  THE ULTIMATE FIERO BUILD LAMBO REPLICA (Page 1)
THE ULTIMATE FIERO BUILD LAMBO REPLICA by merciero
Started on: 04-14-2009 07:55 PM
Replies: 152 (34230 views)
Last post by: psychosurfer on 02-22-2012 06:33 PM
merciero
Report this Post04-14-2009 07:55 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK i just though i should do a build diary on this... im building a lamborghini murcielago LP640 replica. my base is a 85 fiero 2m4. well first i pulled all the body off, then the doors, then the interior, dash, air box, ect. then i pulled the entire wire harness out..... then pulled the whole suspension, brakes, cradles,ect. the only thing left was just the frame and tub. i then took it to my shop where we stretched the frame 10.5 inches. sheet metal on the gap, and did a very clean stretch job to it. i stretched the cradle once i made a jig for it on the following day. poly bushings on the whole front and rear. i did the beretta brake upgrade for the front, and just got new calipers for the rear. i painted the springs and calipers orange to match the body. now i had to choose gauges....... there are so many out there. the closest i could get was in a junk yard where there lied a t boned 06 grand prix GT. so in order for these gauges to work i needed the wire harness out of the car, so i pulled the entire harness out of the car gauges, air box, a/c controls, hud center, steering column, fuse box, bcm, pcm, gas pedal, brake pedal, door harnesses, window motor, all the switches, radio, everything. now the steering column all i had to do is fab a bracket to mount it up. and push the u joint out the top connector and swap the steering shaft with the fiero shaft, pressed it back in so now i have the fiero steering shaft with the GP yoke to bolt to the steering comlumn. i have the aluminum dash brace with the air box mounted out of the GP and im trimming it to fit tomorrow. now i know this sounds way to much but its not just the gauges. now i have a 06 grand prix just in a fiero. i get the new climate control and a/c controls. gauges, a working hud unit, on star, air bags, and i have absolutly zero conversion to put my 06 drive by wire series 3 supercharged 3800 in,,,, i just plug it all in. also i now will have all diagnostics on the car. all CELs will be legit. im in the middle of trying to get the comp g tapshift to go into my car.... so how many fiero based lambos do you see with tap shift (paddle shifters) and the fastest way to ruin a good replica is old gauges and a/c controls. but i will get pics up of everything once my wife gets her damn camera. but i figured i would share my ideas.... for everyone wanting to do a 3800 this is the best way although it is a whole lot of work but ill keep everyone updated....thanks
couldahadaV8
Report this Post04-14-2009 09:03 PM Click Here to See the Profile for couldahadaV8Click Here to visit couldahadaV8's HomePageSend a Private Message to couldahadaV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Of course another way to ruin a good replica is to look inside and immediately see gauges from a GM car. All this work so you can have an unrealistic interior? I guess I just don't get it.
Oh, have you stretched the cradle to increase the wheelbase an extra 1" compared with your frame stretch? Otherwise you are 1" short.
[This message has been edited by couldahadaV8 (edited 04-15-2009).]
katatak
Total ratings: 82
Report this Post04-14-2009 10:44 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Must have proof of life! In other words, This Thread is Useless Without Pics! Got to have them! Please!
exoticse
Total ratings: 108
Report this Post04-14-2009 11:59 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
What body kit are you using (made by whom) ?
BlackThunderGT
Report this Post04-15-2009 12:49 AM Click Here to See the Profile for BlackThunderGTSend a Private Message to BlackThunderGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What no pictures...is this a Lambo or a LAMO
merciero
Report this Post04-15-2009 04:13 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
lamo... "lmao" but yes i did stretch the cradle i just got all the suspension components back on. i will take pics tonight hopefulley. the kit is an lp640 kit, im getting it from mike vetter. but the who made it part,,,,, he got the molds from triangle G who shut down a while ago. so T G made the kit. but mike vetter is the bad ass selling them now..... and yes the best way to ruin a good replica is to see gm gauges but. an even faster way to ruin it is to keep the out dated fiero gauges... ive seen plenty of replicas that kept the stock gauges. at least im trying to stay as close as possible to a good replica. if you want i could ruin it by using some honda gauges instead...
pontiackid86
Total ratings: 344
Report this Post04-15-2009 04:19 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
you have a way of putting it to people dont you katatak
merciero
Report this Post04-15-2009 08:56 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok well the dash frame would not fit to save my life. so i had to remove the airbox and mount it alone. which included plasma cutting alot of **** out of the way..... so hey all i had to do was diminish the structural intergrity of the car..... small price to pay. so tomorrow i have to weld some braces in. i also mounted the steering column with some small modifications to the brackets but its in.
americasfuture2k
Total ratings: 105
Report this Post04-15-2009 09:56 PM Click Here to See the Profile for americasfuture2kSend a Private Message to americasfuture2kEdit/Delete MessageReply w/QuoteDirect Link to This Post
First LX9 Fiero GT, 1987 | My Fiero Fuel Economy | MPG Display for OBD I
Youtube Videos of My GT | 87 GT Inside Test Run | 3500 Fiero GT Test Run 01
3500 Fiero GT Test Run 02 | 3500 Fiero GT Test Run 03 | 3500 Fiero GT Test Run 04
If you can't fix it with a hammer, you've got an electrical problem
Fiero's are people too. We pay just as much attention to them, if not more than our loved ones
screw paying those bastards. im not going to become rich by paying for things.....
exoticse
Total ratings: 108
Report this Post04-16-2009 04:27 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
murciero,
Are you familair with murci-me on the Kit car forum ?? ( Note: you might have to join the forum, it's free, to be able see the pics)
http://www.madmechanics.com...-me-build-(changes)/
He made an LP640 out of a triangle G kit and it is unbelievable ! Please go see his build thread before you finish your build,..it has tons of great ideas, from working bat wings, to working paddle shifters.
[This message has been edited by exoticse (edited 04-16-2009).]
katatak
Total ratings: 82
Report this Post04-16-2009 05:14 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Until I got this XTC, I was not really into the rebodies but now that I have one, I want to do one myself and the lack of pictures does not help me.....lol! I want to see how the stretch was done..... Please....!
merciero
Report this Post04-17-2009 07:52 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok got a camera postin pics sat. morning
merciero
Report this Post04-19-2009 01:42 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have never posted pics on a forum before so if this doesnt work ill try again
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kitfront-1.jpg" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/jj230/brandon86jones/kitfront-1.jpg" border="0" alt="Photobucket"></a>
heres the front
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kitside-1.jpg" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/jj230/brandon86jones/kitside-1.jpg" border="0" alt="Photobucket"></a>
the side
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kelsoldstuff074.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj230/brandon86jones/kelsoldstuff074.jpg" border="0" alt="Photobucket"></a>
this is with all the air box pulled out and i cleaning up the wiring so none of it is in there at the moment
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kelsoldstuff078.jpg" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/jj230/brandon86jones/kelsoldstuff078.jpg" border="0" alt="Photobucket"></a>
here is the stretch and the rear bracing that will be used for my batwings
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kelsoldstuff082.jpg" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/jj230/brandon86jones/kelsoldstuff082.jpg" border="0" alt="Photobucket"></a>
the inner stretch keeping the steet metal stock look
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kelsoldstuff081.jpg" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/jj230/brandon86jones/kelsoldstuff081.jpg" border="0" alt="Photobucket"></a>
upper inside stretch
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kelsoldstuff088.jpg" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/jj230/brandon86jones/kelsoldstuff088.jpg" border="0" alt="Photobucket"></a>
cradle stretch
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kelsoldstuff079.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj230/brandon86jones/kelsoldstuff079.jpg" border="0" alt="Photobucket"></a>
lower stretch once again keeping the stock look
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kelsoldstuff140.jpg" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/jj230/brandon86jones/kelsoldstuff140.jpg" border="0" alt="Photobucket"></a>
all the grand prix wiring i took out to clean up
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kelsoldstuff123.jpg" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/jj230/brandon86jones/kelsoldstuff123.jpg" border="0" alt="Photobucket"></a>
a bunch of air ducts and window motors, ect.
<a href="http://s273.photobucket.com/albums/jj230/brandon86jones/?action=view¤t=kelsoldstuff128.jpg" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/jj230/brandon86jones/kelsoldstuff128.jpg" border="0" alt="Photobucket"></a>
the air box
by the way does anyone have some good rims they wanna get rid of
merciero
Report this Post04-19-2009 01:44 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
merciero
Member since Mar 2009
merciero
Report this Post04-19-2009 01:48 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
merciero
couldahadaV8
Report this Post04-19-2009 04:07 PM Click Here to See the Profile for couldahadaV8Click Here to visit couldahadaV8's HomePageSend a Private Message to couldahadaV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice metal work on the stretch!
RWDPLZ
Total ratings: 305
Report this Post04-19-2009 04:55 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I was thinking, too, I've seen so many that look like they were done by drunken amateurs with no welding skills or common sense.
1984 Fiero SE
pontiackid86
Total ratings: 344
Report this Post04-19-2009 05:00 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
wow im stunned thats not a cheap rebody........GRRRRRR if only i wasent 21 and had a good job. My lil space capsule as my dad calls it will be good enough for now.
ducattiman
Report this Post04-19-2009 05:08 PM Click Here to See the Profile for ducattimanSend a Private Message to ducattimanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok i am man enough to say it,,
Just finished read this and started to think,,,,,,,,,,,,,,,,,,,,,
GOD MY LIFE SUCKS,,,,,,,,,,,,
SWEET PICS
katatak
Total ratings: 82
Report this Post04-19-2009 05:12 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's exactly what I was talking about. I have looked at a few stretch jobs that do not look too good. This one looks to be done right. Very nice. Thanks for the pics.
Fiero84Freak
Report this Post04-20-2009 01:01 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
You got my attention. That stretch is beautiful.
What the story with the spoilerless 2G DSM? Looks like another project you have going.
merciero
Report this Post04-20-2009 08:52 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
well thanks guys. i could of done a lil better on the stretch but i did it in like 2 hours at my work im a heavy duty truck fabricator. but the kit is a lil more affordable then people think. but yeah that dsm i got it when i was 16 my first car. it was a non turbo automatic. i raced it around thinkin i was fast and got a 600 dollar ticket so my parents took it away. so it sat in my driveway. so i put a kit on it. then that started my obsession. after like 4 kits it now has a widebody i blew the motor so i put 12 Gs into building and boosting the motor. then i shattered my tranny. an auto made for 115 HP had 435HP didnt hold up so i did a manual conversion on it. ive been working on that think for 7 years and everytime i get it done i wanna change something else. lol if you care ill take some pics of it.... i fiberglassed the whole interior, air cylinder suspension, 400+ motor its, not bad. but this was a GM forum so i didnt think anyone would care bout it.............
anyways update i got the harnesses all laid out with all the components hooked up there are a few places i had to cut the wires to get it out. so i just got done soldering like 100 wires together, i am missing an on star antenna in the rear so im looking for a grand prix around here i can look at.
merciero
Report this Post04-20-2009 08:54 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
merciero
i need some rims cheap but nice so im not rockin a flat and a dog-nut
Dash
Report this Post04-20-2009 10:05 PM Click Here to See the Profile for DashSend a Private Message to DashEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent about wheels man
merciero
Report this Post04-21-2009 06:37 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok i just go my radiators in so tomorrow i will make brackets and start mounting the radiators in the back
merciero
Report this Post04-21-2009 06:53 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
merciero
you should be able to click on something and see all the photos in the photobucket
excuse the blck front end im repainting the car so i didnt bother spraying it red yet.
http://s273.photobucket.com...j230/brandon86jones/
PaulJK
Total ratings: 237
Report this Post04-21-2009 09:12 PM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by PaulJK (edited 04-23-2009).]
PaulJK
Total ratings: 237
Report this Post04-22-2009 03:29 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
merciero
Report this Post04-22-2009 10:58 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
got the rest of the wiring done. i gotta pull off and finish my ricer for a car show this weekend but im back on the fieralago in a few days.
HC
Report this Post04-24-2009 05:51 AM Click Here to See the Profile for HCClick Here to visit HC's HomePageSend a Private Message to HCEdit/Delete MessageReply w/QuoteDirect Link to This Post
murciero,
I just read through the whole build thread. Now THAT is the baddest Fiero out there, period. Anybody who hasn't yet visited should go over there and check this out. Thanks for the link exoticse, I saw you posting over there, I am user name veyr0n (just like everywhere on the internet but here).
exoticse
Total ratings: 108
Report this Post04-24-2009 10:19 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your welcome !
I agree you should definatly check out the thread and you will have your eyes opened and your jaw dropped.
[This message has been edited by exoticse (edited 04-24-2009).]
FierociousGT
Total ratings: 131
Report this Post04-24-2009 10:30 AM Click Here to See the Profile for FierociousGTSend a Private Message to FierociousGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
merciero, I'm assuming you are going to stretch the frame? Have you consider this?
https://www.fiero.nl/forum/Forum1/HTML/061408.html
http://www.321irs.com/
With this you can stretch and install and LS X with the appropiate tranny.
merciero
Report this Post04-24-2009 03:16 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah i already did my stretch. but i saw this setup online before. dont remember where. but that is a sick design. i would of went that route if i was doing a diablo. but because of the murcie kit i had to stay with this setup. but im working on getting a building and build these for a living.... after this first one i should have the hang of it.... but i will look more into this setup on my next build which is gonna be a dee-low. but did that setup take care of your bump steer also? oh and by the way that mercie me build........ he is my idol...... he got that car so clean and exact...... the best is the interior
madcurl
Total ratings: 314
Report this Post04-24-2009 05:23 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless prices have dropped... that stretch isn't cheap.
FierociousGT
Total ratings: 131
Report this Post04-24-2009 05:37 PM Click Here to See the Profile for FierociousGTSend a Private Message to FierociousGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Compared to what the guy in North IL charges for 6 speed kit (which does not include the tranny), $3000 is cheaper for the stretch kit than the 6 speed (G6/F40) kit for $3500.
[This message has been edited by FierociousGT (edited 04-24-2009).]
madcurl
Total ratings: 314
Report this Post04-24-2009 06:06 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Price for the Master 6 Speed Conversion Kit Without the Transmission is $ 3271.00, but your about right once you add the taxes. Keep in mind that the stretch kit you'll need the Porsch tranny... that's way more than a Pont G6 tranny @ $400-500 on Ebay. I really like the stretch for the Redux using this set-up (pipe dream).
Sorry about the hijack. Back to the build.
FierociousGT
Total ratings: 131
Report this Post04-24-2009 06:30 PM Click Here to See the Profile for FierociousGTSend a Private Message to FierociousGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good to hear he discounted his price. Also an Audi tranny will work too. I heard those G6/F40 trannys on ebay have issues. I was thinking about the stretch too, would be very sweet.
Sorry for the hijack too.
merciero
Report this Post04-27-2009 08:36 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok i sorry i had to take a break on this one and do some work on my other car. but i just got done plasma cutting some holes for the airbox. the wires and airbox goes in tomorrow.... pics will come up once im done for the day.
merciero
Report this Post04-30-2009 09:20 PM Click Here to See the Profile for mercieroSend a Private Message to mercieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
got the radiators on pics tomorow... and wiring goes in
SAFASTRO
Report this Post05-09-2009 02:10 AM Click Here to See the Profile for SAFASTROClick Here to visit SAFASTRO's HomePageSend a Private Message to SAFASTROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's a free bump!!
I love the the quality of workmanship on that stretch........I hope mine turns out half as nice as yours!!!
Any tips for me??? I know the tricky part is keeping everything square. What's the best method to use?
I should be pulling my motor this weekend, so I can get going on my stretch.....wish me luck!!!
Order Pennock's Forum decals in this thread. https://www.fiero.nl/forum/Forum4/HTML/040445.html
Other decal, poster, banner, floor graphic needs, go here: https://www.fiero.nl/forum/Forum4/HTML/045657.html
2" Choptop
Shortened Front Bumper
Shortened Rear Bumper
10" Stretch
Dubs
350 V8 Conversion pushing 350 ponies!!
