  Designing a new dash need a few ideas (Page 26)
This topic is 27 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27
Designing a new dash need a few ideas by OH10fiero
Started on: 11-01-2002 11:37 AM
Replies: 1071 (132376 views)
Last post by: rbell2915 on 02-08-2021 09:01 PM
jscott1
Total ratings: 415
Report this Post10-21-2009 01:57 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by OH10fiero:
jscott1,
(for starters i'm a buddy of OH10fiero and i'm currently using his login at work); also i do not own a fiero at the moment. i'm attempting to 'retrofit' my 87 Iroc with a 01 camaro ss gauge cluster. i've noticed that you were doing the conversion to your fiero and figured i'd ask you some questions. as a bit of background; it's a 87 Iroc camaro with the 305 tpi v8 and had the mech. speedometer. i was thinking (and here lies the question) would i be able to run a 8k signal generator to a 'dakota digital' speedometer signal interface, the signal interface would step down the ppm to 4k ppm and 2k ppm. the 4k would run to the 01 cluster and the 2k would 'emulate' the vss and supply the computer with the much needed 2k ppm input. i understand that the odometer would be incorrect for my camaro and that half of the 'dummy lights' on the 01 cluster would not apply, however that is perfectly fine my me. i could always find a gauge shop to 'calibrate' the odometer. moreover, my question is, do you believe that this setup would work? thanks.
Short answer is that most everything you said sounds like it will work to me.
Longer answer is that you might be able to get away with a single 4K signal generator and use a Fiero speedometer as your divide by two circuit to get the 2K signal. (the '87 IROC may have one as well, but since I've never seen one, I would be guessing). With this setup you would not need the dakota digital SGI-5, (which I find to be very noisy and causes your needle to occasionally bounce all over the place).
I have reservations about the '01 cluster though...assuming it's the same as the '01 Firebird cluster, (and I'm pretty sure it is) that cluster is all digital and it's not going to work with the analog senders in your car without a microprocessor controlled interface to drive the needles. Riceburner 98 was working on one just for fun, but I don't think it would be cost effective for him to build and sell them.
And easier solution is to get a 93-97 cluster. They are known to work with all the analog senders that are in your car.
As for the dummy lights, it's simple to re-map them to be whatever you want them to be. You will have extras but just ignore them.
Sharkman
Report this Post03-01-2010 04:48 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally some news from my build.
Europe # 1 choptop
Placed an order for a Custom Firebird Gauge overlay with Fiero Pegasus and SHARKMAN instead of KPH
http://6litereaterdesigns.c...5_77&products_id=102
Something like this
And new doors are coming along. The car will be on a big show here in Sweden soon.
Finally, this is try #4. The other doors have not been good...
Regards SHARKMAN
Europe # 1 choptop
http://www.fieroforum.se/fo...=1342&st=0&sk=t&sd=a
http://www.fieroforum.se/fo...topic.php?f=10&t=173
[This message has been edited by Sharkman (edited 03-01-2010).]
Sharkman
Report this Post03-02-2010 06:29 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
More...
jscott1
Total ratings: 415
Report this Post03-02-2010 09:13 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Europe # 1 choptop
Great Progress... What are those door panels from? They seem like a good fit despite the fact that you have to completely redo the bottom half.
Sharkman
Report this Post03-03-2010 03:03 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are from a Volvo S60. A good fit that will leave room for the E-brake.
[This message has been edited by Sharkman (edited 03-03-2010).]
Sharkman
Report this Post03-03-2010 06:04 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sharkman
Member since May 2004
Also going to make a new cover for the dash front
Sharkman
Report this Post03-07-2010 03:11 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
26 days to the Elmia show... and my car have to be ready http://www.custommotorshow.se/
Amida
Total ratings: 63
Report this Post03-07-2010 10:22 AM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lookin' Good man!
Sharkman
Report this Post03-08-2010 04:53 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some material for the doors and center consol I picked up today
Blue/black, sorry for the bad picture
Sharkman
Report this Post03-08-2010 08:25 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sharkman
The roof got out and a I made 0,5 liter of resin for the first side. I will do the same on the other side before I can get the roof back to 1 piece.
Sharkman
Report this Post03-10-2010 06:54 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
New center consol coming together. I changed my mind by using MDF wood. Fiberglass is better...
[This message has been edited by Sharkman (edited 03-10-2010).]
Sofa King
Report this Post03-10-2010 10:14 AM Click Here to See the Profile for Sofa KingSend a Private Message to Sofa KingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey! A cup holder? Awesome idea! You're doing some amazing work - keep those pics coming
Sharkman
Report this Post03-10-2010 12:20 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, the interior and the hole car need to be ready before April 1...
I might make a Sharkman Interior Thread with more pics after that
Sharkman
Report this Post03-22-2010 09:29 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Brake light gone and will be placed on the outside
[This message has been edited by Sharkman (edited 03-22-2010).]
Sharkman
Report this Post03-24-2010 05:53 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Man I am proud of my work
Regards SHARKMAN
Europe # 1 choptop
aeffertz
Report this Post03-24-2010 06:09 PM Click Here to See the Profile for aeffertzSend a Private Message to aeffertzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Slick!
jscott1
Total ratings: 415
Report this Post03-24-2010 11:25 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed...the door panels, console and dash filler panel are all nice.
Sofa King
Report this Post03-29-2010 09:26 PM Click Here to See the Profile for Sofa KingSend a Private Message to Sofa KingEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should be! The door panel looks fantastic. Take more pics from different angles so we see the details of your work.
LOOKING GOOD!
Sharkman
Report this Post03-30-2010 06:03 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are these angles OK...
The blue area is not fitted on the back yet
[This message has been edited by Sharkman (edited 03-30-2010).]
Sofa King
Report this Post03-30-2010 10:06 AM Click Here to See the Profile for Sofa KingSend a Private Message to Sofa KingEdit/Delete MessageReply w/QuoteDirect Link to This Post
NICE. Keep those build pics coming
Sharkman
Report this Post04-03-2010 07:23 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just waiting for the custom gauge overlay
jscott1
Total ratings: 415
Report this Post04-03-2010 09:37 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice touch on the a/c vents. That looks real nice.
IVANNATINKLE
Report this Post04-03-2010 09:48 PM Click Here to See the Profile for IVANNATINKLESend a Private Message to IVANNATINKLEEdit/Delete MessageReply w/QuoteDirect Link to This Post
that is god like. do you plan on reproducing to sell??? those door panels are wow.
Sharkman
Report this Post04-07-2010 07:00 AM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
No reproduction of these parts, sorry.
I will make them for my second choptop as well but not for anyone else
[This message has been edited by Sharkman (edited 04-07-2010).]
IVANNATINKLE
Report this Post04-07-2010 10:39 PM Click Here to See the Profile for IVANNATINKLESend a Private Message to IVANNATINKLEEdit/Delete MessageReply w/QuoteDirect Link to This Post
i figure it couldn't hurt to ask.
aeffertz
Report this Post04-07-2010 10:42 PM Click Here to See the Profile for aeffertzSend a Private Message to aeffertzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sharkman
Report this Post04-23-2010 06:46 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
My own design. Only Fiero/Trans Am overlay in the world
jscott1
Total ratings: 415
Report this Post04-24-2010 12:27 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
NICE! Can you do one in MPH?
Gandalf
Report this Post08-21-2010 04:26 AM Click Here to See the Profile for GandalfSend a Private Message to GandalfEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTT
dobey
Total ratings: 371
Report this Post08-21-2010 08:43 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Gandalf:
TTT
This one really needs to go in Construction Zone.
Jets303
Report this Post09-20-2010 01:07 PM Click Here to See the Profile for Jets303Send a Private Message to Jets303Edit/Delete MessageReply w/QuoteDirect Link to This Post
Im sorry if I missed this throughout the thread but is the op still making wiring harnesses for the trans am plug and play into the fiero?
IMSA GT
Total ratings: 250
Report this Post09-20-2010 01:12 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you are right
pontiackid86
Total ratings: 344
Report this Post09-20-2010 08:07 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was wondering. Does anyone have any pics of hot they mounter therte dashboard (behind it brackets,etc)
i'm working on a firebird swap into my 87.
dobey
Total ratings: 371
Report this Post09-23-2010 06:44 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It wasn't the OP, but jscott1 who was selling the F-body gauge harnesses (for the 93-96 gauge pods I think). He might still have some. You could PM him and ask.
dobey
Total ratings: 371
Report this Post09-23-2010 06:45 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
Looks like it made it over here.
2Fast2Fiero
Report this Post12-14-2010 05:53 PM Click Here to See the Profile for 2Fast2FieroSend a Private Message to 2Fast2FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
fantastic work. i really like that over lay
Mister I Dont Play Around!!!
Sharkman
Report this Post01-10-2011 03:58 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
A picture from summer 2010, gauge overlay mounted. With blue LEDs and silver painted needles.
Regards SHARKMAN
Europe # 1 choptop
Sharkman
Report this Post01-10-2011 04:03 PM Click Here to See the Profile for SharkmanSend a Private Message to SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sharkman
Sorry, double post
[This message has been edited by Sharkman (edited 01-10-2011).]
bowrapennocks
Report this Post01-11-2011 09:54 AM Click Here to See the Profile for bowrapennocksEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was looking at your door panels. I installed door panels from a 95 Bonneville on my 87 T-top. I noticed that you have four window switches on the driver door, just like on the Bonne. I popped off the rear two switch caps and filled in the bezel with epoxy, sanded it smooth, and repainted the bezel...so I only have two window switches.
Great job!
Jim
Sharkman
Report this Post01-12-2011 06:43 AM Click Here to See the Profile for SharkmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here you can see my doorskin being made with the Firebird switches and Volvo S60 doorskin
https://www.fiero.nl/forum/Forum1/HTML/080553.html
Great job!
Jim
