fieroguru Lateral Link Relocation Kit - for 88 fieros by fieroguru
Started on : 02-12-2012 01:59 PM
Replies : 181 (10212 views)
Last post by : fieroguru on 10-12-2018 05:00 PM
Jan 20th, 2014
fieroguru Member Posts: 12436 From: Champaign, IL Registered: Aug 2003
Monday Bump!
07:33 AM
Jan 27th, 2014
Feb 3rd, 2014
Feb 10th, 2014
Feb 17th, 2014
Monday Bump!
I have the parts for 1 more set currently on hand and the parts for 10 more sets should be here in a week or two.
------------------fieroguruperformance.com
07:52 AM
Mar 10th, 2014
Mar 17th, 2014
Mar 24th, 2014
Monday Bump!
I also received the shipment of laser cut parts and machined tubes to make 10 more sets.
06:55 AM
Mar 31st, 2014
Apr 7th, 2014
Apr 21st, 2014
Apr 28th, 2014
May 12th, 2014
tshark Member Posts: 4388 From: Registered: Feb 2014
I want to get his straight. These are for the rear of the car, correct? My Fiero is not lowered in the rear, so no benefit to me, correct?
08:41 AM
quote Originally posted by tshark: I want to get his straight. These are for the rear of the car, correct? My Fiero is not lowered in the rear, so no benefit to me, correct?
Yes, this is a kit for the 1988 Fiero Rear Suspension.
If you install them on a stock ride height car, there will still be some benefit.
It will raise the rear roll center, reduce the distance between the RC and CG by 20.7%, and increase the rear roll resistance.
It will also provide 0.8 degrees more camber gain than stock with 6 degrees roll. (The stock 88 rear suspension loses 4.7 degrees of camber during 6 degrees of roll, so gaining back 0.8 is still losing 3.9 degrees). Due to the poor camber curve in the rear, reducing roll will provide signficant improvements in rear lateral grip.
My personal fiero has this kit and is only lowered about 3/4".
12:09 PM
Raydar Member Posts: 41105 From: Carrollton GA. Out in the... country. Registered: Oct 1999
Guru beat me to it.
My car is stock height (pretty much) in the rear, and I have the kit installed.
[This message has been edited by Raydar (edited 05-12-2014).]
12:10 PM
Great. More stuff I need to buy.
05:43 PM
May 19th, 2014
May 26th, 2014
Jun 2nd, 2014
Monday Bump!
------------------ Website: fieroguruperformance.com Products: 88 13" Brake Kit , 88 12" Brake Kit , 88 Lateral Link Relocation , 84-87 Machined Front Hubs , Custom Machining Engine Swaps:LS4/F40 , HSR/SBC/F23 , Pro-Flo/383/Getrag , 4.3CPI/4T60 , Ramjet SBC/Getrag , 4.9/Isuzu , Carb SBC/Isuzu , 4.5/Isuzu
07:54 AM
Jun 9th, 2014
Monday Bump!
07:50 AM
Jun 23rd, 2014
Monday Bump!
07:50 AM
Jul 28th, 2014
Bump!
07:51 AM
Aug 11th, 2014
2 week bump!
07:57 AM
Aug 25th, 2014
2 week bump!
07:45 AM
Sep 15th, 2014
Bump!
07:53 AM
Sep 19th, 2014
msweldon Member Posts: 671 From: Georgia Registered: Sep 2000
Just a friendly bump for a great product and to let you know I'll be opting for a set of these by year end if not within a couple months.
01:16 PM
Oct 2nd, 2014
yellow fever Member Posts: 280 From: Sioux Falls SD USA Registered: May 2002
will these still be for sale come spring time?
07:37 PM
Certainly! I have all the parts for 10 sets laser cut and sitting on the shelf waiting for an order before they are welded up.
07:57 PM
Oct 7th, 2014
Steven Snyder Member Posts: 3326 From: Los Angeles, CA Registered: Mar 2004
Finally got some good pics of the dynamic camber under high cornering forces with these brackets installed.
Static rear camber is -2.5 deg and I have 475 lb/in springs and the stock rear swaybar with polyurethane endlinks.
[This message has been edited by Steven Snyder (edited 10-07-2014).]
02:15 PM
Thanks for the pictures Steven, they are awesome!
05:12 PM
Oct 13th, 2014
[This message has been edited by fieroguru (edited 03-05-2016).]
07:57 AM
Mar 5th, 2016
Fieroguru Performance will reopen April 1, 2016
01:45 PM
Assuming there is no special significance to this being a leap year or the common name for April first, this is great news!
05:38 PM
Mar 6th, 2016
Atlanta1 Member Posts: 405 From: Atlanta Registered: May 2009
Great News! looking forward to buy some Lateral links
08:44 PM
Mar 20th, 2016
Fieroguru Performance reopened March 13th, 2016 I have enough components in stock to make 7 sets of these... accepting orders now.
[This message has been edited by fieroguru (edited 03-20-2016).]
05:35 PM
Mar 28th, 2016
Bump!
08:15 AM
Apr 4th, 2016
Monday Bump!
08:17 AM
Apr 25th, 2016
Bump!
08:17 AM
May 5th, 2016
goforspeed Member Posts: 31 From: Victorville, CA Registered: Jul 2014
PM sent.
08:31 AM
