  3.4L pushrod Swap (lots of pics) (Page 11)
This topic is 16 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16
3.4L pushrod Swap (lots of pics) by sardonyx247
Started on: 05-23-2004 02:00 PM
Replies: 618 (106542 views)
Last post by: Notorio on 02-14-2021 11:28 PM
alex de jorge
Report this Post06-04-2007 07:48 PM Click Here to See the Profile for alex de jorgeSend a Private Message to alex de jorgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by sardonyx247:
It sounds like you got 'flexplate bolts' instead of 'flywheel bolts' for the auto vs stick. I think I have seen them in the "help" section at autoparts stores.
edit:should be m10x1x23 but it has to be a HARD bolt like 11.?
Actually, the bolts that I got were for the 2.8 flywheel. Apparently the are not the same thread size although the right length. I hope to resolve this issue quickly.
sardonyx247
Total ratings: 219
Report this Post06-05-2007 11:21 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
They are the same.
Make sure your holes in the crank are cleaned out very well. Check the bolts for burs and the holes too. Don't forget the loc-tite.
Mabey you have the wrong bolts.
randye
Total ratings: 204
Report this Post06-11-2007 09:57 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
A little update, with another modification on my 3.4 motor build.
I trimmed the tube off the timing mark bracket, (no clue what that tube is for, but heard it had to do with a factory timing device),
anyway, the new timing mark is much cleaner and I think it loos pretty good with the fake gold anodize finish
This images is larger than 102400 bytes. Click to view.
You can also see that the trimming of the front motor mount worked very well and avoided denting in the oil pan.
(That's a power pulley and a Rodney Dickman idler pulley on there too)
randye
Total ratings: 204
Report this Post06-11-2007 10:01 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
randye
Member since Mar 2006
Another vieew of the engine on the cradle:
I managed to destroy the transmission dipstick and tube while installing the cradle in the car. Should have known better, and removed it beforehand, but, oh-well...I'm shopping for a new tube and dipstick now
randye
Total ratings: 204
Report this Post06-11-2007 10:10 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
randye
One last view before installation into the car. We added a bunch more brackets and hung the harness on the engine, but I removed the intake manifolds and valve covers to prevent scratching them. I'd rather go thru the trouble doing them in the car than risk damaging them.
In this view you can see the cold start injector has been deleted and the port in the lower manifold plugged with a 7/8" freeze plug. The throttle body coolant lines are also deleted and the ports on the throttle body are plugged with 7/16-20 X .75 bolts. The fuel rail I used is identical to the stock Fiero rail, but has no fuel fitting for the CSI.
removing all this junk really cleaned up the engine a lot. You can also see the *smooth* upper intake manifold with the cast parting lines removed and the mounting lug for the TB coolant lines ground off as well
[This message has been edited by randye (edited 06-11-2007).]
JimmyS
Total ratings: 124
Report this Post06-11-2007 10:18 PM Click Here to See the Profile for JimmySClick Here to visit JimmyS's HomePageSend a Private Message to JimmySEdit/Delete MessageReply w/QuoteDirect Link to This Post
Damn randye, that motor looks awsome!
I did the exact same thing when installing my 3800SC motor. Wasn't paying attention and broke off the top of the dipstick and moved the tube far enough to rip a hole in it where the bracket is. I had to buy a new dipstick and filler tupe from the local Pontiac dealer.
Once your motor is in and running I would like to arrange a time to come check it out if thats OK?
My best advice when it comes to your Fiero is to "NOT" do any dealings with www.kitcarman.com
VIAGRA - Strong enough for a man but made for a woman
randye
Total ratings: 204
Report this Post06-11-2007 10:37 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Jimmy
I've been working hard on this car for a long time now. I do tend to work slow, but it's all finally starting to come together now.
It's actually become something more than an obsession. I've spent hours cleaning and polishing old bolts and nuts, and have replaced probably a couple hundred dollars worth of fasteners where I wanted them to "show" nicely. I also like the look of the stock Fiero 2.8 motor, but for my 3.4 I decided to just give the stock look a little "twist" to show that it's something different Cast silver block and red timing cover instead of the stock black block and cover, and the red oil pan, (which nobody really ever sees), and the cast silver thermostat housing, instead of the stock black. The cradle is in now, (BIG thanks to my buddy Shawnkfl), and the colors really brighten up the engine bay!
shawnkfl
Total ratings: 72
Report this Post06-11-2007 11:12 PM Click Here to See the Profile for shawnkflSend a Private Message to shawnkflEdit/Delete MessageReply w/QuoteDirect Link to This Post
that's exactly why i was looking for a 84 duke. i wanted to take my time and make it look better than new, then swap it in my 84 one day. i can't seem to get one so it looks like it will get a 2.8 upgrade. funny. 2.8's seem to be easier to find than a 2.4....i'll be up saturday randy to grab the block and lend a hand if needed. maybe it won't be so hot! it was another great day there. nobody got hurt and the only thing that got messed up was the tube and dipstick. note to self....lighten up on tightening bolts....i had no idea i tighten bolts up so much! to me they feel snug but good god! taking them back out is a pain!
alex de jorge
Report this Post06-19-2007 09:07 PM Click Here to See the Profile for alex de jorgeSend a Private Message to alex de jorgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, here is my update. I finally got the lower and middle intake on. I also got the fuel rail, injectors and valve covers installed. The exhaust manifolds are also installed and looking great. I got some of the sensors on. I am working on the timing belt cover and water pump. I hope to have those installed in a couple of days. We'll see what happens. How's everyone else coming along?
randye
Total ratings: 204
Report this Post06-20-2007 12:16 AM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is back in the car and I'm finishing up lots of details...like re-wraping wiring harness, and I got sort of sidetracked rebuilding all the rear suspension
Business travel to Utah, and the birth of my granddaughter have also sidetracked my time on the car lately.
Should be able to wrap it all up this next weekend hopefully.
randye
Total ratings: 204
Report this Post06-20-2007 12:30 AM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
randye
Guess I'd better show that the motor is actually back in the car
[This message has been edited by randye (edited 06-20-2007).]
alex de jorge
Report this Post06-20-2007 01:08 PM Click Here to See the Profile for alex de jorgeSend a Private Message to alex de jorgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Way to go Randy! and congrats on the birth of your granddaughter
sardonyx247
Total ratings: 219
Report this Post06-27-2007 10:00 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am waiting on pistons to get here for mine (2 weeks)
other than that I am starting another 3.4 swap this week.
Swaping in 3.4s has become second nature to me lately.
"DRIVE IT LIKE A FIERO"
'84 Fiero, engine to be determined
'87Blue GT 3.4L Swap Completed!!!!!!!!
Las Vegas Fiero Club
fierorx7
Report this Post06-28-2007 12:27 AM Click Here to See the Profile for fierorx7Send a Private Message to fierorx7Edit/Delete MessageReply w/QuoteDirect Link to This Post
ttt
randye
Total ratings: 204
Report this Post06-28-2007 09:01 AM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah...what's the deal with getting pistons and rings for 3.4's??
I had a hell of a time getting stock, (non-oversize), rings for my rebuild, and I looked briefly into getting new pistons and they were special order too!
Overbore rings and pistons were only slightly easier to come by.
All the rest of the engine parts were easy to get, same day or next day.
Maybe it's just around here.....
sardonyx247
Total ratings: 219
Report this Post06-28-2007 09:59 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rings were not too hard to find $86 is a little high for rings but not as $$$ as my pistons were. The company who are making my pistons screwed up and didn't process the order right so it has been about 4 weeks and now another 2. Not too many places have many 3.4L parts on the self, only V8 stuff. I have everything now just waiting on pistons. I will be doing another 3.4l swap while I wait and helping finish up another one too.
randye
Total ratings: 204
Report this Post07-08-2007 10:11 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I finally finished up my 3.4 swap!
It started right up on the first turn of the key.
Both lower coolant hoses leaking a small amount so new hoses to be installed this week, then timing and tune and a rear end alignment and it's back on the road...FINALLY!
Yes, I did the "Happy Dance"
topher_time
Total ratings: 64
Report this Post07-09-2007 12:28 AM Click Here to See the Profile for topher_timeSend a Private Message to topher_timeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats, another finished. My second is just beginning
I'm going to spend a bit building this one up. I'll pour all my and my machinist's knowledge into this one. I shooting for over 200hp at the wheels.
sardonyx247
Total ratings: 219
Report this Post07-23-2007 10:26 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well we finsihed another 3.4L swap. Pics will be coming soon. And pulled out another engine that is getting a 3.4L. So from one, straight into another. It was a busy night. I will have pics from the last couple of swaps to post soon. And some of this one.
Just out of curiosity, who all has done a 3.4L swap based off of this thread?
[This message has been edited by sardonyx247 (edited 07-23-2007).]
randye
Total ratings: 204
Report this Post07-23-2007 11:25 AM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Me
Installed pics coming soon.
Dodgerunner
Total ratings: 323
Report this Post07-23-2007 11:32 AM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used some of the back ground information from the early pages for my swap.
Was wondering on the old cam that the lobes where worn. Mine was the same way and was the cyl. 5 and 6 lobes. Basically completely round.
Just wondered what you saw on your engines?
As someone suggested, I would now have liked to go with a lighter color for the block. Would make knowing if you had an oil leak much easier to find.
[This message has been edited by Dodgerunner (edited 07-23-2007).]
randye
Total ratings: 204
Report this Post07-23-2007 11:53 AM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The cam I pulled out my 130k mile engine had obvious wear and scoring on the bearing journals and had "shoulder" wear, (uneven lifter contact), on several of the lobes. Seems to me that I noticed the most wear around the middle of the camshaft, (cylinders 3 and 4), no round lobes though.
Spotting any future oil leaks is precisely why I painted my block and heads high temp silver. The silver engine paint turns a little brownish right at the exhaust ports / gasktes on the heads pretty fast, but so far, (after a few hours run time), the rest of the engine paint looks great. No exhaust leaks, so it's just the localized heat on the heads..
The other advantage of the silver painted block and heads is that it reflects light really well and makes working under the car or down in tight spaces with a work light easier.....just something I noticed after I installed the motor....
randye
Total ratings: 204
Report this Post07-23-2007 12:07 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
randye
randye
Total ratings: 204
Report this Post07-23-2007 01:14 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
randye
Me
alex de jorge
Report this Post07-23-2007 06:03 PM Click Here to See the Profile for alex de jorgeSend a Private Message to alex de jorgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sardonyx,
do you have to install a different flywheel for an automatic or just use the neutral from the '88? I decided not to install it on my manual but in the automatic.
thanks
randye
Total ratings: 204
Report this Post07-23-2007 07:11 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sardonyx,
thanks
You should use the 88 flexplate, (Neutral balance)
I did.
[This message has been edited by randye (edited 07-23-2007).]
sardonyx247
Total ratings: 219
Report this Post07-23-2007 07:27 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
sardonyx,
thanks
the manuals use a flywheel, the autos use a flexplate. Either has to be from a 88.
I have not noticed much wear on the cams. But the engines we have used have only 50,000ish miles on them
alex de jorge
Report this Post07-23-2007 08:16 PM Click Here to See the Profile for alex de jorgeSend a Private Message to alex de jorgeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the answers !
red_rock
Report this Post07-24-2007 02:32 AM Click Here to See the Profile for red_rockSend a Private Message to red_rockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had my 3.4 painted silver. It looks like an aluminum engine. I did the right choice. I would do it again. Thanks to this thread I was able to get my 3.4 project done last year.
sardonyx247
Total ratings: 219
Report this Post07-26-2007 03:51 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any one else? I assume less than 80 as my feedback is only at 80.
Waerloga
Report this Post07-28-2007 07:28 PM Click Here to See the Profile for WaerlogaSend a Private Message to WaerlogaEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is godsend!
The tutorial is amazing. I registered on this site just for it.
Now, I just bought a 85 Fiero GT from a friend of mine with the 3.4 swap already complete. The car has been sitting for 2 years so on my way home The waterpump and alternator belts broke.
Should I just replace those and be on my merry way or should pull the engine out and hope I can put it back together in the end?
I am about to start adding onto the thread with more crappy pictures!
Waerloga
Report this Post07-28-2007 07:47 PM Click Here to See the Profile for WaerlogaSend a Private Message to WaerlogaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Waerloga
Member since Jul 2007
Ok so here it is
My new baby. Keeping it red
Engine bay as of now. It is an actual working 3.4 swap. Made it home.
Notice the missing belt. When I got home and opened the trunk. Steam exploded in my face.
The water pump is pretty rusty. Should i worry about replacing it?
Also the thermostat housing is leaking. I was told by the owner that I would need a new one. Should I look for a fiero 2.8 one or a 3.4 camaro one?
[This message has been edited by Waerloga (edited 07-28-2007).]
Waerloga
Report this Post07-28-2007 09:21 PM Click Here to See the Profile for WaerlogaSend a Private Message to WaerlogaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Waerloga
Here's another question.
There were 2 bent pipes attached to the trunk heatshield. Looks like the served no purpose as there was nothing connected to them. Is it safe to remove those?
randye
Total ratings: 204
Report this Post07-28-2007 10:20 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is the oil pressure sending unit.
As for the thermostat housing, you need one from a 2.8
randye
Total ratings: 204
Report this Post07-28-2007 10:25 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
randye
It also looks like your car had cruise control at one time, but all the equipment on the trunk side, (rear), firewall has been taken out.
Might explain the 2 lines you're talking about with nothing attached to them.
Richjk21
Report this Post07-28-2007 11:01 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your probably talking about the pipes for the engine compartment blower, they supply air to the coil and alternator, the blower motor is behind the trunk carpeting, it comes on whenever the radiator fan comes on.
Rich
randye
Total ratings: 204
Report this Post07-28-2007 11:06 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yellow arrows pointing to the air cooling pipes for the coil and alternator:
Waerloga
Report this Post07-29-2007 03:31 AM Click Here to See the Profile for WaerlogaSend a Private Message to WaerlogaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome. It all makes sense now.
So is it possible to just put on the belt or do I have to take the engine out?
Should I try seeing if this will work before pulling it out?
sardonyx247
Total ratings: 219
Report this Post07-29-2007 04:50 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just put a belt on it to start. All you have to do is loosen the alternater and put the belt on, then tighten the alternator.
Grab the water pump pulley and check for play, also see if it wobbles at speed. after it is running see if it leaks at all.
Go from there
FierOmar
Report this Post07-29-2007 10:20 AM Click Here to See the Profile for FierOmarSend a Private Message to FierOmarEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you count PIP (Projects In Progress), you can add two; one 88 GT that will use a nearly stock 3.4; and an 87 coupe that will use a carb'd 3.4 that will be built close to ORIEF's specs.
FierOmar
[This message has been edited by FierOmar (edited 07-29-2007).]
