  Black Betty, Round 2 (Page 2)
Black Betty, Round 2 by BobadooFunk
Started on: 06-24-2007 11:36 PM
Replies: 290 (17374 views)
Last post by: Finally_Mine_86_GT on 08-05-2009 01:46 PM
Back On Holiday
Report this Post07-09-2007 08:14 AM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
your Y-pipe is still loose? you should be able to line it up and then tighten everything down if thats the case, unless it is WAY off. then I suggest fabing some 1/4 thick pieces of steel to bolt into each end, hope this pic shows what I mean im a novice photoshopper
removed pic....
I own page 2!
[This message has been edited by Back On Holiday (edited 07-15-2007).]
BobadooFunk
Total ratings: 128
Report this Post07-09-2007 10:23 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
no the bolt holes on the flange are almost exactly 90 degrees off of the y pipes but i have an idea that may work, remember the cat you gave me? well the bole holes peice on that rotated... so if i cut the little tab welds on this one, i should be able to rotate it and voila! but seeing as i get home around 10:30pm.. im not sure when i can make lots of noise... perhaps the basement..
summerjim
Report this Post07-09-2007 10:59 AM Click Here to See the Profile for summerjimClick Here to visit summerjim's HomePageSend a Private Message to summerjimEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by BobadooFunk:
had to plug up some odd hole..
Did you plug that small hole in the bottom of hte muffler? That hole is a water drain... something you definitely want there. A normal byproduct of combustion is H2O, and until your exhaust gets hot enough to keep it vaporized, you will get a lot of condensation in the exhaust. If it can't drain, it will rot the muffler from the inside.
eldervampire
Report this Post07-09-2007 12:52 PM Click Here to See the Profile for eldervampireSend a Private Message to eldervampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Jerry, glad to see that things are working out, i've been off-line for a year and have been reading up on whats been goin on.
I wish I could help in some way, but for now all I can offer you is my prayers and well wishes.
Michal
Back On Holiday
Report this Post07-09-2007 02:13 PM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
excellent! myself, I stalled today because I have to wait for replacement gas tank filler rubber hoses where it connects to the tank. Fierostore to the rescue as no part stores carryed them, or could get them for me today and mine is severly dry rotted
BobadooFunk
Total ratings: 128
Report this Post07-11-2007 01:35 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
It worked!
Modified this..
its amazing what i wire brush will do..
for now the exhaust is just zip tied up.. just for aligning purposes, and its a perfect fit! awesome.
i started her up for literally a split second, she fired right up nice and strong cant wait to drive her..
BobadooFunk
Total ratings: 128
Report this Post07-14-2007 04:42 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
New brake lines in
Exhaust ALL connected!
I took some video, and discovered something... NOW IVE GOT A FUEL LEAK!! UGH!! now i need THOSE lines again, for now i may just cut+paste some hose.. good thing it didnt catch fire!! ill have the vid up in 30mins or so..
BobadooFunk
Total ratings: 128
Report this Post07-14-2007 05:41 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
BobadooFunk
Member since Jun 2003
BobadooFunk
Total ratings: 128
Report this Post07-18-2007 03:37 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok well i attempted to fix the leak tonight, till i realized i had no small clamps... so off to wally world or napa tomorrow...
anyone have a GOOD fuel line laying around? the one without the filter?
tomorrow i work on my 4.5 in school and then when i get home... fix fuel line, bleed brakes, drive. (hopefully....)
Back On Holiday
Report this Post07-18-2007 09:43 PM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump for tonights progress
mtownfiero
Report this Post07-18-2007 09:49 PM Click Here to See the Profile for mtownfieroSend a Private Message to mtownfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not bad cept for leakin fuel a little.
BobadooFunk
Total ratings: 128
Report this Post07-20-2007 01:11 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel leak fixed.
Before
After
then i bled what i could of the brakes..
then complete and utter disappointment.. https://www.fiero.nl/forum/Forum2/HTML/084455.html
drumwzrd
Total ratings: 50
Report this Post07-29-2007 07:21 PM Click Here to See the Profile for drumwzrdSend a Private Message to drumwzrdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a bump for good measure........even though you have so many different posts of this build, I don't know which to bump !!!
BobadooFunk
Total ratings: 128
Report this Post07-31-2007 02:22 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
BLACK BETTY BAM A LAM!!
Click here to watch She-MOVES-96
drumwzrd
Total ratings: 50
Report this Post07-31-2007 02:40 AM Click Here to See the Profile for drumwzrdSend a Private Message to drumwzrdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats what I'm talkin' about.....CONGRATS !!!!!!!!
avengador1
Total ratings: 571
Report this Post07-31-2007 10:04 AM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you check your trannie's oil level again now that you have it running and fix that left side exhaust tip so it doesn't drag.
Congrats.
Fiero Thomas
Total ratings: 125
Report this Post07-31-2007 01:03 PM Click Here to See the Profile for Fiero ThomasSend a Private Message to Fiero ThomasEdit/Delete MessageReply w/QuoteDirect Link to This Post
She is alive. Now get her to fierorama.
Fiero Thomas
85 Fiero GT
86 Fiero GT
88 Formula T-Top C+C # 1239 of 1252, Build Digit 26,224 of 26,402
NIFE Member
Fiero News dot net
BobadooFunk
Total ratings: 128
Report this Post07-31-2007 03:23 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have the exhaust up with hangars for now so no more scraping
im going to bring the GT to school tuesday next week so i can work out all the little bugs, change the brake lines etc..
i still have to rev it a bit before itll go into gear... any ideas?
whadeduck
Total ratings: 103
Report this Post07-31-2007 03:35 PM Click Here to See the Profile for whadeduckSend a Private Message to whadeduckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Low fluid? Clogged filter?
Whade' "The Duck Formerly Known As Wade" Duck
'87 GT Auto
'88 Ferrario
'84 Indy
Formula88
Total ratings: 554
Report this Post07-31-2007 04:04 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just be very gentle with it until you get it figured out. That having to rev it could be causing some clutch slippage and it may be slipping some while in gear. Definitely change the filter if you haven't already and check the fluid daily and see if it smells burnt.
Back On Holiday
Report this Post07-31-2007 08:12 PM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
WOOT!
BobadooFunk
Total ratings: 128
Report this Post07-31-2007 11:52 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
tis a new filter..
Formula88
Total ratings: 554
Report this Post08-01-2007 12:12 AM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does the Fiero automatic use a TV cable? If so, it has to be properly adjusted for the transmission to shift properly.
BobadooFunk
Total ratings: 128
Report this Post08-01-2007 05:17 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
i think so, thats the one that goes to the TB right? how do i adjust that
Formula88
Total ratings: 554
Report this Post08-01-2007 05:35 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure. I've never had an automatic Fiero. I'll see if I can look it up in my shop manual.
If you have a Haynes or Chiltons manual, they might also have the procedure.
I do know on other cars that the TV cable affects shifting and if it's not hooked up and properly adjusted, it could damage the transmission. Or so I've been told.
I'll see what I can find out if someone doesn't post the info here first.
Richjk21
Report this Post08-01-2007 05:48 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here's a couple threads discussing aadjusting the TV cable...
https://www.fiero.nl/forum/Forum2/HTML/079573.html
https://www.fiero.nl/forum/Forum2/HTML/083502.html
Rich
BobadooFunk
Total ratings: 128
Report this Post08-01-2007 07:36 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
but from what i see, that affects shifting while driving.. it seems like my driving shifting is fine.. it just takes a minute to get INTO gear (im guessing build pressure..)
this is what happens..
i put it in gear and release brake.. nothing
i up it to 2k for about 30 sec's then itll move.. once moving.. its fine from R to D takes a sec.. but once i put it in park.. i have to rev it a bit again to get it to move...
is it possible theres air in the system, and everytime i turn the car on, it compresses the air till it works?
BobadooFunk
Total ratings: 128
Report this Post08-02-2007 05:10 AM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
messed with TV cable, no difference.. checked fluid, full.
is it possible not enough fluid in the actual torque converter? air in system?
avengador1
Total ratings: 571
Report this Post08-02-2007 09:09 AM Click Here to See the Profile for avengador1Send a Private Message to avengador1Edit/Delete MessageReply w/QuoteDirect Link to This Post
You might not have enough fluid in the torque converter for it to work properly. I'm guessing you have a bad or sticking valve or modulator. You can read about how the torque converter works here http://auto.howstuffworks.com/torque-converter.htm
Here are some things that can cause tranny failure from the Wikipedia article on torque converters.
Overloading a converter can result in several failure modes, some of them potentially dangerous in nature:
Overheating: Continuous high levels of slippage may overwhelm the converter's ability to dissipate heat, resulting in damage to the elastomer seals that retain fluid inside the converter. This will cause the unit to leak and eventually stop functioning due to lack of fluid.
Stator clutch seizure: The inner and outer elements of the one-way stator clutch become permanently locked together, thus preventing the stator from rotating during the coupling phase. Most often, seizure is precipitated by severe loading and subsequent distortion of the clutch components. Eventually, galling of the mating parts occurs, which triggers seizure. A converter with a seized stator clutch will exhibit very poor efficiency during the coupling phase, and in a motor vehicle, fuel consumption will drastically increase. Converter overheating under such conditions will usually occur if continued operation is attempted.
Stator clutch breakage: A very abrupt application of power can cause shock loading to the stator clutch, resulting in breakage. When this occurs, the stator will freely counter-rotate the pump and almost no power transmission will take place. In an automobile, the effect is similar to a severe case of transmission slippage and the vehicle is all but incapable of moving under its own power.
Blade deformation and fragmentation: Due to abrupt loading or excessive heating of the converter, the pump and/or turbine blades may be deformed, separated from their hubs and/or annular rings, or may break up into fragments. At the least, such a failure will result in a significant loss of efficiency, producing symptoms similar (although less pronounced) to those accompanying stator clutch failure. In extreme cases, catastrophic destruction of the converter will occur.
Ballooning: Prolonged operation under excessive loading, very abrupt application of load, or operating a torque converter at very high RPM may cause the shape of the converter's housing to be physically distorted due to internal pressure and/or the stress imposed by centrifugal force. Under extreme conditions, ballooning will cause the converter housing to rupture, resulting in the violent dispersal of hot oil and metal fragments over a wide area.
Retrieved from "http://en.wikipedia.org/wiki/Torque_converter"
[This message has been edited by avengador1 (edited 08-02-2007).]
Mr.PBody
Total ratings: 101
Report this Post08-02-2007 11:42 AM Click Here to See the Profile for Mr.PBodyClick Here to visit Mr.PBody's HomePageSend a Private Message to Mr.PBodyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did the tranny ever come out? If it did you're supposed to pour oil directly into the torque converter (according to my reading and an episode of monster garage) much like putting oil in the oil filter during and oil change.
BobadooFunk
Total ratings: 128
Report this Post08-02-2007 12:11 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
right, i think there was some in there, but i think thats the problem... not enough.. but at least it moves.. now i can get it to school to work on.. ill probably drive it mon or tues and have it ready to go by thurs or fri.. (brake lines, alignment,.. etc as well..)
rjblaze
Report this Post08-02-2007 08:15 PM Click Here to See the Profile for rjblazeSend a Private Message to rjblazeEdit/Delete MessageReply w/QuoteDirect Link to This Post
hey jerry, does this sound like a recent phone call?
BobadooFunk
Total ratings: 128
Report this Post08-02-2007 09:17 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
yep but at least it moves now
BobadooFunk
Total ratings: 128
Report this Post08-06-2007 11:53 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
thought id update..
tranny still a bit laggy.. i still have to rev it to get it to move, but it IS driveable!!
so far i have driven it back+forth to work twice, and to school once, where it was then aligned for free!!
i had an overheating problem (as well as a non working temp gauge...) i think the overheating was the fan.. i just gounded it so its always on.. i live in Pittsburgh anyways
temp gauge still does not work.
alt belt was LOUD and squeaky, JUST fixed that.. also got a couple of rattles im about to go out and take care of (lose coolant tube and a heat sheild..) BUT MAN AM I GETTING THERE!!
things to do:
replace fuel filter
replace brakelines + bleeder screws
get new CV boot on it ASAP.
Get an ebrake
sound system
carpet
hood scoop (you know cut a line in the front.. i always liked that one..)
here she is!
Disillusion
Report this Post08-07-2007 01:16 AM Click Here to See the Profile for DisillusionSend a Private Message to DisillusionEdit/Delete MessageReply w/QuoteDirect Link to This Post
For your temp gauge, it may sound stupid, but is it plugged in right? it does plug in both ways. I had to unplug mine cause the unit went bad, and plugged it in backwards, couldn't figure out why the guage didn't work..I felt real smart.
Cars looking good though.
Back On Holiday
Report this Post08-07-2007 08:28 PM Click Here to See the Profile for Back On HolidaySend a Private Message to Back On HolidayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice to see her up and about
F-I-E-R-O
Total ratings: 294
Report this Post08-07-2007 09:26 PM Click Here to See the Profile for F-I-E-R-OSend a Private Message to F-I-E-R-OEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check to make sure your radiator fluid is filled and burped. Fill it in the front and in the back and keep checking the back. Try to get as much air out of the system as you can by rocking the car when you fill it or just before to try and get more air pockets out of the system. Make sure you do this when the coolant is "cool."
BobadooFunk
Total ratings: 128
Report this Post08-07-2007 11:43 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got some stuff done today...
new fuel filter
5w-30 Mobil 1 synthetic
Alignment done
engine as it is now
Car at school
the tranny is still not right, so tomorrow begins the 3rd drop.. and other tranny is being put in. thank god for school..
Formula88
Total ratings: 554
Report this Post08-08-2007 02:05 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
engine as it is now
Be careful of the wiring between the battery and the engine. The wiring harness runs close to the water pump pulley and I've had wires get rubbed by the belt or pulley until it cut right through them. My luck it was the Orange ECM power wire - so the car was dead in the water until I figured out what the problem was.
BobadooFunk
Total ratings: 128
Report this Post08-08-2007 11:01 PM Click Here to See the Profile for BobadooFunkClick Here to visit BobadooFunk's HomePageSend a Private Message to BobadooFunkEdit/Delete MessageReply w/QuoteDirect Link to This Post
funny you mention that, i had the 84 die on me a couple weeks ago for that same reason, so i knew to watch out for it on this car
so far, cradle is out, and im picking up a new CV shaft tomorrow
no pix as i left them cam here, but ill snap em off tomorrow i got some homework to do (piston rings and crankshaft bearing stuff..) but tomorrow is mostly Betty dedicated time
O YEA!! one of the other instuctors walked up to me and told me him AND his girlfriend used to own a Fiero.. and it wasnt a bad story!! he said he loved it and was thinking about buying another one because they are so much fun to drive!!
ALSO!! crankshaft+dropping+leg=knot/bruise. i discovered this today.. dropped a 3800 series II n/a crank onto my leg.. a knot built up REAL quick... didnt really hurt though..
[This message has been edited by BobadooFunk (edited 08-09-2007).]
