  The Mall
  FS: Built Pass Axle for 3800SC Swaps (Page 1)
FS: Built Pass Axle for 3800SC Swaps by MstangsBware
Started on: 03-29-2013 04:00 AM
Replies: 45 (2924 views)
Last post by: adm927 on 10-15-2018 08:03 PM
MstangsBware
Total ratings: 459
Report this Post03-29-2013 04:00 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Offering up service on building the pass side axle for the 3800SC swap when using PR/FieroX or WCF mounts. The axle is plug/play when using the the mounts listed and a stock auto DRV side axle can be used on DRV side. I supply all the needed parts to build the axle. $250 shipped for axle....I use all OEM parts and no aftermarket parts. PM or post here if interested...
[This message has been edited by MstangsBware (edited 10-30-2013).]
MstangsBware
Total ratings: 459
Report this Post03-30-2013 08:24 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTT
MstangsBware
Total ratings: 459
Report this Post04-03-2013 10:20 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTT
FieroGTguy
Total ratings: 101
Report this Post04-03-2013 11:29 PM Click Here to See the Profile for FieroGTguyClick Here to visit FieroGTguy's HomePageSend a Private Message to FieroGTguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you know what power range they will be capable of tolerating, and how much HP one should have before considering the axle "the next weakest link"? I'm thinking of adding an intercooler. I'm on the edge right now with an XP cam, WCF headers, and GenV SC. I'm using rubber mounts though.
Thanks,
Greg
MstangsBware
Total ratings: 459
Report this Post04-04-2013 01:22 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks,
Greg
I run the same axle setup I sell and have on my swap for the past 6 years with no issues. That was canned, ICed, and cutting hard launches with 1.6s. Nosrac also runs the same axle setup with same MODs running around the same times with no issues. Hard to say when the axle will become the weakest link but with ur MOD list u will have no issues. I can tell u that u need to ditch the WCF style headers cause they r killing u on.the exhaust side....
MstangsBware
Total ratings: 459
Report this Post08-06-2013 06:18 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTT
FieroGTguy
Total ratings: 101
Report this Post08-06-2013 01:48 PM Click Here to See the Profile for FieroGTguyClick Here to visit FieroGTguy's HomePageSend a Private Message to FieroGTguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's your best recommendation for the exhaust? I considered 3" SS WCF, but just have the 2.5" now. I didn't wan't to cut the trunk, or I would have went with the TOGs over the SLP or Pace Setters. Not quite sure what the best bang for the buck is.
Thanks,
Greg
MstangsBware
Total ratings: 459
Report this Post08-06-2013 08:33 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks,
Greg
This all depends on what ur goal is HP and MOD wise..I don't care for WFC headers as they r prone to cracking and way over priced. I run TOGs but also cut my trunk but Amir runs then and didn't have to cut his trunk just dent it a little.
MstangsBware
Total ratings: 459
Report this Post08-11-2013 08:54 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTT
TTT
Rare87GT
Total ratings: 173
Report this Post08-11-2013 01:34 PM Click Here to See the Profile for Rare87GTSend a Private Message to Rare87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did have to dent the trunk barely if any. I really like the TOG headers. I haven't had any issues with them in 9 years of having them. I am going to be pulling them off to ceramic coat them soon and my entire exhaust. Really good deal on the axles being built. If I ever break one, I know who I'll be emailing. I've been lucky and ran multiple 11 second passes with no issues, on the strip and on the street hooking up quite well with no issues.
Take care,
Amir
Lou6t4gto
Report this Post09-27-2013 01:36 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just got an axle from mstangsbware. Quick and reasonable.
RUNDLC
Report this Post10-05-2013 01:32 PM Click Here to See the Profile for RUNDLCSend a Private Message to RUNDLCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello MBW
We need some info. we are swapping a 2000 3.8 sc from a grand prix into a 88, getting rid of the getrag and using a stock 4T65E-HD from the donor. we are going to try and use the stock mounts cut from the donor cradle and mock up to fit the 88 cradle. Can we use the axle that you supply trying it this way?
Can you tell me total cost +shipping to 95624 please. What would be the eta for the part?
I will pm you my contact info as I am not on here too often.
Thanks
MstangsBware
Total ratings: 459
Report this Post10-11-2013 08:36 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RUNDLC:
Hello MBW
Thanks
Donor axles ordered and will build axle as soon as they r here.....
Anyone else need an axle built?
MstangsBware
Total ratings: 459
Report this Post10-21-2013 04:52 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Axle built and will ship tomorrow......
Anyone else need one built?
cam-a-lot
Total ratings: 99
Report this Post10-21-2013 10:14 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any reason you are not making engine/tranny mounts to go with them? There seem to be no reliable vendors for these, and it would be great to sell a kit to go with the axles- ensuring they all work together. PR and Fiero X mounts seem to be knock-off/improvements over the WCF mounts, but there seems to be no "real" vendor selling proper 3800 mount kits.
Just a thought...
MstangsBware
Total ratings: 459
Report this Post10-21-2013 11:02 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a thought...
I have thought about making up mounts that pretty much copy the other 3 mounts mentioned but really dont have the time to do so with everything else I have going on. I have brought it up to another vendor that is in good standing but hears nothing else about it..
fieroVAN
Report this Post10-22-2013 03:50 PM Click Here to See the Profile for fieroVANSend a Private Message to fieroVANEdit/Delete MessageReply w/QuoteDirect Link to This Post
You got a PM.
Phil
MstangsBware
Total ratings: 459
Report this Post10-25-2013 09:47 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by fieroVAN:
You got a PM.
Phil
Donor axles ordered..Will build when they come in...
Anyone else? In an axle building groove...
MstangsBware
Total ratings: 459
Report this Post11-08-2013 05:39 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
You got a PM.
Phil
Axle shipped to address in PP email....
Anyone else need one?
don297
Report this Post01-20-2014 01:37 AM Click Here to See the Profile for don297Send a Private Message to don297Edit/Delete MessageReply w/QuoteDirect Link to This Post
Payment Sent. So glad I found out about this service. I was not looking forward to figuring out the mess of axles.
MstangsBware
Total ratings: 459
Report this Post01-21-2014 09:04 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Axles have been oredered and are on there way. Will build as soon as they get here...
MstangsBware
Total ratings: 459
Report this Post02-10-2014 01:14 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone else.....Building a few now but taking more orders...
crashmydaytona
Report this Post02-10-2014 03:26 PM Click Here to See the Profile for crashmydaytonaSend a Private Message to crashmydaytonaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent. Thanks
MstangsBware
Total ratings: 459
Report this Post02-10-2014 04:29 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Recieved and will order needdd axles tonight amd get them on the way..
MstangsBware
Total ratings: 459
Report this Post02-13-2014 10:37 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Axle shipped and tracking # in PM. Sorry for the time it took on getting it built and on the way.
MstangsBware
Total ratings: 459
Report this Post02-19-2014 09:46 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Axle is built..boxed up and will ship Friday morning.....
Anyone else needing an axle built?
don297
Report this Post02-20-2014 12:12 PM Click Here to See the Profile for don297Send a Private Message to don297Edit/Delete MessageReply w/QuoteDirect Link to This Post
Axle has been received very cleans looks like great quality. Will post again when swap is finished to tell you how it performs. Thanks again.
MstangsBware
Total ratings: 459
Report this Post02-20-2014 06:43 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good to hear....
MstangsBware
Total ratings: 459
Report this Post03-16-2014 11:23 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump.....
Grantman
Report this Post07-10-2014 09:21 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent
MstangsBware
Total ratings: 459
Report this Post09-01-2014 06:54 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump for anyone looking..Just finished up one so ready to build another...Who needs a plug/play axle for there 3800 swap?
MstangsBware
Total ratings: 459
Report this Post09-20-2014 07:20 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTT....
JCircs
Report this Post09-20-2014 07:28 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I forgot you made these, I got mine locally for the same price but after only a few runs it spat grease all over. During my recent upgrade I had him replace it for free but if it happens again I will surely be buying yours.
MstangsBware
Total ratings: 459
Report this Post09-20-2014 07:39 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably over packed the boot with grease..Ran into this issue with the axle I built for my swap when I dropped it for clean up. I used a new axle I had been holding onto and it resulted in slinging grease out over a period. I just cleaned up each time and it finally stopped..
MstangsBware
Total ratings: 459
Report this Post10-08-2014 12:45 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump..
nosrac
Total ratings: 51
Report this Post10-21-2014 11:27 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
MstangsBware
Total ratings: 459
Report this Post01-31-2015 01:56 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been a while since a bump..Incase new comers need an axle built
daniel87fierogt
Total ratings: 52
Report this Post12-16-2015 01:55 PM Click Here to See the Profile for daniel87fierogtSend a Private Message to daniel87fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am in need of the passenger axle. I seen you a pm, did you receive it. Thanks daniel
MstangsBware
Total ratings: 459
Report this Post12-16-2015 11:09 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did...I don't get on here as much but replied with my #..Text me whenever u get it.
MstangsBware
Total ratings: 459
Report this Post01-28-2016 03:05 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTT..Back to making if anyone needs...Email me if needing or PM me..Email is best
