Appreciate PFF? Please consider making a donation.
Pennock's Fiero Forum has been the largest source for Fiero related information during the past 23 years and it has always been free for everyone - members, vendors and visitors. However, it isn't free for me to maintain. If you want to help me keep PFF up and running, please consider a donation. Your support will be greatly appreciated. Not only by me, but by the thousands of daily visitors that use PFF. If you want to make a donation (PayPal, Bitcoin, Ethereum, etc.) please (or simply send your PayPal donation to info@pennock.nl).
Thanks!
Cliff Pennock
  FieroGT stretch Concept (Page 24)
This topic is 60 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60
FieroGT stretch Concept by Amida
Started on: 02-11-2006 05:08 PM
Replies: 2392 (261437 views)
Last post by: Amida on 03-31-2024 09:12 PM
Amida
Total ratings: 63
Report this Post07-24-2009 11:10 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fabrication of the illuminated Fi40 switch panels.
RCR
Total ratings: 102
Report this Post07-26-2009 09:42 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
...And how do you make those fantastic switches? The Fiero world wants to know.
Bob
Amida
Total ratings: 63
Report this Post07-26-2009 11:44 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by RCR:
Bob
They're replica switch caps made in two pieces. A clear window is cast in an RTV silicon mold. The window is then inserted into the switch cap mold which is injected with urethane encapsulating the window. The cap is form fitted to aftermarket illuminated switches with adhesive.
Aug 3rd, 2009
Amida
Total ratings: 63
Report this Post08-03-2009 02:38 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally was able to push the Formula into the garage & have a look at the nose underside on level ground. It looks to me that the front splitter will have an open mid-section due to the shape of the nose. It'll have to be like a spoiler in the middle directing air flow up to the radiator. Similar to the Grandprix but without the center column.
[This message has been edited by Amida (edited 08-03-2009).]
Aug 9th, 2009
Amida
Total ratings: 63
Report this Post08-09-2009 06:45 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Amida:
This template is 1.5" tall at the wheelwell & 2" at the front. Parallel with the rocker & ground. Fine for these rockers that I have but too low for the stock GT rockers. I'll have to raise it up 1/2".
Amida
Total ratings: 63
Report this Post08-09-2009 07:02 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Member since Jul 2003
This template is shortened to an 1" & 1 1/2" front/rear. I will settle for this height as the lowest common denominator for all applications.
Aug 10th, 2009
RCR
Total ratings: 102
Report this Post08-10-2009 06:30 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Watching closely, Rob...
Bob
Aug 19th, 2009
Amida
Total ratings: 63
Report this Post08-19-2009 11:14 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A negative of the nose bottom side was fabricated to become the mating flange surface. After fastener points are established the flange will be trimmed to a 2" perimeter.
Template of nose profile being tranfered to 3/4" MDF.
[This message has been edited by Amida (edited 08-19-2009).]
Amida
Total ratings: 63
Report this Post08-19-2009 11:21 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Cut & test fitting.
Amida
Total ratings: 63
Report this Post08-19-2009 11:26 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Chamfered the front edge. Adjusting for height & level.
Amida
Total ratings: 63
Report this Post08-19-2009 11:49 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Fender flares would be needed to cover the open wheels.
Aug 20th, 2009
whodeanie
Total ratings: 120
Report this Post08-20-2009 09:45 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job Rob
D.
ferrobi
Report this Post08-20-2009 03:36 PM Click Here to See the Profile for ferrobiSend a Private Message to ferrobiEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by Amida:
Progress ?
Amida
Total ratings: 63
Report this Post08-20-2009 07:04 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job Rob
D.
My low profile jack won't fit under the nose now. Thanks.
Amida
Total ratings: 63
Report this Post08-20-2009 07:06 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Originally posted by ferrobi:
Progress ?
I'm making my rounds, will be getting back to it.
ferrobi
Report this Post08-20-2009 09:10 PM Click Here to See the Profile for ferrobiSend a Private Message to ferrobiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Total ratings: 63
Report this Post08-20-2009 09:37 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Upper & lower halves are bonded together, then the gaps are filled with urethan foam.
Aug 21st, 2009
RCR
Total ratings: 102
Report this Post08-21-2009 07:03 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
I find your work intriguing...I would like to subscribe to your newsletter.
Bob
Aug 22nd, 2009
Amida
Total ratings: 63
Report this Post08-22-2009 11:01 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
This IS it. No time to write news letters.
RCR
Total ratings: 102
Report this Post08-22-2009 01:06 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Aug 25th, 2009
whodeanie
Total ratings: 120
Report this Post08-25-2009 12:38 PM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob you are the man!
I just got the 2 consoles I had ordered from you. very nice work
the carbon fiber one will be going in my 88 GTP
and the other is going in Ben's 355 I have been working on.
thanks again,
Dean
Amida
Total ratings: 63
Report this Post08-25-2009 10:56 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bondo, sanding & fitting. Whoever invented bondo must be enjoying life.
Erik
Total ratings: 168
Report this Post08-25-2009 11:11 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
probably the after life ..its been around for a long time ..anyway ..your work is fantastic!
Aug 29th, 2009
Amida
Total ratings: 63
Report this Post08-29-2009 12:04 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right, I forgot how long it's been around. Thanks.
Amida
Total ratings: 63
Report this Post08-29-2009 12:06 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Fi355 chin spoiler plug painted & drying in the oven.
doublec4
Total ratings: 150
Report this Post08-29-2009 12:18 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Amida, I saw your post in my build thread and remembered you were building up a chin splitter for your front bumper. You have some great skills! I'd love to build a splitter for my chin spoiler, yours looks great!
Check out my build!
https://www.fiero.nl/forum/Forum3/HTML/000100.html
Aug 31st, 2009
ace5514
Report this Post08-31-2009 08:54 PM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rob,
the chin spoiler looks great. i'll be watching.
al
Sep 3rd, 2009
RCR
Total ratings: 102
Report this Post09-03-2009 07:16 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob, You make it look too darned easy. For those of you that pop in and marvel at Rob's work, take it from me, it's waaayy harder than it looks.
Awesome work...
Bob
Sep 5th, 2009
Amida
Total ratings: 63
Report this Post09-05-2009 09:38 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your chin spoiler is a splitter isn't it?
Amida
Total ratings: 63
Report this Post09-05-2009 09:40 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Awesome work...
Bob
The special for today is....epoxy chin sandwich. Mmm, mmm, good.
Amida
Total ratings: 63
Report this Post09-05-2009 10:18 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Another idea for the use of Grandprix/Solstice combo lights. Bonneville type upper intakes added, but probably not necessary since steel chassis is directly beneath. BTW, this is a widebody.
[This message has been edited by Amida (edited 09-05-2009).]
doublec4
Total ratings: 150
Report this Post09-05-2009 11:14 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
lol I guess you could call it that. I see a splitter more as a small, flat, protruding element added to the front bumper. Mine is more of a chin spoiler I guess. Yours could go either way.
Here is a "splitter" in my opinion
http://image.musclemustangf...ng+chin_splitter.jpg
or this one:
http://www.mlrmotorsports.c...nt_wind_splitter.jpg
Either way, yours looks great! I would love to have a flat piece, like the second picture I posted, under my chin spoiler. R Runner has something similar on his IMSA
Check out my build!
Sep 6th, 2009
Amida
Total ratings: 63
Report this Post09-06-2009 12:37 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
With your spoiler already scraping the ground there isn't much ground clearance left, but you can cut a piece of 1/4" ABS and attach it to the spoiler.
doublec4
Total ratings: 150
Report this Post09-06-2009 01:08 AM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've looked into that, but can't seem to source out a good place that sells ABS sheets that large around here
Amida
Total ratings: 63
Report this Post09-06-2009 01:23 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A little more refining to the widebody Formula .
Amida
Total ratings: 63
Report this Post09-06-2009 01:29 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Probably not available at a hardware store, but all plastics dealers/distributors will carry.
ace5514
Report this Post09-06-2009 01:56 AM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
guys,
i have dealt with tap plastics for a couple years, they sell abs sheets 2x2 2x4 and probably larger just email them and ask. they have always treated me well and the prices aren't bad either. plus you can order and they ship it to your door (for a price of course.)
www.tapplastics.com
al
Amida
Total ratings: 63
Report this Post09-06-2009 11:07 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ace5514:
guys,
www.tapplastics.com
al
I've done business with a couple TapPlastics in my area. I don't think they are in Canada, but if you look in the yellow pages for plastic suppliers you should be able to find a source. ABS would be ideal since it won't shatter on impact like acrylic would.
Sep 7th, 2009
Amida
Total ratings: 63
Report this Post09-07-2009 07:06 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A little more tweeking on the latest front end. Rounded outer corners of turn signal pockets & added flush 300zx headlights. Not bad.
Amida
Total ratings: 63
Report this Post09-07-2009 12:03 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Fi355 chin spoiler mould prep.
