  Project Genisis Lo Budget 3800SC (Page 11)
Project Genisis Lo Budget 3800SC by hercimer01
Started on: 05-05-2011 01:13 AM
Replies: 415 (52691 views)
Last post by: hercimer01 on 09-19-2020 11:13 AM
kcn0
Report this Post06-20-2016 01:49 PM Click Here to See the Profile for kcn0Send a Private Message to kcn0Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice ride. I live near you and would like to see it whenever you are available. Check your PMs for my contact info.
Thanks!
RCR
Total ratings: 102
Report this Post06-21-2016 01:03 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by hercimer01:
The mirror is Gentex which is in alot of different car makes. I found theses on a 1999 Buick LeSabre Limited. Personally I don't like the looks of the Corvette side mirrors because of the telescoping look which to me doesn't flow with the styling of a fiero. These are similar, fiberglass and easily modded to fit right. (I hope)
Maybe these will work. They have power,defrost and auto dim.
Have you mounted the mirrors yet? Pics??
Bob
hercimer01
Report this Post06-22-2016 01:47 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry. Life got busy. The rear view mirror is in. MP3 Pontiac CD player to. I put in Dynamat also with 2 layers on the rear firewall even under the computer must.
I will post pics tonight.
hercimer01
Report this Post09-21-2016 12:46 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
adm927
Report this Post09-21-2016 01:44 AM Click Here to See the Profile for adm927Send a Private Message to adm927Edit/Delete MessageReply w/QuoteDirect Link to This Post
looks pretty fast so what was the time? Was it quarter mile, or eighth mile?
hercimer01
Report this Post09-22-2016 12:07 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
This was this past weekend on premium with junk in the trunk.
[This message has been edited by hercimer01 (edited 09-22-2016).]
hercimer01
Report this Post09-22-2016 12:16 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Member since Mar 2008
This was 2 years ago. The car was completely empty (3000LBS w/ me in it) and on race gas
hercimer01
Report this Post11-18-2016 01:05 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I put some LEDs in. Nice.
Before
After notice the faded needles
[This message has been edited by hercimer01 (edited 04-04-2017).]
AustinH
Report this Post09-22-2018 12:01 AM Click Here to See the Profile for AustinHSend a Private Message to AustinHEdit/Delete MessageReply w/QuoteDirect Link to This Post
The needles before and after.
Testors Pactra RC78.
hercimer01,
How did you get the needles on and off without messing the position of the coil up? How did you recalibrate the true position of the needle's offset on the coil (NOT the potentionemter way)??
hercimer01
Report this Post12-15-2018 12:16 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry it took so long to post.
First I took a good picture of the position of the needles resting position before i started. I popped them off with an upholstery tool, protect the gauge face with a piece of paper under the tool when your prying. They come off ok, it's a little unnerving but doable. When you put them back on, just be sure and put them back where they were when you started. You can verify the speed with your GPS app in your phone and the rest of them aren't critical for position. I haven't noticed anything worthy of concern. Since you have a 3800SC, I used the Torque app to verify the tach. You might have to reposition the needle so its correct.
[This message has been edited by hercimer01 (edited 12-15-2018).]
hercimer01
Report this Post12-25-2018 01:26 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still here. I've been painting Ed's 88GT for the past year, Mine was in his garage. I really missed it, but i have stocked up a few parts for it. Now I just have to get off my but and do it.
Headers
And Gen 2 headlights. One of my Gen 1 headlights melted.
[This message has been edited by hercimer01 (edited 12-25-2018).]
hercimer01
Report this Post01-03-2019 11:12 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post08-19-2019 11:12 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, i'm putting in the OEM subwoofer system with a Tang Band W5-1138SMF 5-1/4" sub.
These are corners from an electrical box I cut up.
I went with the larger metric plastic screws for the sides.
I got the exit wrong for the wires, I have too cut it open and reroute them to the back.
Also I read somewher to tune for the Tang Band the port tube needs to be trimmed back 2" and poly fill needs to be added inside the tube and enclosure. Anyone see this before?
hercimer01
Report this Post08-11-2020 11:50 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I put a stock nose back on.
hercimer01
Report this Post08-31-2020 10:21 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post09-19-2020 11:13 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sold!
12.840@104.8 MPH Intense-Racing 1.9 rockers, 3" exhaust, 3.4 pulley, ZZP tune and 18 year old tires.
88 Coupe under construction SOLD
88 formula 3.4L 4t60 swap SOLD
88GT resurrection in progress.
