  Sourmug's 3.4 DOHC Swap (Page 4)
Sourmug's 3.4 DOHC Swap by Sourmug
Started on: 04-29-2011 08:56 PM
Replies: 277 (26598 views)
Last post by: jetfighterv on 01-24-2018 01:40 PM
Sourmug
Total ratings: 144
Report this Post08-18-2011 10:59 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by The Aura:
What Brand spark plug wires are those?
These ones:
Sourmug
Total ratings: 144
Report this Post08-18-2011 11:05 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourmug
Member since Sep 2002
Originally posted by Fierobsessed:
Thanks for that!
I was looking all over for an air canister like the Fiero's that has an offset inlet. That's the challenge right there.
Here are some pictures:
Nolan
Sourmug
Total ratings: 144
Report this Post08-26-2011 05:09 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here are some additional pictures.
A nice shot of those yummy ports and valves:
The intake neck and throttle body:
The fourth mount:
Some of the trimming and cleaning of the engine bay:
The new electrical terminals from the front mount battery:
Relocated battery:
Nolan
qwikgta
Total ratings: 84
Report this Post08-27-2011 12:03 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking good. Pics take me back to when I was doing mine. I loved coming up with new ideas for any problem I faced. If I ever had to do it again, I'd do another 3.4 DOHC. Hell, after you finish one, you know all the problems before hand. I'd be able to cut my install time by about 80%. I really like the stock style air cleaner look you have going on, and the 4th motor mount. (wish I thought of that). One thing I'd do differant is with the 96-97 intake/elbow/TB setup. I spend so much time looking it over, i think i'd take it to a machine shop, have two small hose adapters welded in for the coolant hosed, remove the TB mount, so the upper and lower intakes can be free of each other. Then make a 90 elbow off the Upper Intake to move the TB up and away from the stock location. Just too much going on in that area. I had fuel lines, coolant lines, shifter cables and air intake all fighting for the same real estate.
Again, really love the look
Rob
Steven Snyder
Total ratings: 106
Report this Post08-28-2011 08:37 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice, clean swap! Good job man.
Do you have any concern about the exhaust holding up against motor movement & vibration without a flex coupler? The 91-95 motors had a flexible spring-loaded cup joint on the rear manifold dump, which prevents engine movement from stressing the exhaust, but I see that with your 96-97 era motor it's a flat bolted flange.
1988 Pontiac Fiero 3.4 DOHC V6 5-speed
California Smog Legal!
Sourmug
Total ratings: 144
Report this Post08-28-2011 09:48 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't actually do the swap, Fieroking did. He has a similar exhaust set up in his DOHC car and it has been running for a few years with no exhaust issues that I'm aware of.
Thanks
Nolan
Steven Snyder
Total ratings: 106
Report this Post08-29-2011 04:40 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
His exhaust setup has the spring-loaded connection I was referring to. This gives it some flex.
From Fieroking's build thread:
vs.
Sourmug
Total ratings: 144
Report this Post08-29-2011 05:14 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah, I see what you mean. I'll ask Joe about it.
Thanks
Sourmug
Total ratings: 144
Report this Post09-03-2011 07:09 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
I asked Joe about the exhaust, here's his response:
"I don't think there will be a problem there is not a lot of movement and the mounts for the exhaust are pretty tight. My exhaust wraps around the cradle were yous is more of a straight shot to the muffler."
So we'll see how it holds up.
On a side note, I had to replace the heater core yesterday. Just about the only thing on the car that's not new and it fails, go figure
[This message has been edited by Sourmug (edited 09-03-2011).]
Reallybig
Report this Post09-09-2011 02:32 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any new progress, or are we done till next summer?
Sourmug
Total ratings: 144
Report this Post09-09-2011 01:22 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
What? I didn't do enough?
There are a few things that I'm going to do here soon, nothing major though. I'm still having a few issues with the tach, it looks like the Dakota Digital SGI may be faulty and has to be returned for a replacement, and it also looks like one of the axle seals is leaking.
I did have the car on a dyno when I picked it up. If I can find the slip that I brought home I'll post it.
Thanks
Nolan
Reallybig
Report this Post09-12-2011 02:16 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh I think you've done more that enough for now, it's just that some of us know what you are capable of! Besides, those of us who tinker with projects and upgrades enjoy watching those who accomplish them in short time...kind of like an inspirational shot of visual adrenalin.
Sourmug
Total ratings: 144
Report this Post09-13-2011 09:12 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's some pictures of the dyno used:
And the Dyno slip:
This is when the engine had less than 100 miles on it. The engine was tight and the consensus from the speed shop was that the hp and torque would go up once the engine was broken in and should be about 205 HP and 210 torque at the wheels.
Nolan
[This message has been edited by Sourmug (edited 09-13-2011).]
Sourmug
Total ratings: 144
Report this Post09-15-2011 03:40 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, here's an update. Not pertaining to the swap but some additional work that I have done.
The inside of my decklid isn't black it's more of a blue/grey colour. Most other Fieros seem to be black on the underside of their decklids so it's been bugging me. I had also purchased a mirror set from Snapperhead (excellent products by the way ) a few months ago so I figured now was a good time to do something about it.
Here's a couple pics in the middle of the clean-up process. I fixed a few blemishes and removed the now obsolete emissions system sticker and a few others:
See what I mean about the colour of the underside?
Once the prep was done I used Eastwood's Pre paint prep also a great product for getting rid of wax, contaminants etc. before painting. Here's a link: http://www.eastwood.com/eas...e-painting-prep.html
Then the decklid was masked off before primer and paint:
Here's a shot showing the painted underside. I didn't paint the two locations where the mirrors will sit and you can really see the colour difference:
The stainless steel mirrors installed and then on the car:
I had painted the underside of my hood last winter and installed Snapperhead's acrylic mirror set this week too.
Nolan
[This message has been edited by Sourmug (edited 09-15-2011).]
JPH87
Report this Post09-15-2011 06:45 PM Click Here to See the Profile for JPH87Send a Private Message to JPH87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice touches
Sourmug
Total ratings: 144
Report this Post09-18-2011 08:01 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
And... Woot, in the "Construction Zone"
Reallybig
Report this Post09-20-2011 02:14 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Construction Zone is a well deserved location for this build!
You have a PM
exoticse
Total ratings: 106
Report this Post09-20-2011 09:29 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Painting the undersides of the hood and decklid really cleans things up and gives it that fresh " New Car" look.
Definatly going to do this when it comes to paint time.
Sourmug
Total ratings: 144
Report this Post09-20-2011 09:57 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a PM
Thanks!
PM responded to.
Sourmug
Total ratings: 144
Report this Post09-20-2011 09:58 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourmug
Yes, it makes a world of difference.
Nolan
elitopr
Report this Post09-28-2011 09:44 PM Click Here to See the Profile for elitoprClick Here to visit elitopr's HomePageSend a Private Message to elitoprEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't wait get start my 3.4 DOHC swap!!!!!!!1
Carswell...Wellscar
Report this Post10-01-2011 12:16 PM Click Here to See the Profile for Carswell...WellscarSend a Private Message to Carswell...WellscarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome swap!! Looks great!! i wanted to do this swap but then changed my mind! I still have the engine if anyone is looking for one or one for parts! ..sorry dont mean to hi jack!
How does it sound???
War Hammer
Report this Post11-06-2011 10:01 AM Click Here to See the Profile for War HammerSend a Private Message to War HammerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks great
Sourmug
Total ratings: 144
Report this Post11-07-2011 05:07 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by War Hammer:
Looks great
Thanks!
FieroAK
Report this Post11-07-2011 05:23 PM Click Here to See the Profile for FieroAKSend a Private Message to FieroAKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I love your car. Haha. Very nicely done.
Sourmug
Total ratings: 144
Report this Post11-07-2011 05:24 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's one minor issue that I have been haveing that has now been resolved. In order for the new VDO tack to read the RPM signal from the ECM Joe has to install a Dakota Digital SGI-8 unit to convert the signal. Here's a link to the unit: http://www.dakotadigital.co...mode=prod/prd127.htm
What I was finding was that the tack worked perfectly well up intil 5300 RPM. Anything over that and it would drop to Zero until the RPM dropped below the 5300 threshold. I tried all the claibration steps outlined in the instructions and went though all the connections but couldn't find the cause. I sent the unit back to Joe at his request and he tested the unit on his 3.4 DOHC car with a spare VDO tach that he has and he had the same problem.
Joe contacted Dakota and it turned out that because there are only 3 coil packs the SGI unit had to be set for 3 cylinders not 6. Joe retested it and confrimed it operates correctly and it's on its way back to me. Just a heads up for anyone else who is going to use one of these modules as this isn't defined in the instructions.
Nolan
ricreatr
Report this Post11-07-2011 08:02 PM Click Here to See the Profile for ricreatrSend a Private Message to ricreatrEdit/Delete MessageReply w/QuoteDirect Link to This Post
And the Dyno slip:
Nolan
it the tach issue what kept you from running up to 7k?
first time i have seen the mirrors. they look sharp.
Sourmug
Total ratings: 144
Report this Post11-07-2011 09:57 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, not at all, they don't use the vehicle tach on the dyno in any event.
Nolan
BV MotorSports
Total ratings: 189
Report this Post12-24-2011 09:07 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you give me some more information on the tach? Use a 95 Monte Carlo "8k" tach and a DakotaDigital controller needs to be used? I am curous why the 3.4's ecu wont control it.
Great swap BTW, excellent workmanship!
Sourmug
Total ratings: 144
Report this Post12-26-2011 12:24 AM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
The tach being used is a VDO tach, not a GM tach. According to the VDO literature it's supposed to work with the stock signal from the 3.4 DOHC ecm however, it won't work. The SGI unit adapts the signal and the VDO tach works fine with it. I didn't actually do the work Je (aka Fieroking) did the work. If you need more detailed information you would have to contact Joe.
Yes he did a great job.
Thanks
Nolan
[This message has been edited by Sourmug (edited 12-26-2011).]
L67
Total ratings: 219
Report this Post01-21-2012 12:05 AM Click Here to See the Profile for L67Send a Private Message to L67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tachometer is controlled by the ICM board, not the computer.
Sourmug
Total ratings: 144
Report this Post01-21-2012 01:30 AM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, Thanks
Snapperhead
Report this Post02-29-2012 04:17 PM Click Here to See the Profile for SnapperheadClick Here to visit Snapperhead's HomePageSend a Private Message to SnapperheadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely Beautiful !! What else can I can say. Oh and thanks for the thumbs up.
Vince
Sourmug
Total ratings: 144
Report this Post03-01-2012 12:08 AM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Vince, and you're welcome!
I'm pretty happy with her
sergioazevedo
Report this Post03-01-2012 01:16 AM Click Here to See the Profile for sergioazevedoSend a Private Message to sergioazevedoEdit/Delete MessageReply w/QuoteDirect Link to This Post
sourmug. good to see shes still going. msg me if you go to the a&W with the other. me and chris should have ours out this summer hopefully with all the goodies we bought from u.
Sourmug
Total ratings: 144
Report this Post03-08-2012 12:26 AM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I go the the A&W meets. You guys should come out, we would love to see what you guys have been doing.
Nolan
Curtisk1060
Report this Post03-15-2012 08:08 PM Click Here to See the Profile for Curtisk1060Send a Private Message to Curtisk1060Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you know how I can contact the seller of the rear deck hood mirrors? I have been looking for these for quite some time to finish up my 88GT for shows and they look awsome!! Curtis
Sourmug
Total ratings: 144
Report this Post03-22-2012 01:31 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
See this thread: https://www.fiero.nl/forum/Forum4/HTML/053137.html
Nolan
Snapperhead
Report this Post03-22-2012 04:21 PM Click Here to See the Profile for SnapperheadClick Here to visit Snapperhead's HomePageSend a Private Message to SnapperheadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Nolan
[This message has been edited by Snapperhead (edited 03-22-2012).]
JSzpotek
Report this Post03-22-2012 04:31 PM Click Here to See the Profile for JSzpotekSend a Private Message to JSzpotekEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amazing build, a definite favorite of mine.
Wondering where you got your front lip from?
