Appreciate PFF? Please consider making a donation.
Pennock's Fiero Forum has been the largest source for Fiero related information during the past 23 years and it has always been free for everyone - members, vendors and visitors. However, it isn't free for me to maintain. If you want to help me keep PFF up and running, please consider a donation. Your support will be greatly appreciated. Not only by me, but by the thousands of daily visitors that use PFF. If you want to make a donation (PayPal, Bitcoin, Ethereum, etc.) please (or simply send your PayPal donation to info@pennock.nl).
Thanks!
Cliff Pennock
  FieroGT stretch Concept (Page 31)
This topic is 60 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60
FieroGT stretch Concept by Amida
Started on: 02-11-2006 05:08 PM
Replies: 2392 (261410 views)
Last post by: Amida on 03-31-2024 09:12 PM
Amida
Total ratings: 63
Report this Post04-04-2010 10:39 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
This weekend I pulled the getrag out by the 'tilt the cradle method'...what a PITA that was. Better to just drop the whole cradle next time.
This is how I found my clutch after removal, anyone see some thing strange in these photos? Symptom was: Pedal fell to the floor with clanking sounds coming from the engine compartment.
ace5514
Report this Post04-04-2010 11:00 AM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
looks like a few amputations..lol ...clutch didn't owe money to anyone did it?
any damage to the motor?
al
Amida
Total ratings: 63
Report this Post04-04-2010 11:06 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
al
Yes, 5 fingers missing, and the thrust bearing actually spun out of the fork...makes me wonder if the fork was spread open. What doesn't make sense is how the thrust bearing can wear down the fingers so much....as if it was riding the bearing at all times.
Exhaust crossover bolts snapped off & now stuck in the manifolds, discovered a huge crack in front manifold, & discovered a floppy waterpump pully.
[This message has been edited by Amida (edited 04-04-2010).]
ace5514
Report this Post04-05-2010 01:43 PM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
bearing could have seized, fork could have bent and fingers may have been broken by anyone of those ( i still think the mob is involved..lol). either way all need to be replaced also don't forget the pilot bearing/bushing it may have taken a beating during all that!
Amida
Total ratings: 63
Report this Post04-05-2010 11:40 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is no pilot bearing/bushing. For some reason the v6 doesn't use one.
ace5514
Report this Post04-06-2010 12:29 AM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
i thought all motors had a bearing or bushing in the crank shaft. but then i never did a clutch on any gm v6 let alone a fiero.
i guess the only thing to do is replace all that you can...why take a chance.
good luck!
Amida
Total ratings: 63
Report this Post04-10-2010 10:47 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Received clutch parts from the Fierostore. I remember now why I never became a mechanic...it's greasy, grimey, nucklebusting, backbreaking work. Nothing like maneuvering a 100lbs. tranny into position while sitting on your ass.
New alternator, waterpump, hoses & belts from the Fierostore. Might as well do it all at once because I'm not doing this again! I couldn't believe how floppy the old water pump was.
[This message has been edited by Amida (edited 04-10-2010).]
Amida
Total ratings: 63
Report this Post04-11-2010 12:53 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's no wonder the exhaust manifold cracked....failed tranny mounts. Anyone doing a clutch job who still has original 22-26 y.o. mounts should get them replaced.
This was alot of work to just be able to move the car around in the driveway especially when an engine swap is due around the corner. But, maybe when I get the bodywork finished I'll have a chance to take it around to some local shows before the end of the year.
Amida
Total ratings: 63
Report this Post04-13-2010 02:05 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's alive! After two years in a coma...ready for a makeover.
Bridgetown
Report this Post04-13-2010 04:13 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work Amida. How bout some outdoor shots of those flares/rockers?
Amida
Total ratings: 63
Report this Post04-13-2010 11:06 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
No brakes yet. Waiting for debut of new affordable '88 brake upgrade.
doublec4
Total ratings: 150
Report this Post04-15-2010 10:47 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Happen to be waiting on the held Ferrari upgrade? Would look pretty sweet with all the extensive work
hinesb1890
Report this Post04-17-2010 06:50 PM Click Here to See the Profile for hinesb1890Click Here to visit hinesb1890's HomePageSend a Private Message to hinesb1890Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can i just say I stumbled upon this thread for the first time today and it is almost exactly what i've been wanting to do to my formula... I can't tell you how many times that has happened on this forum with other ideas. Very nice work though, it is something I aspire to be able to do someday!
Amida
Total ratings: 63
Report this Post05-06-2010 10:24 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe I'll have a widetrack body package for you someday. When the prototype is completed I may tour around to some shows & gatherings. Thanks.
Amida
Total ratings: 63
Report this Post05-06-2010 10:33 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Member since Jul 2003
The new '88 rotor upgrade kit arrived from Erik at HTmotorsports ( Westshorefabricators.com ). They are 12" Vette drilled for 5x100, with pressed in rings & adapters for stock '88 calipers.
ace5514
Report this Post05-07-2010 06:47 AM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
rob,
i thought your car wasn't an 88
is that kit for the 84 to 87 car with 88 calipers?
al
whodeanie
Total ratings: 120
Report this Post05-07-2010 08:46 AM Click Here to See the Profile for whodeanieClick Here to visit whodeanie's HomePageSend a Private Message to whodeanieEdit/Delete MessageReply w/QuoteDirect Link to This Post
rob,
al
Erik just devloped a kit to use 88 calipers on the 84 - 87 fieros with anything from stock 88 roters to 13" ones.
D.
Amida
Total ratings: 63
Report this Post05-07-2010 11:58 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
rob,
al
Al, I have an '88
ace5514
Report this Post05-07-2010 10:23 PM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
my bad rob..don't know why i thought it wasn't.
al
dean
you have a pm
aaronkoch
Report this Post05-08-2010 06:28 PM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
They don't have that kit on the website yet, would you mind sharing the price of the brake kit, or PM me?
Currently in the middle of my 88 + 3800NA swap
Amida
Total ratings: 63
Report this Post05-09-2010 09:00 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Contact Erik at : ERIK@WESTSHOREFABRICATORS.COM
The kit comes with rotors, rings, brackets & hardware.
doublec4
Total ratings: 150
Report this Post05-09-2010 09:26 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Brakes look great Amida, 12 inch will fill those wheels nicely !
Amida
Total ratings: 63
Report this Post05-15-2010 10:09 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the stock rotors were just too small looking with 18s. I've got Held 2" drop spindles going in which shouldn't have any caliper issues during install according to Erik at HT.
[This message has been edited by Amida (edited 05-15-2010).]
Amida
Total ratings: 63
Report this Post05-15-2010 10:18 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Blkcofy did a nice job on his ride. Nice color combo. His post was buried in an engine tech thread.
ghost187x
Report this Post05-15-2010 10:28 AM Click Here to See the Profile for ghost187xSend a Private Message to ghost187xEdit/Delete MessageReply w/QuoteDirect Link to This Post
is that what you are going for? I like to see your flare kit on a GT
might have another buyer muahahha
Amida
Total ratings: 63
Report this Post05-15-2010 10:35 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ya very close...a track racer look. It's going to be pretty low, so I'll have to add a front lift so that I can get it on a trailer.
ghost187x
Report this Post05-15-2010 11:17 AM Click Here to See the Profile for ghost187xSend a Private Message to ghost187xEdit/Delete MessageReply w/QuoteDirect Link to This Post
i guess i can throw away my mecham scoops idea. might have to buy this kit. looks good, but to be sure i need a real pic of it from a distance or a photoshop render. Just to be sure
doublec4
Total ratings: 150
Report this Post05-24-2010 11:17 AM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any updates on your kit?
Check out my build!
https://www.fiero.nl/forum/Forum3/HTML/000100.html
blkcofy
Report this Post06-23-2010 01:29 AM Click Here to See the Profile for blkcofySend a Private Message to blkcofyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Am I allowed to BUMP?
Austrian Import
Report this Post06-23-2010 09:34 PM Click Here to See the Profile for Austrian ImportSend a Private Message to Austrian ImportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hopefully we can talk Fieroaddiction into making his 13" Wilwood brake upgrade or anybody else into making something similar one of these days.
[This message has been edited by Austrian Import (edited 06-23-2010).]
Vendetta
Report this Post07-07-2010 12:54 PM Click Here to See the Profile for VendettaSend a Private Message to VendettaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any progress? Bump
War Hammer
Report this Post08-07-2010 12:13 AM Click Here to See the Profile for War HammerSend a Private Message to War HammerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Rob,
I am friends with the duck. Any news on the 512 nose?
Thanks,
Paul
1988 Fiero
3800SC Series 1 w/5spd Getrag
Lowering Springs
18's w/Pirellis
Corvette Dash Mod
1985 GT
1986 Notchie
1987 Notchie
Gokart Mozart
Total ratings: 159
Report this Post08-07-2010 09:23 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.tiltahitch.com/
- The Tilt-A-Hitch has met or exceeded the requirements for a class 4 (6-10,000 lbs GVWR) Weight Carrying Hitch in accordance with Society of American Engineers J684 test and the Vehicle Equipment Safety Commision Regulation V-5 test.
- It is approved for an 8000 lb. towing capacity.
- It is built to last and is quality constructed of over 32 pounds of heavy steel.
- The Tilt A Hitch has a beautiful black powder coat finish.
- The Tilt A Hitch can also function as a load leveling Hitch, by choosing one of 12 different pin positions.
- Mounts to a standard 2" reciever
- Works on any ball-mount trailer.
NOTE: Ball NOT included with purchase!
PRICE REDUCTION
Due to our high sales volume, our manufacturer has reduced our Regular Retail price to: 139.95!
SO FOR A VERY LIMITED TIME ONLY, we will drop our Tilt A Hitch special internet price to $129.95 + shipping!
ELECTRIC JACK PRICE REDUCTION
We are dropping the electric jack price to $169.95 + shipping.
SPECIAL COMBO PRICE
During this limited time special, the new combo package price is $279.90 + shipping.
aaronkoch
Report this Post08-07-2010 10:33 PM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida, you can showcase your products next weekend at the Northwest Fiero Fest, in Richland.
bubbajoexxx
Total ratings: 112
Report this Post08-14-2010 01:25 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
I see all kinds of work but where is the stretch you planned
SMTHGT
Report this Post09-12-2010 11:25 AM Click Here to See the Profile for SMTHGTSend a Private Message to SMTHGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah... what ^^^he^^^ said..??
Steve
Aka. "SmoothGT"
1987 GT 4.9L-V8
SmoothGT-II
ace5514
Report this Post09-20-2010 03:13 AM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rob,
still no build thread, but i wanted to show your nose with the mad arch wide body. almost ready to start bonding the panels.
BTW I love this nose!!!!
al
fencerenu
Report this Post09-23-2010 11:57 PM Click Here to See the Profile for fencerenuSend a Private Message to fencerenuEdit/Delete MessageReply w/QuoteDirect Link to This Post
Funny...I'm not ready for rug rats.
You're looking at wrong... They're Ranch Hands... Now are ya ready? lol
Amida
Total ratings: 63
Report this Post10-09-2010 02:28 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob,
al
Looks good Al.
Amida
Total ratings: 63
Report this Post10-09-2010 02:32 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amida
Test fitting begins on latest fi355 interior upholstered in Mr.Mikes grey vinyl for stock Fiero. Hvac controller by Riceburner98.
[This message has been edited by Amida (edited 10-09-2010).]
