  FieroGT stretch Concept (Page 27)
This topic is 60 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60
FieroGT stretch Concept by Amida
Started on: 02-11-2006 05:08 PM
Replies: 2392 (261558 views)
Last post by: Amida on 03-31-2024 09:12 PM
Austrian Import
Report this Post11-17-2009 08:16 PM Click Here to See the Profile for Austrian ImportSend a Private Message to Austrian ImportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida, I like the Carbon Fibre insert. It reminds me of a DeTomaso Pantera I saw at an Auction in Monterey, CA a couple years ago. I think it'll look really good.
Careful, CF is a slippery slope.. Next you'll want to do the mirror housings and other random black trim pieces. It also works great in interiors (when used sparingly (see: Audi RS-4. NOT BMW M6) )
-Max
Fenix
Report this Post11-18-2009 12:22 PM Click Here to See the Profile for FenixClick Here to visit Fenix's HomePageSend a Private Message to FenixEdit/Delete MessageReply w/QuoteDirect Link to This Post
neat build, looks great.
Current Rides
1988 Pontiac Fiero GT
1996 Cadillac Eldorado
1965 Pontiac GTO
Amida
Total ratings: 63
Report this Post11-19-2009 08:20 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't had much time to work on my own car. Clutch & water pump still down. Thanks.
Amida
Total ratings: 63
Report this Post11-19-2009 08:27 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Member since Jul 2003
-Max
CF mirror skins would be neat. I may try it if I can figure out how to work around the base/pedestal, and do it in one piece.
Got the B-pillar caps coated in UV epoxy. Looks smooth except for a few dust specs here & there. Don't think that can be avoided when using a brush.
Amida
Total ratings: 63
Report this Post11-19-2009 09:17 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
A-pillar corner caps with UV epoxy clear coat.
Amida
Total ratings: 63
Report this Post11-20-2009 02:31 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
These will look pretty sharp once back on the Formula. First, I need to get some 3M double tape.
ferrobi
Report this Post11-20-2009 06:31 PM Click Here to See the Profile for ferrobiSend a Private Message to ferrobiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put them on I want to see um - are you going to sell them too?
Amida
Total ratings: 63
Report this Post11-21-2009 12:33 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I now have the tooling made, so I can make duplicates.
Amida
Total ratings: 63
Report this Post11-21-2009 04:58 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Did some visualization with templates to see what would be needed to cover the wide wheels. I may do a foam fill to further see how it will look.
ace5514
Report this Post11-22-2009 12:38 PM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
this i gotta see!
Rob, this looks interesting can't wait to see what you come up with.
al
whodeanie
Total ratings: 120
Report this Post11-22-2009 12:43 PM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob,
I had to do the same thing with my choptop to cover the wheels as well.
the one thing I did because of the 355 nose being so wide to begin with was to take a mold off the stock front fender and make fiberglass ones.
then on top of the fender I split the top so the fender has no taper to the front anymore. this gave me about an inch in the front then I cut the wheel well and did an old school flair that gave me the other 3/4" I needed. the one thing I never liked about the shape of the fiero was that wedge shape in the front.
but for you to do this you would have to widen the nose as well. it is a lot of work. I like where you are going with your car, I know what ever you come up with will look great
D.
Amida
Total ratings: 63
Report this Post11-22-2009 07:22 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ace5514:
this i gotta see!
al
Start a thread yet?
Amida
Total ratings: 63
Report this Post11-22-2009 07:29 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Rob,
D.
I'm just doing one wheel for now to see how it'll work. I'm leaning towards a separate piece attached with fasteners rather than moulding it into the bodywork.
Amida
Total ratings: 63
Report this Post11-22-2009 07:41 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
The corner caps fit very well. This looks really cool! Adhesive may be a better choice than using double tape due to it's zero margin of error when fitting; there's no chance to adjust once stuck. The pitted mirror housings are not so cool, however.
ace5514
Report this Post11-23-2009 07:49 AM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
no thread yet...and if you don't stop making things i like, i am going to have to keep working overtime to pay for them. hence i will never have time to start one.....
.......now how much for the carbon fiber covers pictured above???????
al
ps do they come in cloors other than red and or standard black?
[This message has been edited by ace5514 (edited 11-23-2009).]
Amida
Total ratings: 63
Report this Post11-28-2009 02:27 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
-Max
A CF roof panel skin would be cool. I saw one on a Honda S2000 recently.
Austrian Import
Report this Post11-28-2009 04:14 PM Click Here to See the Profile for Austrian ImportSend a Private Message to Austrian ImportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida, I can't tell from the pics: Is this 2x2 twill weave?
Also, have you considered making the sail panel window CF? (replacing the plastic "window glass" )
Amida
Total ratings: 63
Report this Post12-02-2009 01:19 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, it's twill. No plans on doing notchie sails, but I'm sure someone makes it for the GT .
ace5514
Report this Post12-09-2009 05:22 PM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rob,
any update on the flairs?
al
skuzzbomer
Total ratings: 92
Report this Post12-22-2009 12:05 AM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump for the fibre...?
Tusch
Report this Post01-12-2010 01:11 AM Click Here to See the Profile for TuschSend a Private Message to TuschEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
Hockaday
Report this Post01-13-2010 12:29 PM Click Here to See the Profile for HockadaySend a Private Message to HockadayEdit/Delete MessageReply w/QuoteDirect Link to This Post
On this 2nd version the car has a wide track. The fenders are curved & widened w/ hot air opening at rear edge. Rear 1/4 glass reduced & notched like a GT.
looks like a euro corvette.
Austrian Import
Report this Post01-13-2010 05:29 PM Click Here to See the Profile for Austrian ImportSend a Private Message to Austrian ImportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida, not sure what you have planned, but you could look towards the Audi R8, Electric Audi R8, Audi R4, or even the new TT for inspiration on shaping the fenders..
Carcenomy
Report this Post01-14-2010 12:12 AM Click Here to See the Profile for CarcenomyClick Here to visit Carcenomy's HomePageSend a Private Message to CarcenomyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The CF trims came out top notch Amida. How much would you be looking for a set?
Amida
Total ratings: 63
Report this Post01-15-2010 12:54 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
There was another , more refined, mod that I made after that one.
Amida
Total ratings: 63
Report this Post01-15-2010 12:55 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
This one from page 1.
Amida
Total ratings: 63
Report this Post01-15-2010 12:57 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Rob,
al
Maybe after it's all done & painted.
Amida
Total ratings: 63
Report this Post01-15-2010 12:59 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Seems like you're a Fox fan.
Amida
Total ratings: 63
Report this Post01-15-2010 01:03 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
It depends on clear coat or uncoated. I'll send you a PM.
ace5514
Report this Post01-15-2010 01:20 AM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
well when it's painted...i'll be waiting!
also don't forget me when you start to make the cf covers for by the mirror. (i keep forgetting what they are called)
IVANNATINKLE
Report this Post01-15-2010 04:17 AM Click Here to See the Profile for IVANNATINKLESend a Private Message to IVANNATINKLEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I think it's a good nose for the Fiero, but people who've said they were interested have now disappeared so it's on the back burner now. Also, I've learned that fiberglassing large body panels, such as bumpers, is really, REALLY, hideous work. I'd rather have someone else do it if I can afford it. But, the dilema is that I don't think enough will be sold to make cents. Make sense?
how much??
sorefeet
Report this Post01-16-2010 08:24 PM Click Here to See the Profile for sorefeetSend a Private Message to sorefeetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great build, if V8Archie didn't build those rockers then who did. I didn't know that anyone else made those.
Amida
Total ratings: 63
Report this Post01-29-2010 06:25 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know anything about my rockers, they were on the car when I bought it. The car was a stolen recovery from the SeedroWooly, WA. area. They might be an earlier version with integrated fiberglass belt mouldings. It's messed up anyway so I'll be trying to Enzo-fy them if I can.
Amida
Total ratings: 63
Report this Post01-29-2010 06:31 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Originally posted by IVANNATINKLE:
how much??
Cannot say at the moment. If done in one piece it should save a little on labor hours.
Amida
Total ratings: 63
Report this Post01-30-2010 07:58 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fender flare that I'll need to cover my Porsche wheels will be about 5.5" wide at the top ( front wheels ). Rather than make individual flares for each corner of the car, this foam & wood plug will be used to form a universal flare which will then be used to make frp flares for all four corners. The plan is to tailor each corner, add flanges & secure with hidden fasteners.
[This message has been edited by Amida (edited 01-30-2010).]
doublec4
Total ratings: 150
Report this Post01-30-2010 09:03 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow those are going to be WIDE flares! But it will look really nice when it is done. Your work is excellent.
I can't wait to see what the rear flares look like!
Check out my build!
https://www.fiero.nl/forum/Forum3/HTML/000100.html
Fierofreak00
Total ratings: 170
Report this Post01-31-2010 09:15 AM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
I too would like to know how much the CF panels would be...Neat idea! -Jason
Amida
Total ratings: 63
Report this Post01-31-2010 06:53 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the front fenders it's mostly at the top because it has to blend in with the stock fender. Around 2-3" frontside & very little on the backside...The Fiero is narrow up front. Thanks.
Amida
Total ratings: 63
Report this Post01-31-2010 06:56 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Let me get my new B-pillar sails back on the car first so that I can take some installed shots. I think it'll look pretty sharp...it's not too much carbon, just enough to give it a little more detail.
Fierofreak00
Total ratings: 170
Report this Post01-31-2010 07:08 PM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Great! I can't wait to see it! -Jason
