  My interior build... (Page 1)
My interior build... by RCR
Started on: 03-19-2006 09:28 AM
Replies: 178 (24543 views)
Last post by: kendell on 02-06-2023 08:57 PM
RCR
Total ratings: 102
Report this Post03-19-2006 09:28 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
In the spirit of "My dash conversion" thread, I thought I would start a thread more appropriate to what's now going on. It's no longer just a dash conversion (located here: https://www.fiero.nl/forum/Forum2/HTML/043545.html ), but a total update of the interior, including the center console, headliner, dash, door panels, AV system, etc.
Jscott convinced me that a cassete/cd changer audio system was not the way to go (Thanx Jon ), so I pulled it all out and picked up a Chinese knock-off DVD player (cds & MP3's too) and a 10.4" video screen. Still working on how the screen goes, but I roughed in all the stereo equipment so I can put the dash back in.
The addition of the dash required tossing out the center console. My plan was to find one I liked and incorporate it into a totally new design. Also, one of my later ideas was to incorporate a subwoofer in the dash, but after putting the dash back in, I realized it just wasn't going to fit. So I've decided to go with a center console subwoofer.
So, here are a couple of pics to get this started. More will come as the thread builds towards completion.
The first thing I did was build an amp rack to mount the equipment. I did not want to sacrifice space in the cab for the amps, but I wanted the extra power and room to grow. Here is the top of the rack:
I had to situate the amps around the brake booster, AC stuff, and washer bottle. I also wanted everything servicable, so it had to be hinged.
I plan on finishing it off with a glass cover over the amps, and fabric over the outside.
With the wiring in and the dash sub out, I went to work on the console sub.
I started out by forming a piece of cardboard around the ECM, making sure it fit nice up against the firewall. I removed it and built a form on my table to keep everything square. Then I put a coat of resin over the cardboard, making it nice and stiff. I put it back in the cabin and taped up the console area to get it's shape. Wax paper and paiters tape kept everything from sticking to the console. I layed several layers of glass over the back and bottom, to form the base for the subwoofer. (Sorry, no pics of any of this). Then I built up the ring. I decided I didn't need thunderous bass and I didn't want something protruding out that would get in the way of my arm, so I went with an 8" sub. I haven't picked one yet, but I'm leaning towards Kicker, or Rockford Fosgate. I built the ring around these. My buddy Matt came down for a few hours, so I put him on making the rings. He did a decent job considering the equipment he had to work with. He made two rings, meant to be stacked on each other. The bottom ring is where the sub is mounted, the top ring gives the sub a flush-mount look. Here are the pics so far:
Today I hope to get the fleese and resin on to give it some shape.
More later,
Bob
edits for speelin'
[This message has been edited by RCR (edited 03-19-2006).]
revin
Total ratings: 234
Report this Post03-19-2006 09:53 AM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RCR:
Are you planning a fan in there to keep the amps cool? I say a few computer fans need to be added.
or you can cut ahole toward the rad fan.
Custom2M4
Total ratings: 114
Report this Post03-19-2006 12:16 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
That might actually make it hotter then the amps would do... But I still agree on something cooling them off.. one computer fan facing one way, forcing hot air out, and another one sucking it in should work, as long as you had a hood scoop .
Fino
Report this Post03-19-2006 12:32 PM Click Here to See the Profile for FinoSend a Private Message to FinoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you are doing great work and it looks nice. But I also have to agree with the amps AND battery you need to cool it. Can you cut two holes in the front and install a fan on one to move air, then protect the two holes from water intrusion. Not going to be easy.
Ed
Fino
www.feroce.us
Member National Kit Car Club
Fiero1Fan
Total ratings: 100
Report this Post03-19-2006 01:20 PM Click Here to See the Profile for Fiero1FanClick Here to visit Fiero1Fan's HomePageSend a Private Message to Fiero1FanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks real good.
The Steel Lady: Pix to follow........
Super Bowl XL CHAMPS!!!
jscott1
Total ratings: 415
Report this Post03-19-2006 02:12 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work Bob, welcome to the 21st century
Hopefully no one has a hood scoop that vents into the forward trunk. That area is supposed to be sealed from the elements. Which means it will get hot up there. With the amps mounted upside down natural convection is going to be working against you. You might conider changing to an aluminum plate and mount the amps to that as a heat sink.
I like your center console. I am just startng to work with fiberglass and my next one is going to be a lot better than the one I have now. If I ever figure out how to do molds I would be all set to make more. I'm very interested to see your large screen. I'm wanting to do a carputer one of these days but mounting a large touch screen in our cars is the challenge.
RCR
Total ratings: 102
Report this Post03-19-2006 05:49 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, I hadn't considered the heat in front. I guess I'll have to come up with something slick. Or, maybe a hole somewhere..Hmm, I'll have to think on that.
Last update for the week:
I put the fabric on. It's a 100% polyester t-shirt type material. $2.00 a yard at Walmart. I think I looked like a fool feeling up all the material there, trying to find the stretchiest stuff they had. Oh well, I've got enough to do a bunch of stuff. The material is attached to the backing using staples (temporarily, I pulled them afterward), and hot glue.
Here's what it looks like attached to the framework:
And in the car for fitting:
Once satisfied with the fit, I coated it with a layer of resin:
Afterwards, it gets several layers of fiberglass. The glass I picked up on Ebay. It's 18oz weave. It seems to flow with the curves pretty well. And for 16lbs of glass for $16, you can't beat that.
I'll get more pics when it's further along.
Bob
...Ventilation, huh?? Hmmm....
revin
Total ratings: 234
Report this Post03-19-2006 06:12 PM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
run a drier vent hose from the front facia and drill a hole in the trunk for the "fresh air" Then down under the tub of the trunk.
RCR
Total ratings: 102
Report this Post03-22-2006 02:40 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
I purchased an 8" Kicker CVR for the subwoofer box. I'm hoping it sounds as good as it looks.
Bob
datacop
Total ratings: 52
Report this Post03-22-2006 03:37 PM Click Here to See the Profile for datacopClick Here to visit datacop's HomePageSend a Private Message to datacopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Love how that center console is turning out! I can't wait to see the final result.
fiero_silva
Total ratings: 51
Report this Post03-22-2006 05:54 PM Click Here to See the Profile for fiero_silvaSend a Private Message to fiero_silvaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice work.. I love the amp rack idea!
RCR
Total ratings: 102
Report this Post04-09-2006 07:57 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Update time:
The weather has been warm then cold, so work is sporadic, but I have the box built up with glass and the mounting flanges installed.
The following picture shows the creation of the flanges. I taped off the areas on the firewall where the flanges would be, using painters tape and wax paper. I put a coat of carnuba wax on the tape to help seperation. I installed the box back in the car, making sure it was at the proper mounting location. I then built up a flange using 2oz mat and 18oz cloth, overlapping the box and the flange to ensure it was nice and strong.
This picture shows the flange cut to shape. The back of the flange is an exact mirror copy of the firewall. (Pss..that's my first shot at the new door panel in the background)
The last two pics show the box in early sanding steps. I've added some kitty hair to strengthen the box and give it a better shape, and I've used a guidecoat of primer to see where I'm at with the sanding. I hate sanding....Lots more of that to come.
Bob
[This message has been edited by RCR (edited 04-09-2006).]
3800superfast
Total ratings: 191
Report this Post04-09-2006 09:39 AM Click Here to See the Profile for 3800superfastSend a Private Message to 3800superfastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Bob, you do very nice detailed work, heres a idea for the cooling part # PRM-19120
http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&Ntt=19120
RCR
Total ratings: 102
Report this Post04-09-2006 09:58 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanx for the heads-up.
Bob
vortecfiero
Total ratings: 57
Report this Post04-09-2006 10:02 AM Click Here to See the Profile for vortecfieroClick Here to visit vortecfiero's HomePageSend a Private Message to vortecfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
very nice ! Looks great !!!
I have always wondered how the custom installers did that kind of work..
I never really asked.. but the pics tell all
84 Fiero Turbo Vortec 4300 Phantom GT
L35 block, Syclone Intake and ECM with Moates adapter
50lb injectors, 3 bar map sens, T04B H3 Turbo
87 GT just waiting for the conversion
www.cardomain.com/id/vortecfiero
Murphy's Constant Matter will be damaged in direct proportion to its value
Murphy's Law of Thermodynamics Things get worse under pressure.
Arthur C. Clarke "Any significantly advanced technology is indistinguishable from magic"
jscott1
Total ratings: 415
Report this Post04-09-2006 01:17 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any more detals on those door panels??
Fiero1Fan
Total ratings: 100
Report this Post04-09-2006 01:29 PM Click Here to See the Profile for Fiero1FanClick Here to visit Fiero1Fan's HomePageSend a Private Message to Fiero1FanEdit/Delete MessageReply w/QuoteDirect Link to This Post
RCR, you're doing some very fine work. Keep up the progress pix. Good ideas are always welcome.
RCR
Total ratings: 102
Report this Post04-09-2006 07:44 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a couple more pics of todays progress.
This one shows a half can of primer to start the "smoothing" process.
Almost smooth:
And todays fan club. My two youngest cheering on Dad.
Thanx for popping in.
Bob
Sourmug
Total ratings: 144
Report this Post04-09-2006 11:23 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob:
The speaker enclosure looks great! Isn't sanding fun
I'd like to see some pictures of the door panels as well.
Nolan
UCFieroCharger
Report this Post04-10-2006 02:01 AM Click Here to See the Profile for UCFieroChargerSend a Private Message to UCFieroChargerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a quick question, and other peopel with subboxes, what is the interior volume of the sub box?
Can anyone tell me what the suggested volume is for an 8in sub? I tried looking online and actually wasnt very successful.
Im just curious.
After seeing everyone doing all this work since its getting nice, im getting that itch to do something....
RCR
Total ratings: 102
Report this Post04-10-2006 07:38 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry guys, the door panel is an up & coming project. I don't have much info on it, other than I started by following what Roy did on his Firebird panels. The gist of the door panel is that I'm using firebird components and form fitting it to the dash. The raised portions will be custom made, their will be an integrated 5.25" door speaker, and a custom center section. Not much else to tell, yet.
The recommended volume for my Kicker CVR is .4 to 1.8 cuft for a sealed enclosure and .8 to 1.2 cuft for a ported enclosure. I'm estimating that I'm just short of .4 cuft so I will be using polyester batting to fill the box to make it seem larger to the sub.
Bob
UCFieroCharger
Report this Post04-10-2006 09:07 AM Click Here to See the Profile for UCFieroChargerSend a Private Message to UCFieroChargerEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok, thanks for the info.
Fiero1Fan
Total ratings: 100
Report this Post04-10-2006 08:20 PM Click Here to See the Profile for Fiero1FanClick Here to visit Fiero1Fan's HomePageSend a Private Message to Fiero1FanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cute little girls. Aren't dads lucky people?
Custom2M4
Total ratings: 114
Report this Post04-10-2006 08:44 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know what kids look like in germany.. but one of them is a boy . So cute boy/girl.
The build is looking pretty good so far! Maybe it will look even better with a widebody?!?!?!?! Muahhaha
Best of luck,
Chase.
Fiero1Fan
Total ratings: 100
Report this Post04-10-2006 08:52 PM Click Here to See the Profile for Fiero1FanClick Here to visit Fiero1Fan's HomePageSend a Private Message to Fiero1FanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oops!!! I'm blind in one eye (j/k), that must have caused the stupidity!!! Thanks for the correction.
RCR
Total ratings: 102
Report this Post04-11-2006 07:34 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Custom2M4:
Widebody??? Hmmm. Maybe you're onto something....Maybe something like this?
Only a handful of projects at one time.
Bob
Custom2M4
Total ratings: 114
Report this Post04-11-2006 11:14 AM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
Thats not near wide enough! Handful of projects? Pfft, you can never have enough projects!
RCR
Total ratings: 102
Report this Post04-11-2006 07:53 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Custom2M4: It's not as wide as yours, but it is 3.5" wider that stock, on each side. Plus it still "looks" stock, just modern. But, back on topic...
Here is a quick shot of the final product, in primer, just to make sure it all still fits properly.
I shot the first coat of metalic cast iron, butran out of paint, Doh! More later...
Bob
Scott-Wa
Total ratings: 147
Report this Post04-11-2006 08:38 PM Click Here to See the Profile for Scott-WaClick Here to visit Scott-Wa's HomePageSend a Private Message to Scott-WaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks sweet... going to have clearance for your arm?
Custom2M4
Total ratings: 114
Report this Post04-11-2006 10:09 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well mine is only about 3.5-4inches wider then stock... I dont really wany anymore because I don't plan on running spacers.. Just a RWD offset..
Its looking pretty good!
If you look in the first picture of the box, it seems like its about perfect for your arm .
Sourmug
Total ratings: 144
Report this Post04-11-2006 11:18 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job, it looks like it belongs there. Much better looking than most sub enclosures I have seen.
Nolan
[This message has been edited by Sourmug (edited 04-11-2006).]
fieroracer86
Report this Post04-11-2006 11:45 PM Click Here to See the Profile for fieroracer86Send a Private Message to fieroracer86Edit/Delete MessageReply w/QuoteDirect Link to This Post
That looks sweeet! Can't wait to see it covered or painted
RCR
Total ratings: 102
Report this Post04-12-2006 07:36 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Arm clearance will be good for me. With my hand resting on shifter, my arm doesn't touch the box. The speaker is recessed, so that won't be an issue, either. Thanx everyone for popping in and the kind words. I'm just hoping to add to the knowledge base and show that it's not that difficult if you work at it a little.
Bob
cliffw
Total ratings: 295
Report this Post04-12-2006 07:50 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking good.
Curious if you are gonna be using your seat speakers. If so, what type do you have in mind ?
RCR
Total ratings: 102
Report this Post04-12-2006 12:09 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
cliffw: I will be eliminating the seat speakers. I plan on getting new seats sometime in the future. I'm thinking of building some boxes up in the corners to house some 5.25s or 6.5s since my '84 does not have the provision for B-pillar speakers. Not sure how that'll work out, yet.
Bob
Fie Ro
Total ratings: 132
Report this Post04-12-2006 01:28 PM Click Here to See the Profile for Fie RoSend a Private Message to Fie RoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work! Love to see the little tricks like the stretched polyester to make these shapes -relatively- easy. I still spend way too much time on filling and sanding...your work looks good.
Sourmug
Total ratings: 144
Report this Post04-12-2006 02:53 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Incidently, here is a link to a forum that has a ton of info on this sort of thing:
http://glassmanscustomforum.com/v-web/bulletin/bb/index.php
Nolan
RCR
Total ratings: 102
Report this Post04-12-2006 04:55 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm a silent member at Glassman's. That and the Alpine site is where I came up with most of this.
Thanx Fie Ro, having watched your progress, I had a high target to shoot for. Still a long way to go.
Bob
Sourmug
Total ratings: 144
Report this Post04-12-2006 11:58 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob:
Have you purchased any of the products from Glassman particularily the instruction videos? If you did, how do you like them?
Thanks
Nolan
BobadooFunk
Total ratings: 128
Report this Post04-13-2006 12:14 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
looks awesome so far!!
