  The Turbo Super Duty Build. (Page 11)
This topic is 16 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16
The Turbo Super Duty Build. by FastIndyFiero
Started on: 09-27-2004 06:50 PM
Replies: 629 (86146 views)
Last post by: fieroguru on 09-28-2024 06:28 PM
FastIndyFiero
Total ratings: 70
Report this Post10-02-2007 06:09 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by darkhorizon:
Assuming it flows in the same ballpark to what a dohc head can flow, 600 horsepower is not at all far off. The only problem i see is the fact you will need to run MORE than 30psi of boost.
I think an hx40 or hx55 holset would do this for you. They live at 30psi, and can even go higher without to much efficiency loss.
Peak flow is almost 280CFM for my 2v head, not fantastic, but it's no slouch. I'm also not sure why you think I will need to run more than 30 psi. I already have a Garrett GT3776, 76mm compressor wheel, HX55 is slightly smaller at 72mm.
I almost forgot to add, also, that this is computed with 110 octane, and icewater in the IC. Obviously on pump gas it would be much less. I have no idea if I could hit 800HP, if I'm going to try I'm probably going to need another set of injectors. Historically this program has been very accurate...Only one way to find out
(I think the "one way to find out" is MORE MONEY)
darkhorizon
Total ratings: 451
Report this Post10-02-2007 08:27 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
the moltron #65's that you can get and still run high imped, will limit you to 400-500 horsepower anyway, just go all out and get the 1500CC injectors and call it a day. (about 150# injectors lol)
86FieroCentPa
Report this Post10-02-2007 09:51 PM Click Here to See the Profile for 86FieroCentPaSend a Private Message to 86FieroCentPaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im sorry I dont have anything productive to add to this thread. Other than I have been following it for awhile, and I think that this motor will be amazing.....But this 800HP stuff just reminded me. You're lucky that your thread didnt fall to these dogs....
https://www.fiero.nl/forum/Forum2/HTML/086397.html
FastIndyFiero
Total ratings: 70
Report this Post10-24-2007 10:38 AM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was surfing the net in between classes and found this, thought it was pretty sweet.
http://www.hotrod.com/featu...cylinder_engine.html
1030hp/680lb-ft of torque on 20PSI. Yikes! The new-tech old-4cyl approach worked well for them...
FastIndyFiero
Total ratings: 70
Report this Post11-07-2007 07:28 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been getting bored again...Also following yet another lead on camshafts....
So I've been designing a new 4-bolt splayed cap (again). My cap girdle got me thinking about how thermal expansion affects cap and bearing deformation, and the results are pretty amazing. I've been testing various cap geometries to try to get the least deformation at the crank-cap interface. The standard cap geometry used by most vehicles does some interesting things when heated to 200*F. I don't have any pics of the test results yet, but here's one design I've gone through:
Nate
RandomTask
Total ratings: 150
Report this Post11-07-2007 07:33 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Catia?
Mr.PBody
Total ratings: 101
Report this Post11-07-2007 09:57 PM Click Here to See the Profile for Mr.PBodyClick Here to visit Mr.PBody's HomePageSend a Private Message to Mr.PBodyEdit/Delete MessageReply w/QuoteDirect Link to This Post
As of today in what state is the motor in? Are you nearing completion? I have been following this thread forever!
KurtAKX
Total ratings: 128
Report this Post11-08-2007 12:33 AM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bet its farther from assembled than it was at this time last year
FastIndyFiero
Total ratings: 70
Report this Post11-08-2007 04:12 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh, I think it actually might be LESS assembled than this time last year. At this point, all I need is some deciding factor to either use the Cossie stuff or the Pontiac stuff I already have. It seems like I've come 10 miles, and the long block is only about 1 inch away from being done (and done right too) if I use the Pontiac head. Lack of parts might end up nixing the Cosworth gear, but it's always been what I really wanted to try. The geometry of the Cossie head allows me to make optimizations with the intake and exhaust system that I wasn't able to do with the Pontiac head, and I think in a street environment the Cossie would probably be more reliable.
Anyway, the State of the Motor Address, by item (using Pontiac SD parts):
BLOCK - Needs to be plateau honed .002" and a couple oil holes on the deck plugged.
Crank/Rods/Pistons - Done
Head - Coated, P&P'd, Flowed, needs to be reassembled
Intake - Done
Oil Pan - Need one
Valve train - Need pushrods
Exhaust - Need to go through a few more header designs, it's a PITA
Clutch/Trans - Need to determine gear ratios => Trans => Trans spacer and spline for 3 disc 5.5" clutch
Engine management - Ehhhh......Haven't decided how done I am on this yet. (VEMS? MS-II? Big $tuff 3?)
This is your State of the Motor
FastIndyFiero
Total ratings: 70
Report this Post11-08-2007 04:18 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
FastIndyFiero
Member since Aug 2002
Forgot pics from my FEA results...
Because of where I constrained the mock engine block, the displacement of the cap is shifted on the scale. I'm EXTREMELY happy with how this design has turned out, there is VERY little deformation of the cap bearing surface (around .00004" variation) when thermal and bolt-tightening loads are applied. The stock SD main cap was around .002" at the top of the cap bearing surface.
RandomTask
Total ratings: 150
Report this Post11-08-2007 05:11 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
So did you hear anything back from cosworth about your cam stuff?
*fap* *fap* *fap* as I go through this thread. . .
30+mpg
Total ratings: 97
Report this Post11-08-2007 09:53 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Fast,
How much have you actually driven your Indy in the last 3 years?
The_Stickman2
Report this Post11-08-2007 10:24 PM Click Here to See the Profile for The_Stickman2Click Here to visit The_Stickman2's HomePageSend a Private Message to The_Stickman2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Intake - Done
Oil Pan - Need one
Ah!! you need an Oil pan. You should get one like this. I will need to have it modified to use the stock motor mount bracket but that shouldn't be hard. I wonder how many quarts it holds. I also have the one that came on my IMSA which looks like a stock oil pan with the sump modified and two tubes for the drain down from the intake. BTW I in no way paid anywhere near that $508 price tag you see on the pan.
FastIndyFiero
Total ratings: 70
Report this Post11-14-2007 07:21 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bored again.
Right now it's REALLY messy, and isn't the configuration I want, but it's buildable.
RandomTask
Total ratings: 150
Report this Post11-15-2007 08:31 AM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
just some quick tips on your exhaust, route them into the collector in correspondence with the firing order. By this, I mean, have the first cylinder that fires, next to the 2nd. Have the 2nd next to the 3rd, the 3rd next to the 4th, and the 4th next to the first. With this, it keeps a velocity (less turbulence) in your exhaust, increasing the scavanger effect. May not seem like much, but i've seen 5hp gains in 105 hp 600cc engines by ONLY doing this.
FastIndyFiero
Total ratings: 70
Report this Post12-02-2007 09:41 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
My turbo uses a divided turbine housing, so cylinder pairs 1-4 and 2-3 will be seperated from each other. This also means that the turbo C/L will be running fore/aft, so I might need to "clearance" the front firewall a bit. Or I may still design one that puts the turbo C/L running transverse. Don't know yet. That involves physical mockup that I need to do...
Here's a very short video of my more refined exhaust model:
http://www.youtube.com/watch?v=A-EQsGb0q9k
88 Silver Formula
Report this Post12-02-2007 10:45 PM Click Here to See the Profile for 88 Silver FormulaSend a Private Message to 88 Silver FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
any more updated?
FastIndyFiero
Total ratings: 70
Report this Post12-24-2007 03:47 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm pretty sure it's done...Length from head flange to collector is 19". Each runner is composed of 4 seperate bends, 3 welds required for each, plus the transition from oval to round.
The_Stickman2
Report this Post12-24-2007 09:40 PM Click Here to See the Profile for The_Stickman2Click Here to visit The_Stickman2's HomePageSend a Private Message to The_Stickman2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Why use 4 single flanges vs one large flange?
My sites
http://the-stickman.tripod.com
http://www.youtube.com/TheStickman
RandomTask
Total ratings: 150
Report this Post12-28-2007 08:21 AM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
You say tomato I say tomato. . . Just a different way, four flanges will actually give you a little more adjustability and less weight Also, when you build off one flange, you might hit some tolerance stack.
FastIndyFiero
Total ratings: 70
Report this Post12-30-2007 12:48 AM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Using individual flanges puts less stress on the head...Thermal strains at 1200* are pretty high in aluminum. When coupled to a thick steel plate (the exhaust flange) that doesn't expand as much, it puts alot of stress on fasteners and the head. By using 4 single flanges, the stress induced on a fastener is from a 2-3" length of steel expanding instead of 18" of steel expanding. Granted, the header tubes still have to flex pretty much the same distance, but there's not really any way to get around that. Also, it saves a little weight and looks cool.
FastIndyFiero
Total ratings: 70
Report this Post12-30-2007 09:28 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put in an email RFQ for 321 stainless flanges for the 16V today with SPD Exhaust. Looks like they do really good work, I think I probably don't want to know how much these flanges are going to be. I might have them make me a collector too, but it's too soon for that.
http://www.spdexhaust.com/HomeB.html
FastIndyFiero
Total ratings: 70
Report this Post01-05-2008 04:35 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found the guy who bought Toddster's DOHC head, that had cams with it. VERY cool guy, said he didn't have a problem with me using his cams to reproduce a set for myself. He also needs a front cover though, I was hoping that I can find one so I can get dim's to make one for myself. With any luck I could have a set of cams made. I think between the two of us we should be able to figure out solutions to our common problems. If nothing else, I've met another friend along way.
Also going to be ordering some mild steel tube sometime this week and start building a prototype header.
cowan1984
Report this Post01-05-2008 08:05 PM Click Here to See the Profile for cowan1984Click Here to visit cowan1984's HomePageSend a Private Message to cowan1984Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have GOT to see this car when you get it done. You should park it behind velvet ropes and charge $50 a ride, you'll make back part of what you spent on that head!
Seriously though, you've got to let everyone on PFF know if you put it in a show, I'm not the only one who's dying to drool in your engine compartment.
FastIndyFiero
Total ratings: 70
Report this Post01-14-2008 11:11 AM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hehe, when I get done I'll be too old and senile to drive. I'll have to pay for someone to drive me around in it. Thanks for the compliment
Right now I'm undertaking a COMPLETE inventory of my DOHC equipment, every nut, bolt, and random part. I was also going to order steel for my proto exhaust but I've been having a hard time finding 1-7/8" diameter bends on a 4" CLR, where it exits the head. That may be something I need to change in the design.
[This message has been edited by FastIndyFiero (edited 01-14-2008).]
FastIndyFiero
Total ratings: 70
Report this Post01-30-2008 10:53 AM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been talking to a couple camshaft manufacturers that do one-off camshaft cutting/grinding. Keep in mind that no camshaft cores exist for this head, so the core has to be cut on a CNC lathe before it's ground. There are no cam grinding master plates either, which means that it also has to be CNC ground. When you factor in those requirements, prices go up and available sources go down to practically nothing. So far I've found 2 companies that can do this.
One is Integral Cams Inc. They do ground-up cam design. I would send them physically measured head flow numbers as well as complete valvetrain and intended engine specs, and a sample camshaft or a drawing. From there they would design intake and exhaust profiles and do a complete analysis on the entire cycle throught the RPM range...That's pretty cool.
BUT, I got quoted $2500 from the point where I send them sample cams to where I'm holding my own 2 heat-treated billet perfect camshafts.
The other place is Custom Camshaft Co. I have yet to get back with them on details, but it looks like they might be cheaper, though I'm not sure they have the same design capability.
Goodbye $$$$$.
The_Stickman2
Report this Post01-30-2008 03:11 PM Click Here to See the Profile for The_Stickman2Click Here to visit The_Stickman2's HomePageSend a Private Message to The_Stickman2Edit/Delete MessageReply w/QuoteDirect Link to This Post
EEK!!!! That's alot of cash just for cams. Is using that head worth the expense?
My sites
Mr.PBody
Total ratings: 101
Report this Post01-30-2008 05:38 PM Click Here to See the Profile for Mr.PBodyClick Here to visit Mr.PBody's HomePageSend a Private Message to Mr.PBodyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think so, hes spent so much on the head itself and the head it so rare, may as well use it.
FastIndyFiero
Total ratings: 70
Report this Post02-12-2008 05:11 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The original cams:
The passenger-side thrust/support bearing:
I don't have the bearing all the way in as it seems to be press fit, but you can see the idea.
Mr.PBody
Total ratings: 101
Report this Post02-12-2008 05:18 PM Click Here to See the Profile for Mr.PBodyClick Here to visit Mr.PBody's HomePageSend a Private Message to Mr.PBodyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am getting all giddy, come on get those cams made!
30+mpg
Total ratings: 97
Report this Post02-12-2008 06:07 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
1 . 2 . 3 . 4 . 5 . 6 . 7 . 8 . 9 10 11
Somebody wake me when the engine fires up!
[This message has been edited by 30+mpg (edited 03-03-2008).]
KurtAKX
Total ratings: 128
Report this Post02-12-2008 11:47 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have those original cams in your possession?
If so, you could probably have them reground on essentially the same base circle a little bit MILDER and have something useful for a wild street turbo app.
Kurt
FastIndyFiero
Total ratings: 70
Report this Post02-13-2008 06:30 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a tool I've been making today for drilling the middle four cam bearing bosses. Apologies for the crappy cell pics.
Here's what it's supposed to look like when finished:
Looks more complicated than it actually is, I've only spent about 20 minutes on it so far. First I turned down some aluminum stock to camshaft size, put it on the mill and cut an orientation flat, then milled down another flat to the centerline. I then squared another little bit of scrap. Tomorrow, it's going to have an angled flat milled into it, and drilled for .25" cap screws to hold it to the cam bushing. Once the cam bushing is drilled and tapped, they will be assembled, and the nub for handling the cam bush will be cut off and the assembly milled flat on both sides. The assembly will go back into the mill, and the angled hole will be drilled in, then lined with a steel bushing. The whole unit will then simply bolt in place of the camshaft bearing cap.
Elapsed time...Hopefully not more than 1hr.
Mr.PBody
Total ratings: 101
Report this Post02-13-2008 08:07 PM Click Here to See the Profile for Mr.PBodyClick Here to visit Mr.PBody's HomePageSend a Private Message to Mr.PBodyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why don't you just machine up your own motor your skills are intense man, nice work,
FastIndyFiero
Total ratings: 70
Report this Post02-14-2008 09:34 AM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Started on header design number.......whatever
[This message has been edited by FastIndyFiero (edited 02-14-2008).]
Fastback 86
Total ratings: 231
Report this Post02-14-2008 03:46 PM Click Here to See the Profile for Fastback 86Send a Private Message to Fastback 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ummm.......I think this project is starting to get to you Nate. That cluster**** you got there is gonna be a ***** to build, and I'd love to know where some of those pipes are going.
FastIndyFiero
Total ratings: 70
Report this Post02-14-2008 04:14 PM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tube 1:
And from the jumbled mess...
FastIndyFiero
Total ratings: 70
Report this Post02-18-2008 12:39 AM Click Here to See the Profile for FastIndyFieroClick Here to visit FastIndyFiero's HomePageSend a Private Message to FastIndyFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL...Scott, you were pretty much right. I would show you guys the rest of the "trimmed" header if it didn't look like crap, and if it wasn't wrong.
So here's something positive:
Almost done. Hopefully I'll be bored at work again tomorrow.
[This message has been edited by FastIndyFiero (edited 02-18-2008).]
Fastback 86
Total ratings: 231
Report this Post02-18-2008 03:09 AM Click Here to See the Profile for Fastback 86Send a Private Message to Fastback 86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I want your job. My work doesn't have toys nearly that cool.
Toddster
Total ratings: 504
Report this Post02-18-2008 11:10 AM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
The guy I bought the head from might have a custom made timing cover still. If not, I know he sold several other DOHC items to some racers in Puerto Rico. I'll try to get the contact info.
