Audi A8 My Fiero by engine man
Started on | : 06-10-2012 12:09 PM |
Replies | : 2192 (104375 views) |
Last post by | : engine man on 08-26-2024 11:39 PM |
Jul 7th, 2020
engine man Member Posts: 5309 From: Morriston FL Registered: Mar 2006
yes i took long needed vacation to get me back to feeling like even looking at it or any of my projects i have been following yours and it is coming along nicely
08:56 AM
Ok tonight without data logging i first tried to give it some more acceleration enrichment that was the wrong way as i did data log that and it just stumbled all over being to rich so i pulled that back out plus some more then i pulled some water meth out and it is better now i will data log and am sure i will need to pull some fuel out and maybe some more water / methanol . i do know one thing when i finally get this to where i can just slam it to the floor it is going to really be a hand full !
08:56 PM
pmbrunelle Member Posts: 4543 From: Grand-Mère, Québec Registered: Sep 2008
Methanol is fuel, so when you're on the spray, you should cut back a bit on the gasoline to maintain the same lambda.
Is your dyno working now? On the dyno it would be a good way to measure the difference with/without the water/meth.
09:39 PM
no pmbrunelle that is another project that needs finishing but it would be helpful right now
11:15 PM
Jul 8th, 2020
Franked Member Posts: 51 From: Bay area, California Registered: Jun 2020
Hi, I just read through almost the whole 54 pages of this over the last few days. I am off work for a couple weeks because I may have the dreaded COVID. I skipped a few pages here and there, but i saw you saying it was for sale a while back, but you still have it. I am glad you didn't sell it. I read Shem's whole build too, you guys are awesome, saying how you hate bodywork, but you kick ass, my body work would look like a lumpy potato. Anyway, love your build, want to see dyno runs and drag strip time slips, don't get rid of that car!!!!
05:09 PM
Thanks Franked as i am not going to sell as i have to much into it and it seems people think they can buy it for next to nothing
06:00 PM
Jul 27th, 2020
Well it looks like the slipping belt is back so i will try one more thing by going back to a manual belt tensioner on 1 of the belts and if that does not work then i need to either go to a toothed belt or just pull the Supercharger and put a turbo on but i am pretty sure i will end up with the toothed belt as i do really want this to work .
07:19 AM
Ok i just ordered this SBC drive kit for water pump and alternator it give me a crank pulley and i think the alternator pulley i will use on the blower as i think it is a 2 to 1 ratio so at 6500 the blower will be turning 13000 rpm but this will get me going to a non slip solution and it cost me $113 to start
03:20 PM
Aug 22nd, 2020
one of these days i will get the Fiero engine tuned correctly as still can not go right to the floor but with what i can do it pulls hard i can't wait to see how it pulls when i can just jump on it as know it will be the fastest street car i have driven in both Quickness and top speed
09:32 PM
Aug 24th, 2020
Hmm walked back ignition timing 4 degrees but no change it is still showing knock even though i can not hear anything i am starting to think i might be picking up noise from something else but on the plus side i have made more progress getting it tuned now i can floor it and it goes but it is still about 10.5 to 1 mixture so it need some more leaning out in places
06:22 PM
Aug 25th, 2020
ok i just did another run and put some timing back in since it seems me i am getting a false reading i am not sure but i think the supercharger is causing it but i am also getting the fuel much better it seems to pull hard in third gear and i am sure it would continue in forth but i am already going over the legal speed limit
07:03 PM
Aug 26th, 2020
Rickady88GT Member Posts: 10649 From: Central CA Registered: Dec 2002
Such. Cool swap. Thanks for rhe continued updates.
11:59 PM
Aug 27th, 2020
Thank you Rickady88GT i hope it is informative to everyone as i learn things and have questions like right now i am trying to figure out my knock sensor setting on the megasquirt 3 as i want them working but i am getting false readings in fact i data logged some just sitting in the garage in neutral and if shows noise and the second you rev it it is showing knock i have turned the gain way down played with the frequency now am starting to play with the sample time to see if i can get this to work as i feel this would be a good thing to have working right
06:53 AM
anyone with high powered 88 Fiero have any Problem with it giving you a squirmy rear end handling feeling under acceleration
02:40 PM
Aug 28th, 2020
dremu Member Posts: 293 From: Livermore CA Registered: Feb 2019
| quote | Originally posted by engine man:
anyone with high powered 88 Fiero have any Problem with it giving you a squirmy rear end handling feeling under acceleration |
Heck, my STOCK one's like that. Thought it was par for the course for 30-year-old short wheelbase RWD cars  -- A
06:27 PM
i had a 85 with a 88 rear cradle in it and a 3.4 dohc and it was not like this and the car was not like this until added the supercharger and i had this combo without the supercharger in my 88 GT T Top and it did not act like this but this is scary the way it is moving around i am not sure if it is the links running forward or if the cradle is flexing but i am going to X brace the cradle i hope it solves the problem
07:32 PM
fieroguru Member Posts: 12433 From: Champaign, IL Registered: Aug 2003
| quote | Originally posted by engine man: anyone with high powered 88 Fiero have any Problem with it giving you a squirmy rear end handling feeling under acceleration |
Sounds like you need rod end lateral links if you don't have them already. https://www.fiero.nl/forum/Forum2/HTML/120882.html
08:34 PM
ok i can build those as my buddys speed shop is out front of my shop that i rent off him and he has 1/2 -5/8 rod ends along with radius rod as i built these for my motion simulator and i used the QA1 ends
09:15 PM
Aug 30th, 2020
Ok today I took the car over to the shop and tightened all the lateral link bolt as tight as i could , then i X braced the bottom of the cradle but before i was done welding i ran out of welding gas so now i need some more welding gas so i can finish that up . when i drove it home but not pushing it hard it felt tighter in the backend but i really won't know until i really stand on it. [This message has been edited by engine man (edited 08-30-2020).]
05:43 PM
Sep 2nd, 2020
just ordered Heim joints and radius rods and 5/8 to 12mm spacer bushing paid $132 i should have it all next week
06:17 PM
Sep 6th, 2020
well today i took it for a ride up over 100 and it seems to be fine now that i have cross braced the bottom and tightened all the lateral link bolts up good and tight but i will make sure with the solid links that i have on the way
08:59 PM
Sep 10th, 2020
i bought some 5/8 rod ends and rods and some 5/8 to 12mm spacers , i only bought 8 of the spacer to do the inner mounting points but i will drill & tap the knuckle to 5/8  Ok
11:52 AM
Oct 1st, 2020
just the other day i was looking at the car and see where i am going to need to do some repair as the fiberglass is cracked as i just did not make it thick enough but that is all right as i will repair all those things i feel that can be done better on the body but as far as the engine tune it is good now and the car runs fast and quick i want to do both a 1/4 mile and a top speed run i just have not had the time to go to the drag strip as it is about 100 miles away and i have had a bunch of things on my plate
05:26 PM
Oct 3rd, 2020
Wow today i did a experiment first i ran the car down the road and brought it up to 6500 in 2nd gear got 14 psi boost then i removed just the air filter and did the same thing and got 16.7 psi of boost a 2.7 pound gain i say it is time to find a better air filter or maybe dual filters as that from what i think is 50 to 70 hp it is costing me
01:19 PM
Fixing that would give a lot of hp for the dollar!
07:56 PM
Oct 4th, 2020
pmbrunelle yes i need to do something do a dual air cleaner so no restriction and like you said cheap HP per dollar
12:15 PM
Oct 10th, 2020
I put a new Airaid air filter on today and went and tested and all is good now i am hitting 16.8 pounds of boost @ 6500 rpm and the car is getting really close on the tune i did a test from a dead stop and i know that in 1/10th of a mile it does about 90 mph [This message has been edited by engine man (edited 10-10-2020).]
04:23 PM
Oct 13th, 2020
Wow today i did a experiment first i ran the car down the road and brought it up to 6500 in 2nd gear got 14 psi boost then i removed just the air filter and did the same thing and got 16.7 psi of boost a 2.7 pound gain i say it is time to find a better air filter or maybe dual filters as that from what i think is 50 to 70 hp it is costing me |
WOW, crazy. I guess clean costs? Either in upfront restrictions or back door completely that takes up valuable space, time and resources.
11:01 PM
Oct 14th, 2020
yes Rickady88GT it pays to get a better filter the correct size and i even wonder if i took my air intake off completely if it would pick up even more boost amd think about smoothing things out in the blower to get more flow and then going to larger pully to slow it down but but keep the same boost due to improved flow in the blower
06:55 AM
Oct 22nd, 2020
well the car is up or the rest of the year and I am in a happy place about the car as t is close on the tune and it needs some minor work on the body as I did not get the fiberglass thick enough in a few places and it cracked but not a real big deal so I could just take it out next year and drive it or I could repair it first
05:51 PM
Nov 8th, 2020
shemdogg Member Posts: 1841 From: The Ghetto CA USA Registered: Apr 2017
Well done sir, well done. Whatcha gonna work on in the meantime?
shem
10:10 AM
Nov 12th, 2020
shemdogg working on my house now every one wants out of the city and is moving to small town USA like where I am and housing is selling like it is on fire so gonna cash in on it and I will build a new one as I am capable and am going 30 X 40 2 story garage 1t floor living space 2nd floor
05:08 PM
Nov 18th, 2020
Nice man, Im on that train too hopefully soon. Cant wait to get outta commiefornia and move to america lol
shem
10:17 PM
Jan 5th, 2021
wow it has been awhile but the house will be on the market Friday and I have been looking for a place in FL and looking for a project to do after I finish this car and i ran across A Manta Mirage that I will buy if there after selling the house . see picture below
05:52 PM
Jan 16th, 2021
Finished working on my house and it is on the market as of yesterday and i am looking at houses in FL so i hope to be back working on my project by late spring to early summer
07:21 PM
Mar 11th, 2021
09:28 PM
Mar 12th, 2021
sourmash Member Posts: 4558 From: Registered: Jul 2016
Total ratings: 50
WooHoo! Cool. What's that other red car in the 3rd picture. Looks like it's straight out of a Rush song. Looks like a death machine. I want one! [This message has been edited by sourmash (edited 03-12-2021).]
09:56 AM
Not sure what the other kit car was in his shop but I can tell you it was SBC powered and around 2000 Lbs he also told me 50/50 weight balance [This message has been edited by engine man (edited 03-12-2021).]
12:55 PM
This will be a cool build! I am more partial to the Montage, but this one is super cool as well! I think that other car is a Cheetah replica.
07:36 PM
Total ratings: 50
Similar to the Cheetah, but it's flatter in the quarters and a little (very little) longer in the tail. A little more like a Lucra(?). I can't find what it is. Similar to a Scaglietti. I've seen a real something with that tail before. 50s or 60s. [This message has been edited by sourmash (edited 03-12-2021).]
08:07 PM
