fieroguru 13" Brake Upgrade for 88 Fieros - available Jan 15th, 2012 by fieroguru
Started on | : 12-27-2011 07:41 PM |
Replies | : 258 (13282 views) |
Last post by | : ChanningB on 06-10-2020 02:58 PM |
Jan 16th, 2014
fieroguru Member Posts: 12426 From: Champaign, IL Registered: Aug 2003
Below is the pricing summary so you don't have to check other pages for it. Pricing Summary: All prices shipped for US and Canadian addresses unless noted. Hardware Kit only – Front:.....................$150 Front Only w/ plain rotors:.....................$225 (+$35 shipping surcharge to Canada) Front Only w/ Drilled/Slotted/Zinc Rotors:.$300 (+$35 to Canada) Hardware Kit Only – full car:...................$350 Full Kit with Plain Rotors:.......................$565 (+$70 to Canada) Full Kit with Drilled/Slotted/Zinc Rotors:....$640 (+$70 to Canada) If you are running a non-stock wheel pattern, I can drill the supplied rotors to either the 5 x 4 3/4" or 5 x 114.3mm patterns and modify the concentric rings... at no additional charge. Edit: Here is a picture of the rotors that that I have been using for the last 6 months:  [This message has been edited by fieroguru (edited 01-16-2014).]
01:24 PM
| quote | Originally posted by KissMySSFiero:
Do you think you'll be selling the LS4 starter mount plate? I just picked up my LS4. I'll most likely be going with the 282 w/HTOB but may do the F23 since I have one.
Yes, later this spring. I will start with the F40 one. The ones for other transmissions will be slightly different as the rear mounting point changes between transmission types.
01:26 PM
Jan 20th, 2014
Monday Bump!
07:31 AM
Jan 27th, 2014
Feb 3rd, 2014
Feb 10th, 2014
Feb 17th, 2014
Mar 10th, 2014
Mar 17th, 2014
Mar 24th, 2014
Mar 31st, 2014
Apr 7th, 2014
Apr 21st, 2014
Apr 28th, 2014
May 12th, 2014
May 19th, 2014
May 26th, 2014
Jun 2nd, 2014
Monday Bump! ------------------ Website: fieroguruperformance.com Products: 88 13" Brake Kit, 88 12" Brake Kit, 88 Lateral Link Relocation, 84-87 Machined Front Hubs, Custom Machining Engine Swaps: LS4/F40, HSR/SBC/F23, Pro-Flo/383/Getrag, 4.3CPI/4T60, Ramjet SBC/Getrag, 4.9/Isuzu, Carb SBC/Isuzu, 4.5/Isuzu
07:49 AM
Jun 9th, 2014
07:49 AM
Jun 23rd, 2014
07:52 AM
Jun 28th, 2014
deloreanant Member Posts: 216 From: Missouri Registered: Mar 2010
You wouldn't be planning a 4th of July sale, would you?
03:18 AM
Jul 28th, 2014
Bump!
Down to 4 hardware kits left in stock, but have placed the order for another 100 (25 full car kits) that should be here in 2-3 weeks.
07:48 AM
Aug 11th, 2014
2 week bump! ------------------ Website: fieroguruperformance.com Products: 88 13" Brake Kit, 88 12" Brake Kit, 88 Lateral Link Relocation, 84-87 Machined Front Hubs, Custom Machining Engine Swaps: LS4/F40, HSR/SBC/F23, Pro-Flo/383/Getrag, 4.3CPI/4T60, Ramjet SBC/Getrag, 4.9/Isuzu, Carb SBC/Isuzu, 4.5/Isuzu
08:04 AM
Aug 12th, 2014
Shho13 Member Posts: 916 From: Jersey Registered: Feb 2014
Couple quickie questions:
Very interested...
1) Do you drill the 5X100 bolt pattern into the rotors so they are ready to install on arrival? 2) When the rotors eventually need replacing will you still offer these in the future for easy replacement? 3) Factory sized pads are still put into the stock calipers? 4) I have a set of 16 inch rims installed now that I was planning on using for track use and buying 17 soon for road use. Will they squeeze inside the 16s in your experience?
When the tax return shows up I may have to do this upgrade...
12:22 AM
| quote | Originally posted by Shho13:
Very interested...
When the tax return shows up I may have to do this upgrade... |
1. Yes, the supplied rotors come with the 5x100 pattern already drilled into them. You just take them out of the box and slide them on. 2. Yes, I plan to keep offering this kit for years to come. 3. Yes, I use stock calipers, so stock pads are used. 4. Not w/o a lot of work (modification to the calipers) and 3/8" wheel spacers in the rear to clear the hose attachment (assuming a 16x7 35ET wheel, wider or more offset will make it worse). If you plan to use 16" wheels, my 12" kit is probably a better choice (and lower priced).
06:23 AM
Aug 25th, 2014
07:43 AM
Sep 15th, 2014
Bump! Inventory of the hardware kits has been replenished. I now have over 25 full car hardware kits in stock. ------------------ Website: fieroguruperformance.com Products: 88 13" Brake Kit, 88 12" Brake Kit, 88 Lateral Link Relocation, 84-87 Machined Front Hubs, Custom Machining Engine Swaps: LS4/F40, HSR/SBC/F23, Pro-Flo/383/Getrag, 4.3CPI/4T60, Ramjet SBC/Getrag, 4.9/Isuzu, Carb SBC/Isuzu, 4.5/Isuzu
07:55 AM
Oct 13th, 2014
08:00 AM
Oct 23rd, 2015
DKcustoms Member Posts: 1071 From: Central NY Registered: Oct 2013
Are you still making these? Asking due to the first post red text
11:52 PM
Oct 24th, 2015
Danyel Member Posts: 6089 From: Lévis, Québec, Canada Registered: Sep 2008
| quote | Originally posted by DKcustoms:
Are you still making these? Asking due to the first post red text |
Also been wanting a kit but he PMed me saying he is closed till 2016 ------------------
 Black Widow Build Thread 2007 - 2014 Tylers Toy
01:49 AM
I am not selling any of my products... way to busy with other stuff.
03:57 PM
... [This message has been edited by Danyel (edited 11-11-2015).]
07:06 PM
Mar 5th, 2016
Fieroguru Performance reopened March 23rd, 2016[This message has been edited by fieroguru (edited 04-25-2016).]
01:42 PM
Raydar Member Posts: 41092 From: Carrollton GA. Out in the... country. Registered: Oct 1999
I have this kit on my car. It rocks!
05:41 PM
Mar 18th, 2016
Steven Snyder Member Posts: 3326 From: Los Angeles, CA Registered: Mar 2004
| quote | Originally posted by fieroguru:
Fieroguru Performance will reopen April 1, 2016 |
Awesome news!
03:40 PM
Apr 25th, 2016
Bump!
08:15 AM
RMOR235 Member Posts: 43 From: Waynesboro, VA Registered: Jan 2012
I have an 87 with an 88 rear cradle and suspension, what do i need to make your kit fit the front? i would like to buy the entire kit but first i need to know if its possible to use this in the front
10:32 PM
| quote | Originally posted by RMOR235:
I have an 87 with an 88 rear cradle and suspension, what do i need to make your kit fit the front? i would like to buy the entire kit but first i need to know if its possible to use this in the front |
I do not offer any brake parts for the 84-87 Fieros. Sluppy123 is now using these same rotors for an 84-87 kit, so he can supply the needed parts for the front. I can supply the parts for the rear, but would recommend you buy the full set of rotors from one source (either from him or from me) to ensure they match front/rear. [This message has been edited by fieroguru (edited 04-25-2016).]
10:42 PM
Jun 20th, 2016
Bump!
08:28 AM
Jul 19th, 2016
Bump!
08:08 AM
