  Corvette ZR1 power steering rack: next project? (Page 1)
This topic is 10 pages long:  1   2   3   4   5   6   7   8   9   10
Corvette ZR1 power steering rack: next project? by Rickady88GT
Started on: 01-05-2006 02:06 PM
Replies: 365 (34796 views)
Last post by: Rickady88GT on 10-26-2020 09:27 PM
Rickady88GT
Total ratings: 200
Report this Post01-05-2006 02:06 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just got a Corvette ZR1 power steering rack and am planning on putting it into my next power steering equipt Fiero. So far it looks like a good choice. Almost the same travel as the Fiero. The Fiero has 5" of travel and the ZR1 rack has about .5" less. With wide tires this means nothing. And the ZR1 has 2 turns lock to lock were the Fiero is almost 3.5 turns lock to lock. The ZR1 rack moves 2.25" per turn of the steering wheel and the Fiero rack gear moves 1.5" per turn of the steering wheel. To put it in other words the ZR1 rack is like a GO CART the steering ratio is VERRRRRRY FAST.
Has anyone done a Vette rack? I think I saw Rockcrawl do it before?
The 84-94 Vette racks are basicaly the same. the ZR1 or "sport" rack has 2 turns lock to lock. The rest have 2.5 turns lock to lock.
[This message has been edited by Rickady88GT (edited 05-03-2006).]
sspeedstreet
Total ratings: 53
Report this Post01-05-2006 04:02 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Power steering: bah! humbug! GIRLIEMAN!!
There, it's been said, no further such posts accepted.
Crap, Rick. You're making my install obsolete before its started.
Need a test bed?
Neil
1988 GT, 5-speed, white, beechwood leather, 3.4 DOHC installation in process.
Rickady88GT
Total ratings: 200
Report this Post01-05-2006 08:45 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
So far the Vette rack looks like it will work better.
Sorry, my dig cam batteries are dead no pics, yet.
Formula88
Total ratings: 554
Report this Post01-05-2006 08:51 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
If the ZR1 rack looks that close, does that mean all C4 racks are gonna be just as good (maybe slower ratio, but the same dimensions and travel, etc.)
Looking forward to seeing this. I'm seriously considering power steering on my Formula.
Rickady88GT
Total ratings: 200
Report this Post01-05-2006 11:15 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know about the other Vette racks? I never got into the part numbers or when any changes were made between them. But I will do that because I wont put a ZR1 rack into every Fiero I drive. That FAST ratio might be kinda fast for a daily driver.
After I get this into a car and get it working I will buy several more Vette racks. As it looks right now I wont need to cut into the spare tire tub to clear the hydraulic lines. It looks like they will fit under the stock tire tub and allow for a spare tire to fit. One of the draw backs of the "F" body rack is that you cant fit a spare tire into the tire tub because of the placement of the hydraulic in put and out put lines.
The mounting points of the Vette rack are a breeze but the rack extension adapters are more complex. Take the good with the bad I guess?
Report this Post01-06-2006 04:38 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe all Z51 equiped C4's will have the 2.0 ratio rack.
My 86 was a non-Z51 car, but had been upgraded with the 2.0 rack. Biggest issue is the turn signals may not cancel around turns due to the steering wheel not being turned enough. You might be able to swap the turn signal assy from a Z51 car to fix this though.
Rodney
Total ratings: 267
Report this Post01-06-2006 09:06 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure it is a front steer or turning the wheel left will make the car go right. We looked at Corvette racks when we did that steering rack R&D and I don't remember any Corvette racks look promising. Thay may not have had a C5 rack at that time.
PLEASE NOTE MY NEW ADDRESS
7604 Treeview Drive
Caledonia, WI 53108
(262) 835-9575
www.rodneydickman.com
Rickady88GT
Total ratings: 200
Report this Post01-06-2006 01:04 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
All of the Vette racks are front steer. In fact the Vette rack looks like a cross breed between a Fiero rack and a Chevette rack. with a few other changes.
I only needed to make a new mount on the driver side. The pass side I used the stock Fiero mount. I used the Fiero rubber mount from the pass side and slid it onto the hydraulic cylinder of the Vette rack and was able to bolt it down with only a slight mod to the rubber mount. The Hydraulic lines come out of the cylinder straight up, so a front mount battery will be tight. The input shaft is the same as the Fiero and seems to be oriented the same direction as the Fiero, so there may be no need to index the steering wheel after installation.
[This message has been edited by Rickady88GT (edited 01-06-2006).]
Rickady88GT
Total ratings: 200
Report this Post01-06-2006 01:13 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rickady88GT
Member since Dec 2002
Need a test bed?
Neil
I am always on the lookout for a better rack for the Fiero Infact the best rack seems to be the Fiero rack with the power steering "stuff" from other racks to convert the Fiero rack over to power steering. BUT the problem is that none of the GM rack other than the Chevette rack has the same input shaft angle. So a custom rack and pinion will need to be machined $$$$$. So I keep looking for a conversion. I could use the Cylinder from the chevette and the steering spool from the Chevette and put them on a Fiero rack and convert the Fiero rack to Power assist, but it would still have a weak ratio.
ryan.hess
Total ratings: 319
Report this Post01-06-2006 01:30 PM Click Here to See the Profile for ryan.hessSend a Private Message to ryan.hessEdit/Delete MessageReply w/QuoteDirect Link to This Post
So when you go to a quicker ratio, wouldn't this mean the already twitchy steering will get even twitchier? (is that a word?)
Gonna need to be hyped up on something to keep you on the road at high(er) speeds... Am I right?
btw- ZR1, sounds expensive.
[This message has been edited by ryan.hess (edited 01-06-2006).]
Rickady88GT
Total ratings: 200
Report this Post01-06-2006 02:14 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I love the "F" body ratio. I never thaught it was too fast or twitchy. So a slightly faster ratio may put it over the edge? or maybe not? But it is worth a try because the standard Vette racks could be used in place of the ZR1 rack if the ratio is too fast.
jscott1
Total ratings: 415
Report this Post01-06-2006 02:14 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe, but Fiero steering shouldn't be twitchy in the first place. That 3.5 turns lock to lock doesn't qualify as twitchy in my book anyway. I preferred driving the f-body with its 2.2 turns LTL.
And no a stock Fiero doesn't need power steering but a lot of us are running tires one, two, three (and more) plus sizes bigger than stock.
ryan.hess
Total ratings: 319
Report this Post01-06-2006 02:29 PM Click Here to See the Profile for ryan.hessSend a Private Message to ryan.hessEdit/Delete MessageReply w/QuoteDirect Link to This Post
It does on a short wheelbase...
MikeW
Report this Post01-06-2006 02:40 PM Click Here to See the Profile for MikeWSend a Private Message to MikeWEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the ZR1 rack was a ZR1 only item. Could be the amount of assist inside. I'll try to remember to check some part numbers since I have the ZR1 and later part numbers on CD.
MikeW
Report this Post01-06-2006 08:24 PM Click Here to See the Profile for MikeWSend a Private Message to MikeWEdit/Delete MessageReply w/QuoteDirect Link to This Post
MikeW
Member since Aug 2004
Didn't go to well, looks like GM doesn't sell the entire units and I'm missing the gear application charts. Looks like there may have been an early and late '89 car. Late '89 thru 90 have the same number for the steering gear. 91/92 has another. I have no number for later gears. As far as remanufactured Delco gear kits, again the show 2 different 89 cars. Looks like late 89 thru 96 uses kit 26044839 (Delco number is 369090) I would assume the reman/Delco is most of the unit. Numbers may be superceded by now. Best I could do.
Rickady88GT
Total ratings: 200
Report this Post01-07-2006 02:59 AM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know much about the Vette racks, this is the only one I have seen up close but one strange thing about this rack is that it has the small diameter hydraulic cylinder like the Chevette and 88 Fiero (the black still part of an 88 rack is an unfinished hydraulic cylinder) but I have seen smaller GM cars us the larger Hydraulic cylinders than this Vette rack. So if the other Vette racks use the larger cylinder they will have less effort to steer than this rack. Thus this rack would have more "Road Feel"
THE BEAST
Report this Post01-09-2006 02:21 PM Click Here to See the Profile for THE BEASTSend a Private Message to THE BEASTEdit/Delete MessageReply w/QuoteDirect Link to This Post
*Bump*
Rickady88GT
Total ratings: 200
Report this Post01-09-2006 03:45 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Adapters are being made at the machine shop. So I will try to get some pics of what I have so far.
THE BEAST
Report this Post01-09-2006 07:13 PM Click Here to See the Profile for THE BEASTSend a Private Message to THE BEASTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good!
JG
Rickady88GT
Total ratings: 200
Report this Post01-10-2006 04:08 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here are a few pics, gotta run off to work now.
THE BEAST
Report this Post01-12-2006 04:04 PM Click Here to See the Profile for THE BEASTSend a Private Message to THE BEASTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome!
JG
madcurl
Total ratings: 314
Report this Post01-12-2006 06:19 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice.
gascarracer
Report this Post01-15-2006 10:57 PM Click Here to See the Profile for gascarracerSend a Private Message to gascarracerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Ernie
1988 Silver GT
One owner 47000 miles.
Soon to be a 3.4 DOHC powered.
mcaanda
Total ratings: 129
Report this Post01-15-2006 11:07 PM Click Here to See the Profile for mcaandaSend a Private Message to mcaandaEdit/Delete MessageReply w/QuoteDirect Link to This Post
With only access to 56k I finally gave up on the internet, but today I finally got to check out this thread being that Im back home.
Is this planned to be placed into the black GT?
Drop me a call tomarrow and lets see if we can't get togeather for lunch / dinner. I think that I hear the BOCK calling.
--Allen
Rickady88GT
Total ratings: 200
Report this Post01-16-2006 12:52 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I plan on putting this one into the Black 88GT with a smog legal 3800SC and sell it.
Rickady88GT
Total ratings: 200
Report this Post01-16-2006 04:10 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rickady88GT
Here is the car that will get the rack.
gascarracer
Report this Post01-18-2006 01:14 AM Click Here to See the Profile for gascarracerSend a Private Message to gascarracerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Steven Snyder
Total ratings: 106
Report this Post01-18-2006 02:20 AM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
That car is missing its rocker panels! :-D
Rick, just wanted to say your work is amazing. Can't wait to see where you take this one!
Rickady88GT
Total ratings: 200
Report this Post01-18-2006 11:44 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. The rest of the body is on the floor. The car dose need some work, but over all it looks good.
darkhorizon
Total ratings: 451
Report this Post01-18-2006 11:48 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hear that people hate the stock 88 rack, but I like it just fine, but I like the pre-88's better. Overall I think they serve their duty, I am 135lbs and can get in and out of parking spots really easy, who needs power steering?
Can the autoX guys really see much of an improvement from a Vette rack?
Rickady88GT
Total ratings: 200
Report this Post01-19-2006 08:36 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are either joking or misinformed?
I have never heard anyone say they hate the 88 Fiero rack? Even I think the 88 steering is a good step up from the 84-87 Fiero's. And that the 88 is fine without power steering. BUT if the tires are larger the steering in an 88 can get heavy too, so some may just want an extra boost for the larger tires. I just want faster ratio steering. So the ONLY way to get faster ratio without adding more effort to the steering wheel is to do a power steering rack with a faster ratio.
I have said that I drove an 87 GT for years and HATE the slow ratio steering an heavy feel of the manual Fiero rack in the pre88's. No such thing as "road feel" in the pre88 Fiero, just a slow ratio rack that is hard to turn at walking speed. The power steering I put in my 88 Fiero feels VERY stock and the "road feel" is just fine.
"Who needs power steering?" Let me ask you this."Have you ever driven a Fiero with close ratio power steering?" I can tell that you never have or you would not even ask "who needs power steering?" People want ALL KINDS of mods on the cars they drive, why is it strange that people want power steering? Who needs 12" subs in a Fiero? Who needs a V8? Who needs new paint? I "need" power steering because I want FAST ratio steering (2.25 turns lock to lock) without extra effort. Others can answer your question with the reason that fits their needs.
Can AutoXers benefit from FAST ratio steering? Hmmm YES. First it is ALLLLLLOT less work for the driver to get around and second it does not take any HP or TQ from the engine. The only time the pump needs to make pressure is wen the car is turning. This is RARELY at a time when full throttle is used. The parasitic loss of the pump is null and void.
mcaanda
Total ratings: 129
Report this Post01-20-2006 01:04 AM Click Here to See the Profile for mcaandaSend a Private Message to mcaandaEdit/Delete MessageReply w/QuoteDirect Link to This Post
He who is apparently 135 pounds, and likes the 3+ lock to lock ratio of the stock Fiero dosent.
I take it that you have got to have stock rims / tires on your Fiero. Take a set of very large aftermarket rims, ie: 17x8's w/ a 35mm offset on an 88’s for example, and see if you still think that the stock "feel" serves it's purpose.
I'd bet a Super Sized Double Bacon Cheeseburger from Carl’s Jr. that you'd defer to not...
Nope - there's no improvement; Until it's installed into their Fiero anyhow.
Have you been to / participated in any Auto X event? With a 3+ lock to lock you’re going to be spinning a lot of steering wheel around vs the guy that has a 2.o lock to lock ratio who is also sipping on his bourbon while cruzing through the cones while compared to the guy w/ the stock setup.
[This message has been edited by mcaanda (edited 01-20-2006).]
Flyguyeddy
Report this Post01-21-2006 01:01 PM Click Here to See the Profile for FlyguyeddySend a Private Message to FlyguyeddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
it the vette steering rack the same length? it appears to be shorter, however i have never had a fiero rack apart, so i dont know for sure where everything ends/begins under those dust boots....
Rickady88GT
Total ratings: 200
Report this Post01-21-2006 03:19 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the Vette rack is short, so is the "F" Body rack. It is about 5" shorter. That is what the adapters are for. They move the tie rods out to the stock Fiero location.
Rickady88GT
Total ratings: 200
Report this Post01-22-2006 06:11 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some new pics
the custom mount. I made it of a few pieces.
The pieces tack welded to the Xmember for fitting
Rickady88GT
Total ratings: 200
Report this Post01-22-2006 06:21 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rickady88GT
GOOD NEWS the rack fits in and the spare tire tub fits over it without any cutting for the hydro lines. I even have the room for a front relocation battery kit.
This vew hs hard to understand, but it is of the steering spool looking from the grond up into the hole that the steering shaft goes thru into the car. You can see that the hydro lines wont get in the way of anything.
Rickady88GT
Total ratings: 200
Report this Post01-22-2006 06:27 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rickady88GT
With the trie tub out you can see the rack a little better.
And with the steering shaft on you can see the hole for the steering shaft will need just a tad bit of grinding to clear the newly oriented shaft.
Zac88GT
Report this Post01-22-2006 07:49 PM Click Here to See the Profile for Zac88GTClick Here to visit Zac88GT's HomePageSend a Private Message to Zac88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
the f body rack is only ~1.5 inches shorter than the fiero rack, so that's about 3/4 per side. and the vette rack is about 2.5 shorter per side. just wondering what your doing for the bellows ( tie rod boots) if your making adapters to locate the tie rods in the original locations, just curious if the vette boots will extend an extra 2.5"
Rickady88GT
Total ratings: 200
Report this Post01-22-2006 08:50 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Zac88GT:
the f body rack is only ~1.5 inches shorter than the Fiero rack, so that's about 3/4 per side. and the vette rack is about 2.5 shorter per side. just wondering what your doing for the bellows ( tie rod boots) if your making adapters to locate the tie rods in the original locations, just curious if the vette boots will extend an extra 2.5"
I don't remember off hand exactly how much shorter the Vette rack is than the Fiero, but the extensions for the "F" body and Vette are off set towards the driver side. The "F" body extensions are something like .35" on the driver side and the pass side is 1.15"
So if the Vette rack is 5" short then the driver side extension will be 1.5" and the pass side will be 3.5". So the dust boot on the driver side will be OK with the extra travel. The pass side will have a hard dust cover to extend the boot out 3". That way the dust boots will be OK. Also the small end of the boot does not need to clamp in the stock location. That gives you about an extra inch.
[This message has been edited by Rickady88GT (edited 01-22-2006).]
Rickady88GT
Total ratings: 200
Report this Post01-23-2006 03:33 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I liked the location of the rack so I had the mount welded as is.
After the mount was welded I cleaned and painted the Xmember.
And one quick pic of the rack on the Xmember shows the steering spool to Xmember clearance.
