  Fiero IMSA Build (Page 5)
This topic is 9 pages long:  1   2   3   4   5   6   7   8   9
Fiero IMSA Build by IMSA GT
Started on: 02-17-2008 01:57 PM
Replies: 343 (31443 views)
Last post by: Sage on 10-05-2017 09:48 PM
IMSA GT
Total ratings: 253
Report this Post11-12-2008 12:52 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The whole IMSA body is from Doug at the Fiero Warehouse. He also sells just the wing. The grille is from an 84 and I just modified it to fit.
pontiackid86
Total ratings: 344
Report this Post11-12-2008 12:56 AM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
i like it a lot i figured the grill was from an 84 i mght have to see what hes got i tried getting in contact with him over the summer but hes never there.
IMSA GT
Total ratings: 253
Report this Post11-18-2008 07:34 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Real quick update....I am leaving for Arizona tomorrow and will be back on Friday so Friday will be a major prep day. I'll be painting the entire weekend so there should be lots of pics to follow. On another note, I have made a decision on the wheels. I have contacted Boze Forged and they are going to make my wheels. The rears are going to be 17x11 and the fronts are going to be 17x8. I am also looking into having the rivets anodized in gold for the older style BBS look.
madcurl
Total ratings: 314
Report this Post11-18-2008 07:57 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sweet!
exoticse
Total ratings: 108
Report this Post11-18-2008 11:17 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can i ask how much the wheels cost ?
Looking for some reasonably priced widebody wheels.
Thanks
Tony
IMSA GT
Total ratings: 253
Report this Post11-18-2008 11:50 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The ones in the picture are $530.00 each for the 17x11 in the 5x100 bolt pattern. The other style which is exactly the same minus the rivets is $495.00 per wheel.
fierosound
Total ratings: 287
Report this Post11-19-2008 08:49 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very impressive work! This will definitely turn heads!!
3.4L S/C 87 GT www.fierosound.com
2002/2003/2004 World of Wheels Winner &
My SD4 Indy www.fiero.nl/forum/Forum2/HTML/096075.html
IMSA GT
Total ratings: 253
Report this Post11-21-2008 09:32 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since I just got back into town after a business trip, I focused on one of the parts that had to be made from scratch. I removed the vinyl trim around the windshield and made the windshield hold downs tonight. Here is what I started with.....aluminum stock:
A little shaping:
And installed for a test fit. I plan to replace the windshield, clean up and paint where the vinyl trim normally goes, and delete the trim all together. It should look pretty clean when completed.
FieAirRo87
Report this Post11-22-2008 04:12 PM Click Here to See the Profile for FieAirRo87Send a Private Message to FieAirRo87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely amazing work, its looking great!
IMSA GT
Total ratings: 253
Report this Post11-28-2008 11:16 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today, I continued my painting of the car after all that damned turkey The first thing was to lay a nice coat of primer over the front end and then wetsand it to make sure everything looked ok. I then sprayed a line of silver right below the moulding line and continued this all the way around the front end.
Once that had dried, I masked over the silver with the proper width tape to create the silver stripe and also masked off the upper portion to spray the black.
Once that had dried, I masked the bottom and sprayed the white on top.
After removing the masking tape, the silver stripe could be seen.
I will tell you it is a pain in the A$$ to move the car back and forth between garages to do bodywork in one and paint in the other. Fortunately, the rest of the paint for the front end is all airbrushing so I can do that where it sits and I am working on that right now and will post pictures later on tonight.
FierociousGT
Total ratings: 131
Report this Post11-28-2008 11:22 PM Click Here to See the Profile for FierociousGTSend a Private Message to FierociousGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking good. Nice wheels!
[This message has been edited by FierociousGT (edited 11-28-2008).]
IMSA GT
Total ratings: 253
Report this Post11-29-2008 01:24 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
One more quick update. I layed down the pinstriping for the red stripe. The warp in the center is where the front end goes to a point. When I took the photo, it gives the illusion of a crooked line but the line is very straight.
I then masked the rest of the area and airbrushed the red stripe.
And the final result. Starting to look like my goal
For those of you that want to see a variation of this design on a notchback, check out Don Kraus' build here. It is really looking nice. https://www.fiero.nl/forum/Forum1/HTML/071254.html
[This message has been edited by IMSA GT (edited 11-29-2008).]
Amida
Total ratings: 63
Report this Post11-29-2008 12:28 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why not go with 18s ? They'll have more cool factor.
IMSA GT
Total ratings: 253
Report this Post11-29-2008 12:42 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Funny you should mention that......I actually just got done discussing this with another member. The IMSA body has a really low rear wheel well arch. By going to 17" wheels and low profile tires, I am barely going to clear the fender wells. I did not want to have to cut the rear wheel well openings wider although most people do that. If I go anything larger than 17", the car will be undrivable. The stock 15" tire is about 24" and the wheel and tire size that I am looking at is 25.6" so I am pretty close to the stock height. This also allows me to lower the car a little without issue.
R Runner
Total ratings: 98
Report this Post11-29-2008 09:08 PM Click Here to See the Profile for R RunnerSend a Private Message to R RunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Funny you should mention that....The stock 15" tire is about 24" and the wheel and tire size that I am looking at is 25.6" so I am pretty close to the stock height. This also allows me to lower the car a little without issue.
For what it is worth, my IMSA uses 25.5" in the rear as well with a 16" rim. 17" and 18" wheels look good, but are not necessary. Infact I think it will look better with the 17" than the 18" . Then again my chassis ride height is 3 5/8" in the rear so the rear tire is pushed up in to the wheel well pretty good. I'm surprised you didn't try to find a Jongbloed street clone and paint the centers gold.
It is really looking good! Good job and keep up the great work.
Amida
Total ratings: 63
Report this Post11-29-2008 11:20 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you get the wheels made so that they tuck behind the bodywork? That way you don't need to worry so much about wheel diameter & hitting the bodywork. I've got 18x10 rims with Pirelli p275/35 zr-18 and they measure almost 25.5" diameter. You can even go wider & not much taller with 30 series rubber.
[This message has been edited by Amida (edited 11-29-2008).]
IMSA GT
Total ratings: 253
Report this Post11-30-2008 10:19 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
A couple more things that are going on right now. I layed the stencils for the logos on the front end. I am using more modern sponsor names to mix the old and the new
Here are the stencils layed out
And 90% completed
I am just waiting for the orange to dry on the K&N logo and then I will finish airbrushing that and install the hood later tonight.
DeLorean00
Total ratings: 100
Report this Post11-30-2008 10:26 PM Click Here to See the Profile for DeLorean00Send a Private Message to DeLorean00Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is just awesome!! Man I love this build!!
IMSA GT
Total ratings: 253
Report this Post12-01-2008 12:03 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you.....but wait theres more !!
IMSA GT
Total ratings: 253
Report this Post12-01-2008 12:05 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMSA GT
Member since Aug 2007
Here is the car with the hood mounted. The top picture is a little dark but the second shows a little better. I had to custom mix the orange for the K&N logo so it is taking a long time to dry so don't pay attention to the white sticker on the fender
I am clearcoating the entire car in one spray so that is why all of the panels look dull right now.
I just thought of something funny......hopefully, GM doesn't go under otherwise its back to the paint booth
[This message has been edited by IMSA GT (edited 12-01-2008).]
DeLorean00
Total ratings: 100
Report this Post12-01-2008 12:19 AM Click Here to See the Profile for DeLorean00Send a Private Message to DeLorean00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nah dont worry about it, if GM goes under you can just sell me that car and you dont have to worry about repainting it.
fierosound
Total ratings: 287
Report this Post12-01-2008 06:54 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMSA GT
Total ratings: 253
Report this Post12-06-2008 09:33 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Almost done with prepping the rear portion of the car for paint. Today, I continued my mod of the back decklid by starting on the matching side vents. I bought a new 84 grille from Fiero Store and hacked it up
I then measured and cut the vent louvers out.
Here is the trial fit
And the fit after bending some temporary sheet metal and fitting the metal to the vent with rivets.
The next step will be to use the proper thickness of sheet metal, adhere it to the vents using 8115 adhesive, and blend the vents in to match the decklid.
Fiero Thomas
Total ratings: 125
Report this Post12-07-2008 12:04 AM Click Here to See the Profile for Fiero ThomasSend a Private Message to Fiero ThomasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have not said it yet but what a great build that you have going on here. I am very impressed with the work that you are doing on this car
Indy#64~FieroNews~Boots~Bag s~Wallets~Headliner~Spare Cover~
Visors~Sunshads and T-Top Sunshades~Download the Fieronews Catalog HERE~
IMSA GT
Total ratings: 253
Report this Post12-07-2008 01:53 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you. It is really starting to come together now that I am in the paint stages.
R Runner
Total ratings: 98
Report this Post12-07-2008 07:20 PM Click Here to See the Profile for R RunnerSend a Private Message to R RunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am more and more impressed each time I check this thread. It stinks to think I may never get to see it in person. Who knows, maybe I'll take a trip to the west coast some day and bring my entire family (that means the IMSA). We'll call it a family vacation... yea.. that's it.. A family vacation.
IMSA GT
Total ratings: 253
Report this Post12-07-2008 10:32 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I may take a trip myself towards you especially with the G.A.S tour happening in 2010.....even though the tour ends 20 minutes from my house at Rockaway Beach
R Runner
Total ratings: 98
Report this Post12-07-2008 10:55 PM Click Here to See the Profile for R RunnerSend a Private Message to R RunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
My house is one of the stops. I'm about 12 miles south of Route 50. I am planning on hosting some type of cookout or something. I will most likely drive some of it as well, but getting time off work is the main issue.
IMSA GT
Total ratings: 253
Report this Post12-10-2008 09:13 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need to change gears here for a minute. One of the major features that is missing from the "street" version of the car are lower parts of the rear quarter panels. I think they make an incredible difference in the look of the car so I have to fab some up.
Street version
Race version
doublec4
Total ratings: 150
Report this Post12-10-2008 09:21 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good eye
I love your attention to detail!
DeLorean00
Total ratings: 100
Report this Post12-17-2008 08:22 PM Click Here to See the Profile for DeLorean00Send a Private Message to DeLorean00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Update?
R Runner
Total ratings: 98
Report this Post12-17-2008 09:02 PM Click Here to See the Profile for R RunnerSend a Private Message to R RunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Allow me to help out... Street Verison:
Race Version:
[This message has been edited by R Runner (edited 12-17-2008).]
IMSA GT
Total ratings: 253
Report this Post12-17-2008 09:31 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update?
I had to take a break because I am in the process of painting 2 Harley Davidson bikes for a couple of co-workers. Both are doing complete rebuilds so I am painting all of the individual parts separately.
IMSA GT
Total ratings: 253
Report this Post12-17-2008 09:32 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMSA GT
Race Version:
That is a good view of what I need to do to my car. It actually helps with my design.
R Runner
Total ratings: 98
Report this Post12-18-2008 05:07 AM Click Here to See the Profile for R RunnerSend a Private Message to R RunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I can help with measurements or other close-up pictures, just let me know.
IMSA GT
Total ratings: 253
Report this Post12-25-2008 06:10 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tomorrow is an all paint day for me. I should have the entire car done and the logos sprayed by the end of the afternoon. Hopefully, my windshield removal tool shows up and I can remove my old windshield and really clean up the area around the glass since I am deleting the windshield vinyl trim piece. It will be a long day....stay tuned
DeLorean00
Total ratings: 100
Report this Post12-25-2008 06:57 PM Click Here to See the Profile for DeLorean00Send a Private Message to DeLorean00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Waiting with baited breath....
IMSA GT
Total ratings: 253
Report this Post12-25-2008 11:22 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just finishing up removing all the weatherstrip from the doors and masking everything. Looking forward to driving over and showing it to you when I'm done.
IMSA GT
Total ratings: 253
Report this Post12-26-2008 06:36 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right now, the lower portion of black is drying. Later, I will be doing the white on top as well as the red molding and the logos. Here are a couple of pics of the door jamb and lower intake.
More to come later
[This message has been edited by IMSA GT (edited 12-26-2008).]
IMSA GT
Total ratings: 253
Report this Post12-27-2008 01:34 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, needless to say, it was a pain in the ass day today. The black paint took a few more hours to dry than usual, my windshield removal tool showed up half way through the paint job, and the windshield took about an hour to remove and another hour to clean up all the excess adhesive.
Tomorrow afternoon, I will continue the painting and post more updates.
