  Project "off the Rickst'er Scale" begins (Page 15)
This topic is 30 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30
Project "off the Rickst'er Scale" begins by Bozzie
Started on: 01-26-2012 05:45 PM
Replies: 1166 (48908 views)
Last post by: Bozzie on 02-21-2023 06:27 PM
Bozzie
Report this Post11-12-2014 11:24 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
With is level and straight I measured out and made the cut. Afterwords I pulled the car apart 4" and welded some braces in to hold for now.
Bozzie
Report this Post11-12-2014 11:28 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Member since Oct 2007
Even braced the car is VERY flexable and unsturdy. Care must be made to keep it solid till its braced. I had to jack the center when I cut the roof. Its hard to believe what the roof actually does to strengthen the car.
Here the roof is cut and I cut a 1" notch into the B pillar for a slight rake to the roof line. Guess im a in the chop top club now....just a baby thou
Bozzie
Report this Post11-12-2014 11:30 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Another pic of the 1" "CHOP"
Bozzie
Report this Post11-12-2014 11:32 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
As it sits....ready to build a new side frame.
1st I cut the door jamb out from the top of the B pillar down to the bottom rail. I will use this again later in the build
[This message has been edited by Bozzie (edited 11-12-2014).]
Bozzie
Report this Post11-12-2014 11:34 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Then I trimmed the rest of it for the addition of the new 2x3 Frame section. I also cut the rear frame section out from the strut towers as these will be replaced as well with 1 long piece.
Starting with a 23' section I started to cut the frame out
Bozzie
Report this Post11-12-2014 11:37 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Here you can see the rear frame out and a piece of the new 2x3 section .
I Trial fit the frame on the rear section. Just mocked up the door jamb to check.
Fie Ro
Total ratings: 132
Report this Post11-12-2014 04:00 PM Click Here to See the Profile for Fie RoSend a Private Message to Fie RoEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are family of Car-Lo ?
ghost187x
Report this Post11-12-2014 05:53 PM Click Here to See the Profile for ghost187xSend a Private Message to ghost187xEdit/Delete MessageReply w/QuoteDirect Link to This Post
What interior is that?? And wow...
355Fiero
Report this Post11-13-2014 12:49 PM Click Here to See the Profile for 355FieroSend a Private Message to 355FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie;
My apologies if you already answered this. I looked back a few pages and could not find this discussion but I am sure you have already stated why you are doing what you are doing.
Why did you lengthen the cockpit area vs. the engine bay? Height restrictions or looking for more cockpit area vs. just the wheelbase stretch? Just curious.
Thanks
Don
Car-Lo
Report this Post11-13-2014 01:53 PM Click Here to See the Profile for Car-LoSend a Private Message to Car-LoEdit/Delete MessageReply w/QuoteDirect Link to This Post
WOW, talk about SURPRISES this is the BIG ONE there are still after shocks all the way up the west coast to Vancouver great work Bozzie
Bozzie
Report this Post11-16-2014 12:08 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fie Ro..............LOL. Car Lo is definatly my mentor !
Bozzie
Report this Post11-16-2014 12:09 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Ghost.............THANKS !!! and its out of a 2000 Monte Carlo....with a lot of fitment
Bozzie
Report this Post11-16-2014 12:13 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Hey Don....never a problem. I did a 3.25" cradle stretch first. Then while I had it apart I was just looking at it one day and figured if I didn't do the chassis stretch it would be a LONG way back to this point to do it. Cradle stretch basically to extend the wheelbase and get some more weight on the front end. I also wanted alittle more room in the engine compartment and the 3.25 " make a big difference. The Chassis stretch of 4" was mostly because I am basing my build now on the 512 wheelbase and its correct now. Also I wanted alittle more rake to the roofline and the extra room is just a bonus. Thanks for the question !
Bozzie
Report this Post11-16-2014 12:15 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Car-Lo... thanks man.....I really look up to what your doing there. Yes its a big step. But winter is setting in here so time is all I have ! Keep the builds going !! One day East and West coast is going to have to get together
Bozzie
Report this Post11-16-2014 12:18 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Another shot of the rear frame rail
mocking up the frame
and tack welded
Bozzie
Report this Post11-16-2014 12:20 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
All cleaned up and ready for the new frame
welded in and working on the B pillar
Bozzie
Report this Post11-16-2014 12:22 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
on the ground.... SOLID !!
Bozzie
Report this Post11-16-2014 12:33 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Removed the C Pillar and speaker mount
Here I opened up in front of the intercooler to expose the lower frame which I'll be connecting to the new frame later
[This message has been edited by Bozzie (edited 11-16-2014).]
Bozzie
Report this Post11-16-2014 12:36 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
TIme to get the passenger side done
Triple checking the level
Bozzie
Report this Post11-16-2014 12:37 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Tacked in place
finishing the welding on the frame
Bozzie
Report this Post11-16-2014 12:38 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Cleaned up and ready to mount the new frame section
welded up some center supports to the lower window frame
Bozzie
Report this Post11-16-2014 12:40 AM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
passenger side frame welded in and working on matching C pillar
Here I connected the lower frame to the new frame section.
Bozzie
Report this Post11-18-2014 04:58 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Moving on to getting the roof squared away and the B and C pillars as well as the new hatchback
Bozzie
Report this Post11-18-2014 05:00 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
another shot of the rear roof
Bozzie
Report this Post11-18-2014 05:01 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Back on the ground for a bit. getting more and more solid. Next up it to tie the front lower frame to the front door support and add a lower frame brace..
Bozzie
Report this Post11-18-2014 05:04 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
All for the day.....
cleaned up some .... contemplating the new rear hatch area. Also thinking of reworking the body and rear fenders a bit.
Tucked away till next time
davylong86
Report this Post11-18-2014 05:10 PM Click Here to See the Profile for davylong86Send a Private Message to davylong86Edit/Delete MessageReply w/QuoteDirect Link to This Post
That is a event I would go too. Let that meeting be at SEMA with MadCurl and Troy&Lisa and the Fiero's just might take the show!
[This message has been edited by davylong86 (edited 11-18-2014).]
Bozzie
Report this Post12-12-2014 01:47 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time to mind the gap....
New piece welded in and seam sealed....
Bozzie
Report this Post12-12-2014 01:49 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Working on the roofline.............
Bozzie
Report this Post12-12-2014 03:18 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Notching the inside for room on the passenger side to connect the lower frame to the upper frame vertical support
Bozzie
Report this Post12-12-2014 03:21 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Finally got the door jamb pillar back in and welded. Door is super solid now and it closes better than factory.
Primered
Welded to the frame with sheetmetal and sealed..
[This message has been edited by Bozzie (edited 12-12-2014).]
Bozzie
Report this Post12-12-2014 03:24 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Put in Vertical supports for where the window will now go.
Bozzie
Report this Post12-12-2014 03:25 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
End pieces installed for rear window sides.
Bozzie
Report this Post12-12-2014 03:26 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Rear shot with rear side window filler panels.
Bozzie
Report this Post12-12-2014 03:28 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Passenger door jamb installed and sealed. Filler panel made for side extension and sealed. Also hinges welded in for the future hatchback.
Bozzie
Report this Post12-12-2014 03:33 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Taking a break on metal work. Made some flat panels for the side window area.
Pieces trimmed and cut to shape.
1st layer of glass
Bozzie
Report this Post12-12-2014 03:35 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
After it dried I took it off and glassed the inside and traced out the window. You can also see here the door jamb area and extension tin is in and welded and sealed.
I put the lower rocker panel back up just to see what it looks like now. Im going to have just just toss this and make a new one from scratch later.
Bozzie
Report this Post12-12-2014 06:16 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Got the other side matched and held up for now.
Needed more room so I tapered the rear frame rail in and down.
you can see the difference now just how much it makes and leaves room for the rear fender to be wider. Both rear inner sails you can see here with the hinges on the roof hanging....waiting ...
Bozzie
Report this Post12-12-2014 06:19 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Widebody door cap doesn't cut it anymore so off it comes. Looks so different now !
With the lower effects removed again....for the last time its time to start making new ones..
Bozzie
Report this Post12-12-2014 06:22 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Starting with the inlets I used flat panels I made out of 2 layers of glass. 2 more will be added later to make it stiff but for now there real flexable and pretty easy to shape. I glassed these to each other and the door. The door normally tapers in or round in at the bottom but these will be cut down straight later.
