  The Mall
  Digital EGR Adapter Plate Kit (Page 3)
Digital EGR Adapter Plate Kit by TopNotch
Started on: 06-21-2011 12:16 PM
Replies: 112 (5627 views)
Last post by: fierofool on 01-09-2022 10:23 PM
Report this Post11-18-2015 08:40 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get your EGR adapter kit before your Christmas money runs out. Shipped the next day.
tshark
Report this Post11-18-2015 01:38 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm. Where to get the digital EGR?
ron768
Report this Post11-18-2015 01:59 PM Click Here to See the Profile for ron768Send a Private Message to ron768Edit/Delete MessageReply w/QuoteDirect Link to This Post
You find them on 90-93 or so GM cars and trucks . Got mine off 92 cutlass supreme .
[This message has been edited by ron768 (edited 11-18-2015).]
Report this Post11-18-2015 03:16 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can order your kit from our website Club Merchandise tab on the home page. There's a link there that takes you to TopNotch's posting.
In TopNotch's first post there's a source listing of compatible digital EGR's.
http://gafieroclub.org/bbs/index.php?topic=733.0
As soon as Paypal notifies me of payment, I ship no later than the Post Office's next business day.
Report this Post04-17-2016 11:45 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Warm weather and Tax Refunds are here. Time to get that 7730 and digital egr swap done.
Report this Post12-17-2016 04:17 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
We haven't bumped this in a while, but we've had another run made and we're down to just 3 remaining. May be still enough time to get that Self-Christmas present.
$55. Free shipping to the US.
[This message has been edited by fierofool (edited 12-17-2016).]
Report this Post03-21-2017 11:19 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spring weather is near. Not too hot and not too cold to be working on the Fiero and updating the engine with a 7730 ECM and digital EGR.
Report this Post08-26-2017 05:53 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
A bump to the top and to say we just made a new run of adapter plates.
Worth quoting again. Quoted with permission:
Benefits of 7730 ECM and Digital EGR
A friend of mine brought me his Fiero to have a swap done. He had a very high mileage stock 2.8 and 125-C and wanted me to swap in a lower mileage 2.8 and 440-T4 OD transmission. Not content with sticking with the stock 2.8 ECM, I convinced him to swap out ECMs during the swap as well. In short, it was an excellent choice!
The ECM that was used in this swap was the 1227730 unit which was used in many 1987-92 era GM cars. For this application, I elected to use the $88 code mask programming which was designed to be used in a 1990-92 Camaro/Firebird 3.1. The Camaro/Firebird 3.1 is very similar to the stock Fiero 2.8 including it's use of a distributor and iron-heads. With that being said, there were some significant differences between the two systems...
The 7730 ECM running $88 code mask does NOT use or need the 7th injector (cold start).
The 7730 ECM controls the coolant fan relay directly.
The 7730 ECM will interface with stock Fiero 2.8 ECM wiring harness. (although some modifications will be needed)
The 7730 ECM uses a knock sensor.
The 7730 ECM interfaces directly with the speed sensor which means changes can be made in the programming to calibrate the speedo without having to change out the plastic gears on the VSS sensor itself.
The 7730 ECM running the $88 code mask will NOT work with the stock Fiero 2.8 EGR valve. It is designed to work with the digital EGR valve used in the early-mid 90's era GM V6 cars. I went ahead and designed an adapter plate and had another Fiero friend make one up so we could use the digital EGR valve on the stock Fiero 2.8 y-pipe.
The biggest advantage to using the 7730 ECM in a Fiero application is not only more tunable options in the programming, but the drivability and response time of the engine improved significantly. Gone was the unstable idle characteristics of the stock 2.8 which some have said existed from the factory. Gone was the high idle flare upon startup. We quickly found out that using the 7730 ECM system on the stock 2.8 greatly improved it's drivability as well as throttle response and performance characteristics. Believe it or not, using the newer computer, even this stock 2.8 ran and acted like a new engine found in today's new cars! And because the 7th injector, fan switches, and vacuum-controlled EGR valve were no longer required, it also allowed us to clean up the wiring and vacuum lines on the stock 2.8 engine as well...
I think this is one of the most worthwhile upgrades for a stock (or even modded) 2.8. Obviously, it can also be used on 3.1 and 3.4 OHV swaps. Although if you are swapping in a newer 3.1 or 3.4 that has provisions for the DIS ignition system, I would recommend using the DIS as well. The 7730 ECM will work with the DIS ignition system if you use a different code mask (programming).
But be aware that I have made some changes in the way I tune things that will affect the viability of your product.
Any Fiero using a stock iron-head 2.8, iron-head 3.1, or iron-head 3.4 will still be able to make use of the 7730 ECM upgrade using the $88 (distributor) and $A1 (DIS) code masks – both of which will require the use of your digital EGR adapter plate.
However, for highly modded iron-head engines, I’m now recommending using the 7730 ECM with the 8D mask which won’t work with a digital EGR (but will work with the stock Fiero EGR).
The reason for this “update” is because the V6 masks ($88 and $A1) used in the 7730 ECM have some nasty limitations in them that prevent them from being able to work well with highly modded engines.
Ryan Gick
Sinister Performance, LLC.
Fort Wayne, Indiana USA
[This message has been edited by fierofool (edited 08-26-2017).]
Report this Post10-10-2017 08:41 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Up To The Top Again!
predmeister
Report this Post10-10-2017 08:47 PM Click Here to See the Profile for predmeisterSend a Private Message to predmeisterEdit/Delete MessageReply w/QuoteDirect Link to This Post
you have PM
Report this Post11-30-2017 11:28 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Give your Fiero a nice Christmas present. The Digital EGR Adapter Kit when installed will bring new life to your car. Combined with the 1227730 ECM conversion, it will bring new energy to your engine. Even does wonders for the driver by removing that frown and replacing it with a smile. Order yours, today.
fierogtx
Report this Post04-12-2018 11:25 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
do you still have kits ready to ship ?
Report this Post04-13-2018 12:03 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. We have 9 kits currently in stock.
fierogtx
Report this Post04-13-2018 06:11 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
sent a pm for internationnal shipping quote
Report this Post04-13-2018 06:18 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM returned.
fierogtx
Report this Post04-13-2018 08:55 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM returned.
dont received your pm
Report this Post04-13-2018 09:11 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I just checked and it wasn't in my outbox. I replied from my mobile, so I don't know what happened. I just pm'd again from my desktop, so you should get it this time.
fierogtx
Report this Post04-14-2018 08:35 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
received and pm returned
fierogtx
Report this Post04-18-2018 04:05 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
payement sent thanks
Report this Post05-16-2018 01:10 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can still Get 'Em, cuz we still Got 'Em. Order your EGR Adapter Kit, today. www.gafiero.org Club Merchandise button.
Report this Post10-15-2018 04:38 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been a while, but we still have them in stock. Bump.
Report this Post01-15-2019 10:04 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another bump to start the new year.
Lurate
Report this Post01-23-2019 12:49 PM Click Here to See the Profile for LurateClick Here to visit Lurate's HomePageSend a Private Message to LurateEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking to buy 7730 swap components. I see where I can buy the 7730 ECM from Rock Auto but I don't see anywhere to buy the pigtail. Anyone have these components that they want to sell? The only thing I have so far is the EGR adapter kit.
[This message has been edited by Lurate (edited 01-23-2019).]
Report this Post01-23-2019 01:31 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine Control Module (ECM) 1227730
66 COMPATIBLE MODEL YEARS
Pontiac 6000 1987, 1988, 1989, 1990, 1991
Chevrolet Beretta 1987, 1988, 1989, 1990, 1991, 1992, 1993
Chevrolet Camaro 1990, 1991, 1992
Chevrolet Camaro IROC-Z 1990
Chevrolet Camaro Z28 1991, 1992
Chevrolet Cavalier 1987, 1988, 1989, 1990, 1991, 1992, 1993
Chevrolet Celebrity 1987, 1988, 1989, 1990
Buick Century 1987, 1988
Oldsmobile Ciera 1987, 1988, 1989
Cadillac Cimarron 1987, 1988
Chevrolet Corsica 1987, 1988, 1989, 1990, 1991, 1992, 1993
Oldsmobile Cutlass (Ciera) Cruiser 1988, 1988, 1989, 1989
Oldsmobile Cutlass Ciera 1987, 1988, 1989
Pontiac Firebird 1990, 1991, 1992
Pontiac Firebird Trans Am 1990, 1991, 1992
Oldsmobile Firenza 1987
Buick Skyhawk 1987
Pontiac Sunbird 1991, 1992, 1993
Pontiac Tempest 1987, 1988, 1989, 1990, 1991
Report this Post04-12-2019 08:34 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now with the weather turning more favorable to working on our cars, it's time to finally do that 7730 conversion. Get your Digital EGR Adapter Kit while they last. We still have a few in stock.
http://gafiero.org Click on Club Merchandise
[This message has been edited by fierofool (edited 04-12-2019).]
Report this Post03-04-2020 06:33 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been nearly a year since the last bump. We're down to 1 adapter kit in stock and we're about to make another limited production run. Prices may be going up soon so get your orders in at the current $55 price.
Report this Post05-14-2020 10:30 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
We have just produced a new run. Due to dwindling conversions, I expect this to be the final run. There are only 12 remaining.
Report this Post01-02-2022 09:13 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! Nearly 2 years since a bump. WE have about a half dozen kits left. As I stated earlier, this may be the last run. You can order from this thread or from the Club Merchandise tab at www.gafiero.org
fierolover87
Report this Post01-02-2022 10:51 PM Click Here to See the Profile for fierolover87Send a Private Message to fierolover87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for bumping this. I've been considering doing a 7730, but I couldn't find who made these. I guess this was the sign.
Mike
87_special
Report this Post01-03-2022 01:55 PM Click Here to See the Profile for 87_specialSend a Private Message to 87_specialEdit/Delete MessageReply w/QuoteDirect Link to This Post
So glad I saw this! Just purchased one kit from the Club page.
Thanks,
Joe
Report this Post01-05-2022 09:25 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
As of this morning, January 5, there is only one adapter kit remaining. First come, first served.
fierolover87
Report this Post01-07-2022 10:05 PM Click Here to See the Profile for fierolover87Send a Private Message to fierolover87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine showed up yesterday. Thanks!
Mike
Report this Post01-09-2022 10:23 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
SOLD OUT. SOLD OUT. SOLD OUT. SOLD OUT.
