  Black Betty Build! (Page 8)
This topic is 14 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14
Black Betty Build! by BobadooFunk
Started on: 08-28-2006 04:50 PM
Replies: 528 (28774 views)
Last post by: Formula on 07-01-2007 12:24 AM
RideZiLightning
Report this Post03-14-2007 03:59 AM Click Here to See the Profile for RideZiLightningSend a Private Message to RideZiLightningEdit/Delete MessageReply w/QuoteDirect Link to This Post
Double post
[This message has been edited by RideZiLightning (edited 03-15-2007).]
BobadooFunk
Total ratings: 128
Report this Post03-18-2007 12:09 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK minor minor update, but some q's as well..
1. Under the plenum, that hose that connects to the lower intake.. how exactly does it attatch ? im really confused at this one..
2. i have the coil.. waiting till i get some bolts to finish up exhaust (well at least to y-pipe)
3. As soon as we return from Daytona, its full blown fix Betty month... ill need all the energy, luck (and any last parts you guys can spare!) because Betty has now turned into a NEED because i start Mechanics college/school June 25. !! YAY!
Back On Holiday
Report this Post03-18-2007 08:24 AM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
theres a tube that looks like an "L" - goes from that lower intake part to the bottom of the throttle body, maybe someone has a pic to show?
BobadooFunk
Total ratings: 128
Report this Post03-18-2007 09:13 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
yea i think thats the one you sent me, a metal tube right? i dont understand how it attatches to the throttle body part..
Formula88
Total ratings: 554
Report this Post03-18-2007 11:01 AM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
It just pushes into the hole - there isn't an attachment on the pipe itself. Bolting the throttle body onto the plenum holds it on the pipe.
Take some pics and make a list of questions show you can compare them to the cars at Daytona next weekend.
[This message has been edited by Formula88 (edited 03-18-2007).]
David DeVoe
Report this Post03-20-2007 03:06 PM Click Here to See the Profile for David DeVoeSend a Private Message to David DeVoeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Bobadoo just make sure that there's an o ring in the hole in the throttle body before you install that tube. The best way I've found to install it is to push it into the rubber hose on the lower intake and then guide it into the tb as you push the tb up to the plenum. It may help to lube it slightly. Then install the tb bolts. Have fun.......aint engine assembly a hoot??
BobadooFunk
Total ratings: 128
Report this Post03-28-2007 09:35 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
ugh.. a real hoot.. connecting the hose, egr tube, and tightening exhaust bolts was no fun
More connected etc.. getting close to trying to start it!
This is my OPSU connector ... does anyone atleast know which goes where?
What goes there (minus the wrench)
shawnkfl
Total ratings: 72
Report this Post03-28-2007 09:47 PM Click Here to See the Profile for shawnkflSend a Private Message to shawnkflEdit/Delete MessageReply w/QuoteDirect Link to This Post
are you sure that middle plenum is orientated correctly? that last pic looks off to me, due to that boss you show.
litespd
Total ratings: 175
Report this Post03-28-2007 11:10 PM Click Here to See the Profile for litespdSend a Private Message to litespdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jerry, you NEED to get this wiring harness off of the EGR tube! On the 85-87 V6 engines, this tube normally has an insulating "blanket" around it, as very hot exhaust gases pass through it. The 88 tube is also insulated, but is done differently than the earlier engines. If you leave that harness where it is, you'll melt through it in no time. You can either tie up the harness so it isn't anywhere near the tube, or check with a local auto parts store, and see if they have some kind of insulation you can put on the tube. Either way...you need to do something with this before it causes you all kinds of headaches...
F-I-E-R-O
Total ratings: 294
Report this Post03-29-2007 12:17 AM Click Here to See the Profile for F-I-E-R-OSend a Private Message to F-I-E-R-OEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oops.
[This message has been edited by F-I-E-R-O (edited 03-29-2007).]
BobadooFunk
Total ratings: 128
Report this Post03-29-2007 12:58 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
ah thanks for pointing that out, i will see what i can come up with! (most likely some type of insulation)
BobadooFunk
Total ratings: 128
Report this Post03-29-2007 01:01 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
BobadooFunk
Member since Jun 2003
MAN i hope so... i dont feel like going that far backwards.but there is a hole like that on both sides, the other side has some line bolted to it (i forgot which one..)
thismanyfieros
Total ratings: 120
Report this Post03-29-2007 10:55 AM Click Here to See the Profile for thismanyfierosSend a Private Message to thismanyfierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
header insulation....done...tim
litespd
Total ratings: 175
Report this Post03-29-2007 11:05 AM Click Here to See the Profile for litespdSend a Private Message to litespdEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's heat tape already wrapped around the wiring harness, as you can see...but it won't be enough to insulate it from the heat in the EGR tube. Would sure hate to see you go to all of that work and get it started, only to have the harness melt through shortly afterwards. Maybe someone on the list has an old, cracked EGR tube that still has the insulation blanket on it that could send it to you? I'd send you mine, but I put it on the braided stainless line that I replaced the original EGR tube with.
[This message has been edited by litespd (edited 03-29-2007).]
BobadooFunk
Total ratings: 128
Report this Post04-02-2007 08:44 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
ooo lookie what i got in the mail!!! a gift!!
head near driver/passenger.. missing what?
How it looks
i need a complete new ebrake setup...
Looks good
ok ... so... we tried to try to start it and it was weird, no engine turning over.. no rotation, just a weird buzz.. but only sometimes, not every time.. sounded like it was coming from starter, but not sure.. and its not ded battery.. i had it charged, and we had it boostered to another car, and its a newer optima... any help??
D B Cooper
Total ratings: 54
Report this Post04-02-2007 09:43 PM Click Here to See the Profile for D B CooperSend a Private Message to D B CooperEdit/Delete MessageReply w/QuoteDirect Link to This Post
starter solenoid or cables. The solenoid has an electromagnet (winding) inn it that pushes a flat washer on a plunger across a couple contacts; the plunger can stick some (no audible 'click' when the key is turned) or the contacts could be crusty (audible 'click' but not much else afterward). Or the cables might not be getting good power to the starter assembly ('click' then 'buzz' like you get with a very low battery).
Try tapping on the solenoid; it might just be a little crudded up inside.
Hope this helps narrow the trouble down.
[This message has been edited by D B Cooper (edited 04-02-2007).]
D B Cooper
Total ratings: 54
Report this Post04-02-2007 10:03 PM Click Here to See the Profile for D B CooperSend a Private Message to D B CooperEdit/Delete MessageReply w/QuoteDirect Link to This Post
D B Cooper
Member since Jul 2005
also you can test the starter operation by shorting the two large wires on the solenoid togerther if you can reach the contacts from the topside. I wouldn't recommend doing that from under the car though for obvious reasons. ***caution - make sure car isn't in gear or it will roll***
85sliverGT
Report this Post04-02-2007 11:23 PM Click Here to See the Profile for 85sliverGTSend a Private Message to 85sliverGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
this is how i started my 84 every time. believe.
OH10fiero
Report this Post04-02-2007 11:30 PM Click Here to See the Profile for OH10fieroSend a Private Message to OH10fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got the same set as you.
What I did was get a 2 inch hole saw and cut the center out of the blue poly bushings. You will need to do this to center the spring to your strut plate, if not the noise will drive you insaine. Trust me when I say you will get half a block before you turn around and tear the thing apart to make this modification.
Icelander
Report this Post04-02-2007 11:42 PM Click Here to See the Profile for IcelanderSend a Private Message to IcelanderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am SOOOO jealous! I'm finally going back to work so now I can have the money but not the time to do this mod. :P
Lotsa pictures of this conversion when you get to it please.
Kendall (Icelander) Whitlatch
'85 Fiero 2M4 - 5spd Isuzu
'67 LeMans/GTO clone 6.5 litre TH400
All the rest aren't Pontiacs, so what does it matter?
BobadooFunk
Total ratings: 128
Report this Post04-03-2007 01:09 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
thats what it sounds like... ill check power, grounds, and connections tomorrow early before work..
and as for those coil over things, yea they look sweet (i need new stuff too!) i have no idea on installation yet, but im gonna tey on my extra set of struts..
DRA
Total ratings: 96
Report this Post04-03-2007 02:45 AM Click Here to See the Profile for DRAClick Here to visit DRA's HomePageSend a Private Message to DRAEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to see things are moving along!
Keep at it.
Don't take life too seriously -- you'll never get out if it alive.
OH10fiero
Report this Post04-03-2007 03:00 AM Click Here to See the Profile for OH10fieroSend a Private Message to OH10fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you need help let me know, I might be able to make a trip out there on a weekend sometime. Since I have a V6 we can compare the two side by side to help you along. The coil over swap is an easy one, but you WILL NEED an alignment when you are done, no way around it so keep that in mind.
BobadooFunk
Total ratings: 128
Report this Post04-03-2007 03:15 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
car needs an alignment anyways since i have to replace the struts, and anyone who could make a trip out here to help me would be great! im USUALLY off on sundays.. anytime after easter is good (the sooner the better!!) i NEED this girl running ASAP!!! school in june!!
BobadooFunk
Total ratings: 128
Report this Post04-03-2007 04:03 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
BobadooFunk
ugh... today... not a good work day. i found out the starter wasnt even wired up (explains some other problems i had earlier with wiring) BUT! it didnt change anything.. car still doesnt turn over, and makes same click sound when i try to start it.. so what comes before the starter?
i also broke one of the bolts on the starter was just turning the 8mm one, and then i felt it... i really dont want to have to put a new starter on it...
another really making me mad thing.. the passenger side door, WONT OPEN!! (no its not locked.) great....
so right now i need someone to help me... anyone near Pittsburgh got some time next week?
ly41181
Report this Post04-03-2007 10:27 PM Click Here to See the Profile for ly41181Send a Private Message to ly41181Edit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure the battery is fully charged. If it is, rap on the starter solenoid with a hammer while Alex turns the car over. I can't remember the 8mm bolt was for. If you broke it off on the inside thats not good. It's not going to get a good connection.
Josh
"I reject your reality, and substitute my own."
Adam Savage
FormulaGT
Report this Post04-03-2007 11:05 PM Click Here to See the Profile for FormulaGTSend a Private Message to FormulaGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it is a manual trans, make sure the clutch safety switch is properly working or run a jump wire through it to make sure it is not at fault. Good luck! Hmmmm.....After reviewing page 1 I see an auto trans. Like said before, go over all connections thoroughly.
[This message has been edited by FormulaGT (edited 04-03-2007).]
s550w
Report this Post04-04-2007 12:26 PM Click Here to See the Profile for s550wSend a Private Message to s550wEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you get full dash lights, "click" of fuel pump, and zero starter....on an auto, check the plug on the transmission where the kill switch is to prevent starting in gear. I believe the two relevant wires are yellow from wall and purple (red originally?) from the starter. My automatic did as described when the connector got dirty and lost connection.
I simply dis-connected, cleaned and attached connector to start mine.
D B Cooper
Total ratings: 54
Report this Post04-04-2007 11:40 PM Click Here to See the Profile for D B CooperSend a Private Message to D B CooperEdit/Delete MessageReply w/QuoteDirect Link to This Post
I often had to put the old '84 in neutral, pop the decklid, and reach down there and short across the solenoid to get it to pop Beat the heck out of push starting it every time it acted up... I kept an extra copy of the door key in the trunk for that purpose. I can't count the number of times I had the starter off that car to mess with that solenoid.
Looking back I think I had a weak ground issue causing the key switch to not get enough 'umph' to the small pin on the solenoid to actuate it right. (also had weak power supply in the dash, and engine wanted to stumble when turning on headlights or heater motor etc... good battery, good alternator...) But I didn't realize that until years later.
F-I-E-R-O
Total ratings: 294
Report this Post04-05-2007 12:38 AM Click Here to See the Profile for F-I-E-R-OSend a Private Message to F-I-E-R-OEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I first saw these I panicked!
What the heck do these little parts go to? I don't remember these when I started taking the top of my engine apart! Does he have something that I should have??? Where do I get that little tool once I figure out where those little parts go?!!!
Please put some reference objects in your post so that those of us who find something we know little about will have a better idea where to imagine them going!
[This message has been edited by F-I-E-R-O (edited 04-05-2007).]
BobadooFunk
Total ratings: 128
Report this Post04-05-2007 12:39 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Andrew, this is how i think they will go, they were a gift from a fellow forum member for my b-day
ok well i ordered 2 new struts+shocks, wipers, and a new part of the starter (just that solinoid part) from rockauto so we'll see what i can do once that arrives... (then i can try to do the coil overs as well...)
i also received the OPSU connector!!! thanks!!! its snowing out right now we are going to Buffalo for easter to visit family, but i will be working as hard as i can when we return! but untill we leave im bringing interior peices in the house to restore/paint them
[This message has been edited by BobadooFunk (edited 04-05-2007).]
OH10fiero
Report this Post04-05-2007 02:21 AM Click Here to See the Profile for OH10fieroSend a Private Message to OH10fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent.
BobadooFunk
Total ratings: 128
Report this Post04-05-2007 03:50 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
and returned just got done playing with my Wii
this is what i did tonight (yea not much, but mainly a test peice)
i still need the other 2 light covers that go on there... a new center console, and a radio surround bezel.. (as long as bezel is in one peice its kool, im gonna get something to put on it..)
I love the way it turned out, looks like it came that way! gonna do alot of the rest of the interior like that, i hate greys/browns..
as for the starter thing.. like i said i bought a new peice, i also noticed 2 grounds near there arent connected, i haveta look through my pics to see if i can find where they go, but maybe thatll help...?
BobadooFunk
Total ratings: 128
Report this Post04-10-2007 03:31 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
These came in while i was away for easter!
(except the grey brackets on the left, i picked those up from my grandfathers house where ive had em for years with my strut tower bar..)
sweet. now tomorrow hopefully it isnt too cold and i can go do something!!! but for now im off to work..
[This message has been edited by BobadooFunk (edited 04-10-2007).]
Doc John
Report this Post04-10-2007 07:48 PM Click Here to See the Profile for Doc JohnSend a Private Message to Doc JohnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any luck starting the engine?
BobadooFunk
Total ratings: 128
Report this Post04-11-2007 01:26 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
we'll find out tomorrow ill start working on it round 11am-4, then once i get back from filling out finnancial stuff for college, ill get right back to work
BobadooFunk
Total ratings: 128
Report this Post04-11-2007 10:34 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
BobadooFunk
started attacking the starter today, but hell hath no fury like a rusty, stripped bolt. I NEED to know where those 2 wires go..?
Door panel off
the mechanism with the hole in it seems like its disconnected from the other part that holds it closed.. i still have no idea what to do here
BobadooFunk
Total ratings: 128
Report this Post04-12-2007 12:35 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok the guys in tech helped me out
BobadooFunk
Total ratings: 128
Report this Post04-13-2007 08:59 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
old starter is out, gonna pick up new bolts for the new one tomorrow , connect those 2 grounds, then try to start her again!! if it doesnt work.. off to tech with me
D B Cooper
Total ratings: 54
Report this Post04-13-2007 09:56 PM Click Here to See the Profile for D B CooperSend a Private Message to D B CooperEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought you meant you had a stripped 15mm head on one of the bolts holding the starter itself in place... good to see it was just the little guys holding the solenoid on there. It never occurred to me to pull the solenoid off while leaving the starter in place lol.
Hope she fires right up for you.
