  Madcurl's Arch Rival !! (Page 63)
This topic is 79 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78   79
Madcurl's Arch Rival !! by exoticse
Started on: 04-07-2005 02:39 AM
Replies: 3142 (257257 views)
Last post by: exoticse on 12-03-2016 10:12 PM
Bloozberry
Total ratings: 311
Report this Post03-18-2011 05:55 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Madcurl, I love your work. I think this is the first time I've posted in here but it's certainly not the first time I've ogled your pictures.
Bubbajoe is right about the e-brake caliper. The actuating lever only moves the inboard pad closer to the rotor. Once it makes contact, the entire caliper must be able to slide over so the outboard pad can pinch the rotor between itself and the inboard pad. I have these same puck-calipers installed on my 29 hot rod's Jag rear end. Here's a picture of what the bracket should look like:
I'd also like to point out that if you decide to remake the brackets, you should consider designing them without any joggles and much beefier where they mount to the hub if you plan on using them for anything other than a "hill-hold" or parking brake. If you try to stop the car with the design you're currently using, the forces exerted on the offset bracket will apply a moment (or a twisting force) and without sufficient torsional rigidity in your "long-arm" design, it will likely result in it becoming cockeyed and jamming against the rotor at an angle the first time you use it hard.
Edit to add: As an example of what the hot rod's e-brake caliper braket looks like, I dug up this old sketch... maybe it'll help you.
[This message has been edited by Bloozberry (edited 03-18-2011).]
Archie
Total ratings: 547
Report this Post03-18-2011 08:27 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by bubbajoexxx:
that is the wrong way to install that caliper it is a floating caliper and it has 2 groves one on each side for the floating bracket the way you have it mounted will ware the front shoe off in no time look in my thread and you will see how it is suposed to be mounted shame on you
He's right Curley. The inside pad will wear out quickly & the outside pad will rattle as you're driving down the road.
Archie
madcurl
Total ratings: 314
Report this Post03-19-2011 11:22 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Thanks BubbaJoexx, Bloozberry, and Archie. Next week we will address these issues using Bubbajoexx design.
[This message has been edited by madcurl (edited 03-19-2011).]
madcurl
Total ratings: 314
Report this Post03-19-2011 01:03 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
madcurl
Member since Jul 2003
The right side exhaust tip need some minor adjustments, but I'm loving the look.
madcurl
Total ratings: 314
Report this Post03-19-2011 07:10 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
madcurl
i hope you are going to put a heat shield between the wire and loom and the cat as that cat runs at 1200 degrees and the plastic melts at 300
Oh I have a plan for that.
and here they are
here is the simple bracket needed to install the caliper. If you use the 88 to 96 rear caliper it has the Ebrake on it and will save you time and money so you wont have to buy the manual ebrake caliper that I did
This is the extra bracket needed if you use the 84 to 87 caliper
This bracket is not needed with these calipers
this is the 2 brackets used with the 84 to 87 caliper the 88 to 96 dose not require the rear caliper bracket
this is all you install for the 88 up caliper
Thank you Sir.
bubbajoexxx
Total ratings: 112
Report this Post03-20-2011 09:56 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by madcurl:
Thank you Sir.
[/QUO
never seen you do any thing halfassed so I thought I should give you a heads up if that was OK
madcurl
Total ratings: 314
Report this Post03-20-2011 11:38 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by bubbajoexxx:
Never seen you do any thing halfassed so I thought I should give you a heads up if that was OK
So I can use the e-brake bracket from the 84-87 or purchase this one?
bubbajoexxx
Total ratings: 112
Report this Post03-21-2011 05:36 AM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I made these using the hurst airhart slider and a piece of 1/4 plate the airhart slider comes with the calipers when you by them here from princess auto
madcurl
Total ratings: 314
Report this Post03-21-2011 10:07 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
Meanwhile, the engine beautification is complete. Moving onto the front compartment to add more pop and bling!
madcurl
Total ratings: 314
Report this Post03-31-2011 05:31 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been a mad week, but I finally got around to viewing #020. Now that the actuators are in place, now it's time to move onto the light switches.
The location:
The switches: Watson's Street Works.
On Friday I hope to start the mock-for the passenger side.
madcurl
Total ratings: 314
Report this Post04-07-2011 02:30 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
madcurl
Total ratings: 314
Report this Post04-08-2011 07:03 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
bubbajoexxx
Total ratings: 112
Report this Post04-08-2011 08:49 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see you have not fixed the ebrake caliper yet bad move
InTheLead
Report this Post04-09-2011 09:00 AM Click Here to See the Profile for InTheLeadSend a Private Message to InTheLeadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Love the tips those are nice~
madcurl
Total ratings: 314
Report this Post04-09-2011 01:31 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope. We haven't, but we talked, but spring is near.
We shall test the device next week on Chris's Fiero (manual). There's several hills in town to test the system. If it works-its stays. If it bends, squeeks, and/or breaks it will be replaced. As for the e-pad replacments-I have a box of them. Of course we did remove the gay-like appearance of the attachment.
Letsbuildanexotic
Report this Post04-10-2011 12:05 AM Click Here to See the Profile for LetsbuildanexoticSend a Private Message to LetsbuildanexoticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by War Hammer:
Why an automatic? Are you missing your left foot?
Paul
response:
Origionally posted by Madcurl:
One word: CALIFORNIA.
Does California have anything against paddle shifters? Sorry you may have answered this before but I could not stop drooling at the pics. Your car is AutoPornography!
-Chris
Letsbuildanexotic
Report this Post04-10-2011 12:08 AM Click Here to See the Profile for LetsbuildanexoticSend a Private Message to LetsbuildanexoticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Letsbuildanexotic
Member since Nov 2010
Didn't know you were testing anything on my Fiero, but sure go ahead, you can test anything you want on my Fiero, but please, once you test it, leave it on.
-Chris
madcurl
Total ratings: 314
Report this Post04-10-2011 01:07 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
-Chris
I only know of one person, but they maybe more.
Originally posted by MountainHiBlue87GT:
This is the blue car in the posts above.
Almost finished -Last major mods: Champion Alumium Radiator, Drive by Wire Cruise Control, 4T65E HD Tapshift Rebuilt with many hard parts and soft parts from Triple Edge, Tap Shift wiring, Wester's PCM programming for Tap Shift and performance, Snow Performance Boost Cooler, some chrome from Mad Curls chrome shop, stainless grill inspired by Madcurls recent work, and ?
Regards,
David
https://www.fiero.nl/forum/Forum1/HTML/080119.html
madcurl
Total ratings: 314
Report this Post04-11-2011 07:39 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today we briefly tested the E-brakes on Chris's car. Chris applied the E-brakes and we both pushed (Chris at the drivers door and me in the rear) to see if the car would move. Using two people you could hear the E-brake clamp down on the rotors, but the car does move ever so slightly. Using one person to push the car doesn't move. Simply, there isn't enough surface and/or lock pressure using the hand brake to hold the car in place with the E-brake engaged on a steep hill or in a emergency were you need to stop on a dime.
In the case of an emergency the E-brakes might slow you down, but in no way will it lock-up. At best the E-brakes will slow you down, but nothing that would stop you dead in your tracks. I need to test these results on #011 since it uses the correct arm, but I have to wait for pads since they're worn out too.
#011 worn pads
[This message has been edited by madcurl (edited 04-11-2011).]
Letsbuildanexotic
Report this Post04-11-2011 07:59 PM Click Here to See the Profile for LetsbuildanexoticSend a Private Message to LetsbuildanexoticEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think I might have a solution for ya. I'll try looking it up again, I didn't have much luck last time, but I'll give it a shot. I used to drift/race with a 240sx, and although I did not perfect the Keiichi Tsuchiya e-brake manuver ( I used speed to my advantage ), many others did. And they used a type of e-brake design that was manually operated yet hydraulically actuated. So, this system used their actual rear brake calipers, and brake lines to apply brakes (at full 100% capacity) to the rear calipers only. I took a closer look at the system which had vavles and a master cylinder directly attached to the e-brake handle, then hydrauic lines that somehow through a valve bypassed the normal brake line pressure and applied its own braking pressure through the rear caliper brake line. Now their system was designed differently than the fiero e-brake handle, but could work, with a little tweaking, anything can be done. Let me see if I can find more information on this system.
-Chris
Letsbuildanexotic
Report this Post04-11-2011 08:02 PM Click Here to See the Profile for LetsbuildanexoticSend a Private Message to LetsbuildanexoticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Letsbuildanexotic
Here you go, the company is BWR:
http://catalog.rpmware.com/catalog/group/62374
So crazy, it might just work!
-Chris
Letsbuildanexotic
Report this Post04-11-2011 08:20 PM Click Here to See the Profile for LetsbuildanexoticSend a Private Message to LetsbuildanexoticEdit/Delete MessageReply w/QuoteDirect Link to This Post
And here's one from K-sport
http://www.ksportusa.com/asp/hydraulic.asp
- Chris
Bloozberry
Total ratings: 311
Report this Post04-11-2011 09:40 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Without a doubt those are interesting... but in any State with annual inspections, they wouldn't pass for E-brakes if they were tied into the hydraulics of the main calipers. E-brakes have to be independent of the main hydraulic system. What would be neat though would be to connect one of those hydraulic E-brake handles up to a pair of hydraulic motorcycle calipers that were wide enough to bridge the vented rotors.
Letsbuildanexotic
Report this Post04-12-2011 12:10 AM Click Here to See the Profile for LetsbuildanexoticSend a Private Message to LetsbuildanexoticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your probably right, I don't know that much about the laws when building a street car. And the only cars I've seen these on are track cars. In Arizona, we don't have a detailed inspection unless the car has a salvage title, infact I'm just not going to say anything to the DMV here once my engine has been swapped in, I'm going on a limb and assuming that it is a different story in Cali.
-Chris
madcurl
Total ratings: 314
Report this Post04-12-2011 01:30 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
After talking with Chris he suggested two options. One was to use Brembo Viper e-brake kit. They're pretty and should stop a car on a dime, but they are not cheap.
http://roeracing.com/produc...t=370&idcategory=151
A thread on the NSX forum has the kit.
http://www.nsxprime.com/for...wthread.php?t=137632
Giving the situation I'm in (N* automatic and to pass inspection) -I think I'll use the spot e-brakes for now. It's not like inspector is going to drive my car off and go power sliding or drifting in the parking lot to pass. As Chris mentioned the e-brake bracket grade of material should be made of thicker material, but since the clapping power is so weak it surely won't come close to bending the bracket. However, it would be nice to have a e-brake system that can stop on a dime. Just to add; I also reviewed the e-brake for the Lamborghini on Ebay. They want $400 per side-I don't think so.
Okay, time to move onto another subject. I'm giving WCF the okay with the P/S. I talked it over with Troyboy and we both agreed-"get the darn power steering unit." Therefore all three chop tops are equal.
Also, I need to get back to designing the underbelly around the driver's side dash.
As of now-spending 1k for E-brakes will have to go on the back burner. I need to get the car painted and move on.
[This message has been edited by madcurl (edited 04-12-2011).]
bubbajoexxx
Total ratings: 112
Report this Post04-12-2011 07:50 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
there is not a production car on eath that will stop dead with the ebrake it is there as a hill holder and desined to slow a car with brake failure if they where to stop on a dime your dead the car would spin wildly out of control as 90% of your braking is done by the front wheels
Letsbuildanexotic
Report this Post04-12-2011 10:45 PM Click Here to See the Profile for LetsbuildanexoticSend a Private Message to LetsbuildanexoticEdit/Delete MessageReply w/QuoteDirect Link to This Post
You must not of driven a 240sx, they will lock up the rear wheels at 60 mph. I know I tried.
-Chris
madcurl
Total ratings: 314
Report this Post04-15-2011 10:01 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Out with the old;
In with the new; Firebird/Camero P/S rack.
Out with the old/rusty parts;
in with the recycled "parts car." I'll wire brush the parts and rattle can them.
madcurl
Total ratings: 314
Report this Post04-16-2011 12:52 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before:
After:
madcurl
Total ratings: 314
Report this Post04-16-2011 01:33 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
madcurl
WCF really surprised me this week. I was expecting at least 3-weeks to gather all of the components for the P/S rack, but WCF already had a rack on hand plus the have a template for the system. Next week they'll perform the piping and hook up. Meanwhile, I got around to the passenger side of the dash. Steve used the template from the driver's side and flipped the pattern. Yes, for now the parts look crude, but like the engine compartment I have some ways to go.
aaronkoch
Report this Post04-16-2011 04:13 PM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
Please excuse the intrusion on your thead, but I'm almost positive there's supposed to be some kind of rubber between the rack mounts and the rack.. I may be wrong, but it seems strange to me to have the steel wrapped directly around the aluminum rack like that..
If I'm wrong, sorry about that, but it just looks like something's missing..
Currently in the middle of my 88 + 3800NA swap
madcurl
Total ratings: 314
Report this Post04-16-2011 05:54 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct. They needed to move my car off the rack inorder to complete another car that arrived. So the rack was quickly mounted and rolled outside. On WCF website demonstrates the rubber sleeve.
http://www.westcoastfiero.c...ering_installed.html
madcurl
Total ratings: 314
Report this Post04-17-2011 02:16 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Baer rotors filling up the 19/20s.
RCR
Total ratings: 102
Report this Post04-17-2011 09:31 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Curley,
What rack are they using?
Bob
madcurl
Total ratings: 314
Report this Post04-18-2011 12:06 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RCR:
Hi Curley,
Bob
The same rack that is on either a Firebird or Camero (both cars use the same one) and the years too are the same from the last procduction 2002-on back.
madcurl
Total ratings: 314
Report this Post04-18-2011 03:08 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
madcurl
exoticse
Total ratings: 106
Report this Post04-26-2011 01:52 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what is next ?
steve308
Total ratings: 58
Report this Post04-26-2011 07:17 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
You might want to consider this http://www.tintek.cz/ as the final touch!
Fixed Link -Chrome wrap and other colors!!!!!
[This message has been edited by steve308 (edited 04-26-2011).]
madcurl
Total ratings: 314
Report this Post04-26-2011 08:48 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what is next ?
I smell paint. Jet black paint! I was at Trenzs paint shop going over the details. Jet black is my choice for #020. I have a few more hardware issues to complete at WCF before paint.
madcurl
Total ratings: 314
Report this Post04-26-2011 08:54 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
madcurl
These pics are for Steven (Fiero 4.9);
Blue hose: high pressure
Copper line: return line.
Starting from the engine to the front of the car the lines snake their way underneath the car along side the gas tank (similar to D1S).
[This message has been edited by madcurl (edited 04-26-2011).]
