Audi A8 My Fiero by engine man
Started on | : 06-10-2012 12:09 PM |
Replies | : 2192 (104367 views) |
Last post by | : engine man on 08-26-2024 11:39 PM |
Apr 6th, 2016
engine man Member Posts: 5309 From: Morriston FL Registered: Mar 2006
surprisingly my new clutch ,pressure plate & throw out bearing came in so i should be able to put that all together and put the engine up in the car this weekend and i might even get started on wiring . [This message has been edited by engine man (edited 04-06-2016).]
08:44 PM
Apr 7th, 2016
well the trany is on and it is on the cradle
06:25 PM
Apr 8th, 2016
motoracer838 Member Posts: 3751 From: Edgewater Co. USofA Registered: Jan 2006
That is tight...
Joe
04:41 PM
yup it is a tight fit but it is all under the deck lid so no one will know
05:39 PM
Apr 9th, 2016
worked on the wiring and i now have the injectors wired to the megasquirt i will wire up the ignition coils tomorrow
03:31 PM
Apr 11th, 2016
today i cut away all the wires that i will not need on the old fiero harness as i am putting the megasquirt ecu in the trunk area
06:24 PM
Apr 14th, 2016
Have any of you tried Extreme tape it is rated to 500 degrees F and it has no glue and you heat it to get it to bond i am going to try it on the wiring harness i am hoping for good results
09:13 PM
Apr 15th, 2016
well i tried some of the tape and it work good i will finish putting the harness together and then use it . the only thing i don't like about it is you have to cut off a length of it to be able to wrap the wiring it is hard to use right off the roll but i will take pictures off the harness when done
10:33 PM
Apr 16th, 2016
doublec4 Member Posts: 8289 From: Oakville, Ontario, Canada Registered: Jun 2003
Where did you buy this "extreme tape" Any pictures of it? By the way, great work on the build. I check back periodically... it's going to be quite the beast! [This message has been edited by doublec4 (edited 04-16-2016).]
09:14 AM
i bought it on Amazon
02:11 PM
Apr 20th, 2016
08:15 PM
Apr 22nd, 2016
11:46 AM
Apr 23rd, 2016
i just need to wire the knock sensor but i am taking the weekend off but on Monday i will wire that up and should be able to finish the wiring then i will give it a test before wrapping it then put some oil in it and fire it up
09:02 PM
Apr 26th, 2016
04:26 PM
Apr 27th, 2016
Well today was a sad day as my mother passed away at the age of 86 she had Alzheimer for over 10 years she fought hard and passed quick and with little pain due to the great program and nurses to make sure she was not hurting in the end
07:22 PM
Neils88 Member Posts: 4057 From: Jeddore,Nova Scotia Registered: Aug 2013
So sorry to hear about your loss.  Our thoughts and prayers are with you and your family.
07:24 PM
Thanks Neils88 i just cant say enough great things about my Mom and I will miss her
10:45 PM
Apr 28th, 2016
today i tested the megasquirt and wiring the only thing i have wrong is 2 wires on the tps just need to swap the ground and 5 volt positive and i need to run a injector and ignition test
06:08 PM
| quote | Originally posted by engine man:
Well today was a sad day as my mother passed away at the age of 86 she had Alzheimer for over 10 years she fought hard and passed quick and with little pain due to the great program and nurses to make sure she was not hurting in the end |
I lost my grandmother to Alzheimer's a long time ago, it was very painful to watch her slip away, you and your family have my condolences. Joe
07:38 PM
motoracer838 it isn't so bad at first when they are just forgetful but in the end when they become like a vegetable and can not talk or move and even getting them to just eat because they don't know how to anymore and they have no clue who you are and don't even know you are in the room with them it makes you sad for them
08:26 PM
May 1st, 2016
well i fixed the 2 wires on the tps and the wiring is done and i put the exhaust on so now i just need to plumb up the fuel lines and coolant lines and vacuum line then add some oil and battery and start it up
06:22 PM
1shot Member Posts: 49 From: FL Registered: Jun 2010
Mark, Sorry to hear about your Mom. Looks like that tape is working well, I may just have to give it a try. George
09:58 PM
May 3rd, 2016
thanks 1shot and the tape works really well i would buy it again
11:57 AM
07:02 PM
May 4th, 2016
Good call on the header wrap, it makes a pretty good difference in the engine bay. You can actually touch the exhaust with the engine running.
12:14 AM
yep i like the header wrap they had it in many colors bought it on ebay for $15 for 50 ft roll
12:50 PM
wftb Member Posts: 3692 From: kincardine,ontario,canada Registered: Jun 2005
i like that it is set up for rear mount starter so the flywheel just needs to be made with the Honda ring gear [This message has been edited by engine man (edited 05-04-2016).]
02:13 PM
the Acura Legend transmission and differential weighs around 150 Lbs from what i can find
06:08 PM
fieroguru Member Posts: 12426 From: Champaign, IL Registered: Aug 2003
I like that the differential could be swapped out with one from another MFG with a more appropriate final drive. Plus it would be rather simple to install a small drive shaft to get it out from under the engine and can flip the diff and use it for an extended wheel base mid engine setup. Lots of possibilities... All it needs to be even better is for the output shaft from the transmission go out the backside as well for AWD applications.
07:26 PM
look it can have a shaft on the back side so you could do AWD i think just remove the plug that is next to the bolt they have circled  [This message has been edited by engine man (edited 05-04-2016).]
08:14 PM
May 6th, 2016
Saturday i will be trying to get this to start up and have a video posted if i get it running
09:39 PM
May 7th, 2016
Will Member Posts: 14267 From: Where you least expect me Registered: Jun 2000
Well... you'd have to figure out how to put a diff rather than a spool in that side housing if you were to do AWD. However, it would be find for use "Lambo Style" with the pulleys to the back, the transmission ahead of the engine and the diff back by the pulleys
08:05 AM
May 8th, 2016
well did some work on it but dint get it done enough to start and have a few things on order
02:31 PM
back to work the weekend is over need make some money to spend on the addiction
06:44 PM
May 10th, 2016
? what diameter are the fiero manual transmission cables i have found some 1/4 and 10-32
08:45 PM
May 11th, 2016
well i ordered the 1/4 inch cables so we will see how it works out they where $50 each at 102 long
09:32 PM
May 12th, 2016
Hope those cables work out for you. If they do, I might have to order some myself. What kind of shifter did you use and was it a 5 or 6 speed?
05:59 PM
