3.4L pushrod Swap (lots of pics) by sardonyx247
Started on | : 05-23-2004 02:00 PM |
Replies | : 618 (106020 views) |
Last post by | : Notorio on 02-14-2021 11:28 PM |
Jul 30th, 2007
sardonyx247 Member Posts: 5032 From: Nevada, USA Registered: Jun 2003
Wahoo page 12 | quote | Originally posted by FierOmar:
If you count PIP (Projects In Progress), you can add two; one 88 GT that will use a nearly stock 3.4; and an 87 coupe that will use a carb'd 3.4 that will be built close to ORIEF's specs.
Cool 2 more 3.4s about to be on the road. I should be finishing up another 3.4 swap tonight. I will have more pics to post of some of the 3.4 swaps I have been doing. I need to get them off another computer and get back to my high speed, dial up sucks. ------------------ "DRIVE IT LIKE A FIERO" '84 Fiero, engine to be determined '87Blue GT 3.4L Swap Completed!!!!!!!!Las Vegas Fiero ClubFiero Road Club Of Northern Nevada[This message has been edited by sardonyx247 (edited 07-30-2007).]
03:43 AM
Jul 31st, 2007
Waerloga Junior Member Posts: 6 From: Houston, Texas Registered: Jul 2007
Ok so I put the belt on and it seemed to run fine for a little while. But the second time I tried to start it it had a really hard time turning over. Not sure why.
Now the real problem, the second time I ran the car, it wouldn't cool properly. In fact, the water in the reservoir in the front of the car was boiling. Yes, actually boiling. So I am going to change the thermostat. But what else could cause this problem? Also how hard is it to change the starter.
08:03 PM
Aug 1st, 2007
| quote | Originally posted by Waerloga:
Now the real problem, the second time I ran the car, it wouldn't cool properly. In fact, the water in the reservoir in the front of the car was boiling. Yes, actually boiling. So I am going to change the thermostat. But what else could cause this problem? Also how hard is it to change the starter. |
the starter is easy, (after doing one) but you have to get to it from under the car. Hard time starting might be just a low battery. when you fill it, open the thermastat cap and the front rad cap, fill from the back, when water starts to come out the front, cap it. Then fill it up from the back. Make sure you have the belt tight, as a loose belt won't charge right and won't cool right.
11:27 PM
Aug 5th, 2007
Ok, great that seemed to solver the problem.
So, considering that the interior of the car is.. missing is a good way to put it. Can I simply remove the sensor that I pointed to in the picture? Is it just for the gauges that I don't have or does it send something to the ECU?
Also thanks for the filling instructions. That solved the problem.
12:04 AM
Aug 16th, 2007
my-fiero Member Posts: 299 From: The Netherlands Registered: Dec 2002
02:53 AM
David DeVoe Member Posts: 1358 From: Grand Blanc, MI US Registered: Jul 2001
My Fiero, did you make those vacuum lines? I know there was one member here using aluminum tube to make them up. Looks good, real good.
10:47 AM
randye Member Posts: 14174 From: Florida Registered: Mar 2006
VERY NICE! Good work and you will like having the engine painetd silver. (easy to find any oil leaks) When it's done drive over to Dusseldorf and convince Yellowstone to get started on a 3.4 swap
12:06 PM
Aug 17th, 2007
| quote | Originally posted by David DeVoe:
My Fiero, did you make those vacuum lines? I know there was one member here using aluminum tube to make them up. Looks good, real good. |
No I ditn't make those lines, the vacuum lines come from http://www.rodneydickman.com/ | quote | Originally posted by randye:
When it's done drive over to Dusseldorf and convince Yellowstone to get started on a 3.4 swap  |
First I had the engine painted black, but then I can not see any oil leaks, so I used silver. ( and it is better than black) If the fiero is ready I drive to Yellowstone!!! I have to try it on the german highway
01:32 AM
Sep 3rd, 2007
04:05 PM
yellowstone Member Posts: 9299 From: Düsseldorf/Germany Registered: Jun 2003
First, I need to install the Trueleo and the 1:1.6 roller rockers I have lying around... and I'm bringing the parts for the Archie big brake conversion back when I go to the US in 3 weeks. So I'll be busy, don't worry! My-fiero: Very nice work! When you find the time, update the pix on your website... :-) | quote | Originally posted by randye:
04:21 PM
Sep 19th, 2007
perry rhodan Member Posts: 802 From: Roxton Pond, Quebec,Canada Registered: Apr 2006
bump!!
04:57 PM
Sep 22nd, 2007
DarkRanger4200 Member Posts: 186 From: Rochester, NY Registered: May 2007
any one have a price list or total for how much the conversion cost them? I'm hope to do a 3.4 swap just what to know what the necessary parts cost to do the conversion, and do any of the fuel or coolant lines need to be changed?
10:33 AM
Oct 8th, 2007
I know this is probably a dumb question but should you use the 3.4 heads or 2.8? im assuming the 3.4 is better, and what about the lower intake manifold should you use the 3.4 or 2.8?
05:17 PM
Oct 10th, 2007
| quote | Originally posted by DarkRanger4200:
any one have a price list or total for how much the conversion cost them? I'm hope to do a 3.4 swap just what to know what the necessary parts cost to do the conversion, and do any of the fuel or coolant lines need to be changed? |
The first time it cost me under $900 including powdercoating, painting etc. No fuel lines or coolent lines have to be changed. | quote | Originally posted by DarkRanger4200:
I know this is probably a dumb question but should you use the 3.4 heads or 2.8? im assuming the 3.4 is better, and what about the lower intake manifold should you use the 3.4 or 2.8? |
They are the same heads on both the Fiero 2.8 and the 3.4. They are both the H.O. (High Output) heads. Reading through my thread would have giving you answers to all your questions. ------------------ "DRIVE IT LIKE A FIERO" '84 Fiero, engine to be determined '87Blue GT 3.4L Swap Completed!!!!!!!! Las Vegas Fiero Club Fiero Road Club Of Northern Nevada
11:34 PM
Oct 11th, 2007
eldervampire Member Posts: 327 From: Hickman, KY Registered: Jan 2006
Sardonyx,
Man, you are my hero. I was given a link here, and he was right. This has to be the best 3.4 swap writeup there is. Anyone turbo one yet? I know about the Bird pulling almost 400 torque, and thats what I'll be looking to as my goal.
+ for you man, great job
09:47 PM
Oct 12th, 2007
| quote | Originally posted by eldervampire:
Sardonyx,
+ for you man, great job |
Thanks | quote | Originally posted by eldervampire: Anyone turbo one yet?
Yes ------------------ "DRIVE IT LIKE A FIERO" '84 Fiero, engine to be determined '87Blue GT 3.4L Swap Completed!!!!!!!! Las Vegas Fiero Club Fiero Road Club Of Northern Nevada
06:10 AM
08:11 AM
03:29 PM
03:34 PM
04:57 PM
05:00 PM
06:48 PM
09:37 PM
Oct 13th, 2007
Another 3.4L swap This GIRL had her Fiero transported from OR down to Vegas so we could do a 3.4 swap in it.    Here is the bottom end of a 3.4L just compare it to a 2.8 and you will see the difference, Its like comparing a duke to a superduty. (anyone want to send me a pic of the bottom end of a 2.8 so I can put the pics side by side?)  The pile of parts to go on the 3.4  The engine going in  And in the car  It went into this Fiero  ------------------ "DRIVE IT LIKE A FIERO" '84 Fiero, engine to be determined '87Blue GT 3.4L Swap Completed!!!!!!!!Las Vegas Fiero ClubFiero Road Club Of Northern Nevada[This message has been edited by sardonyx247 (edited 10-13-2007).]
04:01 PM
Oct 16th, 2007
Oct 17th, 2007
McNasty Member Posts: 122 From: Philadelphia Registered: May 2007
So I know these swaps are usually done with engines that have been pulled from old camaros and firebirds. looking aroudnd I found this: http://www.rebuiltcarengines.com/ce06.htmlwould this be the same engine as the one used but it's new and being sold as a replacement for an s10 upgrade. and if not what would it take tp install this engine. just a question sorry if this was already discussed somewhere else, thanks guys
08:32 PM
| quote | Originally posted by McNasty:
would this be the same engine as the one used but it's new and being sold as a replacement for an s10 upgrade. and if not what would it take tp install this engine. just a question sorry if this was already discussed somewhere else, thanks guys |
That is the same thing execpt that one looks like it has a bigger cam in it. ------------------ "DRIVE IT LIKE A FIERO" '84 Fiero, engine to be determined '87Blue GT 3.4L Swap Completed!!!!!!!! Las Vegas Fiero Club Fiero Road Club Of Northern Nevada
09:35 PM
Oct 18th, 2007
cool thanks that's great news I'll probably be putting a 3.4 in the next year or so... compliments on this great thread, very very very informative
12:03 AM
Oct 19th, 2007
Oct 20th, 2007
02:51 PM
04:48 PM
Carving in oil groves for better oil flow.  The block with new bearings  Assembeld with the new forged pistons   All oil returns are duburred  The bottom end  The 3.1 crank (that is what is used in 3.4Ls)  [This message has been edited by sardonyx247 (edited 10-20-2007).]
05:01 PM
05:32 PM
topher_time Member Posts: 3231 From: Bailey's Harbor, for now. Registered: Sep 2005
Looks good! When are we going to see it with the turbo?
05:36 PM
alex de jorge Member Posts: 501 From: Kissimmee, FL Registered: Nov 2005
Well, I have finally finished my swap. After starting in March and being side tracked, I finished it this morning. I am extremely happy about this. The best thing is that it started right up on the first try and was pretty much in timing. Although I haven't driven it yet ( Car is at my shop), I will come Monday and will post my experience. I will also post pics. Many thanks to Sardonyx and Randye for all the help.
06:47 PM
| quote | Originally posted by alex de jorge:
Well, I have finally finished my swap. After starting in March and being side tracked, I finished it this morning. I am extremely happy about this. The best thing is that it started right up on the first try and was pretty much in timing. Although I haven't driven it yet ( Car is at my shop), I will come Monday and will post my experience. I will also post pics. Many thanks to Sardonyx and Randye for all the help. |
Thats cool you got yours done, another 3.4L Fiero on the road
07:04 PM
My metal vacume lines You can get the tubbing from a hobby store for less than $10. There is a thread on this here which gives you basic idea https://www.fiero.nl/forum/A...070315-1-061913.html  My Ceramic boot spark plug wires     [This message has been edited by sardonyx247 (edited 10-20-2007).]
07:13 PM
