  Project "off the Rickst'er Scale" begins (Page 19)
This topic is 30 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30
Project "off the Rickst'er Scale" begins by Bozzie
Started on: 01-26-2012 05:45 PM
Replies: 1166 (48908 views)
Last post by: Bozzie on 02-21-2023 06:27 PM
motoracer838
Total ratings: 83
Report this Post10-11-2015 04:10 PM Click Here to See the Profile for motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump.
davylong86
Report this Post02-05-2016 10:31 PM Click Here to See the Profile for davylong86Send a Private Message to davylong86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Big Bump! Hope life is good for you and the Project.
Bozzie
Report this Post03-14-2016 04:24 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello ALL and thanks for the bumps and Views ! After alittle hiatus , mostly from working on customers cars im getting back to Alchemy. Lots of plans and changes, thoughts and dreams of this project. Hears where we continue with the build
http://i252.photobucket.com...ec/2007_12240001.jpg
Bozzie
Report this Post03-14-2016 04:26 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Member since Oct 2007
Making some mounting bracket for the body. Its about time she hangs herself !!
Bozzie
Report this Post03-14-2016 04:27 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Bozzie
Report this Post03-14-2016 04:29 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Here the doors are getting a glassing of the underside of the efx. I'll cut a slot in them for the electric releases that I got from a corvette....just a pushbutton , no more handles
Bozzie
Report this Post03-14-2016 04:30 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
A few more layers of plastic on the mirrors and sandings. Looking like something now.
[This message has been edited by Bozzie (edited 03-14-2016).]
Bozzie
Report this Post03-14-2016 04:33 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
more sanding of the body. I placed the upper cap of the hatch on and looking at how I will glass it all together for the final plexi window later
Bozzie
Report this Post03-14-2016 04:35 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Because I changed some of the lines of the body the lower intake no longer fit right., so making another one to fit. Cant tell how many times ive made this part in all different shapes....hope this is the LAST one for this car
Bozzie
Report this Post03-14-2016 04:37 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
I decided to hold down the hatch with the original latches I had. I made some brackets for the lower stud and cut out the top for the latchs.
Bozzie
Report this Post03-14-2016 04:39 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Some metal work ...............
Pin Mounting
Bozzie
Report this Post03-14-2016 04:40 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
On to the next step
The hatch lifts fine , but ill replace the hinge with one like Niels Advenador build later thanks for the tip Niel
Bozzie
Report this Post03-14-2016 05:02 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Before I glass the hatch pieces together I welded a lip on the side for the wing to bolt to. Im figuring this wing is going to put some stress on the body and should be attached well
Bozzie
Report this Post03-14-2016 05:06 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Time to put this hatch together Making a few filler pieces for the rear trailing edge. The idea is that after this whole thing is glassed together it will be able to slide off the frame for any type of repair or access.
Just gluing these pieces together with quick glue to glass over later
Glassed
Bozzie
Report this Post03-14-2016 05:08 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
And the other side..................
Bozzie
Report this Post03-14-2016 05:11 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
and the top corner
Neils88
Total ratings: 56
Report this Post03-14-2016 06:29 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
You're welcome Bozzie! ...only fitting...I'm stealing borrowing ideas from your build all the time...
Love this build! Keep up the great work!
LornesGT
Report this Post03-14-2016 10:08 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad you are back, now if I could schedule a vacation for some glass work clasSes in CT. I hope to have Archie's widebody in my shop soon.
RCR
Total ratings: 102
Report this Post03-15-2016 06:00 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Yay, you're back
Bob
ITALGT
Report this Post03-15-2016 05:49 PM Click Here to See the Profile for ITALGTSend a Private Message to ITALGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RCR:
Yay, you're back
X2!
Keep pecking away at it, it's coming along beautifully. And thanks for taking the time to share your progress.
Lookin' sweet.
[This message has been edited by ITALGT (edited 03-15-2016).]
Bozzie
Report this Post03-17-2016 05:11 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Feels great to be back in the swing here everybody !! NEILS88.......RCR.......LORNESGT......ITALGT......and so much more of the Fiero builders and modders ......I feel that we pull from each other and ideas are born and raised within our builds. In my eyes we are all leaders and followers in the hobby and it just keeps getting the bar raised every time. Just wish somehow the knowledge of the tips and tricks could be easier to access. LORNESGT.......looking forward to you getting your widebody !! And the build continues......
The bottom of the wing gets aluminum angles to attach to the metal frame of the hatch. It will be bolted for strength. I bonded them for now but they will be glassed as well
alittle filling in
Bozzie
Report this Post03-17-2016 05:12 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
more filling of the body, this is where the time goes by faster
ready to start the next modd
Bozzie
Report this Post03-17-2016 05:14 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
smoother and smoother Getting ideas for the rear diffuser and rear fenders
Bozzie
Report this Post03-17-2016 05:15 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
In the air getting ready for the tilt nose
I used the front hinges for this. Just cut them up a bit and bolted them onto the lower frame I already made.
Bozzie
Report this Post03-17-2016 05:18 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
And she tilts !!
and back down
going to make it a lot easier to access the front and with a few quick bolts it'll all come right off. A lot of finish work to do yet
LornesGT
Report this Post03-18-2016 12:05 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably asked before but how many layers of fiberglass does it take to have enough strength in the parts? What type of Fiberglas is best?
RCR
Total ratings: 102
Report this Post03-18-2016 06:04 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Great stuff, Bozzie. Same question as Lorne asked above ^^^.
Also, are you going to leave the rear portion of the fender bottom attached to the hood, or cut it off at the belt line? My thought (and this is something I thought about on mine) is that that little extra part hanging down gets in the way of accessing the front, unless you do pull the whole thing off.
Just my penny and a half.
back to the
Bob
Bozzie
Report this Post03-30-2016 04:46 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
LornesGT and RCR, Usually I use 1.5oz matting. I just started using Fiber Glast Resin. It seams much thinner than other brands and MUCH easier to break down the matting for a easier soak thru. I Vary thickness, usually 2 3 or 4 layers of matting , and rolling out the excess Resin with a ribbed roller. Its the Matt that provides the strength once saturated, so rolling out the excess Resin is important for a good bond and thin strong results. I just picked up a Shredder and a 50lb spool of "hairs" so as to make curves and uneven surfaces much easier to build up. Hope that helps
Bozzie
Report this Post03-30-2016 04:47 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Bob..... your ahead of me on the hood buddy ! That's EXACTLY what I was thinking !! I very much appreciate your build and watch it carfully. So, Bob..... heres your answer
Bozzie
Report this Post03-30-2016 04:51 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
This ones for Bob ! Your absolutely right about that extra fender area ready to punch ya ! ......so im going to chop it right at the beltline !
Drawing the new line on the body line
and OFF she goes
Much better and out of the way
Bozzie
Report this Post04-02-2016 04:04 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Making a left and right mount for the lower front fender and upper hood
and welding them in with bracing
Bozzie
Report this Post04-02-2016 04:06 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
now that things are layed out im fine tuning things..... like the B pillar. Before...
After
Bozzie
Report this Post04-02-2016 04:08 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Working on the passenger side mirror......my zigg
Bozzie
Report this Post04-02-2016 04:11 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
just got in this 88 CJB for some upgrades
Put in some new Fiero Store Sailpanels
Bozzie
Report this Post04-02-2016 04:12 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Just got in this 85 308 as well for some electrical repairs
[This message has been edited by Bozzie (edited 04-02-2016).]
Bozzie
Report this Post04-02-2016 04:14 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Larger Brake booster upgrade in the CJB
Bozzie
Report this Post04-02-2016 04:16 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
Tucked away for the night
Bozzie
Report this Post04-07-2016 03:22 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got some pieces in for the black CJB Install to come soon
Bozzie
Report this Post04-07-2016 03:23 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
on the 85' 308 this is what the wiring looked like. Customer states the brake lights don't work....wonder why ?????
Bozzie
Report this Post04-07-2016 03:25 PM Click Here to See the Profile for BozzieSend a Private Message to BozzieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bozzie
more carnage !
