  The Mall
  FS: Built Pass Axle for 3800SC Swaps (Page 2)
FS: Built Pass Axle for 3800SC Swaps by MstangsBware
Started on: 03-29-2013 04:00 AM
Replies: 45 (2936 views)
Last post by: adm927 on 10-15-2018 08:03 PM
MstangsBware
Total ratings: 459
Report this Post10-02-2016 03:02 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTT..Back to making if anyone needs...Email me if needing or PM me..Email is best
Another needed bump...Still building
Lancer-AM
Report this Post10-08-2016 08:22 PM Click Here to See the Profile for Lancer-AMSend a Private Message to Lancer-AMEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks man, the axle fits like a champ.
PRFiero
Report this Post10-10-2018 04:12 PM Click Here to See the Profile for PRFieroSend a Private Message to PRFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you still making these?
Total ratings: 328
Report this Post10-12-2018 09:24 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its great that a forum member is still building these swap axles but I have found that swaps are not always identical in how the powertrain is mounted. For the stick swaps the powertain is mounted in a fixed position due to the fact that the transmission stays in the exact same place on the exact same mounts. The stick swap can use a specific size axle. For the autos a number of different mounts have been used like those made by FieroX, Purple Reign and Fierorog. . I used West Coast Fiero mounts/brackets and the mounting is nearly centered. There is less than 1" difference on axle size from side to side, the passenger side being the longer one. Point is to specify
nosrac
Total ratings: 51
Report this Post10-15-2018 03:10 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, but you have to contact him here.
https://www.facebook.com/gr...800.Fiero.Swap.Page/
adm927
Report this Post10-15-2018 08:03 PM Click Here to See the Profile for adm927Send a Private Message to adm927Edit/Delete MessageReply w/QuoteDirect Link to This Post
I plan to use mounts made by James L. Brown. Do you think there will be any problem with using your axles? 3800 auto setup?
