  Sourmug's 3.4 DOHC Swap (Page 6)
Sourmug's 3.4 DOHC Swap by Sourmug
Started on: 04-29-2011 08:56 PM
Replies: 277 (26424 views)
Last post by: jetfighterv on 01-24-2018 01:40 PM
fierogtlt1
Report this Post05-03-2014 08:29 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work on the Center Console Skeleton.
https://www.fiero.nl/forum/Forum1/HTML/092166.html
Sourmug
Total ratings: 144
Report this Post05-04-2014 02:28 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't really do anything, just lucky enough to get an undamaged skeleton, but thanks.
Sourmug
Total ratings: 144
Report this Post05-04-2014 02:29 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourmug
Member since Sep 2002
Ok, the dash is out:
My poor baby looks a mess...
Sourmug
Total ratings: 144
Report this Post05-05-2014 10:59 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store black carpet for the cabin and the trunk arrived today, along with new sealant for the tail light housings! Looks good all though it is definitely thinner than the stock carpet.
Their shipping costs are high but they do deliver quickly.
Nolan
Sourmug
Total ratings: 144
Report this Post05-08-2014 11:12 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Minor update:
Painting of some of the interior components has started. After a bit of digging on the forum and elsewhere I found a decent how to video:
Based on that here are the products that I'm using in order from left to right:
The color coat is landau black.
And painting is underway:
Sourmug
Total ratings: 144
Report this Post05-09-2014 06:40 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dash and glove box are done. I've retained the charcoal dash top and side vents as the centre console and shift cover will remain charcoal as well. Black is hard to photograph and some of the colors look a bit off in the pictures but not in real life.
Before:
After:
Progress!
Sourmug
Total ratings: 144
Report this Post05-11-2014 05:33 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not a whole lot of exciting things to mention.
Door panels are painted, waiting now for the new lower covers and armrests. Cleaned up a bit of wiring through the tunnel below the center console. Plans for the upcoming week: I'm going to look at installing some LED projectors in the doors and possibly keyless entry. Once that's done I'll start to reassemble the dash.
Nolan
Inferno
Report this Post05-12-2014 08:05 PM Click Here to See the Profile for InfernoSend a Private Message to InfernoEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are doing what I am just starting.
Thanks and I look forward to seeing your car this summer as I am only in Edmonton.
Sourmug
Total ratings: 144
Report this Post05-12-2014 09:54 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi!
I hope that my thread is helping you out a bit. What all are you planning for your car?
Sourmug
Total ratings: 144
Report this Post05-12-2014 09:57 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourmug
So... I'm looking at putting the projectors into the bottom of the door, similar to what some others have, and I can't see how they did this short of pulling off the door skins, something I'm not all too eager to do at this point. Either that or they have awfully small hands. I might have to rethink this a bit, perhaps use them as the foot well courtesy lights...
Sourmug
Total ratings: 144
Report this Post05-14-2014 09:49 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
A bit of an update:
I went and picked up some 1/4" acrylic rods from a local supplier. A couple of these were cut to length:
Then they were lightly sanded with 220 grit sand paper, rounded the ends and cleaned with plastic cleaner:
After some self etching primer and paint I ended up with these:
I then used this adhesive which is transparent when it comes out of the bottle and dries transparent as well:
And finished up with this:
I did this to echo the red piping on my seats:
I then took a longer length of rod and formed it to the curved groove in the dash as well. My heat gun worked perfectly to soften the acrylic for forming:
After priming and painting I used my super advanced clamping method of small sockets and extensions to help the rod adhere to the dash:
And the end result:
I like it!
Also, my fiberglass headliner arrived from V8 Archie, need to cut out for the 3rd brake light, coat hooks and visors:
Oh and my hydrographics shop called, my trim pieces and bezels are ready for pick-up
[This message has been edited by Sourmug (edited 05-14-2014).]
RCR
Total ratings: 102
Report this Post05-15-2014 06:50 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks really good, Nolan.
Bob
Lonster
Report this Post05-15-2014 12:10 PM Click Here to See the Profile for LonsterSend a Private Message to LonsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you sand the acrylic rods to frost them and then light the end of the acrylic rod with a light source (LED or 12v bulb), they will glow. I'm sure light would glow through the paint... If this is your thing ; )
http://www.youtube.com/watch?v=UXUBl9AR42s
fierogtlt1
Report this Post05-15-2014 04:23 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice work on the door panels and dash.The red trim really pops and matches the seats,Great Job.
Sourmug
Total ratings: 144
Report this Post05-15-2014 05:39 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys.
I noticed that the tubing carries light well, but I don't think that's my thing for this car, thanks for the suggestion though.
Nolan
Sourmug
Total ratings: 144
Report this Post05-15-2014 11:05 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourmug
Time to do the headliner. Placed my old ratty one on the new fiberglass headliner to mark out the holes. They are a bit different than the marks on the V8 Archie head liner, so if you're doing this as well make sure you check:
And after the vinyl is applied and ready for install:
Nolan
Sourmug
Total ratings: 144
Report this Post05-16-2014 07:26 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yay, the head liner is in! Pain in the but, finicky but it's in and looks nice. I'd take a picture but all you would see is an expanse of black with a sunroof though it, you get the idea..
It's nice to be putting things back into the car.
[This message has been edited by Sourmug (edited 05-16-2014).]
fierogtlt1
Report this Post05-16-2014 09:20 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
That is how I did my door panels with grey 1/4" PVC in the groove...Turned out pretty good.
But that red and black looks bad ass.
[This message has been edited by fierogtlt1 (edited 05-16-2014).]
Sourmug
Total ratings: 144
Report this Post05-16-2014 11:17 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the groove is just begging for something to be placed in it. Er, I'm not sure that came out right...
The grey and black looks great too!
Russ sent me a few pictures of how things are progressing:
Door Pockets
Door Panels
Visors
Sourmug
Total ratings: 144
Report this Post05-17-2014 12:03 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Picture of the armrests as well:
Sourmug
Total ratings: 144
Report this Post05-17-2014 02:24 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourmug
Picked up my trim and bezels from the hydrographics shop. Here are a few pictures:
They used a silver carbon fiber transfer film over black for the trim and the same over red for the bezels.
Here's a link to the shop I used: http://www.brokentine.ca/
Your can also check out this link if you're not familiar with the process: https://www.youtube.com/watch?v=ADq96RGRf00
Nolan
Sourmug
Total ratings: 144
Report this Post05-17-2014 02:36 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wanted to add this about the rear speaker covers. I essentially duplicated the recovering method that I used way back when I was working on my 87 GT. The grilles are heat welded to the interior trim and if you try to remove them they will break the plastic pins that hold it in place. Here's my solution to the problem.
When you pull the grilles off this is what you will see, first the holes that are left in the trim piece:
The larger round hole is for the upper seat belt attachment. And the back of the grilles look like this once the existing fabric has been removed:
Here's how the plastic pins look:
There's no easy way to re-weld these back on so a different attachment is required. On the face of the grilles there are four small dimples that are over-top of the pin locations on the back. These are a result of the injection molding process and fortunately show the exact positing of each pin. The dimples can be hard to see but are visible in good light. I ground the pins off smooth on the back side and marked the dimples with a sharpie marker.
I the drilled out the dimples to suit #8 machine screws on the drill-press. I'm suing screws with a tapered head and need to flare the holes so that the screws sit flush with the grille surface. To do this I used a conical grinding stone in my dremel:
And carefully using the dremel on a low speed I matched the hole to the tapered screw:
The screw are then held in place with nuts on the back side:
After a test fit the grilles were then sprayed with a black self-etching primer and were left to dry overnight:
I purchased some grille cloth from Rodney Dickman, it comes in two rectangles large enough for the front speaker grilles:
And to attach the cloth I coated the grille faces with 3M spray adhesive:
The fabric was laid onto the grille after the adhesive was applied and carefully positioned and stretched so that it lays flat and smooth at the corners. Heres the back side after the cloth was attached:
And after the trimming to size:
The spray adhesive is very tacky and the cloth sticks to it right away. Make sure your work area is clean.
I then used a heat gun to run a bead of glue along the back of the grille and folded the excess cloth over the back edge:
The grilles were then inserted onto the trim piece and attached with nuts.
And the extra screw length was cut off and the nuts secured using Loctite.
[This message has been edited by Sourmug (edited 05-17-2014).]
Sourmug
Total ratings: 144
Report this Post05-17-2014 04:49 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourmug
One more minor update for today, then I'm calling her quits for the afternoon.
Insulation reattached to the back of the pillar trim:
Added vinyl to the door sills:
And a GT badge added to the glove box door:
That's it, off to get ready for a friends birthday party tonight!
Nolan
fierogtlt1
Report this Post05-17-2014 11:03 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The hydro graphics look great and the extra detail on the glove box....Definitely makes me want to go redo all my interior now.
Steven Snyder
Total ratings: 106
Report this Post05-18-2014 03:17 AM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm getting ready to do my interior color change tomorrow. Yours looks FANTASTIC! I can't wait to see those parts installed!
Sourmug
Total ratings: 144
Report this Post05-18-2014 05:41 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
I'm looking forward to it too!
I managed to get the new Fiero Store trunk carpet installed along wit the new trunk seal that I purchased nearly 2 years ago:
It certainly takes some wrestling to get into the nooks and crannies and in the end it is not a perfect fit compared to the OEM carpet. It is pre-formed to the structure of the trunk though which helps all the holes have to be cut and it's pretty darn stiff. Not perfect but not bad either.
Nolan
quins&dads88
Report this Post05-18-2014 07:25 PM Click Here to See the Profile for quins&dads88Send a Private Message to quins&dads88Edit/Delete MessageReply w/QuoteDirect Link to This Post
My gaaawd man! You've motivated me in ways I only thought women could do. I've read all 6 pages and I'm keen to get my sorry arse back into the garage and work it!!! Who knows maybe one day my 88 will be as beautiful as yours! Thank you for the inspiration.
Regards
B.J.
Sourmug
Total ratings: 144
Report this Post05-20-2014 11:47 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Regards
B.J.
Err, umm Thanks, glad I could inspire you, LOL.
Sourmug
Total ratings: 144
Report this Post05-21-2014 12:07 AM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
The cup holder dilemma...
I have a TXGOOD cup holder for the centre console which I think is a great, well crafted product. I like it but I find that putting a drink in it makes it a bit hard to shift. I've spent a fair bit of time looking for options and I think most of the aftermarket options are just "bandaid" solutions. I wanted something that pulls out and is relatively concealed when closed. I settled on the 4th generation Jetta cup holder:
This unit is 6.9" wide X 5.6"front to back, pulls out just over 3" and most importantly is just under 3/4"thick. Consequently, it will fit nicely under my glove box with a bit of cutting on the dash.
Dash cut marked:
And cut using a cut off wheel in my dremel:
I drilled some mounting holes through the top and some matching but larger holes on the bottom for access to the holes for the screws. The screws will mount into the bottom of the glove box which has a 1/2" plywood frame:
Test fit without the glove box:
There are a few things to be aware of.
1. The glove box door in the open position swings under the glove box bottom by 1/4"+/- so the cup holder door has to stop before that.
2. The cup holder door swings up and cant be tight to the underside of the glove box, a spacer is needed.
3. The case of the cup holder cant have pressure points applied to pinch the case or the mechanism won't function.
Installed position , screwed in place (again, can't distort the case) and then caulked with silicone:
The back side:
Closed:
And open:
Yay, a functioning cup holder!
I'll add some coloring to the silicone but you won't really be able to see it once the dash is in the car anyways.
Nolan
Sourmug
Total ratings: 144
Report this Post05-21-2014 11:12 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourmug
Russ sent some pictures of the covered console:
Everything is done and will be hurtling its way just as slow as USPS and Canada Post can manage!
Also, the dash has started to go back in!
I think the hydrographic carbon fiber is going to look just fine.
And some more of how the cup holder looks.
Nolan
Sourmug
Total ratings: 144
Report this Post05-22-2014 10:34 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
My LED kit arrived for the tail lights, manufactured and designed by doublec4 and assembled by Danyel. Well worth the cost I'd say. Can't wait to see how the finished product looks!
Sourmug
Total ratings: 144
Report this Post05-23-2014 07:48 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, so I reassemble the dash and all the wiring is connected, no wiring modifications. My two map lights won't illuminate and there's way too much base from the performance sound subwoofer. Suggestions?
Thanks
Steven Snyder
Total ratings: 106
Report this Post05-24-2014 01:43 AM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
The map lights ground through a metal tab under one of the mounting screws. You probably painted over it.
Sourmug
Total ratings: 144
Report this Post05-24-2014 11:09 AM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't paint the center area but perhaps the clip is off. Thanks for the suggestion, I'll have a look at her tomorrow. A pile of people are coming to our house today for the father in-law's 80th birthday.
Nolan
Sourmug
Total ratings: 144
Report this Post05-25-2014 02:40 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I feel sheepish...
Steven you were on the right track, however it wasn't paint per se. Thanks again for the tip, I should have just checked it right away.
Note to self, when fastening a component through a connection that has a grounding tab use the uncoated fastener shown on the left rather than the coated one on the right. It also helps to remember the specific fasteners used...
Also, this appears to have corrected the performance sound baes level, the slider is now working too.
Sometimes it's the simplest things that just want to make you scream...
Now, onto the carpet install.
Edit to add that I have given you a +.
[This message has been edited by Sourmug (edited 05-25-2014).]
Sourmug
Total ratings: 144
Report this Post05-25-2014 05:33 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sourmug
Driver side carpet first. Started with the rubber backing which I removed from the OEM carpet. I taped it in place with duct tape to hold it in position while inserting the carpet:
Then the carpet was set in place and trimmed as needed, holes made for the seat bolts, seat belt anchors and the door trim fasteners, the carpet is easy to cut.
All in all it's a reasonably good fit but much thinner than the OEM carpet and probably won't wear as well either. It's a fairly easy install if you've never done it before, so don't let that hold you back.
I might get to the other side today, we'll see.
Thanks
Nolan
RCR
Total ratings: 102
Report this Post05-25-2014 08:42 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking good, Nolan.
You should grab the red seat belts mike myers has for sale. They'd look good with your colors.
Bob
Sourmug
Total ratings: 144
Report this Post05-25-2014 09:10 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Bob.
I saw his posting but they are shorter than the stock belts and to be honest I don't know how much excess my belts have when I'm in the car. If they were the stock length then I'd pick them up for sure.
Nolan
Sourmug
Total ratings: 144
Report this Post05-27-2014 09:38 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, the carpet, firewall cover and the door trim pieces are all in. Just waiting for my other interior goodies to arrive.
Not a great picture, I'll take better ones once the car gets outdoors.
Steven Snyder
Total ratings: 106
Report this Post05-29-2014 05:52 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am really liking those b-pillar and a-pillar covers! How durable is the finish?
