  Project Genisis Lo Budget 3800SC (Page 9)
Project Genisis Lo Budget 3800SC by hercimer01
Started on: 05-05-2011 01:13 AM
Replies: 415 (52708 views)
Last post by: hercimer01 on 09-19-2020 11:13 AM
hercimer01
Report this Post01-18-2014 04:58 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK, so I got the new tach.
I modded the housing so it will fit.
I put the 1Meg ohm trimmer pot in place of R14. This tach is the less desirable one because of the face so its not covered as far as I can find. The PC board is different than most covered MODs.
This is mine and how I did it.
Edit: Make sure to run the Tach Gauge Ground wire (black) to the ECM C1 pin 13 MAP ground. I ran mine to the back of the gauge and it showed over 20PSI of boost which is not correct.
Edited because i just tried it and it worked.
[This message has been edited by hercimer01 (edited 09-21-2014).]
hercimer01
Report this Post01-18-2014 04:59 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Member since Mar 2008
hercimer01
Report this Post01-18-2014 06:21 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
This is the car running
I still have to wire in the Green wire to the MAP signal.
I calibrated it with the Torque App. ( there's an app for that LOL)
hercimer01
Report this Post01-23-2014 01:42 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
The needles before and after.
Testors Pactra RC78.
nosrac
Total ratings: 51
Report this Post01-24-2014 04:26 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you log Fuel Trim Cell with Torque? I'm doing some tuning and can't find that PID.
hercimer01
Report this Post01-25-2014 03:44 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have seen the PIDS for fuel trim on Torque, I would imagine they could be logged.
hercimer01
Report this Post01-25-2014 03:46 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
This is what I came up with.
I used GIMP photo-editing freeware to edit them.
https://drive.google.com/fi...Tkk/edit?usp=sharing I printed directly from this to plain white paper.
This pic is only a Low Res JPG
Courtesy of 85GT_3800SC
This is the back-lighting. I think it looks OK printed onto white paper then with the gauge face glued on to it with a light coat of contact spray.
https://docs.google.com/fil...RHdhOFY2WmFwRTg/edit
These are the GIMP Files For editing If anyone wants them.
Gimp Free Ware.
http://www.gimp.org/
[This message has been edited by hercimer01 (edited 02-01-2014).]
hercimer01
Report this Post02-01-2014 05:15 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm trying to adjust the boost gauge and it seems to be acting weird.
Maybe someone could tell me if this correct?
Here are some reference voltages.
http://www.robietherobot.com/storm/mapsensor.htm
This is with the key on, engine off.
This is with the engine at idle.
Something seems to be wacked out.
I have a ZZP tune with a 3.4 pulley. Otherwise stock.
If anyone has any ideas, please help.
hercimer01
Report this Post02-02-2014 12:43 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Its all back together for now. I need to recalibrate the tach one last time because I redid the overlay again.
hercimer01
Report this Post02-02-2014 12:46 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
I checked my Tahoe with Torque and it reads the same at idle. Like -20PSI
fieroaddicted
Report this Post02-02-2014 03:51 PM Click Here to See the Profile for fieroaddictedSend a Private Message to fieroaddictedEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is this gauge out of? It's probably ok I would think. I take it the car is running well?
Nice build by the way... I see i have the same "Eaton Inside" sticker on my back window. lol
hercimer01
Report this Post02-02-2014 09:20 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the car has never ran better. Knock on wood.
I got the gauge on eBay from Fieroaddiction. It's a later one that's all I know.
hercimer01
Report this Post02-04-2014 12:03 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's hard getting the lighting just right. The overlays look good but getting the distribution is a challenge.
hercimer01
Report this Post02-08-2014 01:36 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Notice I installed the Performance shift light too!!
Before. Notice how faded the needles are.
After.
hercimer01
Report this Post03-02-2014 10:39 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a low mileage L32 for it yesterday, 67K. (With wire harness and computer) From an 05 GTP. The PO put a Gen 3 supercharger on it because of the drive by wire. He was going to swap it into a truck but never did. I will port it and put a N* throttle body I already have.
88 Coupe under construction
[This message has been edited by hercimer01 (edited 06-28-2015).]
hercimer01
Report this Post03-12-2014 01:14 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got the Gen V Back on today.
I got some nice bolts for it.
[This message has been edited by hercimer01 (edited 03-08-2015).]
hercimer01
Report this Post03-17-2014 11:43 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
It is an L67. I was had.
[This message has been edited by hercimer01 (edited 03-20-2014).]
hercimer01
Report this Post03-31-2014 02:38 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I picked up a set of INTENSE-Racining 1.9 Ratio Rockers in the Mall.
I am literally afraid to drive the car on the streets now, it was scary fast before.
I started it and it sounds good,but haven't test driven it yet.
I didn't want to wake up the neighbors at 11:30 on a Sun. night.
I cleaned out the stud holes with a QTip and compressed air
Then I torqued them to 11 FT Lbs, +90 deg with red Lock Tight.
Then I started it up after I did the other side just the same.
hercimer01
Report this Post04-20-2014 12:51 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got to race it today! I got into the twelves!
[This message has been edited by hercimer01 (edited 05-26-2014).]
ignorant prodigy
Report this Post04-21-2014 04:22 PM Click Here to See the Profile for ignorant prodigySend a Private Message to ignorant prodigyEdit/Delete MessageReply w/QuoteDirect Link to This Post
just read the whole post. worth the read, nicely done!
hercimer01
Report this Post05-26-2014 02:55 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
My nose badge fell off. So I put this on.
hercimer01
Report this Post06-02-2014 01:15 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
There is Archie.
And the run at the Dells.
[This message has been edited by hercimer01 (edited 06-02-2014).]
Archie
Total ratings: 547
Report this Post06-02-2014 07:46 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is Archie.
I had fun running tandem with you on the way up to the Dells Saturday morning.
Archie
hercimer01
Report this Post06-03-2014 01:08 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post06-03-2014 01:30 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Just a note, I got 31 MPG on the highway coming back. It was 26 MPG before I added the rockers.
solman105
Report this Post06-29-2014 11:36 AM Click Here to See the Profile for solman105Send a Private Message to solman105Edit/Delete MessageReply w/QuoteDirect Link to This Post
I love the thread; I'm just starting my 3800sc build, gathering all the necessary pieces now.
My wiring harness is mostly complete; I got it out of a pick and pull but I had accidentally (absent-mindlessly) cut it at what I think was the ABS module and past the relay box going into the passenger compartment. I haven't broken down the harness yet, but I was wondering if you ran into any problems in either area? I'd like to hope that the ABS is unnecessary and the other wires that I cut went to the display, car power, and OBDII connector.
Thanks!
my-fiero
Report this Post07-02-2014 08:19 AM Click Here to See the Profile for my-fieroSend a Private Message to my-fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
How?
is this whit a bluetooth ?
Please more info
Thanks
jmbishop
Total ratings: 169
Report this Post08-06-2014 04:12 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, you can buy the adaptor for $10-$20 on ebay, just search elm327. The app is free unless you decide to spend a few extra $ for the pro features. I bought the pro version just because it was a great app and wanted to give back to the developer.
[This message has been edited by jmbishop (edited 08-06-2014).]
hercimer01
Report this Post09-22-2014 03:52 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
My next Mod.
I made this drawing today. I went to the pick and pull and got a one touch module for the windows from a 97 Bonneville and some lighted switches from a Grand Prix.
[This message has been edited by hercimer01 (edited 09-26-2014).]
hercimer01
Report this Post09-26-2014 11:34 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
This was my mock up. It was all crimped together with cheap splices, but that was just for testing. When I installed it I did solder it all together. I cut out the old window switch socket and and soldered in this harness. I only put the one touch on the drivers side to keep in line with stock appearances. The passenger switch was just the switch. I ended up epoxying the switches into the switch panel after i trimmed it up a bit.
hercimer01
Report this Post09-27-2014 12:10 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by hercimer01 (edited 09-28-2014).]
johnyrottin
Total ratings: 85
Report this Post09-28-2014 08:45 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are the window switches out of? What did you have to modify to get them in?
hercimer01
Report this Post09-28-2014 08:00 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
The switches are from a 98 Grand Prix. The one touch module is from a 97 Bonneville. I had to trim the opening for the switches a bit with a file. Then I used 60 second epoxy on the back side to hold them in. I finished off the trim plate with a coat of DupliColor Trim Paint. I also glued the center console rubber back together and painted the ashtray and cigarette lighter plate.
hercimer01
Report this Post10-26-2014 11:57 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ive been tinkering again. Some sleepy HIDs will be on the stove for this winter.
The grey box is a variable power supply. I'm running 13.5v to a 270 ohm resister which drops it down to 6.6v.
Each diode can handle 3.3v max and are wired in series.
I used this as a reference.
[This message has been edited by hercimer01 (edited 10-27-2014).]
hercimer01
Report this Post10-27-2014 12:04 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are red angel eyes illegal? I want to put some in at least for the shows.
RCR
Total ratings: 102
Report this Post11-02-2014 06:09 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool project I've always wanted to do...
FYI, 3.3V is not the max voltage for the LED. It is the forward voltage drop across the LED. The thing to be concerned about is current. Add the two Vfwd's for the LEDs and subtract from the source voltage. This difference is the voltage across the resistor. Divide this by the resistor value to get the current. Also watch the power across the resistor, which is the current squared times the voltage across it.
Bob
knarfluna
Report this Post12-28-2014 03:58 PM Click Here to See the Profile for knarflunaSend a Private Message to knarflunaEdit/Delete MessageReply w/QuoteDirect Link to This Post
WOW
Great read and pics!
I am just starting my swap....having somebody do it for me...at least the major stuff.
Im pumped
I may have a few questions a bit later
thanks
hercimer01
Report this Post01-22-2015 02:08 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post03-15-2015 02:13 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used Danyels 90MM buckets with my 60MM projectors. I had to modify them.
hercimer01
Report this Post04-14-2015 01:54 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I installed a boost gauge in the pillar. Nothing fancy. Next i need an AFR gauge so I can drop the pulley size more.
It's running 8-9 PSI boost.
