  spoiler LED 3rd brake light install (Page 1)
spoiler LED 3rd brake light install by fierosound
Started on: 03-13-2007 04:52 PM
Replies: 41 (6540 views)
Last post by: fierosound on 12-07-2019 10:07 PM
fierosound
Total ratings: 287
Report this Post03-13-2007 04:52 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wanted to install an LED 3rd brake light in my spoiler for a clean modern look.
This is the 25" LED I settled on (Update: they're using my pictures)
https://www.spoilerlights.c...ght-type-sl-1780ard/
We decided to cut a slot in the spoiler using a router and secured and blocked the wing to give us a fence for the router guide.
The outside edge IS straight with the wing. It's just distortion in the picture. The slot cut will be straight.
We used a 1/2" diameter x 3" long router bit to cut the opening.
My friend was afraid to make the cut in one pass, and did it in two passes (he thought, to be safe).
Unfortunately, by doing that there was no support on the 2nd pass for the "flat side" (bottom of wing)
and it "flapped" allowing the cutter to gouge the edge instead of leaving a clean cut (made quite a mess).
If you set the cutter deep enough, cutting in a SINGLE pass will give the nicest result and not gouge.
A strip of MFD approx. 2"wide x 26"long supports the LED. It's on the table between the wing and strip.
It is tapered to match the angle of the wing, being 5/8" thick at the front edge and 1/2" thick on the inner edge (near center on wing).
Once you get this far, it will be obvious why the MDF is required.
It will be bonded inside to the top of the wing with the front edge flush with the slot we just cut.
The LED strip has 5 mounting holes.
I will drill 5 holes in the bottom of the wing matching the mounting holes in the LED strip.
Five screws in the bottom on the wing pass through the mounting holes in the LED strip and into the MFD strip we glued inside the wing.
Yeah, I flipped the pictures so we're not looking at the wing "upside down".
Once the edges are finished and the wing is painted, I think this should look very "factory".
3.4L S/C 87 GT www.fierosound.com
2002/2003/2004 World of Wheels Winner &
[This message has been edited by fierosound (edited 07-15-2024).]
Fieroseverywhere
Total ratings: 89
Report this Post03-13-2007 07:07 PM Click Here to See the Profile for FieroseverywhereSend a Private Message to FieroseverywhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like it!
Blind them "new" car drivers like they always do to us.
twocoda
Report this Post03-13-2007 10:37 PM Click Here to See the Profile for twocodaSend a Private Message to twocodaEdit/Delete MessageReply w/QuoteDirect Link to This Post
actually i was contimplating the rear window light but im now leaning towards this app...looks good . btw nice shop isnt it nice to find more purposes for wood working tools ?? i wonder how a dado cut on the tablesaw might have faired out
fierosound
Total ratings: 287
Report this Post10-23-2008 11:33 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update. Finished edges, repainted and on the car. LEDs are not on, just reflecting the flash.
[This message has been edited by fierosound (edited 04-25-2011).]
BabyVet
Report this Post10-23-2008 12:31 PM Click Here to See the Profile for BabyVetSend a Private Message to BabyVetEdit/Delete MessageReply w/QuoteDirect Link to This Post
looks awesome always thought that would be a cool addon but my question is
how did you mount it the LED that is? how did you get it to stay in the wing w/o moving?
fierosound
Total ratings: 287
Report this Post10-23-2008 12:34 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't read the information above did ya?
kennn
Report this Post10-23-2008 12:44 PM Click Here to See the Profile for kennnSend a Private Message to kennnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Truly bitchin'. I would like to try it on my Formula.
Ken
'88 Formula V6
'88 GT TPI V8
BabyVet
Report this Post10-23-2008 12:59 PM Click Here to See the Profile for BabyVetSend a Private Message to BabyVetEdit/Delete MessageReply w/QuoteDirect Link to This Post
did but couldn't quite get how exactly. is there more pics you can show?
sorry slow learner LOL
FieroReinke
Report this Post10-23-2008 01:43 PM Click Here to See the Profile for FieroReinkeSend a Private Message to FieroReinkeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where did you get the LED strip from? I really like the way this turned out.
fierosound
Total ratings: 287
Report this Post10-23-2008 02:50 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
See the 2nd line at the top of the page?
fierosound
Total ratings: 287
Report this Post10-23-2008 03:21 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Member since Nov 1999
Sorry, don't have more pics, but I went back and tried to clarify it above.
BabyVet
Report this Post10-23-2008 03:40 PM Click Here to See the Profile for BabyVetSend a Private Message to BabyVetEdit/Delete MessageReply w/QuoteDirect Link to This Post
appreshate it looks good what would you charge for one complete? would you do another one?
whodeanie
Total ratings: 120
Report this Post10-23-2008 03:46 PM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
nice job and I like the woodshop also!
fierosound
Total ratings: 287
Report this Post10-23-2008 04:31 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, but it's not my woodshop and I don't have the facilities or tools to do another wing. Sorry guys, but you're on your own to do this modification.
BabyVet
Report this Post10-23-2008 05:27 PM Click Here to See the Profile for BabyVetSend a Private Message to BabyVetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Darn
Dodgerunner
Total ratings: 323
Report this Post10-23-2008 09:26 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would also be cool if the bar could be in three parts so you could do the turn signals on the ends of the bar...
Or sequence the turn from the middle out... just dreaming...
chrismclubm
Report this Post10-23-2008 11:41 PM Click Here to See the Profile for chrismclubmSend a Private Message to chrismclubmEdit/Delete MessageReply w/QuoteDirect Link to This Post
looks clean and modern
1986 GT Fiero Owner & Enthusiast
For Fiero updates, visit my site and don't forget to click on the ads!
http://educatorstop15.we.bs/fieropage.htm
Santa Nic
Report this Post11-28-2008 06:17 PM Click Here to See the Profile for Santa NicSend a Private Message to Santa NicEdit/Delete MessageReply w/QuoteDirect Link to This Post
The quality of your work and the attention to detail is awsome
fierosound
Total ratings: 287
Report this Post11-29-2008 08:13 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's the SD4 Indy this went on https://www.fiero.nl/forum/Forum2/HTML/096075.html
I have since changed the decal back to just Indy Fiero. The SD4 looked too big and made the decal too long.
[This message has been edited by fierosound (edited 09-07-2009).]
Mister
Total ratings: 56
Report this Post11-29-2008 10:17 PM Click Here to See the Profile for MisterSend a Private Message to MisterEdit/Delete MessageReply w/QuoteDirect Link to This Post
AWESOME my kind of project
T-Top ~HUD~LEDs ~Red Fieros~Carputer~Reverse lights
fierosound
Total ratings: 287
Report this Post02-13-2010 03:03 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys
katore8105
Report this Post02-14-2010 11:36 AM Click Here to See the Profile for katore8105Click Here to visit katore8105's HomePageSend a Private Message to katore8105Edit/Delete MessageReply w/QuoteDirect Link to This Post
A pic of the lights on in the dark would be great!
Edit, I was considering doing something like this with the Cadillac light strip. I don't remember who did it but it came out nice also.
[This message has been edited by katore8105 (edited 02-14-2010).]
fierosound
Total ratings: 287
Report this Post02-14-2010 12:59 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by katore8105:
... I was considering doing something like this with the Cadillac light strip. I don't remember who did it but it came out nice also.
I saw that. The caddy light was almost the full width of the wing, thicker and had a curve that made it more work to fit.
The guy did a pretty good job, but it looked "too oversized" for my taste.
timcha
Report this Post02-23-2010 11:39 AM Click Here to See the Profile for timchaSend a Private Message to timchaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like how the strip ends just above the inside edge of the tail lights. I think this is exactly how GM would have (should have) done it. Great job!
fierosound
Total ratings: 287
Report this Post03-26-2010 12:23 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nobody else try this yet?? Guess it's because the LED ain't cheap??
skuzzbomer
Total ratings: 92
Report this Post03-26-2010 08:06 PM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd do it if I had an extra spoiler to work with and the tools... But, I don't :/
Danyel
Total ratings: 171
Report this Post04-13-2010 02:59 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is a little longer and I have TLG stands now on my Widow ... looks pretty sharp and OEM LED strip cost $19 new on EBAY
http://www.blackwidowfiero.com
Edited to add LED costs
[This message has been edited by Danyel (edited 04-14-2010).]
fierosound
Total ratings: 287
Report this Post05-01-2010 01:29 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good to see another has done this. The LED strip just looks so modern and fits the wing so well.
88GTS
Report this Post05-02-2010 01:06 PM Click Here to See the Profile for 88GTSSend a Private Message to 88GTSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Danyel,
For which car is the OEM LED strip you've installed?
Thanks!
Gokart Mozart
Total ratings: 159
Report this Post05-07-2010 01:22 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try http://www.oznium.com/car-lighting
zacksnacks227
Report this Post04-03-2011 10:04 AM Click Here to See the Profile for zacksnacks227Send a Private Message to zacksnacks227Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know this is a bit off topic but im looking for a gt spoiler for my 86 se and it has been impossible finding a new one. Can anybody help me out? Thanks!
Fiero Thomas
Total ratings: 125
Report this Post04-03-2011 07:42 PM Click Here to See the Profile for Fiero ThomasSend a Private Message to Fiero ThomasEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
1985 Fiero GT 4speed 1986 Fiero GT
1994 BMW 530 V8 1997 BMW 328 85 300ZX
FieroNews~Boots~Bag's~Walle ts~Headliner~Spare Cover~
Visors~Sunshads and T-Top Sunshades~Download the Fieronews Catalog HERE~
Xyster
Report this Post04-05-2011 10:35 AM Click Here to See the Profile for XysterSend a Private Message to XysterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amazing. My favorite part is that it looks stock and like it should have always been there. Very nice.
fierosound
Total ratings: 287
Report this Post04-10-2011 10:57 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank You
yellowTee
Report this Post05-19-2012 05:39 PM Click Here to See the Profile for yellowTeeSend a Private Message to yellowTeeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thought this was a great upgrade. Just wanted to show mine.
Did the install a little different, but turned out great.
lou_dias
Total ratings: 67
Report this Post05-25-2012 02:38 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did I miss how the wiring was done?
fierosound
Total ratings: 287
Report this Post05-26-2012 10:46 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have a third brake light, it's a simple matter to tap and run wires.
I also installed a Brake Pulser for the wing's LED light.
https://www.webelectricprod...ght-Pulser-c67622195
I ran the wires through the wingstand and fished it through the rib of the decklid - same as the trunk popper wiring.
Bozzie
Report this Post05-26-2012 12:07 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very Cool Installs, and the "flasher" relays are a great idea !
fierosound
Total ratings: 287
Report this Post09-18-2015 10:52 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
<bump>
Aztlan10Nation
Report this Post08-04-2019 05:37 AM Click Here to See the Profile for Aztlan10NationSend a Private Message to Aztlan10NationEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Danyel,
Do you know we're I can buy a pair of arms for the wing? Like the ones you have on that picture, the tall ones.
Thank's!
