I am looking for a drivers side air scoop the same as what comes on the 84 fiero pace car. I would take both sides, but really only want the left side. I want to use one as a cold air intake setup for my 3800 s/c swap. Please let me know it you have anything. Thanks, Troy
To my knowlege the scoop was not on either side it was only one directly in the middle. You apparently may be confused, they do make over the roof scoops but they were not on the Indy Pace car.
------------------ 1984 Indy Pace Car\1988 Formula Custom President of Maryland Fiero Owners Club MFOC NYFOC Member
being confused is a possibility. lol All I know is i seen them on a car which i was thinking was the pace car.. my bad i guess
Just a question for those that know, are these scoops actually helpful on 85-88 Fieros? I can see why they'd be wanted on the 84's since your replacing the solid side deck plates with these scoops still allowing air to flow up through the center vent but if you replaced the side vents of an 85-88 with these scoops wouldn't you be countering the air coming out the vents 1. possibly causing an heat issue and 2. adding drag since there is no air pressure/flow to the back of the notch back. Just a question because these are cool looking just don't know if they'd be helpful on an 85-88.
This question has been discussed a bunch of times already. Consensus seems to be that they add no value, since air is supposed to come in from underneath the car and rise through the vents. These snorkel thingies look cool to some (to each their own), but don't apparently add any functional value according to most of the threads on this topic
... These snorkel thingies look cool to some (to each their own), but don't apparently add any functional value according to most of the threads on this topic
Yeah - if you just bolt them to the panels.
It depends what you do with them. Mine are functional on the Indy (otherwise I wouldn't have them). The driver's side feeds directly into an open top air cleaner, the other puts more air into the engine bay. Any EXTRA air into that hot engine bay can't be bad (84's have center vent on decklid).
They sure catch people's attention at the Show n Shines.
