  RBS in-Limbo (extreme makeover) (Page 15)
This topic is 40 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40
RBS in-Limbo (extreme makeover) by Car-Lo
Started on: 09-25-2011 12:29 AM
Replies: 1576 (186648 views)
Last post by: sourmash on 12-30-2020 08:06 PM
Car-Lo
Report this Post08-25-2012 01:36 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Stubby79:
I've found a couple of references for us here in BC (or perhaps it's for all of Canada, but theses were BC specific): 56cm minimum. Which is about 22.5".
Thank you Stubby79 for the info , Then RBS2 be safer installing headlights on upper area even if still lower than 22.5"
Today I started on rocker panels and scoops, tweaked mock up of scoop...
Fitting old RBS rear panel
Trimming rear panel
Cutting out side scoop pieces from old rear deck lid
Viewing bottom part of scoop
Both parts of scoop
Cut rear panel in half, upper will be fiberglass onto rear clip body and lower panel fiberglass to rocker panel scoop (will be removable )
Trim to fit again
Two separate rear panels ready to fiberglass onto upper rear clip and lower rocker scoop
[This message has been edited by Car-Lo (edited 08-25-2012).]
Reallybig
Report this Post08-25-2012 04:21 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Car-Lo:
Trimming rear panel
I sure hope you dont match your socks to your briefs!
madcurl
Total ratings: 314
Report this Post08-25-2012 12:22 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Question: Were is the air intake going to be located?
Car-Lo
Report this Post08-26-2012 01:24 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where the new Mad Max scoop is, but you made me tweak it a bit
The opening before (only half air filter showing)
Lower panel cut and angled more for larger opening
Air filter has larger opening
After Clynt came over checking my work then I stopped work on scoop and help him with rear wing
Tack weld brackets on
Final weld, brackets on wing
Bolting wing on, lower wing is now removable
Long fun day
[This message has been edited by Car-Lo (edited 08-26-2012).]
Car-Lo
Report this Post08-27-2012 02:27 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today Pliogrip scoop...
The Mad Max evil dagger (front part of scoop) I like it a lot a few pics
Clynt showed up with Harley
Clynt playing with shapes and I started to get ready to fiberglass lower panel to rocker panel
Clynt now playing with tweaking front of rocker panel (old doesn't look evil enough) and put rag on sharp dagger
And finally the two are fiberglass together (lower panel to rocker panel)
Nice weekend...
[This message has been edited by Car-Lo (edited 08-27-2012).]
carnut122
Total ratings: 83
Report this Post08-27-2012 09:56 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
This thread just keeps getting better!
turbodad
Report this Post08-27-2012 11:09 PM Click Here to See the Profile for turbodadSend a Private Message to turbodadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe cut out and permanently attach the door section with "the blade"? Or make a false secton with the blade attached that the door lowers behind. Does it make sense?
doublec4
Total ratings: 150
Report this Post08-28-2012 12:21 AM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
So freakin cool. This thing is going to be a piece of art.
Car-Lo
Report this Post08-28-2012 03:12 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Thanks carnut122, Clynt and I are having lots of fun with Mad Max
Thanks doublec4, RBS2 is slowly shaping into a weapon
Today Clynt came over to repair his bubble top, first we played with headlights, visualizing and not to much got done on RBS2
Anyway pics of the day...
Notice rag on "the blade", Clynt doesn't want to get hurt
We jacked up Clynt's bubble top
Clynt's driveway ripped and folded bumper under, troyboy's wheelies would've helped
He drove here with coat hanger tie
RBS2 was a parts car again, this time front wheel liner (Clynt's mounting holes ripped out)
End of day, we got Clynt's ride finished
85SEnochie
Total ratings: 58
Report this Post08-28-2012 10:52 AM Click Here to See the Profile for 85SEnochieSend a Private Message to 85SEnochieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like the T-short
Love The Excitement! https://www.fiero.nl/forum/Forum1/HTML/068738.html
Reallybig
Report this Post08-30-2012 03:55 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't catch it the other day but darn near wet the computer chair laughing this time!
Keep up the great work and entertainment!
85LAMB
Report this Post08-30-2012 08:11 PM Click Here to See the Profile for 85LAMBSend a Private Message to 85LAMBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey
I saw this video and though about your ride
The good part starts at 7:40
http://www.youtube.com/watc...ndex=26&feature=plcp
Car-Lo
Report this Post09-03-2012 01:07 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 85LAMB:
Hey
Thanks for that great video 85LAMB, I sneaked idea from Lambo's lower wing and exposing RBS2 fat 325 Michelins
Back to RBS2...
Well not to much play with Mad Max, Clynt's had to install a rebuilt Camaro power rac (old one was leaking) I had to help him
After Clynt's ride, we had a scoop huddle, maybe adding gill scoop on upper panel, more air intake (but it may look too goofy)
Here's the gill scoop today...
Without gill
Worm's view, lower scoop
Car-Lo's view
[This message has been edited by Car-Lo (edited 09-03-2012).]
Reallybig
Report this Post09-06-2012 10:49 PM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
No progress reports? It must be raining on the coast.
jetsnvettes2000
Report this Post09-13-2012 07:11 PM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey!! get to work posting pics!!! I need my fix of ideas to steal!!!!
Any progress??????
testigo007
Report this Post09-13-2012 09:52 PM Click Here to See the Profile for testigo007Send a Private Message to testigo007Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is ridiculous! Put on your red socks and red drawers and get to work! lol j/k
Car-Lo
Report this Post09-14-2012 12:51 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
will do !
Actually I was helping Clynt with body work on his truck and not to much to show and post on RBS2
Today we tweaked rear wing and final welding again...
Clynt welding brackets on frame to support rear rocker panels.
I also extended "The blade" 1-1/2" longer for a deeper cut will post this weekend
[This message has been edited by Car-Lo (edited 09-14-2012).]
testigo007
Report this Post09-14-2012 10:23 AM Click Here to See the Profile for testigo007Send a Private Message to testigo007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the update and looking forward to the next batch of pics. :-)
Car-Lo
Report this Post09-16-2012 02:51 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally stopped raining and a little progress...
We started playing with upper rear wing, Clynt grinding tack weld off, to angle upper wing same as bottom wing
Turned upper wing up side down to copy bottom angle and tack weld
Tack weld 6-1/2" spacer (will be removed later)
Making upper wing brackets
Tack on brackets
Bit more tack welds
Final welding
Grinding welds smoother
Bolting on upper wing
Good day, upper wing is on, just a little tweaking into shape later
andreww
Report this Post09-17-2012 07:46 AM Click Here to See the Profile for andrewwSend a Private Message to andrewwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking amazing Car-Lo. Will you be working on this over the winter? Are you planning on having it ready for next summer?
Car-Lo
Report this Post09-17-2012 12:24 PM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by andreww:
Looking amazing Car-Lo. Will you be working on this over winter? Are you planning on having it ready for next summer?
Thank you so much andrew. Yes, we'll be working over most winter, the deadline is now for next summer, but that's what I said last year
Yesterday no playing with RBS2, Clynt's friend had free passes for Mission Race Track (about 1 hour from Vancouver), so we went to see some drag racing...
We walked around looking at all the cool race cars
madcurl
Total ratings: 314
Report this Post09-17-2012 02:10 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Taken a break is good. We can all learn a lesson or two from a dog.
Sometimes we come back from a break with newer ideas.
[This message has been edited by madcurl (edited 09-17-2012).]
Stubby79
Total ratings: 58
Report this Post09-20-2012 10:21 AM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
That thing is a work of art! You should incorperate it in to the final design!
Car-Lo
Report this Post09-23-2012 12:40 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trimming more off frame rails
Cut off exhaust tips and moving them inboard
Tips cut to fit inboard and clamped on lower wing
Tack welding tips, right side is already tacked inboard
Tips tacked inboard and ready for welding
Removing exhaust for welding
Exhaust all welded up and grinding welds smoother ready for chroming exhaust
[This message has been edited by Car-Lo (edited 09-23-2012).]
jaredmurray88
Report this Post09-23-2012 08:59 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
maybe not chrome but have you given thought to the DIY powder coat stuff ya do in the oven? Doing the exhaust in a bright color that contrasts the body would be sweeeet! ALL HAIL RBS2!!!
Car-Lo
Report this Post09-24-2012 12:57 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you so much jaremurray88 for your input you are so right about a bright color and today I made a mistake by painting exhaust matt black
Maybe I can repaint exhaust red so it will have something bright in background against all blacked out rear
This is what I used today...
Overall view, exhaust installed
Mean while back in the wheel well, fiberglass 3" filler liner between rear clips to join them together
Bit more sanding
Primed filler liner
Installed wheel liner, also side view of exhaust and wings
Next: finish rocker panel and scoop
[This message has been edited by Car-Lo (edited 09-24-2012).]
bubbajoexxx
Total ratings: 112
Report this Post09-24-2012 10:02 AM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
carlo that door spear needs to be longer it is detracking from the upper door shape and looks chopped short it should extend as far as the middle of the door at least great build otherwise
[This message has been edited by bubbajoexxx (edited 09-24-2012).]
testigo007
Report this Post09-24-2012 08:14 PM Click Here to See the Profile for testigo007Send a Private Message to testigo007Edit/Delete MessageReply w/QuoteDirect Link to This Post
carlo... I've read that many exotic cars these days are using fake tips on the exhaust... they look really good, but are not functional... You could put some cool octagonal tips around your tailpipes with a screen covering the actual pipes. :-o http://www.supertightstuff....ust-pipes-not-tight/
[This message has been edited by testigo007 (edited 09-24-2012).]
Car-Lo
Report this Post09-25-2012 01:21 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Stubby, there you go...
Thank you bubbajoexxx for suggesting a longer spear
Today I did a mock up of door spear 5-1/2" longer and it's looking a lot better, thank you
Back to the rear, just have to trim wheel well liners to expose the 325s
Thanks for the tip testigo007, that is a pretty trick idea I was thinking of fabricating something octagonal like that later on, as for now I'll just use what I have
[This message has been edited by Car-Lo (edited 09-25-2012).]
bubbajoexxx
Total ratings: 112
Report this Post09-25-2012 11:13 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
now that fits the body desine real well that mates with the door line just right man with short spear go hungry man with long spear gets the meat
Quad GT
Report this Post09-26-2012 11:06 AM Click Here to See the Profile for Quad GTSend a Private Message to Quad GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car-lo you are doing a fantastic job, trust me you dont need any advice from Bubba the hack scam artist
madcurl
Total ratings: 314
Report this Post09-26-2012 02:01 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's several examples here: https://www.fiero.nl/forum/F...6/HTML/060802-3.html
jetsnvettes2000
Report this Post09-26-2012 08:25 PM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Really! must you spread poo on such a great thread? not really cool or needed take the gripe someplace else and let Car-lo have his time in the light.
Some people geez man sorry Car-lo you are doing great don't let the haters derail this thread!!
jaredmurray88
Report this Post09-26-2012 10:51 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Although I don't much care for bubbajoe either but I do agree it does look better with the "reaper" {little funny there sorry} farther down the door. I always thought something as just a tad bit off but couldn't put my finger on it. good eye my man
jaredmurray88
Report this Post09-26-2012 10:54 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
jaredmurray88
Member since Mar 2011
Oh and could I get a pm with a pic/info on your buddy Clynt's hood scoop on his fiero? Is it functional as a heat extractor or just for looks?
Quad GT
Report this Post09-27-2012 02:19 AM Click Here to See the Profile for Quad GTSend a Private Message to Quad GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bro this is the first thread I open up when I log on to the forum
I meant no disrespect to my paisanos work which is outstanding
Once again I'm sorry
But when I see that SOB posting on here I get pissed off
He screwed me out of over $2500
Looking forward to more updates
Car-Lo
Report this Post09-30-2012 12:41 AM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you so much Madcurl great pics of show I didn't know this thread even existed, I'll have to surf more here on PFF
Thanks for asking jaremurray88, Yes Clynt's scoop is Functional, pic of Clynt's (bubble top) heat extractor
Today I had a chance to play...
Wheel well gap was not even
Adding a (subtle) flare on fender and making gap even
Gap is even all around wheel
Fiberglass (Evercoat SMC resin)
Sanding
Clynt is always checking my work
Using Evercoat Fiber Tech filler
Meanwhile Clynt is playing with bubbajoe's spear, Clynt wants to make it a bit longer
Smoothing out rough filler
Clynt is now playing with roof edge, wants to angle edge to match fastback pillars
Tomorrow I'll finish wheel well gap and flares
Today I did a bit more sanding, (needs one more pass with filler)...
Before
After
[This message has been edited by Car-Lo (edited 09-30-2012).]
355Fiero
Report this Post10-01-2012 01:34 PM Click Here to See the Profile for 355FieroSend a Private Message to 355FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car-Lo;
Rear flare looks really good. A possible suggestion. What about working the lines on the flare to keep the hard edges from the body lines in tact as it goes into the flare? You could add in a bit more duraglas to fill out the front and rear edges to put in the hard line to match up with the body piece. I think that would finish it off really well and keep the body lines end to end.
Keep it up and keep posting pics
Don
Pete Matos
Report this Post10-01-2012 11:21 PM Click Here to See the Profile for Pete MatosSend a Private Message to Pete MatosEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have just three words for this thread....... MAD FREAKIN' SKILLS!! Way to go that thing is gonna be the most over the top fiero ever made anywhere.... peace
Pete
Xyster
Report this Post10-01-2012 11:41 PM Click Here to See the Profile for XysterSend a Private Message to XysterEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a spectacular build. While part of me is sad that it looks so little like a Fiero, another part is truly amazed by your skills. I hope your hard work helps younger generations want to join the hobby and perhaps save a Fiero.
As Dennis Gage says "Don't crush 'em. Restore 'em."
