  Project "off the Rickst'er Scale" begins (Page 11)
This topic is 30 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30
Project "off the Rickst'er Scale" begins by Bozzie
Started on: 01-26-2012 05:45 PM
Replies: 1166 (48908 views)
Last post by: Bozzie on 02-21-2023 06:27 PM
Bozzie
Report this Post04-28-2014 09:08 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got my paint sticks out again.. Used them to space the cowl from the windshield. These things are Really handy.
http://i252.photobucket.com...ec/2007_12240001.jpg
Bozzie
Report this Post04-28-2014 09:11 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Member since Oct 2007
While i glassed the cowl i bonded the Quarter windows to the car. I had to cut them to fit the new opening. I taped both sides when i cut them and used a fine air saw blade. No problems and they fit pretty good.
Bozzie
Report this Post04-28-2014 09:12 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Bozzie
Report this Post04-28-2014 09:14 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
You can see the curve in this pic. Also i used a marker to mark the new windshield line on it. I will cut this so it lines up better with the black part of the windshield
Bozzie
Report this Post04-28-2014 09:15 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
After much sanding and a little filling its taking shape
Bozzie
Report this Post04-28-2014 09:18 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Had to take her outside and hose her down.. What a mess. Heres the general pic of where shes at. Enough for today. Next is to start molding the fenders back on and getting them to look right with the windshield. Im taking her to Carlisle this year do or die !!!
RCR
Total ratings: 102
Report this Post04-29-2014 06:59 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you set the windshield yet, or are you waiting to do the dash filler panel first??
Bob
Bozzie
Report this Post04-30-2014 09:40 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Bob. The windshield is just sitting there. Its so nice to be able to just lift it off and do work to the dash. Im going to finialize the dash and get it together first. I was thinking about that actually and before the fenders get put back on the windshiled needs to be bonded because its just under the fender. Then the fenders get glassed back on. Thats the day i finally get a Plate on this sucker !!
jediperk
Report this Post05-18-2014 07:24 AM Click Here to See the Profile for jediperkSend a Private Message to jediperkEdit/Delete MessageReply w/QuoteDirect Link to This Post
This build thread is incredible. You have some serious skills AND Patience
mitchjl22
Report this Post05-19-2014 12:46 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
My Car - 87' GT 3800sc
https://www.fiero.nl/forum/F.../HTML/121571.html#p0
exoticse
Total ratings: 108
Report this Post05-29-2014 02:24 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie any videos yet ??
Total ratings: 328
Report this Post06-14-2014 11:36 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent design and workmanship. That's going to be one beautiful custom car when everything is in place. What I do not understand is how you we able to join fiberglass to the urethane rear quarter panels.
OverKill
Report this Post06-15-2014 09:32 AM Click Here to See the Profile for OverKillSend a Private Message to OverKillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the quarter panels he is using are fiberglass parts that come with the widebody and the only urethane left is the door skins.
I have seen it done and seems to work out and if I'm correct all of the mad arch widebodies need the fiberglass door caps glassed into the urethane doors. I may be wrong they might use some sort of two part to bond them together.
Ethan
1985 Base "The Mongoose" under the knife 472 turbo build
1988 Formula daily driver
[This message has been edited by OverKill (edited 06-15-2014).]
Boogaloo
Report this Post06-15-2014 11:10 AM Click Here to See the Profile for BoogalooSend a Private Message to BoogalooEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the most surefire way to do this is grind the spot down and use rivets to hold the parts together this will form a permanent bond then glass it over then use a coat of filler to even it oui.
motoracer838
Total ratings: 83
Report this Post07-09-2014 12:07 AM Click Here to See the Profile for motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump, missing the progress reports.
Joe
Report this Post07-09-2014 11:53 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Amazing.
I love how you design and adapt on the fly.
Bozzie
Report this Post07-10-2014 11:41 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to all the replys. Been super busy but more updates coming soon.
Bozzie
Report this Post09-17-2014 05:46 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time for some MAJOR updates
More work on the windshield / filling n glassing
Bozzie
Report this Post09-17-2014 05:50 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Just a quick shot of the rear at the end of a night
Bozzie
Report this Post09-17-2014 05:52 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Flush Mount latchs i will use on the hood and rear hatch
Bozzie
Report this Post09-17-2014 05:53 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
I mounted the stud into the car and popped a hole thru. Traced the latch for where to cut...
Bozzie
Report this Post09-17-2014 05:55 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
hole cut and latched down....overall a good fit. Lockable and it holds it well
Bozzie
Report this Post09-17-2014 05:56 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Here you can see how the latch works, going thru the pin when you press it down. Its pretty cool ! Repeat for the other side.
Bozzie
Report this Post09-17-2014 05:59 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Back to the dash. WIth the windshield out...a must.... working on the dashpad. Shortened it about 3" and just filling in with liquid plastic which remains flexable so it wont break or crack when i take it out or put it in. Fit and finish is the time consuming part. You can see the forward dash piece against the windshield... tweeters will be mounted into this as well as the photo cell for the auto lights and security LED.
Bozzie
Report this Post09-17-2014 06:00 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Bozzie
Report this Post09-17-2014 06:02 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Interior shot. The Trim bezel is shortend aprox 3" as well. I had to notch it for the tilt wheel lever. Filling and sanding... in and out....over and over.....
Bozzie
Report this Post09-17-2014 06:03 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
dash pad work....
Bozzie
Report this Post09-17-2014 06:04 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Bozzie
Report this Post09-17-2014 06:05 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Trial fitting things. Primered the forward dash pad.
Bozzie
Report this Post09-17-2014 06:24 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Taped off the kick panels for a mould of the floor. Going to put 5 1/2 " speakers down here.........
Bozzie
Report this Post09-17-2014 06:25 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
and passenger side
Bozzie
Report this Post09-17-2014 06:26 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Glassed. Rear part ready
Bozzie
Report this Post09-17-2014 06:27 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Tweeters mounted in Forward Cowl
Bozzie
Report this Post09-17-2014 06:29 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Another Test fit of dash area. Coming together. Filling in the gaps alittle at a time. Theres alot to consider. Gaps top and bottom and along the A pillers...have to make sure once it is upholstered they can all be installed and removed and still look good..
Bozzie
Report this Post09-17-2014 06:30 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Interior shot....coming together
Bozzie
Report this Post09-17-2014 06:32 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
A Pillars trimmed and textered
Bozzie
Report this Post09-17-2014 06:33 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Bozzie
Report this Post09-17-2014 06:34 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Bozzie
Report this Post09-17-2014 06:36 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Here you can see the kick panels coming together for the speakers. Also the hole cut for the Push To Start interface. Also the dash opening for the IPAD Mini and the heater controles remounted below
Bozzie
Report this Post09-17-2014 06:38 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Installed a Removable Steering wheel hub. Makes getting in and out ALOT easier especially working on the interior. I shoulda done this first !! This car also has a working BCM from the monte carlo. Including the functions for the door locks , dome light, auto headlights, switchs, etc. Push to start uses a transponder key like the new cars , proximity sensing for auto unlock as you get close to the car. Amazing system.
