the body swapped. As soon as the 86 is driving again and out of the garage, I can start painting the motor mount parts and have the exhaust ceramic coated...
I paid $496 for the exhaust parts from SPD, that included shipping.
01:14 AM
May 15th, 2006
I thought I would replace the old windshield while the roof was off. Not too hard to cut the top and side sealant away but there is less room to work with on the bottom. once the windshield is out I can get some butyl rope to install the roof and put this yellow 86 back on the street...
04:05 AM
Jul 12th, 2006
MclarenF1 Member Posts: 639 From: Kingston, WA Registered: May 2006
BUMP!
12:11 AM
Jul 18th, 2006
cool! I got bumpped  there has been the usual distractions and the project is waiting on getting the window guy out here to install the new window. (right after I clean the old adhesive off and glue down the top). once that is done and the coupe is out of the garage, the Aurora will be back in for completion. Did anyone mention that it is hot around here? I hear that everyone is getting a taste of what we get for most of the summer. I feel for you all, it ain't great until fall, winter and spring...
04:22 PM
Jul 21st, 2006
good new concerning the butyl rope for the roof. The 3/8's inch size for installing windows seems to work fine. I pinched it a little bit to raise it up a tad more than 3/8's. When I set the roof on, I started from the rear and after the bolts all fit in their holes, I pressed on the front of the roof and then down the a-pillars. The a-pillars seem to be plenty secure. The glass guys are coming tomorrow.
07:26 PM
You ever decide on what to do about the Isuzu shift problem?
08:40 PM
So there is a gap larger than 3/8" between the roof and the panel? I wonder if you can tap into that for airflow....
08:54 PM
Jul 22nd, 2006
I was just wondering the other day what ever hapened to you snoop  - hot? naaaaa it was only 108 here yesterday and is forcast to drop all the way to 106 tomorrow. kind of like your night-time temps  I still have those heads if you need them. new wife, house being built, and won't have time for projects til winter up here. Stay cool, Russ
12:04 AM
| quote | Originally posted by MclarenF1:
You ever decide on what to do about the Isuzu shift problem? |
I think you are talking about the shift cables running through the space where the air intake should be? Or the clutch slave? I have not tackled either but I don't see much problem there. For now the shift cables will stay in their stock location and the air intake will either run just forward of them or around both sides. The clutch slave worked like a champ on the sandrail I used to own, I am hoping for the same success here. I may have to consider the stock master cylinder volume versus the after-market one I was using on the sandrail. | quote | Originally posted by ryan.hess:
So there is a gap larger than 3/8" between the roof and the panel? I wonder if you can tap into that for airflow....  |
|  The butyl rope that came off of the car looked to be about 5/8's to 3/4" round. I decided to try less instead of more for the first go at it. It seemed to smoosh down to around 1/4" or so. As long as it does not make noise while driving, all is well... | quote | Originally posted by Russ544:
Stay cool, Russ |
Hi Russ, I am still here. That danged model helicopter hobby really grabbed me! I'll have to send a pic. I am really embarrassed to admit that the interior pieces that you so thoughtfully gave me were the wrong color. I did not have a light color interior to compair the two and I got it wrong. The good news is that they are going into the 86 and the dark gray ones from the 86 will go into the 88. Thanks again for all the parts! If it looks like the stock heads on this engine are bad, I will see about coming up for a visit.  (I just hope I find out this year...) It was only 118 degrees today, with humidity. Thank goodness for the large thunderstorms blowing through, the temps fell to a cool 108.  Congrats on your new wife and house, that's a lot of project all on it's own! charlie
05:37 AM
the new windshield looks great! Now I have to screw on the front fenders, hood and other body parts on to make it road-worthy, almost got some new space in the garage...
07:20 PM
