  Pantera parts ! (Page 19)
Pantera parts ! by opm2000
Started on: 07-07-2004 11:05 PM
Replies: 741 (85769 views)
Last post by: Sage on 09-18-2016 09:50 AM
Report this Post03-23-2015 02:24 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Fastfocusguy:
Ok - My home internet is up and running againg, as promised.
So, now I can get busy and post pix showing what has been
accomplished in the last 24 months, more or less ! hehehe
Hope you enjoy !
Regards,
David
I'm ready!
Fastfocusguy
Report this Post04-05-2015 10:40 AM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So - where to begin ? Just looked back through my pix and chose two topics to start with.
First I want to show you how my door panels turned out.
The map pouch and carpeting were removed from the lower part of the door panel-
Then that area was reupholstered with black vinyl from JoAnn's fabric store -
Finally the upper portion of the door panel was prepped and sprayed with commercial
automotive grade vinyl dye ( this stuff is NOT cheap ! )
This product was also used to recolor the arm rests and other bits you see in these pix !
I used photo shop to attempt to lighten these up, since black is hard to photograph !!!
Fastfocusguy
Report this Post04-05-2015 10:56 AM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fastfocusguy
Member since Apr 2007
The second item I will share today is my shift gate.
I wanted to use a real Pantera shift gate, but the price is high,
and the pattern is not correct for my muncie four speed -
So I copied the Pantera part, but modified it with the correct shift pattern.
You can see in the pix I did a prototype in masonite ( sprayed silver )
to make sure it would not interfere with the movement of my shift lever !
Then paid a shop up in Green Bay to cut the real deal out of stainless steel
I think they used a high pressure water jet machine !!
The bezel it is screwed to is just 3/4 inch pine, which I upholstered using
the same "Pleather" I have been using for all of my manufactured interior parts.
Compare it to photos of real pantera interiors, and you will see it is amazingly convincing !!
ps - yes, my 2nd and 3rdpix are upside down- so the shift pattern looks goofy ! :S
[This message has been edited by Fastfocusguy (edited 04-05-2015).]
Fastfocusguy
Report this Post04-05-2015 10:24 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fastfocusguy
Figured this might be another good one to post -
as a preface to the pix I plan to post next - - -
Here is the "cockpit" of a 1985 Fiero GT with virtually all of the goodies removed !
You can see the new Pantera-Look GT steering wheel, and the foundation of my
new center console - Notice the framing around shifter - this is where the shift
gate shown above will eventually mount.
Fastfocusguy
Report this Post04-06-2015 10:53 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now a shameless plug for Mr. Mikes, down in Florida, who made the awesome
install them myself seat re-upholstery kit which you see in the pix below.
He patiently listened to my wants and needs, helped me select all the correct
options, and even had the DeTomaso ISIS logo ebroidered onto to leather for me!
Yes, I could not resist the Lure of real leather ! Not cheap, but worth it !
The aroma alone is enough to make visions of Lamborghini's dance in my head !
Did anyone notice the DeTomaso logo on my HAT ? ? ? :O
Fastfocusguy
Report this Post04-06-2015 10:59 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fastfocusguy
What's that ? ?
You want to see pix of the seats IN the Fiero/Pantera ? ?
No problemo ! Your wish is granted !
I will also point out here that the gorgeous new carpet kit you are seeing
is available from Fierostore dot com, and fits amazingly well ,
considering one must locate and cut your own holes for the
seat belt bolts and seat track bolts, and the wiring harness to the seat.
Fastfocusguy
Report this Post04-06-2015 11:18 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fastfocusguy
In case you were wondering -
The 'covers' which fit over the seat recline mechanisms
are simply slightly modified Fiero parts -
I removed the "horn" or "hook", and then used PE resin
and a skim coat of bondo, to build back the area where the
"horn" was formerly located.
Primer and semi-gloss black enamel for styrene followed,
yielding a color correct pantero part, which looks 'right',
and still bolts right up to the fiero seat frame / mechanism !
Fastfocusguy
Report this Post10-27-2015 06:12 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also wanted to mention the seat belts you see in the pictures.
The complete seat belt 'sets' were salvaged from a 1982 Lancia Zagato Spyder
So not only are they color correct Black,
they are of Italian manufacture, and therefor suitable for a
Italian De Tomaso replica !
They also bolted up rather conveniently to the pre threaded bolt holes
in the Fiero tub, using the Factory Pontiac Bolts !
[This message has been edited by Fastfocusguy (edited 10-27-2015).]
wftb
Report this Post10-27-2015 10:33 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have enjoyed this thread for ever .Thanks for keeping it going and love the seats !
Fastfocusguy
Report this Post10-29-2015 08:13 AM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you! I am glad to know you are enjoying and following my slow but methodical build !
So here are those pesky and mysterious "access" holes with the horribly rusted out factory "plugs"
At least the floor pans themselves were not rusted, as you can see. I chose to fiberglass these shut permanently,
and inluded some steel cross braces that tie into the slots in the pan, with glass both above and below !
and this shows the totally cool replica/repro builders plate ( sans VIN number, of course ) which will help lend more
credibility to my "clone" ! I plan to insert the Fiero Vin Number into the appropriate box, of course !
I firmly believe that building a believeable replica is all in the details! don't you agree ?? ??
Fastfocusguy
Report this Post10-30-2015 08:39 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ready for the GOOD stuff?
I have been working on this part for many months now,
and it is time to unveil the nearly complete results !
I have already mentioned getting my hands on an actual
Pantera Dashboard, as well as all the Gauges, and switches -
I think I even made a comment about grafting the forward 9 inches
of the Fiero Dash onto the DeTomaso dash, so I could re-use the
Fiero Defroster vents, and the dash mounted speakers,
as well as the factory mounting points at the base of the windshield.
So, here are a half dozen photos of the dash propped up on the
center console I constructed, including DeTomaso ventilation lever pod.
The radio-cassette unit is from the early eighties, and suits the theme well.
Please feel free to use image search on the net to see some Actual Pantera
interior shots to compare against my results !!
Fastfocusguy
Report this Post10-30-2015 08:48 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fastfocusguy
three overall views !
Fastfocusguy
Report this Post10-30-2015 08:49 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fastfocusguy
and three close - up shots from different angles -
[This message has been edited by Fastfocusguy (edited 10-30-2015).]
Fastfocusguy
Report this Post09-14-2016 04:02 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello? Is this thing on? Can anybody hear me ? LOL
News update for those of you still following my build of the Pantero / Fantera -
I have finally acquired the Holy Grail of Pantera parts : the coveted Carello
license plate light fixture.These were used on two models of FERRARI ,
thereby making spare parts cost 10 times normal prices !! :O
I will post pictures of the part soon !
I have been totally busy this summer taking my 1984 Lancia Delta GT
to car shows every weekend, so the poor Pantero has been largely neglected
these last few months. Hoping that as show season winds down I can get back
to building the perfect Pantera Clone !
[This message has been edited by Fastfocusguy (edited 09-14-2016).]
Neils88
Total ratings: 56
Report this Post09-14-2016 05:50 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Love the dash! Great idea to incorporate the front part of the Fiero dash...that'll give a nice finish and as you mentioned, give the defrost vents in the right spot.
steve308
Total ratings: 59
Report this Post09-14-2016 08:31 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Holy Lazarus Effect!
Fastfocusguy
Report this Post09-14-2016 08:41 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
and so, as promised, here are four pictures of the un-obtainium License plate light assembly.
Prices on flea-bay ranged from 400 all the way up to 999 dollars for this part ! :O
I got very lucky and obtained this one for under 200 dinero !!!
It fits into the moulded in recess, above the license plate, below the keyhole for engine cover latch.
Guess I should fix it in position and snap a photo for ya'll to show you how it fits in so neatly !
Fastfocusguy
Report this Post09-15-2016 09:22 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
so I have three pictures for you, showing the light in position.
I just stuck it on with clear tape for the photo shoot !
and then I added a blank plastic plate, - - -
and then the Euro Plate from my old German Focus !
PS - what do you think of the keyhole? Looks pretty factory, IMHO - - -
( Nothing holding it in at the moment except for friction! ) LOL
[This message has been edited by Fastfocusguy (edited 09-15-2016).]
motoracer838
Total ratings: 83
Report this Post09-17-2016 12:47 PM Click Here to See the Profile for motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's good to see your still at it, lookin' good.
Joe
Fastfocusguy
Report this Post09-17-2016 09:32 PM Click Here to See the Profile for FastfocusguySend a Private Message to FastfocusguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
so I have been wondering how the dash will look
in the cockpit of the Pantero - so here it is,
propped up on a spray-can ! LOL
now for 2 views in through the driver's door - - -
I sure do love those big Veglia Gauges ! ! !
and best of all , here is one of my Supervisor, Supervising the Pantero build !
RCR
Total ratings: 102
Report this Post09-18-2016 09:28 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Great to see some progress. Dash looks great.
Bob
Sage
Total ratings: 71
Report this Post09-18-2016 09:50 AM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
That dash is beautiful! Very nice work indeed.
The longevity of this thread (and build) gives those of us who have similar projects a BIG shot in the arm.
Congrats on the light assembly....yea, that "Ferrari tax" is even steeper than the "Corvette tax" one usually encounters when rounding up parts for a Vette.
Be rest assured, there are more than a few folks who love to see your progress and appreciate your taking the time to update and let us know you're still determined to "get er' done".
Keep up the great work and let us know what you're up to from time to time.
HAGO!
