  We Build a Perfect Union (Page 45)
This topic is 78 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78
We Build a Perfect Union by Archie
Started on: 01-11-2006 09:04 PM
Replies: 3080 (368327 views)
Last post by: troyboy on 10-29-2016 12:55 PM
Total ratings: 259
Report this Post08-11-2008 09:23 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Archie:
"Fiero of dream cars"
Hey, I have a few of those too!
Looking good! I really like the exhaust!
troyboy
Total ratings: 154
Report this Post08-13-2008 05:28 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The mystery box ships out to Archies tomorrow, Don't worry Archie just move forward as planed, this install can be done after paint....I hope .
troyboy
Total ratings: 154
Report this Post08-13-2008 07:52 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
troyboy
Member since Sep 2005
Archie you have a PM re: the box
Archie
Total ratings: 547
Report this Post08-13-2008 09:08 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
A bit of an update.
The last couple of days we've been working on the underside of the car.
We put the A/C lines, Heater pipes, battery cables & P.S. lines along either side of the newly painted gas tank.
Then we put the car on the floor to slightly modify the rear clip to make it easier to remove.
Also put a new double wall floor in the trunk area.
With the engine out of the car, we're working on the McChuck project.
We're also moving & lowering the location where the wire harness passes thru the bulkhead, so the wires will be out of the way as much as we can have them.
To make clearance for the lines running to the P.S. pump, we had to make a slight bubble to the forward bulkhead.
Right now the schedule has us returning this car to Mark next Monday to finish the paint job.
Archie
qwikgta
Total ratings: 84
Report this Post08-13-2008 09:36 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Arch,
Have you ever used a LS4 Harmonic Balancer on the LS1 motor. If you did it could free up some room and you may not need to "notch" the frame. Have you ever given it a try? If you did, what happened? The reason I ask is that the stock LS1 pully is so large, and you never even use the inside set of grooves. I noticed the LS4 only has the one set of pully grooves so it is only half the size of the stock LS1 one. Just thinking ahead for my swap.
Rob
[This message has been edited by qwikgta (edited 08-13-2008).]
troyboy
Total ratings: 154
Report this Post08-13-2008 10:01 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cats out of the bag or in this case box.
http://www.ecstuning.com/st...ing&subcategory=Fogs
the look:
Thanks to carbonfiber_kid for this tweak
the location
Archie
Total ratings: 547
Report this Post08-13-2008 10:49 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
the location
When is this part going to be here?
We're going to have to try to fit it before the front clip gets painted.
It would be crazy to figure that we're not going to need some kind of mods to get it into the position you want.
Even if it would fit right in, we still need to make some method of mounting before the front clip is painted.
Also the towing points we talked about in the front are going to have to be relocated to the lower opening.
Archie
troyboy
Total ratings: 154
Report this Post08-13-2008 11:54 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should have the part by Monday. Just a thought we could also eyeball what the part would look like under the splitter. If someone could photo shop this it would be greatly appreciated.
Firefox
Total ratings: 240
Report this Post08-14-2008 03:41 PM Click Here to See the Profile for FirefoxSend a Private Message to FirefoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
More mods!!!!!
That tank looks great in there. As more little things like that are installed the effect of the color really shows. The grillwork will really help set off the color with a bit of contrast and give some definition to the openings in the car. The car will have just the right amount of accent color to set off the paint.....even the underside of the car.
I'm still up in the Northwoods of Wisconsin and sitting in the truck in Bayfield, Wisconsin. It's a small resort town right on the shore of Lake Superior and it's really pretty here, but Kristie is out doing a little shopping and I've had enough of that today, so I found a nice quiet place to park in the shade and hooked up to a free wi-fi sight. Tourists.....now with laptops!
Anyway, back to vacation.
Mark
Archie
Total ratings: 547
Report this Post08-14-2008 08:37 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob started building the sheet metal panels for the engine compartment today.
There is a small "U" channel down at the bottom to hold the panel & some ST Sheel metal screws at the top edge to hold it in place.
You can also see that he built a box around the hinge box on the drivers side.
Having a Sheet Metal Brake & a Plasma Cutter are really handy sometimes.
This is just the beginning on making these parts. We will still need to put some holes into them when we route the route the Shift cables, ECM wires, hoses etc. This is why we lowered the openings where the harness will pass thru the bulkhead. We will be trying to hide as much of the wires, hoses & cables behind the covers as we can. However this will not be 100% complete until final assembly when we can mount the engine for the last time & hook everything up.
When finished, these will be painted to match the rest of the engine compartment.
Then we put the engine assembly back into the car to check for fit on the shield & to start figuring out where to mount the Electric W/P, P.S. tank, CAI, Oil Tank & several other things. Later panels will be built to the other exposed side panels.
The P.S. pump comes close to the bulkhead, so the shield will have to work it's way around that area.
The CAI, Oil Tank, Shift Cables & any number of wires have to occupy this corner.
We also worked on midifying the dash today to allow mounting of those nice Cup Holders.
Kris came up with a good way to mount them. Then modified the bottom edge of the dash & fiberglassed it all from the inside.
Here he's filling & sanding the new face of the dash.
Archie
[This message has been edited by Archie (edited 08-14-2008).]
Fiero Thomas
Total ratings: 125
Report this Post08-14-2008 08:54 PM Click Here to See the Profile for Fiero ThomasSend a Private Message to Fiero ThomasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great Job Archie and Crew. Keep it up. I know the wait will be worth it
Indy#64~FieroNews~Boots~Bag s~Wallets~Headliner~Spare Cover~
Visors~Sunshads and T-Top Sunshades~Download the Fieronews Catalog HERE~
troyboy
Total ratings: 154
Report this Post08-14-2008 10:47 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The car is coming along nicely Archie.
Archie
Total ratings: 547
Report this Post08-15-2008 09:14 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kris finished up the installation of the cup holders today.
Rob has been on this car pretty much straight thru since the 25th show.
So today I let him work on something else for a change of pace.
Archie
carbonfiber_kid
Report this Post08-15-2008 11:30 PM Click Here to See the Profile for carbonfiber_kidSend a Private Message to carbonfiber_kidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Happy to be able to contribute to your wicked ride
troyboy
Total ratings: 154
Report this Post08-16-2008 12:31 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
the holders look great.
madcurl
Total ratings: 314
Report this Post08-16-2008 03:06 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since we're now waiting for the driving day lamps, lets have some photoshop fun.
"Friends don't let friends drive stock reflectors"
[This message has been edited by madcurl (edited 08-16-2008).]
Archie
Total ratings: 547
Report this Post08-16-2008 05:33 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're a trouble maker, go back to work!!!!!
troyboy
Total ratings: 154
Report this Post08-16-2008 07:57 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
No need to worry, that's one of the Fiero trade marks I plan to keep. BTW thanks 4.9
madcurl
Total ratings: 314
Report this Post08-16-2008 11:20 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fierotaz
Total ratings: 93
Report this Post08-18-2008 02:11 PM Click Here to See the Profile for FierotazSend a Private Message to FierotazEdit/Delete MessageReply w/QuoteDirect Link to This Post
Troy,
The car is looking absolutley amazing! I love that engine and it looks like the engine bay is going to be nice display case for it.
When do you think you will have the car home? I am coming in for a couple of days to catch a Yankees game before they tear down
the stadium, but you probably won't have it home by mid September
troyboy
Total ratings: 154
Report this Post08-18-2008 08:50 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Fierotaz:
Troy,
#22 will not see New York until Oct, but let me know when your in town I have a Peter Luger steak and a beer with your name on it.
Archie
Total ratings: 547
Report this Post08-19-2008 05:47 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let's see, what's new today.....
troyboy
Total ratings: 154
Report this Post08-19-2008 07:23 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it hold oil
Archie
Total ratings: 547
Report this Post08-19-2008 07:56 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it hold oil
Ok, so you guessed.
Archie
madcurl
Total ratings: 314
Report this Post08-19-2008 09:13 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
[This message has been edited by madcurl (edited 08-19-2008).]
troyboy
Total ratings: 154
Report this Post08-20-2008 05:22 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did the box arrive? Pics?
Archie
Total ratings: 547
Report this Post08-20-2008 06:02 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, the lights came in & we have some pics.
For the light beams to be pointed straight down the road, the edges indicated by arrows need to be pointed forward on the car.
We think that the top part of the light (covered in cardboard) is an area that is covered up by the hood or other bodywork in the light's original application.
More pics in a few minutes...
[This message has been edited by Archie (edited 08-20-2008).]
Archie
Total ratings: 547
Report this Post08-20-2008 08:52 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Member since Dec 1999
We're thinking the the area of the light assembly that is covered with the cardboard above, is going to have to be mounted up into the top wall of the top scoop area. (see arrow)
For the lenses to be pointed in the right direction the lights will have to be mounted in deeper on the outside end & shallow on the inboard end.
More pics
Enjoy
Archie
Archie
Total ratings: 547
Report this Post08-20-2008 09:29 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Also today we worked out the positioning of the oil tank & are almost done with the mounting brackets.
We wrapped the tank in plastic wrap to prevent scratches.
It just barely fits in there. If the tank was a half inch larger in diameter, it wouldn't fit. Between the frame rail, transmission case & the forward bulkhead, you couldn't move the tank a quarter inch in any direction without hitting something.
Archie
troyboy
Total ratings: 154
Report this Post08-20-2008 09:36 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a go Archie we are just going to have to tweak it, First we have to shorten it like the VW boys do. pic and link:
http://forums.vwvortex.com/zerothread?id=3866611
mount the light for the best fit to the front end, they are more of a daytime/ accent light, so if the light is not pointing perfectly straight it's ok they are not fog or driving lights. pics:
in the pics the lights are mounted for best fit to the VW nose, they are not perfectly straight like the Audi but still look good IMO.
we will use these to light up the road
[This message has been edited by troyboy (edited 08-20-2008).]
madcurl
Total ratings: 314
Report this Post08-20-2008 09:41 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also today we worked out the positioning of the oil tank & are almost done with the mounting brackets. We wrapped the tank in plastic wrap to prevent scratches.
Archie
Wow!
BlackGT Codde
Report this Post08-20-2008 09:43 PM Click Here to See the Profile for BlackGT CoddeSend a Private Message to BlackGT CoddeEdit/Delete MessageReply w/QuoteDirect Link to This Post
sick foglamps
man you got me drooling, not one but two cupholders, man.
now thats sayin something
troyboy
Total ratings: 154
Report this Post08-20-2008 09:49 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by BlackGT Codde:
sick foglamps
They are stock Audi S6 LED parking lights
Coinage
Report this Post08-21-2008 12:14 AM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Curious what you are doing for an intake with the oil tank there...? enough room for a 4" (<- assuming the TB size?) pipe to go in the fender? Hard to tell how much room is there from those angles.
Archie
Total ratings: 547
Report this Post08-21-2008 12:41 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what we're working on now. The shift cables, CAI & oil tank all have to get along & share that little bit of space.
Archie
Total ratings: 547
Report this Post08-21-2008 11:16 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
The first pics of the fitting of the lights.
Please note that we are currently moving the inboard end of the light forward about 1/4", that's as far as we can go.
Once again, a mod that looks like it's going to come out great.
Troy, call me if you can.
Archie
Sig by Custom2M4
Archie
Total ratings: 547
Report this Post08-21-2008 11:33 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
The opening isn't wide enough for all 5 bulbs to show but it still looks great.
DeLorean00
Total ratings: 100
Report this Post08-21-2008 11:36 AM Click Here to See the Profile for DeLorean00Send a Private Message to DeLorean00Edit/Delete MessageReply w/QuoteDirect Link to This Post
WOW!! THAT LOOKS COOL!! When this car is done its going to look like a factory built super car!! Are you going to enjoy telling people its a Fiero when they ask what it is? I'd love to see the confusion.
[This message has been edited by DeLorean00 (edited 08-21-2008).]
SAFASTRO
Report this Post08-21-2008 12:16 PM Click Here to See the Profile for SAFASTROClick Here to visit SAFASTRO's HomePageSend a Private Message to SAFASTROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking great Archie!!! They look like they fir quite well. I guess making mounting tabs will be fun, eh?
Troyboy!!! Great tweak.....I love those lights......I've been looking at those for my ride as well!
Keep up the great work guys!!!
Order your Official Pennock's Forum decals in this thread. https://www.fiero.nl/forum/Forum4/HTML/040445.html
2" Choptop
Shortened Front Bumper
Shortened Rear Bumper
10" Stretch
Dubs
350 V8 Conversion pushing 350 ponies!!
troyboy
Total ratings: 154
Report this Post08-21-2008 03:27 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
All I can say is wow, thanks Archie and crew, and thanks carbonfiber_kid for the info.
