  The Mall
  Fiero Belt Tensioner (Page 1)
Fiero Belt Tensioner by Dodgerunner
Started on: 10-07-2007 09:48 AM
Replies: 265 (22686 views)
Last post by: Patrick on 03-27-2025 02:44 PM
Dodgerunner
Total ratings: 323
Report this Post10-07-2007 09:48 AM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
....................1-1-2025 Still building brackets on request.
http://dodgerunner.ddns.net
This came about after reading the issue everyone had with belt squeal on their Fiero's. While doing a 3.4 transplant to my 85GT decided to do something about it and designed this modification to solve the problem. I also didn't want to have to bother ever tightening the belt again. The spring tensioner takes care of that for you.
Add a feature that should have been on the engine from the factory!
THE BRACKET WILL WORK ON ANY YEAR 2.8 OR 3.4PR CONVERSION V6 USING STOCK MOTOR MOUNTS, ALTERNATOR BRACKET AND PULLEYS. (As far as I know with over 300 running around the world.)
You would have to size the belt yourself if you are using power pulleys.
The stock crank pulley measure 6.5" across in case you wonder what you have.
I have full kits available OR just the bracket if you would like to get your own belt and tensioner.
###NOTE: If you get your own tensioner be sure and get a bolt with it. New usually come with a bolt. The bolt should be 10M 1.5P. the length can be the thickness of your tensioner plus 20mm. I have tested my bracket with three different models of tensioner. There might be others out there and fit is not guaranteed.
The tensioner can be found used on many cars or you can buy one that fits a 96 Grand Prix with a 3100 as well as a lot of other GM's.
The belt is a Gates K050450 (45") or cross to other brands.
I sell the belt and tensioner at my cost, adding a little shipping charge for the extra weight.
The bracket only and kit prices, include shipping in the U.S. (no additional shipping charge.)
The bracket is made with all 1/4 steel except the alternator arm is 3/16.
The bends are heat bent not cold bent to prevent future cracks.
Every bracket is hand built on a jig engine and test run for correct belt tracking and alignment.
Tensioner Informations
Email is Dodgerunner@Yahoo.com
See link above for current US pricing
(Bracket in photo is revision 2, current bracket are now revision 3.)
Version 3.
Full information on the web site. Tensioner Informations
[This message has been edited by Dodgerunner (edited 02-07-2025).]
brandon87gt
Report this Post02-09-2008 04:59 PM Click Here to See the Profile for brandon87gtSend a Private Message to brandon87gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump, so I can leave feedback.
Fiero-in-Paradise
Report this Post02-10-2008 12:56 AM Click Here to See the Profile for Fiero-in-ParadiseSend a Private Message to Fiero-in-ParadiseEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI, this is a great product, worth every penny! I have had it now on my 86GT D/D for almost 6K miles, on my 88GT for about 2K miles, and have yet to install it on my Mera. Even with the heavy rains we sometimes get here, I haven't heard the belt squeal one single time.
Formula88
Total ratings: 554
Report this Post02-10-2008 05:39 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Dodgerunner:
THE BRACKET WILL WORK ON ANY YEAR 2.8 OR 3.4PR CONVERSION V6 USING STOCK MOTOR MOUNTS, ALTERNATOR BRACKET AND PULLEYS. (As far as I know with over 30 running around the world.)
Has it been tried on an 88? The engine bracket is different on 88 V6s.
Edit: Just re-read this. Does anything need to be done differently on an 88?
[This message has been edited by Formula88 (edited 02-10-2008).]
Formula88
Total ratings: 554
Report this Post02-10-2008 05:40 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Formula88
Member since Jan 2001
oops
Dodgerunner
Total ratings: 323
Report this Post02-10-2008 05:44 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes works on 88's also, I redesigned one part of the bracket since the 88 is different so one bracket works on the years
[This message has been edited by Dodgerunner (edited 05-29-2008).]
fierohobby
Report this Post02-12-2008 06:34 PM Click Here to See the Profile for fierohobbySend a Private Message to fierohobbyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Works fine on '88s. Been on my Formula for a while now. Great product, recommended.
-fh
PineyCreek
Report this Post02-12-2008 08:20 PM Click Here to See the Profile for PineyCreekClick Here to visit PineyCreek's HomePageSend a Private Message to PineyCreekEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to say that I bought his tensioner for my 86 V6 (when it was still working) and I found the bracket to be an easy install. Good quality welds and non-flaky paint. The complete setup completely and I mean COMPLETELY eliminated all of my belt squeal, including in the rain. Unfortunately I was changing the alternator's adjuster bracket at the same time so it took a couple extra hands :P
BIGG_SEXXY
Report this Post02-12-2008 10:25 PM Click Here to See the Profile for BIGG_SEXXYClick Here to visit BIGG_SEXXY's HomePageSend a Private Message to BIGG_SEXXYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump because Im buying one XD
Blacktree
Total ratings: 350
Report this Post02-12-2008 11:08 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just realized I forgot to leave feedback for the bracket I bought several months ago.
BTW, I'm very happy with my belt tensioner. It's some of the best money I've spent on this car.
Dodgerunner
Total ratings: 323
Report this Post02-14-2008 04:10 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the fun of it I added a map to the first post of locations brackets are being used.
BIGG_SEXXY
Report this Post02-14-2008 04:30 PM Click Here to See the Profile for BIGG_SEXXYClick Here to visit BIGG_SEXXY's HomePageSend a Private Message to BIGG_SEXXYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Haha, get ready to add another to California XD lol
BIGG_SEXXY
Report this Post02-14-2008 04:32 PM Click Here to See the Profile for BIGG_SEXXYClick Here to visit BIGG_SEXXY's HomePageSend a Private Message to BIGG_SEXXYEdit/Delete MessageReply w/QuoteDirect Link to This Post
BIGG_SEXXY
Member since Apr 2006
Theirs a FIERO IN JAPAN!!!???
brandon87gt
Report this Post02-14-2008 05:51 PM Click Here to See the Profile for brandon87gtSend a Private Message to brandon87gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
You forgot arizona!
JesseM
Report this Post02-14-2008 06:14 PM Click Here to See the Profile for JesseMSend a Private Message to JesseMEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah i want to know who that is, id love to see one here
Dodgerunner
Total ratings: 323
Report this Post02-14-2008 07:24 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by brandon87gt:
You forgot arizona!
Knew I was missing a couple.
mswenson289
Report this Post02-16-2008 10:29 PM Click Here to See the Profile for mswenson289Send a Private Message to mswenson289Edit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent.
patch
Report this Post02-17-2008 07:39 PM Click Here to See the Profile for patchSend a Private Message to patchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have one on my '88 and love it!! I was living in Fairfield, CA when I bought it. Works so well I might buy more.
Wolfhound
Total ratings: 113
Report this Post02-17-2008 09:22 PM Click Here to See the Profile for WolfhoundClick Here to visit Wolfhound's HomePageSend a Private Message to WolfhoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent product and quick shipment.
BIGG_SEXXY
Report this Post02-17-2008 11:12 PM Click Here to See the Profile for BIGG_SEXXYClick Here to visit BIGG_SEXXY's HomePageSend a Private Message to BIGG_SEXXYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awwww yeah! So cant wait to get mine! haha!
Blacktree
Total ratings: 350
Report this Post02-18-2008 04:23 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like the map. Am I really the only person in Florida with one of your brackets?
Dodgerunner
Total ratings: 323
Report this Post02-18-2008 06:43 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless I missed one yes believe so...
FieroManGT
Report this Post02-20-2008 01:25 AM Click Here to See the Profile for FieroManGTSend a Private Message to FieroManGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I start with one in MN and I have 4 more cars to try soon after. PM me with payment info. Harley
dcfox
Report this Post02-21-2008 04:53 PM Click Here to See the Profile for dcfoxSend a Private Message to dcfoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just transferred funds to my Paypal account.
I'll be ordering one as soon as the money shows up(3-5 business days).
PM sent.
--David
Golden Triangle Fiero Club
Dodgerunner
Total ratings: 323
Report this Post02-22-2008 09:27 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Dodgerunner (edited 03-05-2008).]
BIGG_SEXXY
Report this Post02-23-2008 04:34 PM Click Here to See the Profile for BIGG_SEXXYClick Here to visit BIGG_SEXXY's HomePageSend a Private Message to BIGG_SEXXYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just received mine!!!! XD Cant wait to install! Damn rain
[This message has been edited by BIGG_SEXXY (edited 02-23-2008).]
BIGG_SEXXY
Report this Post02-25-2008 01:52 AM Click Here to See the Profile for BIGG_SEXXYClick Here to visit BIGG_SEXXY's HomePageSend a Private Message to BIGG_SEXXYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just got mine installed! AWWWW YEAH! No more belt squealing for Tom! Thank you Rory so much for everything. thank you for always answering all my annoying questions in a timely manner. Would seriously do business again in the future.
(>-_-)> A signature Is suppose to be in here? <(-_-< )
Xanth
Total ratings: 174
Report this Post02-28-2008 10:15 AM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to buy just a bracket if you have one available.
Dodgerunner
Total ratings: 323
Report this Post02-28-2008 10:39 AM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Dodgerunner (edited 02-09-2010).]
Xanth
Total ratings: 174
Report this Post02-28-2008 11:21 AM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent for bracket only
pswayne
Report this Post02-28-2008 04:19 PM Click Here to See the Profile for pswayneSend a Private Message to pswayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the one in Georgia. Works great!
Bizziedude
Report this Post02-29-2008 04:00 AM Click Here to See the Profile for BizziedudeSend a Private Message to BizziedudeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great set-up everyone...easy install as well
Dodgerunner
Total ratings: 323
Report this Post03-01-2008 02:46 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Dodgerunner (edited 03-27-2008).]
dcfox
Report this Post03-01-2008 03:02 PM Click Here to See the Profile for dcfoxSend a Private Message to dcfoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't wait for mine to get here.
I'm having Fiero withdrawals.lol.
Xanth
Total ratings: 174
Report this Post03-03-2008 06:33 PM Click Here to See the Profile for XanthSend a Private Message to XanthEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got mine today, very nice solid product
Hope to have it in very soon
frankt2012
Report this Post03-03-2008 06:41 PM Click Here to See the Profile for frankt2012Send a Private Message to frankt2012Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
skstibi
Report this Post03-03-2008 09:50 PM Click Here to See the Profile for skstibiSend a Private Message to skstibiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess buying one keeps ya from having to use a big f***ing screwdriver to get some leverage to get the belt just tight enough. I got mine to just the point where it only squeals on REALLY cold days. No more pig screaming at the ricer next to me when I floor it
PhatMax
Report this Post03-04-2008 08:35 AM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
YES, it is a great product...super easy to install no more squeeeeelll.. should help with alternator longevity as excess pressure on the bearing is removed... THANKS Dodgerunner !!!
CoryFiero
Total ratings: 109
Report this Post03-06-2008 02:47 AM Click Here to See the Profile for CoryFieroSend a Private Message to CoryFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, Do you have any in stock? (Full kit(
I would like one ASAP if you do. Let me know so I can paypal you. If possible overnight shipping? (added cost) I have this weekend off of work.
Thanks!
Cory
[This message has been edited by CoryFiero (edited 03-06-2008).]
Dodgerunner
Total ratings: 323
Report this Post03-06-2008 10:38 AM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
