  The Mall
  Haus of Guru: Brake upgrade kit for 84-87 Fieros (Page 8)
Haus of Guru: Brake upgrade kit for 84-87 Fieros by bmwguru
Started on: 11-10-2011 11:45 AM
Replies: 292 (15195 views)
Last post by: IXSLR8 on 11-26-2017 12:29 PM
Driver_WT
Report this Post03-15-2013 08:58 PM Click Here to See the Profile for Driver_WTSend a Private Message to Driver_WTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am in for a front set if there is going to be a group buy.
Wade
hye_4_life
Report this Post03-16-2013 03:45 PM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wade
If you have the time, I can run an extra set for you when I run mine at school in the Fall. You'll have to get the rear brackets welded on your own, but this would probably be the cheapest route.
Driver_WT
Report this Post03-16-2013 05:56 PM Click Here to See the Profile for Driver_WTSend a Private Message to Driver_WTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there welding required for the front brackets? If not, I will take a set for the front if you get a deal with the CNC shop or wait until you do your class.
Thanks.
Wade
[This message has been edited by Driver_WT (edited 03-16-2013).]
hye_4_life
Report this Post03-18-2013 02:58 AM Click Here to See the Profile for hye_4_lifeSend a Private Message to hye_4_lifeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
Wade
The front brackets can be made in one piece. I'll go to a few CNC shops in the next few days to get some quotes and depending on that we can go from there.
sluppy123
Report this Post10-03-2015 05:26 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
FYI these will be available in the next few weeks waiting on material to mill the rears. Anybody interested in a set? All will be milled from 7075 Aluminum and powder coated black. I'm including the required rotor centering rings and the bolts. I'm also going to include a drill bit and tap to re-thread the rear knuckles to M12x1.75. The existing threads are not a common size and I don't want to make custom bolts. I totally redesigned the rears to add strength and allow the use of the factory ebrake cables, Only downside is the rear calipers need to be swaped left to right and this mounts the bleeders pointing down so they need to be bled off the car. I've done it and it isn't hard.
Price to be determined but will be cheaper than listed here, I'm cutting them myself so my overhead is low.
Total ratings: 259
Report this Post10-03-2015 07:55 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The needed bolts to attach the bracket to the rear upright are not rare, they are flywheel bolts from the LS(x) engine family.
WickedFieroGTP
Report this Post10-03-2015 09:04 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put me down for a set of front and rears. Possibly two sets.
fierogt455
Report this Post10-03-2015 10:43 PM Click Here to See the Profile for fierogt455Send a Private Message to fierogt455Edit/Delete MessageReply w/QuoteDirect Link to This Post
I need a set for the rear.
sluppy123
Report this Post10-04-2015 12:09 AM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info, I measure them as being M11 x 1.5 suprised gm would use such a strange thread. Oh and if I'm stepping on toes making these I will pull the plug on it.
Total ratings: 259
Report this Post10-04-2015 09:55 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
That size is also used for many honda head bolts.
Not stepping on any toes here, I have looked at doing something similar, but never finished it up. Now there are many, many other projects I would rather do than this, so I kinda doubt I will ever get back to revisiting a brake kit for the 84-87.
bmwguru
Total ratings: 131
Report this Post10-04-2015 03:40 PM Click Here to See the Profile for bmwguruClick Here to visit bmwguru's HomePageSend a Private Message to bmwguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like that redesigned rear bracket....nice job!
Dave
topcat
Total ratings: 148
Report this Post10-04-2015 04:03 PM Click Here to See the Profile for topcatSend a Private Message to topcatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am very interested in a rear set.
IXSLR8
Report this Post11-26-2017 12:29 PM Click Here to See the Profile for IXSLR8Send a Private Message to IXSLR8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any news on this 84-87 brake kit?
