  Northstar rebuild: Will style (Page 30)
This topic is 30 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30
Northstar rebuild: Will style by Will
Started on: 12-29-2003 09:00 PM
Replies: 1185 (81552 views)
Last post by: ericjon262 on 09-01-2025 05:14 PM
Total ratings: 236
Report this Post04-22-2024 05:31 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's hard to believe, that I have been making progress... I just haven't been posting much
I installed the intermediate shaft and generally assembled things that already existed.
Here's a few shots of the cradle, trying to show some of the cradle mods required to install a NorthStar. The new crossmember is 2x3 rectangular tubing, IIRC 1/8" wall.
This ended up being a terrible photo, but it just shows the shim that came in the box with the urethane mount welded to the cradle on this flat spot
Old skool Rodney Dickman or WCF transmission mount
Not necessary to cut the entire engine mount tray
Rodney Dickman forward transmission mount
Can just barely see where the original cradle crossmember was
The (gross overkill) end treatment to support the remainder of the original crossmember
Forward engine mount just sits on top of the crossmember
Tiny car, huge engine
The only way to get a good photo of the intermediate shaft... and the flash shows off how shiny my engine still is!
OooOo0oops... I'll have to adjust the position of the oil pressure transducer
Temporarily removed the filter adapter to install this bolt. I usually don't like studs, but this is a decent candidate location for one.
I had previously been manhandling the built-from-scratch right rear engine mount bracket into place, but it didn't quite fit. This time I took the opportunity to "tune it up" so that it fit without any shenanigans.
Here's where it goes
[Insert photo of engine mount bracket here]
Weight of the complete powertrain and cradle
The back end of a Fiero weighs less than the cradle assembly that goes into it (Don't think about the fact that the hitch is rated for 200# of tongue weight... )
And I got the damned thing in place for a trial fit
The shift cable clears the MAF and coolant fill, which is good
Here's how much wire ended up in the cabin
A little oopsie on the hinge box clearance
Also did not have to cut quite as much from this angle as I did
Total ratings: 236
Report this Post04-22-2024 05:35 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jun 2000
This will be a sub-topic covering ongoing development of my firewall stiffening plate
Probably the first time The Mule's pedal box had been out since it left the factory.
Get that trash out of the way... Note the location of the electrical connector
Fit check of the years-old R1 template. I did the original on paper, which I have since lost. Pounding a model into CAD from this template was a PITA, but I got it done and now have the R2 drawing ready to cut. The electrical connector just to the right of the brake pedal mounting pattern is the interior side of the C100. It's the same connector as the C500, just in the front compartment. Further to the right of the C100 is the HVAC air handler. Obvi, that's a giant hole through the firewall right next to the place on the firewall where we push the hardest. I can probably add a stiffening rib to the edge of the stiffening plate to counteract this hole making the brake pedal mount more flexible.
The interior firewall metal is curved just below the steering column, which puts a limit on how far down a flat stiffening plate can go
La fiera
Report this Post07-09-2024 10:30 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice to see you are making progress Will! How come you have clearance issues on the back valve cover? You didn't have that problem before right!? Did you change the mounts?
ericjon262
Report this Post07-09-2024 12:26 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Will had previously cut away the hinge box on the car to install the engine, since then he realized he had done so excessively and installed a new hinge box and is more methodically trimming the box for a cleaner fit.
La fiera
Report this Post07-09-2024 03:58 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah!!!
Total ratings: 236
Report this Post09-08-2024 07:53 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the subtle aspects of GMs mounting for the decklid and hinges is that it allows 5-DOF adjustment of the decklid fit. This is solid production engineering that isn't super obvious. My original hinge box modification took away a couple of those DOFs... which I eventually wanted back. I snagged FieroGuru's old hinge box that he removed in favor of his smoothed hinge design and had the box welded into my car.
As Eric said, now I'm trimming it methodically, as I should have done originally.
Report this Post09-17-2024 04:17 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
WOW, 21 years in the making. Must say you're a better man than I. Can't complain as I have a 4.9L swap that was just completed. Never saw a Fiero N* swap so I assume not many owners were ready for one of the most difficult swaps around..
Total ratings: 236
Report this Post09-29-2024 08:41 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
After wildly missing my end of June goal due to the Jeep taking WAY more time than I thought, I was able to get back to The Mule 2 of the last 3 weekends. I looked over my fit check list, then dropped the engine back out to finish up the harness.
I trimmed the right hinge box to give "just enough" clearance with the engine in place.
As it appeared in the last photo + the upper scribe line 1/2" from the old position of the cam cover and the lower scribe line about 1/4":
Cut along the lower scribe line:
Finally have *juuuuuuuust* enough:
Probably will want to increase it for dynamic clearance, but this lets me fit the engine.
I trimmed the 90 degree elbow off the oil cooler and ended up with greater clearance to the AC lines than I'd had with the prior 120 degree elbow, so that's an improvement. I have a 60 degree elbow (120 degree bend) to look at as well.
I was also able to scope out clearance to the '85-'86 style heater tubes with the smaller CS130 alternator installed.
There does not appear to be any satisfactory way to make that work. As shown, the hoses are out of the way, but there's not even a fingertip of clearance between the tube and the mount bracket... and everything is packed into that little space as the heater tubes try to snake around the "shelf" low on the firewall.
I also found that rotating the engine down around the forward cradle bolts drags the connector position assurance (CPA) guard feature on the cam sensor connector against the frame rail. This actually cracked the guard, but that means it did its job in protecting the CPA clip.
I installed and refreshed my memory on what my custom AC lines look like and how they fit. The low side line passes through a loop of the '85-'86 fuel tank vent line, which is undesirable, but not prohibitive. I'm thinking about which pieces of tubing, between the Storm Trooper and The Mule, I need to send off to Inline Tube for reverse engineering. Or maybe just have them 3D scanned?
I also looked at O2 sensor wiring and general harness construction and thermal protection. I think I have that figured out, but need to do some figuring and order some fire sleeve.
When I re-routed my AC lines, I did so for packaging and clearance reasons. I'm thinking I'll have to do the same for the heater lines. The Northstar heater connections are at the LF and LR corners of the engine, as installed. The Fiero heater connections are at the RF corner of the engine bay, regardless of whether the '85-'86 (as I have done) or '87-'88 lines are installed. This means that no matter what, additional plumbing has to wrap around the engine bay.
With the heater return to the waterpump capped, and the heater return from the heater core T'd into the right side coolant pipe, the car takes about 3 times as long to start to deliver heat to the occupants as it does when the return from the heater core is plumbed to the heater return to the waterpump, so there aren't shortcuts in heater plumbing without reworking flow inside the waterpump.
If I cut and bead the heater tubes right where they come out from under the floor pan, then I can run hoses directly from there and do not have to try to find the perfect way to squeeze those lines between the forward engine mount bracket and the "shelf" across the firewall.
If I cut the heater tubes, I might as well swap the '87 heater tubes back into the car.
Instead of running hoses across the bottom of the engine bay, cutting vertical holes through the firewall shelf might work out well... that gets the heater hoses above the shelf where they're no longer competing for space with the AC hoses and oil cooler and oil cooler hoses, but does not require sneaking the heater hoses between the shelf and the engine. I'll have to take a look at that when I'm back at the car. If I do that, then those holes will have to route around the tubes to the fuel tank expansion volume... which I *do* have in SS from Inline Tube :-D
My Samco silicone hose order arrived. 4 meters each of 5/8" (16mm, green), 3/4" (19mm, green), 5/16" (8mm, red) & 3/8" (9.5mm,red), with the red ones being lined so they can handle pressurized fuel. With that batch plus a couple of elbows and joiners to play with... Dam Str8 I deserve a free keychain! :-D
Total ratings: 236
Report this Post09-29-2024 08:44 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got to the point of taking photos of my recent engine bay packaging updates.
And here's what I was really aiming for:
That removes the heater pipes from the gap between the firewall shelf and the engine mount bracket, creating more space all around.
Now that the holes are cut, deburred, cleaned, painted & grommeted, I can install the placeholder tubes as shown. Next step is to cut, deburr, blast/strip, bead & paint/coat the original '87 tubes that came out of the car and install those with some extra SamCo elbows. The angle between the under-car tubes and the pass-through tubes is right at 120 degrees, so a 60 degree elbow is perfect to connect the two. The '87 tube set swaps the places of the supply & return, so now my bright green 120 degree elbow is cut wrong and I have to replace it--although I'll probably go to 90's at those locations now.
This is my other problem:
That's my bespoke refrigerant return line passing through a loop in the '85-'86 four cylinder fuel vapor line that goes up to the vapor canister on the left side of the engine bay.
These two are the '87-'88 fuel tank expansion volume lines. The upper one in frame connects the fuel sending unit vent line to the bottom of the expansion volume. The other line connects the top of the expansion volume to the looped vapor canister line in the photo above.
There's 6 feet of extra tube in the car because the expansion volume is above the right wheel house and the vapor canister is on the left side of the engine bay. I realized I could eliminate the 6 feet of extra tube by relocating the vapor canister to the right side of the engine bay. That would also eliminate my packaging problem between the AC return line and the fuel vent line.
Since the rest of my system is 2006 Corvette, I started off looking at the 2006 Corvette vapor canister. It's a blocky thing that's shared across most of GM's contemporary car lines. I was able to get Dorman to send me dimensions so I didn't have to grab one for a fit check. Unfortunately, it's just too large to tuck under or in front of the battery tray. I was lamenting the loss of the "easy way" when I realized I could mount a vapor canister OUTSIDE the body metal in the right wheel house, just below the fuel tank expansion volume. This gets it out of the engine bay completely and there is, relatively speaking a LOT of room for it. Now I just need to figure out which one I'm going to use. The Corvette bracket mounts it sort of diagonally, so I'll probably want a bracket from something else... just have to figure out what.
So there you have it: the three major fitment challenges I still had are solved.
Total ratings: 236
Report this Post10-07-2024 07:19 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Umm... Thanks! I think...
Things I've done along the way:
-Found a shop that couldn't hone a Northstar block
-Learned about honing and surface finish
-Learned about piston rings, ring groove and bore finish
-Helped a user here get a Northstar running on a 7730 with $A1 code
-Found another shop that couldn't hone a Northstar block
-Verified that the Shelby .bin will run a Northstar in a Fiero
-Found a shop that *CAN* (I hope) hone a Northstar block.
-Learned to start an engine build with the ring pack
-Learned how to spec pistons
-Learned about crevice volume in the cylinder
-Packaged a 7.25" dual disk clutch in the FWD bellhousing
-Developed a Fiero swap accessory drive for the Northstar
-Tried a bunch of things that don't work
-Maybe became a decent engine builder...
Edit:
-Invented how to install '99 and older Northstar heads on a '00 or newer block
-Invented how to modify the '06+ cam sprockets (I hope) to work in '99 and older heads
[This message has been edited by Will (edited 11-19-2024).]
La fiera
Report this Post03-03-2025 10:01 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/_cbCms6ravY?si=tLPFomB_1LqtOQb1
Hey Will, have you seen this??
Total ratings: 236
Report this Post03-04-2025 04:11 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I saw the FaceBlech post about it. Is the guy as much of an idiot as he comes off as in the video?
Total ratings: 236
Report this Post03-04-2025 04:13 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The injectors I'm using are for the LC3 factory supercharged Northstar. I know GM intended them for a high power 4V engine, and that engine has similar port geometry to my engine. Spray pattern should be about as good as it can be for a hot rod fitment. I started off with Bosch EV6 connectors for the injectors because I was having a hard time finding info on Aptiv (Delphi) EV6 connectors. I eventually found the PNs for the Delphi connectors. The Delphi connectors are GT150 series that have individual wire seals and a terminal position assurance (TPA) part that clips onto the connector body and has projections that push against the outside of the wire seals to block egress of the terminals. Of course this ensures that even if the main latch is released or breaks, the terminals won't back out of the connector far enough to break the circuit. ProWire designed and manufactured their own TPA for these connectors. The ProWire TPA includes a booting lip, which the factory part does not. Obvi ProWire also sells a boot that works with that booting lip.
TPA: https://www.prowireusa.com/TPA-EV14
Boot: https://www.prowireusa.com/...ducer-connector.html
There is *ALSO* a GT150 triangular 3 cavity connector which Aptiv themselves make with a booting lip:
https://www.prowireusa.com/...shrink-boot-lip.html
So I ordered the Aptiv injector connectors, the ProWire TPA, the Aptiv triangular connectors and enough boots for everything. I have an ECM oil pressure transducer, an aftermarket oil pressure transducer for logging, the GM 3 wire CTS that works with an ECM *AND* an analog gauge, and the AC pressure transducer... So I needed 12 boots and four triangular connectors.
The GT150 triangular connectors are PUSH-to-seat, while the Metri-pack 150 triangular connectors are pull-to-seat, with all the pain, suffering and fussiness that entails. I originally selected the MP150 part, wrote the wire list and had the spreadsheet build my BOM before I really understood the difference. Once I built one of the pull-to-seat MP150 connectors and understood that, I didn't even need an excuse to get rid of them.
To build with this boot:
  • feed the wires through the boot
  • Install the wire seals, strip the wire and crimp the contact, then crimp the wire seal
  • install the terminals into the connector body
  • Install the boot to the connector booting lip
  • Shrink your DR-25 so that 3/4-7/8" of wire is bare between the end of the boot and the end of the shrink tube
  • Peel the boot off the lip and slide it back so the small end of the boot slips onto the shrink tube.
  • Make small service loops in the wires
  • Install the boot back to the connector over the service loops. The wire used in the service loop pulls the shrink tube closer to the connector so that now the shrink tube and boot overlap
Before (Note the text on the shrink tube):
After (Still note the text):
Service loops (I wound both of these the wrong direction, but they still work):
Service loops inside the boot:
Total ratings: 236
Report this Post03-04-2025 04:14 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've made significant progress on The Mule's wiring as I've been learning how to build a concentrically twisted harness.
OEMs, or at least GM, tend to use split convoluted tubing to sheathe harnesses. This make branch points trivial, since, even with just a one- or two-wire branch, the branching wires can just slip out of the split convoluted tubing wherever they need to. The branch point gets taped to ensure it doesn't come further apart and that's that.
Fancier harness construction methods, like sheathing with a nylon braid or DR-25 instead of spit convoluted tubing, benefit from more planning of the branch points. While it's still *possible* to build a DR-25 sheathed harness with the same topology as the OE harness, that becomes a fussy exercise in cutting, sequencing and shrinking short pieces of large diameter shrink tube to accommodate frequent branch points. The situation is even worse with a nylon braid, since using the braid for trunks requires dressing branch points with RayChem SCL or similar adhesive-lined shrink tube. While the braid *can* be spread to pass a wire through, this creates a potential chafe point for both braid and wire.
The fanciest harness construction method is concentric twisting. This method is defined in MIL-STD-339, which was deprecated and re-issued as MIL-HDBK-508. The authoritative source to download the document is here: https://quicksearch.dla.mil...?ident_number=203296
This method *requires* extensive planning of branch points, since layering and twisting the trunks in between is a very "constrained" operation... only so many ways of doing it work. This document includes tabulated and descriptive information on how to plan twisted layers so that they "work" when building the harness. One of the major considerations is the relationship between the bundle diameter and the number of wires used, which determines the "lay length" or axial length of harness required for the twisted layer to make a complete revolution. This trades inversely with "twist angle"... the steeper the twist angle, the shorter the lay length.
I also took High Performance Academy's online classes in Introduction, Club Sport and Motorsport Wiring, which is mostly based on MIL-STD-339.
I "tailored" the usual methods of motorsport wiring as follows:
-Aptiv (formerly Delphi) connectors for my GM sensors and actuators
-TXL wire rather than Tefzel
-Nested shrink tube at branch points rather than Raychem SCL or formed branch boots
-I use mixed-AWG layers of 18, 20 and 22ga, while most documentation assumes each layer consists of all the same gauge wires.
Installing a Northstar in a Fiero without rewiring the car is a collection of bad options :roll: From the original ECM location, the harness can go through the original pass-through location in the firewall. The layout of the Northstar engine means that the immediate choice is to drape over the waterpump belt drive or route above the exhaust manifold. To help keep the harness from being conspicuous, I chose to route it above the exhaust manifold. I'll be using fire sleeving and probably making a sheet metal heat shield. The harness will turn around the front of the engine and route above the accessory belt drive, then wrap around the rear bank, again above and exhaust manifold. The last leg wraps around the bellhousing end of the engine and ducks under the throttle body to reach the distal branch point.
I started building this harness completely backwards in that I'm working from the distal branch point back toward the ECM.
The distal branch point is under the throttle body and configured with a "back branch" that exits the branch point next to the trunk that goes into the branch point. This branch point splits the trunk into the forward branches: Forward bank injectors (8 wires), MAP (3), DBW throttle (6); and the rear branches: Rear bank injectors (8), MAF (5). The branch point also contains two splices which split two injector feed wires into 8 injector power wires. I used stepped butt splices for this. Two 20ga injector power wires in the small end of the splice as the "forward" branch and the 16ga injector feed wire plus the other two 20ga injector power wires as the "back" branch in the large end of the splice.
I used the "Cadillac Style" injector wiring from '90's Northstars which bundles the end injectors of one bank with the middle pair of the other bank. This contrasts with GM's current method of putting each bank on its own feed. The old Cadillac method reduces peak current in the injector feed because not as many injectors in each feed are energized at the same time.
Here's setting up the injector power wires for splicing
A little in-process action:
The injector wires forming the first component of the branch point. I looped the rear bank injector signal wires around the bundle in order to keep the bend radius large enough to avoid damaging the wires.
And here it is ready to get started twisting the core and first layer:
I twisted the two 16ga injector feed wires together to form the core of my harness. Since there are only two wires, the major diameter of the core is twice the diameter of a 16ga txl wire, or 0.178. The minor diameter is the diameter of a single 16ga txl wire or 0.089. Averaging these two gives a bundle diameter of 0.134. This probably underestimates the working bundle diameter, since the 20ga wires in the first layer are not going to lie in the gaps between the 16ga wires. The result is that I did not use enough wires in the first layer, which results in a steeper twist angle, shorter lay length and use of more linear feet of wire than otherwise.
The first layer over the core consists of the eight 20ga injector signal wires. A ninth wire would have resulted in a shallower twist angle and a longer lay length, but I didn't have a ninth wire. I could have used a filler wire, but since this was the first layer I twisted, I didn't realize it wasn't very optimal.
One of the big frustrations of hand twisting a layer is that as you twist each wire, it's trying to spin around its own axis, resulting in all the adjacent wires twisting together at their far ends and becoming tangled. Thus every 1-3 revolutions you twist, you need to comb out EACH WIRE to prevent all the wires from tangling together, causing you to swear. I cite the range 1-3 because early in the process when the untwisted remainder of the wire is very long, you don't have to comb the bundle out as often. Later in the process when the remaining length is shorter you have to comb it out more often.
The finished diameter of the first layer is ~0.315 with a lay length of ~1.2. This results in a lay length to diameter ratio of 3.8, which is below the lower limit of the range recommended in MIL-HDBK-508.
After I took this photo, I twisted the remainder of the core and first layer to go all the way around the engine.
The second layer consists of The DBW Throttle (6), MAF (5) & MAP (3) wires, totaling 14. The DBW TAC wires (2) and MAF ground are 18 ga, the MAF +12V power is 20ga; all others are 22ga. This count is on the low side, but I didn't have any more wires.
The finished diameter of the second layer is ~0.450 with a lay length of ~1.8, for a ratio of 4. This is still below the recommended range.
The second layer looks like one of those giant ugly candy canes from the '80's or '90's:
While the twist angle is steep and the lay length is short... I still didn't have any other wires to add. However, just around the corner of the rear cylinder head will be the 2nd-to-last branch point. I can use some of the wires that join the harness to add to this second layer to increase the lay length and reduce the twist angle.
Because the part of the harness between the throttle body and 2nd-to-last branch point at the corner of the rear cylinder head will be visible with the engine in the car, I sheathed that portion with clear RT-375 so that I could show off my work and those who see it and know what a concentrically twisted harness is would be impressed. Since the finished diameter was 0.450, 3/4" RT-375 was the right size to use.
In order to add not-previously-planned wires to the second layer, I had to unwind the second layer. Unwinding a layer completely probably isn't as much of a PITA as winding it in the first place, but then rewinding it would be.
So I invented a way to unwind the layer just enough for rework, without unwinding it all the way.
That's just 3/4" PVC pipe
The zip-tied wires are NOT the ones I ended up adding, but this is a good shot of the end of the RT-375
And here's the final 2nd layer product, adding 3x 22ga wires from one of the oil pressure transducers into the layer.
You can see the difference in the twist angle and lay length. The new lay length is ~3.72, while the diameter remains 0.450. This yields a lay-length to diameter ratio of 8.27, which is just above the lower bound of the recommended range.
The design flow of MIL-HDBK-508 is to measure the diameter of the underlying layer, divide by the diameter of the wires to be used in the next layer and look up that ratio in a table in the document to find the suggested number of wires for the next layer.
In taking my first stab at designing my layers, I had used this table:
It came from a reputable source, though I have since asked for attribution.
This table seems to under-estimate the wire count for each layer compared to the MIL-HDBK-508. Also, my mixed-gauge layers and coarse-twist on the two wire core throw the numbers off a little bit as well.
This table is handy for TXL wire diameter: https://www.crimpzone.com/txl-wire-specification/
To rework my second layer per MIL-HDBK-508, I should have added 4 wires. I tried adding 2x 18ga for the backup lights and 2x 22ga for the VSS together. In trying to get that to lie well in a twist, I kept having one wire pop out when I squeezed all the others against the first layer. That was too many wires.
So after trying to add 2x 18ga + 2x 22ga and finding that didn't work, I tried 4x 22ga; that was better but didn't quite work either.
Going down to 3x 22ga added wires, finally worked.
I was able to wind that tightly over the first layer. The finished diameter was the same at 0.450, but the lay length stretched out to 3.72, for a lay length to diameter ratio of 8.27, which is within the recommended range.
So I went from 14 wires in the second layer with a much too short lay length of 1.8 to 17 wires in the second layer with a lay length of 3.72, or more than twice the lay length of my initial combo. When the layer is close to full, lay length is very sensitive to exactly how full the layer is.
I developed my own design flow which, because I'm me, uses plenty of arithmetic. It's based on "centerline circumference" instead of a table look-up.
To develop the parameters for the next layer, count up the number of wires of each gauge in your intended next layer. Use the OD of each wire gauge to add up the diameters of all wires. This is the calculated perimeter. Divide this by the number of wires to find the "average diameter" of wires in this layer. Add this diameter to the diameter of the last completed layer and multiply by Pi. This sum is the centerline circumference.
As the calculated perimeter approaches the centerline circumference the lay length goes to infinity.
The first leg of my second layer has 14 wires with an average diameter of 0.066. This represents a calculated perimeter of 0.922. The diameter of the first layer is 0.315. With an average diameter of 0.066, the centerline circumference is 1.197. The difference between 1.197 and 0.922 is significant, which is why this layer has a short lay length and high twist angle. The diameter of this layer is 0.450. With a lay length of 1.8, this results in a lay-length to diameter ratio of 4.
For the second leg, my first try added in 2x 18ga and 2x 22ga wires. This combination has a centerline circumference of 1.202 and a calculated perimeter of 1.200. This will not work because the centerline circumference is larger than the calculated perimeter.
My second try substituted 4x 22ga wires instead of the 2x 18ga dn 2x 22ga. This combination has a centerline circumference of 1.170 and a calculated perimeter of 1.194. While the centerline circumference is less than the calculated perimeter, it was not *ENOUGH* less than the calculated perimeter to account for any significant twist angle. This combo did not work.
My third try went down from 4x 22ga wires to 3x 22ga wires. This combination has a centerline circumference of 1.108 and a calculated perimeter of 1.194. The difference between these two numbers resulted in a lay length to diameter ratio of 8.27, which is at the bottom end of the recommended range. The diameter was still 0.450, while the lay length was 3.72.
My next step in developing this design flow is to account for twist angle in the centerline circumference, since the tangential component of circumference starts off at the wire diameter for a twist angle of zero and goes up as 1+sin(twist angle). The twist angle affects the centerline circumference. The lay length and centerline circumference are related by Pythagoras' theorem. The square root of the sum of the squares of the lay length and centerline circumference is the wire length of one revolution.
I've been coy about what the "recommended range" of lay length to diameter ratio actually is because... what's in 508 doesn't make sense in light of my very limited experience.
The "recommended range" per MIL-HDBK-508 section 600.3.5 is that the lay length of a layer be 8-12 times the finished diameter of that layer. My rework of my second layer showed that it will not lie correctly--that is, with all 2nd layer conductors lying firmly against the first layer--with even one more 22ga wire. The maximum diametral sum that can possibly fit results in a lay length to diameter ratio of 8.27... just barely into the bottom of the recommended range. I don't know how I'd go for a ratio any larger than what I achieved.
Total ratings: 236
Report this Post03-04-2025 04:15 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
So far I've covered that I twisted the core of 2x 16ga injector feeds, then wound the first layer of 8x 20ga injector signal wires.
The second layer had two legs. The first leg ran from the distal branch point to the next-to-last branch point and consisted of 3x 18ga, 1x 20ga and 10x 22ga. The second leg added 3x 22ga wires to consist of 3x 18ga, 1x 20ga and 13x 22ga.
Here's a photo of the second leg in process. I added the 3x 22ga wires from the ECM oil pressure transducer. I left way too much at the connector end because I hadn't fully dressed and routed it at this point. That's ok... with careful work, all that slack can be pulled through the twist so as not to waste wire.
After building a couple of twisted layers and evaluating the results, I'm getting into the third layer with some idea of what I'm doing.
The third layer starts where the second layer changes from its first leg to its second leg.
The third layer will also have two legs.
The first leg consists of Bank 2 Coils (7), Oil Pressure Logger (3), Coolant Temp & Gauge (3), Back Up Lights (2) & Vehicle Speed Sensor (2).
This collection is 2x 16ga, 2x 18ga, 5x 20ga & 8x 22ga.
Here's a pic of wrapping service loops--in the correct direction this time--on one of the triangular 3 cavity connectors.
This collection has a calculated perimeter of 1.17 with an average diameter of 0.069
The finished second layer has an OD of 0.450, which with the average wire diameter of 0.069 results in a centerline circumference of 1.630.
The difference between 1.630 and 1.17 is WAY too large, and will result in a very steep twist angle and short lay length.
By adding 6x 22ga filler wires, I can bring the calculated perimeter to 1.542. The average diameter comes down to 0.067 and the centerline circumference to 1.624. This combination will work.
This results in a finished diameter of 0.580 and a lay length of 6", with a ratio of 10.34.
The 0.580 finished diameter requires 1" DR-25. I installed that with a resulting trunk diameter of 0.650-0.670. Since this is just under 11/16", I'll need 3/4" heat protective sleeve for this leg, since it passes above the exhaust manifold.
A few shots of that process:
The big tan stripe is my six filler wires
This leg complete
And with 1" DR-25
The back corner of the engine that will be visible in the engine bay does end up a bit cluttered... and obscures visibility of the trunk I sheathed in RT-375
The second leg removes the fillers and removes the Back Up Lights and temperature gauge wire, since those branch off to terminate in the C500 connector. In place of those 9 wires are Bank 1 Coils (7), Alternator L wire (1).
This leg consists of 4x 16ga, 10x 20ga, 8x 22ga. The calculated perimeter is 1.532 with an average diameter of 0.070. The centerline circumference is 1.634. This combo works as well as the first leg. Finished dimensions are essentially the same.
Since this leg will be visible by the battery, I installed 1" RT-375 instead of DR-25. The resulting trunk diameter is 0.625-0.630. My temporary Adel clamps for setup are 1.25 or so... I'll need to switch them for 5/8" Adel clamps for the finished product.
For the third leg of the harness overall...
The 6x 22ga filler wires just end, the 2x 18ga Back Up LIght wires come out and the 1x 22ga temperature gauge sender wire comes out. I replace them with 2x 16ga, 5x 20ga coil wires and 1x 22ga alternator L wire.
And just keep doing exactly the same twist after that:
and shrink 1" RT-375 over it, since this trunk will be visible with the engine installed
I am *FINALLY* at the point where I have the third leg of the harness COMPLETE.
I still have some branch point dressing to finish, and I need to dress and terminate the wires going to the C500--which requires the engine being in the car--but three of the four trunks are DONE. I am deciding if I can build a fourth layer for the fourth trunk, or if the remaining wires will just form a smaller parallel trunk.
The REAR (Bank 1) bank O2 sensor wires did not fit in the Layer 3 Leg 2 winding, so those four will run as a parallel bundle behind the main trunk to get to the next branch point.
Remaining wires to incorporate:
Bank 1 O2 (4), Valley Harness (10), Accessory Branch (15). 29 together is light for the diameter I have to twist now... but I still need to run the numbers to figure out how many fillers I might need. Valley harness consists of Crank Sensor (3), Cam Sensor (3), Bank 1 Knock Sensor (2) and Bank 2 Knock Sensor (2). Accessory Branch consists of Oil Pressure Sender/Switch (4), Oil Level Switch & Sump Temp (3), AC Pressure Transducer (3), AC Compressor Clutch (2), and Alternator (3).
I am also thinking about what I need to do with the red 8ga alternator output wire... it runs from the alternator output stud to the +12V junction block visible in the photo above... but it doesn't readily fit in any twist as anything but a core. I'll probably end up putting small split convoluted tubing on it by itself and running it next to the main harness. The purple 10ga crank wire needs some attention, but not as much. I have an MP480 disconnect for it. The disconnect will come out of C500 from the stock crank wire terminal. I ALSO have a 10ga wire to run inside the car to my fuse & relay module that holds the PWRTRN relay, AC Comp clutch relay & fuel pump relay, as well as the injector and coil fuses.
La fiera
Report this Post03-04-2025 02:08 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 236
Report this Post03-04-2025 02:37 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's no :ROFLMAO: here, unfortunately.
Obvi, he could design the base and has the resources to have it produced. The builds on his YouTube channel look interesting, and YouTube itself probably helps fund his adventures. He's also willing to cut up parts to try things... although an engineer he is not.
With regard to the actual part, I would have designed it with flanges inside to mount short trumpets underneath the Hi-Ram lid, in order to better tune the powerband.
I actually should ask if he has the cams for his Northstar figured out, as I have some ideas about building blanks for the roller cam heads.
[This message has been edited by Will (edited 03-04-2025).]
La fiera
Report this Post03-04-2025 03:53 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
He might not be an engineer like you but he is self certified from a reputable school.
Total ratings: 236
Report this Post03-08-2025 07:29 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://m.media-amazon.com/...UF894,1000_QL80_.jpg
Man, I've seen a video of a dyno comparison between a production TrailBlazer SS intake manifold and a Chinese knock-off of the Holley Hi-Ram. The TBSS beat the Chinesium manifold by 15 hp and 25 tq when the only difference was the manifold.
Just because it looks fancy doesn't mean it's any good.
The proof is with the dyno, without exception.
[This message has been edited by Will (edited 03-08-2025).]
Total ratings: 236
Report this Post04-04-2025 05:55 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nobody knows what to think about a concentrically twisted / wound harness
Between the Bank 1 HEGO wires; the valley sub-harness w/ crank sensor, cam sensor and two knock sensors; and the accessory bundle with AC pressure transducer, AC comp clutch, oil pressure sender/switch and oil level switch/sump temperature sensor; and the alternator wiring... The fourth layer for the last leg is just a smidge too full. I think I can push 1x 22ga wire down to the third layer... then both third and fourth layers will be brim full but probably workable. I may be able to push 1x 22ga all the way down to the second layer, which will result in either the third or fourth layer being brim full.
I have drill this weekend, so I won't get to try any of those options until 4/12.
Total ratings: 236
Report this Post04-24-2025 08:10 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sooo... <sigh> I realized that I had missed several wires originally planned to go from the C500 connector to the ECM.
These included: Tach signal (kind of essential), temperature light, cooling fan (also kind of essential), and brake lights.
The brake lights connection is sort of experimental, as the 2006 Corvette ECM has a brake switch input... and I realized as simple way to create that signal in the Fiero is to run a jumper on the body side of the C500 from the actual brake light circuit going to the rear lights harness to an unused cavity on the engine harness side.
The need to add the missed wires led me to cut off the clear shrink tube and open up the third leg of the harness again.
After evaluating my layering, I determined that I could add 2x 22ga wires to the 2x16ga wire core and 3x 22ga wires to the first layer, which consisted of 8x 20ga injector signal wires. Until this point, the first layer had a fill fraction of only 73%, which made for an inefficient use of wire. Adding 3x 22ga gets that up to 96% fill fraction, which is right where it should be.
Also, I'm copying FieroGuru's alternator wiring and driving the Alternator-L terminal from BOTH the ECM *and* the Fiero alternator light. This preserves the function of the alternator light in the dash and allows the ECM to turn the alternator on if the alternator bulb burns out. However, the ECM no longer gets to turn the alternator off, since the Fiero body wiring will always be turning it on when the key is on.
This means that I run an Alt-L wire from C500 into the main harness at the second branch point, bring that wire back out of the harness at the first branch point, double stuff the -L contact in the alternator, and run the second -L wire back into the harness at the first branch point... so it's a little awkward, but doable.
The second layer remained the same.
The third layer actually loses a wire between the second and first branch points, since it no longer has the Alt-L wire, but gains the Alt-S wire at the first branch point instead.
The Alternator-F terminal will go into the 4th layer, which I'll be winding this weekend.
An amusing thing about adding wires to a layer with a low fill fraction: The bundle does not become larger in diameter... it just gets longer.
Pulling the core out of the first layer was surprisingly easy:
I unwound everything back to the second branch point at the right rear (vehicle coordinates) corner of the engine, near the C500 connector
Cooling fan control wire added to the core:
Cooling fan control and tach wires added to the core (I routed the white wire with another revolution after I took this photo):
I wound the first layer back onto the core with Alt-L, temp light and brake light wires
Unwinding individual groups from subsequent layers was actually surprisingly easy... and since the wires retained their coils, re-winding them was SO MUCH easier than winding them in the first place had been
I stopped there since the replacement RT-375 I ordered had not yet arrived... so I'll install new RT-375 next weekend and then the third leg will be DONE... again.
I also completed winding the third leg all the way out to approximately where it should pass through the firewall... which actually counts as new progress since I hadn't gotten that far before.
TakeTwo
Report this Post05-04-2025 03:30 PM Click Here to See the Profile for TakeTwoSend a Private Message to TakeTwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting, are you worried at all about interference in higher frequency sensors or misfires etc? I've seen this done in racing applications, but only for short runs of a foot or so. Part of me wants to try this on my own build, would certainly make things 'tidier' in my engine bay which is important to me.
Total ratings: 236
Report this Post05-07-2025 08:31 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only wires that GM twisted are for the knock sensors. Of course those are twisted pairs, not twisted bundles.
I have added the twisted pairs into the fourth layer on the last leg of the harness. I should be wrapping that up this weekend.
The crank sensor & cam sensor are digital. Those sensors are three wire units: +5V, GND and signal. The sensor contains the trigger electronics which interpret the analog signal and outputs a 0-5V square wave that is, for practical purposes, immune to interference. The injector and coil signals are also digital. The MAF signal is a variable frequency that GM filters. Other sensors like MAP output a simple voltage level, so averaging those signals over time filters out noise,.
Fierollac71
Report this Post08-26-2025 12:17 PM Click Here to See the Profile for Fierollac71Send a Private Message to Fierollac71Edit/Delete MessageReply w/QuoteDirect Link to This Post
[E]Originally posted by Will:
I think my N* just ate a head gasket. It blows coolant out the rear bank pipe. True duals really are good for something.
Anyway, time for some engine work. Since I have to take the head off... I want to thread-sert the head bolt holes to avoid problems. Since I'm doing one side, I might as well do the other, and springs & retainers while I'm at it.
If I have the heads all the way off and the engine all the way out, I might as well do something about the oil smoke on coast down problem.
option 1: rehone and new rings. Prolly work. Boring.
option 2: mild performance build with stock replacement components. Wcapman's done one with eagle rods and I don't remember what pistons, so I can do what he's done. But who wants to do what's been done before?
option 3: exercise creativity...
I just happened to notice that DSM rods have the same pin diameter (0.866") as the N*, and the same center-center length (151 mm or 5.944"). They have a 45mm rod journal instead of a 54mm journal, however. Extra length DSM rods are available. If I offset ground the crank, I could destroke the engine to 75mm (from 84) and use 155.5mm rods. Not that it needs it, but I like short strokes. I'm kinky that way.
I also noticed that the N* rod journals are 54mm (2.126"). They could be turned down or offset ground to 2.100 in order to use 6.000" large journal Chevy rods, narrowed. Pistons would have to be custom...
How far can a N* be bored? I don't remember seeing that in the manual. I recall something about early LS1's being limited to a clean up hone but nothing else. Is the N* the same way?
If the N* can tolerate a 0.020 overbore, I could use 60 over 3.4 pistons with a relocated pin. 5mm up for stock Caddy compression height, or a little more for a 6" Chevy rod.
Jstricker: what TSB's will I need to properly overhaul a '95 engine?
Thoughts?
[/QUOTE]
Hi will. I have a 88 formula with a 1995 Northstar. I'm looking for a ecm pin out diagram for the 95 ecm for wiring purposes. Can u help?
Total ratings: 236
Report this Post09-01-2025 01:42 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I should. PM me your email address.
ericjon262
Report this Post09-01-2025 05:14 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
there's a bunch of service manual level info on Charm, these are the pinouts for a 95 Seville
https://charm.li/Cadillac/1...Connector%201A%2F1B/
https://charm.li/Cadillac/1...Connector%202A%2F2B/
https://charm.li/Cadillac/1...Connector%203E%2F3F/
others are available here:
https://charm.li/Cadillac/1995/
