  Audi A8 My Fiero (Page 21)
This topic is 55 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55
Audi A8 My Fiero by engine man
Started on: 06-10-2012 12:09 PM
Replies: 2192 (104370 views)
Last post by: engine man on 08-26-2024 11:39 PM
engine man
Report this Post03-17-2015 08:27 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have decided to pull all the injectors due to i have 7 rich cylinders and 1 lean or burning correct i am thinking this is why i am getting a wrong O2 reading
engine man
Report this Post03-18-2015 08:17 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
i sure hope the wideband helps the narowband is nuts i have black smoke coming out and it is say 15:1 AFR. almost forgot i replaced my right valve cover that was bad with a good one
[This message has been edited by engine man (edited 03-18-2015).]
Tweeder
Report this Post03-18-2015 10:51 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by engine man:
not sure what type of info you are looking for on the tips but they are on the car and need a bit of adjustment .
Who makes them an where can i get them?
86 SE Convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
engine man
Report this Post03-19-2015 11:40 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
i bought them on ebay
http://www.ebay.com/itm/2-5...b24571e4684d%26pid%3 D100033%26rk%3D1%26rkt%3D4%26sd%3D161013692480
[This message has been edited by engine man (edited 03-19-2015).]
engine man
Report this Post03-20-2015 05:48 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drove the fiero home tonight it seems to be running good i changed the coil setting from 3.1ms to 3.5ms and that seemed to help but it still wont idle i will work on that after i fix the speedometer
bigformula
Report this Post03-20-2015 08:34 PM Click Here to See the Profile for bigformulaSend a Private Message to bigformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I gotta say this is one heck of a engine swap. nice
engine man
Report this Post03-20-2015 08:55 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks I am having fun with it
engine man
Report this Post03-22-2015 10:42 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
well i am going to have to upgrade to a better fuel pump relay as i have burned up another so i will buy a continuous duty relay from Jegs .
engine man
Report this Post03-23-2015 12:06 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I need some help on hooking the Tach up to the megasquirt i know there are a few that are running megasquirt with wasted spark so how do you get a tach signal i have selected iac1 as my tacho out put do i just hook that up to the tach wire or do i need to do something more?
engine man
Report this Post03-23-2015 07:03 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
Member since Mar 2006
well i will check the wires for some reason i think i might have the blk/wht wire in the c203 pin M not grounded i just hope it is this simple
engine man
Report this Post03-24-2015 10:07 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hate it when a company sells you something but they are out of it but don't tell you then you wait and wait and they try fooling you by printing a shipping label but 7 days after the USPS still hasn't posted it as shipped so i have opened a case against 14point7. Just send me my parts wtf
engine man
Report this Post03-24-2015 06:59 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
tomorrow i will test my tach signal with another tach to see if i am getting a signal then i will go from there. I still havent made the speedometer work it looks like i don't have a signal due to the light is supposed blink when you have a signal from what i understand
[This message has been edited by engine man (edited 03-24-2015).]
engine man
Report this Post03-25-2015 01:10 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
ya i have a tach signal now i just need a signal for the speedometer .
engine man
Report this Post03-25-2015 06:14 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
I have been told the transmission i have uses a reed switch so i need to put power to one side but i don't know what to do with the purple vss wire do i just ground it
zkhennings
Report this Post03-26-2015 09:10 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just so you know, I read your updates like every day, even though there aren't many pictures it is quick and easy to read through everything since you post a little update like everyday.
I am looking forward to seeing this completed! I also have some MS questions I might PM you about.
engine man
Report this Post03-26-2015 10:05 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope i can help and thanks for following the thread
engine man
Report this Post03-26-2015 02:01 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
Well i give up on the Dakota Digital box i cant get a signal so i will go with a GPS interface module that should fix thing
engine man
Report this Post03-26-2015 02:38 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
Ok is the Signal that goes into the speedometer square wave or sine wave
engine man
Report this Post03-26-2015 08:25 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
Well i got the new fuel pump relay hooked up with 30 amp circuit breaker so the problem of eating stock relay is over . I see Dakota Digital makes a GPS speedometer interface and it has both sine wave and square wave output signal so when i can afford one i will buy one and solve that problem.
engine man
Report this Post03-27-2015 11:18 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
finally got the wide band O2 it works great
nitroheadz28
Total ratings: 94
Report this Post03-27-2015 01:52 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to see you still plugging away at this, keep up the good work
Post up some more pics/ vids when you can!
engine man
Report this Post03-27-2015 01:58 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
ya i forgot the camera today i was going to do a walk around video and maybe another drive by video
engine man
Report this Post03-28-2015 11:12 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Walk around video of the car and better sound of it running
https://www.youtube.com/watch?v=eaTMkCyQhtU
nitroheadz28
Total ratings: 94
Report this Post03-28-2015 01:02 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
She sounds awesome! Engine looks right at home in there
engine man
Report this Post03-28-2015 01:17 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
yup it pulls pretty good now i just need to put the supercharger on but that will be late summer early fall i should have the money to do it by then
[This message has been edited by engine man (edited 03-28-2015).]
engine man
Report this Post03-29-2015 09:53 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
well tomorrow i will check the O2 accuracy just to make sure it is perfect then i can start tunning . I cant wait to go to the drag strip just to see what it will do
zkhennings
Report this Post03-30-2015 11:35 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
It sounds awesome and looks clean!
engine man
Report this Post03-30-2015 11:45 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks it looks better than it really is it is going to need paint and like i said the wires need a bit of untangling and i need a coolant expansion / fill tank so i can get rid of the coolant hose going over the top of the engine you know just a bunch of small things
engine man
Report this Post03-30-2015 07:00 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
well tomorrow i will fix the tach if i don't get any work in the shop
engine man
Report this Post03-31-2015 12:28 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
tach done just need to dial it in now
engine man
Report this Post03-31-2015 03:33 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
next on list is fix the power windows wiring as the clown who owned it before did a hack job on the wires
engine man
Report this Post04-01-2015 07:04 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got a good chuckle today when a young woman said to me you drive a Ferrari I told her no it was a Pontiac Fiero
engine man
Report this Post04-03-2015 10:09 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had good weather today been driving the car and i got the windows all rewired now i am going to do some more bracing on the cradle tomorrow then i will start working on getting the new nose i bought for the car a few years back on . maybe some day this thread will be in the construction zone
engine man
Report this Post04-05-2015 07:16 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well i consider this engine swap a complete success sure it is not the fastest 1/4 mile car but it runs good and pulls hard up through the rpm's sounds great and the engine looks like it belongs there . i say to any one who wants to do this swap they should and if you want more power you can go with a turbo or a S8 40 valve engine .
[This message has been edited by engine man (edited 04-05-2015).]
engine man
Report this Post04-09-2015 11:32 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just moded the Porsche shifter it was straight on the sift knob rod unlike the fieros that bends so i cut it down and cut off a Fiero shift knob rod and welded it on now it sits in a better place when shifting the only other thing i would like is if the throws where shorter i may mod that to
[This message has been edited by engine man (edited 04-09-2015).]
engine man
Report this Post04-11-2015 07:31 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
today i worked on the exhaust getting it so the tips sat in same place and put hangers on now it looks good . I was chased down today by a guy who had a V8 fiero some years back he said he missed his Fiero then i showed him the Audi V8 and explained why i used it .
Neils88
Total ratings: 56
Report this Post04-11-2015 07:50 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
This thread needs more pics !
engine man
Report this Post04-11-2015 08:10 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok more pics tomorrow
engine man
Report this Post04-12-2015 10:52 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok this is the shifter mods and pics of the exhaust tips
old shifter before mod
and after
megasquirt mounted
Exhaust tips
engine man
Report this Post04-12-2015 08:14 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine man
today i took the car for a ride and hooked the laptop up and ran EFI Analytics TunerStudio analyzer live this tunes the car while driving .while i was diving i felt a brake dragging so i checked it out by putting my hand near each brake rotor and found the right front hot so i know that brake is dragging i am not sure why it is dragging but i will check out tomorrow
