  The Mall
  FS: SS GM Quick Disconnect Fuel Lines (3800 etc) (Page 1)
FS: SS GM Quick Disconnect Fuel Lines (3800 etc) by MRose
Started on: 05-31-2012 06:38 PM
Replies: 182 (7444 views)
Last post by: Matthew_Fiero on 07-07-2021 03:19 PM
MRose
Report this Post05-31-2012 06:38 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got a few pairs of the popular GM OEM stainless lines
These lines are OEM GM from the early 3800 vans; as such they are obviously used, I pull them from salvage yards. They are standard 3/8 and 5/16 GM late model quick disconnect on one end, and a short piece of metal pipe on the other (originally the plastic fuel line was shrunk over the metal end). You can connect these to your fiero's fuel system any number of ways, including the use of a compression fitting union (not included). See the links above for more info.
$40 shipped to the US per pair.
IF YOU'D LIKE A SET PLEASE EMAIL ME: convert46@yahoo.com
[This message has been edited by MRose (edited 11-15-2015).]
86soon3.4
Report this Post06-01-2012 12:14 AM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are these from a 3800 Lumina minivan?
Steve
85sliverGT
Report this Post06-01-2012 08:05 AM Click Here to See the Profile for 85sliverGTSend a Private Message to 85sliverGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes they are
MRose
Report this Post06-01-2012 12:24 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, dustbuster vans
MRose
Report this Post06-05-2012 03:19 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
bueler
TXOPIE
Report this Post06-05-2012 10:12 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Please PM me...I need a set.
MRose
Report this Post06-06-2012 05:19 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM Sent
[This message has been edited by MRose (edited 06-06-2012).]
Fierotregg
Report this Post06-06-2012 08:59 PM Click Here to See the Profile for FierotreggSend a Private Message to FierotreggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Needing a set, just curious though. Will these mount to the factory Fiero fuel lines, thanks.
MstangsBware
Total ratings: 459
Report this Post06-06-2012 09:22 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Edit cause of PM....These will connect to the factory Fiero lines on the bottom side as you can use a union or rubber hose...unsure what the S1 3800 uses up top as a connector....
[This message has been edited by MstangsBware (edited 06-06-2012).]
MRose
Report this Post06-07-2012 03:35 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have updated the original post with more detailed info about the lines, for those not familiar with their source or use.
MRose
Report this Post06-10-2012 08:56 AM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
bueler
MRose
Report this Post06-13-2012 04:49 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sent a couple sets out
MRose
Report this Post06-20-2012 09:20 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
bueler
solotwo
Total ratings: 62
Report this Post06-22-2012 11:29 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have you run across any Fieros in the yards around GR?
Steve W
NE Grand Rapids, MI
88 Coupe
MRose
Report this Post06-23-2012 07:20 AM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, got an axle a few weeks ago.
Steve W
NE Grand Rapids, MI
88 Coupe
fierofan25
Report this Post06-23-2012 08:55 AM Click Here to See the Profile for fierofan25Send a Private Message to fierofan25Edit/Delete MessageReply w/QuoteDirect Link to This Post
how much for just one. I have the returnless fuel system and only need the 3/8 one. Thanks
MRose
Report this Post06-26-2012 05:09 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shipped
solotwo
Total ratings: 62
Report this Post06-26-2012 10:22 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you seen any 88's?
Steve W
NE Grand Rapids, MI
88 Coupe
MRose
Report this Post06-27-2012 04:37 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Steve W
NE Grand Rapids, MI
88 Coupe
There was an 88 coupe a while back that was mostly complete, but its long gone.
solotwo
Total ratings: 62
Report this Post06-27-2012 05:20 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok thanks!
MRose
Report this Post07-02-2012 04:22 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
bueler
MRose
Report this Post07-12-2012 04:49 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine installed:
[This message has been edited by MRose (edited 12-11-2012).]
solotwo
Total ratings: 62
Report this Post07-12-2012 05:03 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
UUUUUUUUhhh that is what I want!
fieroall
Report this Post07-12-2012 05:25 PM Click Here to See the Profile for fieroallSend a Private Message to fieroallEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would have tucked the lines under the snout ... but that's just me. They are nice item.
[This message has been edited by fieroall (edited 06-17-2016).]
MRose
Report this Post07-12-2012 05:57 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by fieroall:
I would have tucked the lines under the snot ... but that's just me. They are nice item.
It was kind of an odd angle, given the direction that the hard lines come off the firewall, plus the alternator goes up there too.
I do agree with you, but its going to have a pretty OEM look to it anyways and that's the way GM runs stuff. They will probably end up with the OEM rubber sleeves over them, too.
[This message has been edited by MRose (edited 07-12-2012).]
pparker
Report this Post07-14-2012 06:11 PM Click Here to See the Profile for pparkerSend a Private Message to pparkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will take a set if still available. How do you want payment ?
MRose
Report this Post07-14-2012 09:28 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sent you a PM
pparker
Report this Post07-15-2012 02:07 PM Click Here to See the Profile for pparkerSend a Private Message to pparkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
MRose
Report this Post07-15-2012 03:00 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
See previous comment...
MRose
Report this Post07-24-2012 04:53 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
bueler
MRose
Report this Post08-04-2012 08:49 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
bueler
MRose
Report this Post08-10-2012 03:35 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sent a few sets out.
Tom Slick
Report this Post08-10-2012 07:03 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
got mine today
thanks...
MRose
Report this Post08-16-2012 06:19 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Tom
MRose
Report this Post08-28-2012 10:24 AM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
bermp
MRose
Report this Post09-07-2012 06:01 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
bueler
FieroNate
Report this Post09-09-2012 10:02 PM Click Here to See the Profile for FieroNateClick Here to visit FieroNate's HomePageSend a Private Message to FieroNateEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel Lines still available? PM me.
MRose
Report this Post09-10-2012 11:47 AM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sent
MRose
Report this Post09-23-2012 11:06 AM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still have a few sets
MRose
Report this Post09-28-2012 06:42 PM Click Here to See the Profile for MRoseSend a Private Message to MRoseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sent one out
