  1986 Fiero SE 3.4L pushrod build up (Page 5)
1986 Fiero SE 3.4L pushrod build up by justinchristie
Started on: 12-18-2008 02:49 PM
Replies: 232 (29253 views)
Last post by: justinchristie on 01-31-2016 04:49 PM
justinchristie
Report this Post07-21-2011 10:35 AM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
All the components from the interior have been removed.
I also began transferring over the sound proof padding material from the original pieces.
[This message has been edited by justinchristie (edited 03-19-2015).]
justinchristie
Report this Post07-27-2011 09:25 AM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Painting, painting, and more painting.
It is really amazing how many pieces you have to paint when you are changing the colour of the interior.
CommanderKeen
Report this Post07-27-2011 11:59 AM Click Here to See the Profile for CommanderKeenSend a Private Message to CommanderKeenEdit/Delete MessageReply w/QuoteDirect Link to This Post
What kindof paint did you use for all these pieces? What kinda prep do they need?
[This message has been edited by CommanderKeen (edited 07-27-2011).]
justinchristie
Report this Post07-27-2011 01:59 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did a paint test with one of the mock-up pillar pieces I have.
So far the best solution for interior paint is:
- Wipe down the piece with paint thinner;
- Scuff with 3M abrasive pad (lightly);
- One thin coat of clear primer (duplicolor) specifically made for plastic paint adhesion;
- Paint 3 thin layers of flat black; and
- Paint 2 layers of semi-gloss clear coat (must be UV protection paint).
The above recipe seems to produce a solid paint job that is scratch resistant.
The paint process above (listed on page #4) produces the best results. It takes about a week to paint a piece, if you allow it to dry 24hrs in-between each coat. I've done this, ....and remained patient throughout the process, ...and it has produced EXCELLENT results. DO NOT RUSH IT!!!!
I used TREMCLAD brand paint - matte black, and satin clear-coat.
[This message has been edited by justinchristie (edited 07-27-2011).]
CommanderKeen
Report this Post07-27-2011 10:51 PM Click Here to See the Profile for CommanderKeenSend a Private Message to CommanderKeenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh yeah, I already have that page bookmarked too. Lol my bad. Looking great man!
justinchristie
Report this Post08-02-2011 09:37 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I received the interior pieces back, some of the holes I cut out were covered by the leatherette installation.
I used a marker to outline the cuts, a box-cutter knife to slice the leatherette, and super glue to adhere. Super glue works best because it sets fast (10 seconds) – no need to clamp the leatherette while gluing.
justinchristie
Report this Post08-04-2011 09:18 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finished the upholstery on the headliner. The sunroof and overhead light outlets were covered by the headliner material from the upholstery shop.
Due to the gap between the headliner and the sunroof, I used foam tape to fill in the seam.
justinchristie
Report this Post08-08-2011 11:23 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
The upholstery on the centre console/armrest is now complete.
The openings for the shifter and the window switches were created.
justinchristie
Report this Post08-10-2011 11:32 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
The final coat of rubberized paint was applied to the floor pan (driver and passenger) before carpet installation.
justinchristie
Report this Post08-15-2011 01:05 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
The original speaker grilles (both front and rear) were re-covered with speaker cloth.
I used 3M spray adhesive to attach the cloth.
justinchristie
Report this Post08-18-2011 01:14 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I re-used the original grille for the front window vent on the PISA dash. I cut off all the mounting tabs, sandblasted the old paint off, then I put on a fresh coat of black paint to match the rest of the interior.
An epoxy based adhesive was used to attach the grille to the dash.
justinchristie
Report this Post08-21-2011 11:49 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
No more stalling.
Now it begins – the re-installation of the interior.
justinchristie
Report this Post08-24-2011 08:06 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store carpet I purchased way back in 2007 came with instructions that said it should be installed over the existing carpet.
I’m not a big fan of putting NEW over OLD. So in order to maintain the sound-proofing that the original carpet has, I decided to use rubber padding to go under the new carpet.
I bought a few rolls of this from Princess Auto for $2 a roll – quite cheap.
justinchristie
Report this Post08-28-2011 07:51 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I began the installation of the Fiero Store carpet I purchased over 4.5 years ago.
It’s over-sized, so I need to trim down the edges.
Exciting!
justinchristie
Report this Post08-31-2011 10:30 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installation of the carpet is complete. I also installed the back firewall cover.
doublec4
Total ratings: 150
Report this Post09-04-2011 03:01 AM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Lookin good! I'm hoping to see this thing finished soon!
justinchristie
Report this Post09-07-2011 08:27 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since the original tabs were broken on the speaker covers, I came up with a new way of attaching them to the interior “A” pillar piece.
Home Depot sells these nylon based nuts and bolts. With a black coat of paint, they fit right in.
justinchristie
Report this Post09-12-2011 10:45 AM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have re-attached the Fiero seat brackets. They are ready to go back in the car after being out almost 3 years!!
I also sandblasted the seat bolts – they were a bit too “rusty” for the new interior.
justinchristie
Report this Post09-19-2011 11:57 AM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Big day. After 11 months of hard work, the dash is finally back in.
I still need to add the components – such as the extra gauges and the MP3 player.
But it is satisfying to see this interior come together.
FINALLY.
Tinkrr
Report this Post09-19-2011 02:16 PM Click Here to See the Profile for TinkrrSend a Private Message to TinkrrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been watching your thread since the begining. Are you going to have your car on the Road soon?
We should get a few Fieros together at Tim's for a coffee and to look over your car in the flesh. Hopefully before they get stored for the winter.
justinchristie
Report this Post09-21-2011 01:05 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've already taken it out for a few spins around the block, but I'm not sure if it will be ready b4 winter. I have to complete some small projects on it in the coming weeks, because I would really like to get it painted over the winter so that it's ready for spring. After that, for sure we could do a meet at a Timmie's - i'd definitely like to see some of the other Fiero around Durham. they are getting scarce around here
Tinkrr
Report this Post09-22-2011 12:37 PM Click Here to See the Profile for TinkrrSend a Private Message to TinkrrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I posted on the GT Fieros site to see if anyone else wants to get together to checkout your car and have a coffee
justinchristie
Report this Post09-22-2011 08:25 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
The custom speaker covers turned out well....
justinchristie
Report this Post09-26-2011 10:57 AM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed the Rodney Dickman Euro “Ferrari” shifter to the 4-speed shifter assembly.
justinchristie
Report this Post10-02-2011 10:42 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
After 2 years, the seats are back in the Fiero. I can actually sit in the car now.
In the pic I have a pair of old seat covers on them. I want to keep them protected for the remaining installations.
Fiero2m8
Report this Post10-02-2011 11:01 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job on the interior Justin - it's motivating as it goes back together...
Indy Northstar-Stretch
justinchristie
Report this Post10-06-2011 12:05 AM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
We were down in Niagara the first week of September. I completely forgot to PM you ahead of time and ask if you would have been around that week. I would have liked to have seen your stretchy-north-star in person.
justinchristie
Report this Post10-10-2011 12:37 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been almost 2 years since I drove this car. Since the plate stickers are not valid (April 2006 was the expiry date) I just took it for a spin around the block.
I took some HD video as well.
[This message has been edited by justinchristie (edited 03-19-2013).]
justinchristie
Report this Post10-18-2011 08:09 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need to install the interior door panels, …and finish installing the sound system, …but aside from those two elements, the interior is done.
justinchristie
Report this Post11-10-2011 02:56 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
My new audio system arrived in the mail the other day. It is called the Secret Audio SST – “Stealth Sound Technology”.
In other words it is a radio system designed for vehicles without a standard radio/deck DIN size.
CommanderKeen
Report this Post11-18-2011 01:08 AM Click Here to See the Profile for CommanderKeenSend a Private Message to CommanderKeenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Beautiful man, just awesome work
justinchristie
Report this Post11-21-2011 08:57 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks dude, it is a definite labour-of-love.
justinchristie
Report this Post12-10-2011 05:11 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
The new SST radio comes with a flush mounting kit. This allows the controller to be mounted “properly” in the dash – rather than using the standard bracket.
In order to mount it in the Fiero, …like everything else in this interior, …fabrication needs to be done.
I used 16 gauge steel to create a mounting plate.
justinchristie
Report this Post12-26-2011 08:39 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finished mating the SST harness to the Fiero radio harness.
I bought the Fiero radio harness off eBay for $5. It allows you to adapt any radio harness to the stock harness. It also allows quick disconnect/reconnect for servicing – all without cutting any wires.
N3M3S1S
Total ratings: 51
Report this Post12-26-2011 11:57 PM Click Here to See the Profile for N3M3S1SSend a Private Message to N3M3S1SEdit/Delete MessageReply w/QuoteDirect Link to This Post
Damn you do awesome work!
justinchristie
Report this Post01-18-2012 03:44 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finished the installation of the Fiero sub woofers, and powered up the SST radio for a test run.
I still have a wiring mess to hide, …but it sounded great!
justinchristie
Report this Post03-07-2012 02:06 PM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the mounting plate finished and painted, the stereo system was completely installed.
The system sounds great great (4x50w) and the iPod integration works terrific.
Surprisingly this was an easy installation, and only took 3-4 hours (total time).
justinchristie
Report this Post06-22-2012 08:42 AM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the Ferrari 355 nose, I lost the side marker lights. So in order to comply with Ontario law, I needed to re-install marker “signal” lights on the Fiero.
A few months back I saw a real Ferrari 360 Modena in Toronto, and the Modena had simple round marker lights – they looked good.
So I went with the same style, …simple-yet-functional. I used amber “bright” LED lights – they were purchased from eBay for $30 shipped.
justinchristie
Report this Post08-24-2012 10:37 AM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
My outer dew wipes were cracking badly. I bought a set of NOS OEM dew wipes from a PFF member.
Looks 100 times better...
justinchristie
Report this Post09-17-2012 11:27 AM Click Here to See the Profile for justinchristieClick Here to visit justinchristie's HomePageSend a Private Message to justinchristieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took this back in Feb. 2012 - driving it home from the storage unit (we moved in Feb, so i had to store it in a unit for 10 days)
1986 Fiero SE 3.4L pushrod build up | Blog | My Portfolio site
