  Enterra "Dark Shadow" Restore Thread (Page 11)
This topic is 17 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17
Enterra "Dark Shadow" Restore Thread by Lady Lisa
Started on: 06-11-2012 09:44 AM
Replies: 640 (43759 views)
Last post by: FIERO JOHN-WI on 04-15-2019 08:49 PM
Archie
Total ratings: 546
Report this Post10-21-2013 03:24 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let's go to the next page (I own this one)
Update.....
Before we can paint the engine compartment, we needed to layout where the hardess, cables & lines are going to be routed.
The fisrt thing in prepping te engine compartment for paint was to weld closed the small holes from the spot welds we drilled out. Then grind & sand those spot welds. then cleaning the compartment & hitting it with sanding paper & 3M pads to scuff the surface.
In the meantime we were also custom bending & connecting the hard lines for the P.S. rack.
Final preping for primer. We're going to paint the on the EOM front bulkhead & on both sides of the bulkhead cover.
The on Friday, just before we left, we shot the primer....
Right now we're shooting the color in the engine comartment.
Archie
troyboy
Total ratings: 154
Report this Post10-21-2013 05:10 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Total ratings: 546
Report this Post10-21-2013 05:43 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by troyboy:
No kidding.
This is going to POP!!!!!
Spraying the clear now.
A
Archie
Total ratings: 546
Report this Post10-23-2013 10:49 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 1988holleyformula:
No boogers on the shiny parts!
Thanks for the updates and all the pictures, I'm sure I'm not the only one that appreciates seeing the work that's being done to this car.
Pretty artistic don't you think.
Kinda' looks like a conehead.
Archie
Total ratings: 546
Report this Post10-23-2013 11:17 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Member since Dec 1999
Pearl White.
We painted the insides of the frame rails Gloss Black & then masked them off & painted 2 color coats, 2 pearl coats & 2 clear coats.
Then removed the masking.
Let's see if we can see the Pearl with the camera in the sunlight
Ok, back to work
Putting black edge trim around the bulkhead cover.
Putting insulatin on the front bulkhead (before installing the bulkhead cover). Also routing some wires that will be hard to do with engine in car.
Front side of bulkhead cover ready to go on.
Install
As you may have noticed by now, the color theme for this car is Pearl White & Gloss black. We've removed all of the brake lines & wire brushed them & painted them gloss black. It's all in the detail. We'd be getting hate mail if we didn't.
Also, the chrome interior trim pieces came in from plater.
Archie
Report this Post10-24-2013 12:40 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Damn, I can't help but wonder what all this "detail" is going to cost in the end.
troyboy
Total ratings: 154
Report this Post10-24-2013 07:13 AM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Total ratings: 546
Report this Post10-24-2013 11:45 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
You know, that's really the question. & it's a question on both sides of the equation.
For the owner, where do you draw the line?
You just painted a complete engine compartment, do you want everything in that compartment to look as good as you can? For example, the brake lines were in real good condition. They just had a little surface rust on the coils. Do you just put them in or do you wire brush & clean them & paint them?
For the builder, there are 2 questions, 1) If we don't clean & paint it, will the owner be mad when he sees it? or 2) If we clean & paint it, will the owner be upset that it raised the total cost?
These kinds of questions come up 50 or more times in each build. If we contacted the owner ecah time something like this came up, we'd spend as much time discussing it as we would spend doing it.
In this case, it was an easy choice for us because the fluid in the brake system was real bad & we wanted to clean out the insides of the lines anyway.
In this engine compartment, we had the same types of questions on the charcoal cannister & the fuel fill pipes. Do we leave them dirty or with a little surface rust or do we re-burb them?
The good thing about building a 2nd. car for someone like Troy & Lisa, is that we already know that Troy wants stuff done right.
Our biggest worry, is that we miss some detail or opt not to refurb some detail. Then a year after the car is done, The customer calls to point out that we spent all that money & you didn't refurb the dumafliggie up under muffler bearing bracket.
And so it goes.
Archie
Fierostarvin
Report this Post10-24-2013 10:09 PM Click Here to See the Profile for FierostarvinSend a Private Message to FierostarvinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie, you have posted in other builds you make fiberglass sheets on formica, do you spray a releasing agent on first? thanks Jeff
Archie
Total ratings: 546
Report this Post10-25-2013 07:10 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, we wax the surface (like you would wax the surface of a mold) before laying down the Fiberglass.
Archie
troyboy
Total ratings: 154
Report this Post10-29-2013 09:25 AM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok guys Lisa has a question, should we have Archie paint the front compartment pearl white to match the engine compartment or just leave it stock (black). IMO I think it will look odd black
Edit: forgot to ask , Archie any pics with the engine in the car?
[This message has been edited by troyboy (edited 10-29-2013).]
Archie
Total ratings: 546
Report this Post10-29-2013 10:51 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I thought I sent you some pics but guess not.
Here we are putting the engine in the car for the last time.
Then we are working on making as many of the connections from the engine assembly to the chassis.
Here we are making up the AN lines & fittings to connect the fittings for the transmission cooling lines. We also did the same type of fittings for the fuel lines etc.
We wanted to get the car on the lift, to get to things up under the car, so we put the wheels on.
The stance is not too bad. The rear is adjustable with the coil overs we have on the car. And after the car settles down on the suspension, we may want to put on a set of Rodney's 1" lower ball joints. We'd like to drive it before we do that.
On the lift to continue assembly
Front suspension.
We painted the old trunk heatshield (with some high temp paint) & mounted it to the new trunk floor.
At this point we have all of the cooling system & pipes fabricated & connected. We also have all the new hardlines isolated & secured. We have the exhaust system installed. And everything else we can do under the car right now is completed.
Except for the engine wire harness, ECM & TCM all of the connections needed in the engine compartment are also done.
The pictures I took of a few of the above items, like the exhaust & cooling system connections, didn't record properly on my camera. So I'll have to take some more pics the next time we get the car up in the air.
We also have widened the front mount battery tray for the chrome Optima battery hold down & are installing it today.
We have installed the new headlights you bought.
And, we are finishing up the wiring for the tail lights.
Troy, call me today if you can.
Archie
Lady Lisa
Report this Post10-29-2013 11:48 AM Click Here to See the Profile for Lady LisaSend a Private Message to Lady LisaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie, It's gets better every time I look at the pics. It's sick! As far as the front compartment is concerned, my vote is WHITE.
tesmith66
Total ratings: 135
Report this Post10-29-2013 12:56 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
What's the steering rack from?
Nevermind, I found it. Corvette ZR-1 (I'm assuming early 90's version, not the current one).
[This message has been edited by tesmith66 (edited 10-29-2013).]
troyboy
Total ratings: 154
Report this Post11-01-2013 09:25 AM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately Archie has informed me that the front compartment is already reassembled with the funky old black paint and at this point it would drive my budget up quite a bit to redo it in white. Any bets as what will happen before this car comes back to NY. . Unlike the choptop this is a one trip build and needs to be as compleat as possible before the trip home, good thing I have a auto storage unit near your shop . Sorry Archie but you should know me by now, so she can rest up in the storage unit when we complete phase one and redo the front compartment before we ship it home.
PS my motivation:
[This message has been edited by troyboy (edited 11-01-2013).]
exoticse
Total ratings: 108
Report this Post11-01-2013 10:37 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
The car is looking great !
Lisa you are one lucky lady. I hope my wife does not see this thread !!
TXOPIE
Report this Post11-01-2013 04:36 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Troy...a perfectionist like myself! You know you are going to have to get the front painted first...or it will drive you crazy!
Unfortunately Archie has informed me that the front compartment is already reassembled with the funky old black paint and at this point it would drive my budget up quite a bit to redo it in white. Any bets as what will happen before this car comes back to NY. . Unlike the choptop this is a one trip build and needs to be as compleat as possible before the trip home, good thing I have a auto storage unit near your shop . Sorry Archie but you should now me by now, so she can rest up in the storage unit when we complete phase one and redo the front compartment before we ship it home.
PS my motivation:
Bozzie
Report this Post11-02-2013 10:15 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Builds like this are the stars that i shoot for. Amazing job and ups the anti for us all
Boz
http://i252.photobucket.com...ec/2007_12240001.jpg
Carcenomy
Report this Post11-04-2013 05:27 AM Click Here to See the Profile for CarcenomyClick Here to visit Carcenomy's HomePageSend a Private Message to CarcenomyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd almost completely forgotten about this build. I'm glad to see the light at the end of the tunnel, that is gonna be one suh-weet Enterra when it's all done.
Troy, glad whatever the situation was is resolved and you're back, I'd noticed some disappearing posts and was legitimately worried about you dude!
troyboy
Total ratings: 154
Report this Post11-04-2013 04:15 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys its been a fun trip building the car for the wife.
whadeduck
Total ratings: 103
Report this Post11-04-2013 08:27 PM Click Here to See the Profile for whadeduckSend a Private Message to whadeduckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah. But what are you going to have to do next to top this one? Methinks you've set the bar too high. lol
Whade' "Darkwing" Duck
Fieroless (11/18/12)
Archie
Total ratings: 546
Report this Post11-07-2013 03:57 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time for an update
We've been putting the body together for the last time & working on wiring the door panel controls.
Someone had been asking about the mounting of the seats.
We had the drivers seat out to get ready for the carpeting & to remount the seat controls & here are a few pics of the seat mounting.
We had to put new mounting bosses on the floor.
Seat controls remounted to the front of the seat.
I think that I had already posted that we had swapped in a set of the dual pop up lights.
When we installed the hood we found the most unexpected thing.
The Enterra hood is a fiberglass outter shell & a fiberglass inner shell & uses Fiero headlight doors. When we installed the hood, we found that Enterra had made their hood with the headlight doors 1/2" closer together than stock Fiero headlight door.
We couldn't raise the headlights with the hood on. We had to modify the headlight mountings to move them inboard to where they didn't hit the hood as they were going up.
Why Enterra would make them a half inch closer together, I coldn't tell you.
We made a lever for it & mounted Lisa's new shift knob.
We drilled holes to bring the power mirror wire into the car & did a bunch of wiring work on the PW's, PDL's & Power Mirrors. The power mirror control was bad but we got another one in today. (we'll try is first of the week)
We also got the front compartment battery tray & chrome hold down all done.
And Then Guess What
Cleaning & scrubbing a couple of times over....
Cleaning & scuffing up the plastic parts
It looks like the girl is getting a new dress put on....... don't look under that skirt.
Archie
troyboy
Total ratings: 154
Report this Post11-07-2013 05:27 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank You Archie!!
PS. The new OEM fiero T Top P seals came in today and look great!
[This message has been edited by troyboy (edited 11-07-2013).]
Lady Lisa
Report this Post11-07-2013 08:36 PM Click Here to See the Profile for Lady LisaSend a Private Message to Lady LisaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie, thanks for painting the front compartment. It 's gonna look beautiful...
exoticse
Total ratings: 108
Report this Post11-07-2013 08:53 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie, troy, or lisa,....how deep is the lip on the front wheels ??
About to widen my fronts and i like that look.
Archie
Total ratings: 546
Report this Post11-07-2013 10:38 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're welcome.
Before we left the shop today we had it in primer, so tomorrow is the painting day.
Then Monday we'd like to get it back together.
Archie
troyboy
Total ratings: 154
Report this Post11-09-2013 07:18 AM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Before we left the shop today we had it in primer, so tomorrow is the painting day."
Archie
Fierofreak00
Total ratings: 170
Report this Post11-10-2013 09:08 AM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Archie
Great minds think alike, when I did mine, I also had to modify my front mount battery box to get the billet Optima hold down to fit. Nice quality product and gives the front compartment a little bling. -Jason
Archie
Total ratings: 546
Report this Post11-10-2013 09:31 AM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some more pics from Friday
Primer coat then Base coats & Pearl coats
More on this pic later...
Clear coats applied
Archie
[This message has been edited by Archie (edited 11-10-2013).]
motoracer838
Total ratings: 83
Report this Post11-10-2013 11:10 AM Click Here to See the Profile for motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
V-8 Archie's, raising the bar with every big build.
Joe
troyboy
Total ratings: 154
Report this Post11-10-2013 03:00 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice , I like your hold down tray. Who is your Billet tray made by?
[This message has been edited by troyboy (edited 11-11-2013).]
exoticse
Total ratings: 108
Report this Post11-10-2013 04:19 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Archie,
Whose choptop is that in the background ??
troyboy
Total ratings: 154
Report this Post11-11-2013 08:04 AM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joe
Archie and crew are doing a great job once again and Lisa is ecstatic with the progress of her sweet ride.
Archie check your email for info on the gauge setup.
Fierofreak00
Total ratings: 170
Report this Post11-11-2013 11:39 AM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! I bought it off from an ebay company called Wieland Custom Machine the user name is guyincognito2. They sells all types for different Optima bats. I wanted to get one from an off road company (their customer service sucks so I won't mention their name) that had a really cool logo, but their shipping price was more than the tray. -Jason
[This message has been edited by Fierofreak00 (edited 11-11-2013).]
Archie
Total ratings: 546
Report this Post11-11-2013 07:26 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spent all day cleaning & painting parts & putting the front end back together.
Almost done......
Archie
troyboy
Total ratings: 154
Report this Post11-12-2013 05:48 AM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
RCR
Total ratings: 102
Report this Post11-12-2013 06:54 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
The added color sure looks nice.
Bob
Bloozberry
Total ratings: 311
Report this Post11-12-2013 07:42 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! That looks super sharp and clean.
TXOPIE
Report this Post11-12-2013 11:58 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
WOW!
exoticse
Total ratings: 108
Report this Post11-12-2013 01:56 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clean !
