  The Mall
  Fiero 3800 SC Supercharged L67 Swap Conversion Flywheel (Page 1)
Fiero 3800 SC Supercharged L67 Swap Conversion Flywheel by Fierorog
Started on: 09-05-2013 10:30 PM
Replies: 43 (4639 views)
Last post by: Fierorog on 06-14-2018 05:54 PM
Fierorog
Report this Post09-05-2013 10:30 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have 3800sc or 3800na conversion flywheels. I sell them for $250 shipped in the lower 48 states.
These are new flywheels that I turn down and balance to be used in a series II & III engine. The machining was done to enable the clutch to fit properly into the Fiero manual transmission. Please ask any questions you have. Thanks For looking. Roger
cell 319-939-1285
[This message has been edited by Fierorog (edited 01-27-2014).]
FIEROFLYER
Total ratings: 180
Report this Post09-06-2013 07:57 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
How much shipped to Ontario Canada and how long do they take to make or do you have stock made ahead. Dan
Fierorog
Report this Post09-06-2013 06:41 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sent you an email Dan.
Roger
DonP
Report this Post09-07-2013 11:30 AM Click Here to See the Profile for DonPClick Here to visit DonP's HomePageSend a Private Message to DonPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quick question, isn't the flywheel usually balanced by drilling material out of the backside versus drilling the face? That's been my experience... well, observation.
Fierorog
Report this Post09-07-2013 06:09 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
The flywheels i have been buying have been drilled on the front. I agree with you that I would have thought that it should be drilled on the back side.
Glen87
Report this Post09-07-2013 09:54 PM Click Here to See the Profile for Glen87Send a Private Message to Glen87Edit/Delete MessageReply w/QuoteDirect Link to This Post
What diameter of clutch can be used with these? Stock fiero size or do the ones from a camaro work?
Fierorog
Report this Post09-08-2013 09:26 AM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to use the fiero clutch. The camaro clutch has a different input shaft. The fiero has a 1 inch 14 tooth shaft and the camaro has a 1 1/8 inch 26 tooth shaft.
FIEROFLYER
Total ratings: 180
Report this Post09-08-2013 09:30 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure the clutch matches the tranny you are using. The aftermarket heavy duty 4 speed clutch will not clear on a Fiero 5 speed Getrag and only certain clutches will work with the F23. Dan
Fierorog
Report this Post10-03-2013 09:59 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a flywheel for the 3800sc ready to ship. Let me know if your interested.
Thanks,
Roger
Fierorog
Report this Post01-16-2014 10:09 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I keep flywheels on hand. So when you need one just let me know.
You can call or text me if you want at 319-939-1285.
Thanks, Roger
WickedFieroGTP
Report this Post01-18-2014 06:46 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
Fierorog
Report this Post01-18-2014 11:56 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm replied. Payment received. I will mail one out on Tuesday. Thanks, Roger
Fierorog
Report this Post02-05-2014 09:30 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
It time to start getting parts for that spring project.
Fierorog
Report this Post08-21-2014 05:41 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
grsychckn
Report this Post08-31-2014 01:40 PM Click Here to See the Profile for grsychcknSend a Private Message to grsychcknEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
86soon3.4
Report this Post12-25-2014 11:14 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have these in stock?
Price still good?
Steve
Fierorog
Report this Post12-26-2014 05:49 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
In stock and almost ready to go. You but that price is still good. $250 shipped in the U.S.
Thanks, Roger
Cell 319-939-1285
darbysan
Report this Post03-17-2015 01:38 PM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been trying to make a decision on a swap ( have a very low mileage Series I available ), but would like to keep my Getrag 5 spd. Been researching a flywheel for these, and know they are different, but wondered if you did Series I flywheels as well ( or know of a source).
Thanks
'87 GT in process!
Fierorog
Report this Post03-17-2015 07:23 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I do the series 1 also. If your going to do the swap, The series 2 is about 40 hp right out of the gate. I like my hp and I would look for a series 2. But thats just me.
Thanks, Roger
darbysan
Report this Post03-17-2015 07:48 PM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The one I am looking at is a '95 series 1, so 225 hp, with less than 90K miles, for little money. Otherwise, I would look for a series II. Just can't pass up a bargain, especially with low miles. But getting my ducks in a row before I buy it- don't want to be caught with something that is totally unusable.
ChrisMac97
Report this Post06-16-2015 05:09 PM Click Here to See the Profile for ChrisMac97Send a Private Message to ChrisMac97Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM'd
ChrisMac97
Report this Post07-09-2015 12:17 PM Click Here to See the Profile for ChrisMac97Send a Private Message to ChrisMac97Edit/Delete MessageReply w/QuoteDirect Link to This Post
Received and looks good! thanks again Roger
86soon3.4
Report this Post10-18-2015 10:52 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to order a flywheel for a 3800SC.
Please respond
Steve
Fierorog
Report this Post10-18-2015 11:38 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent
86soon3.4
Report this Post10-19-2015 05:26 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Pm replied
Steve
gtxbullet
Report this Post10-26-2015 02:50 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll take a 3800 series 2 balanced flywheel.
You have a pm
FieroFastBackL67
Report this Post10-29-2015 08:25 PM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
I also still need a balanced flywheel for my 3800sc getrag. Does it come with the bolts i need? Pmed you already.
[This message has been edited by FieroFastBackL67 (edited 10-29-2015).]
FieroFastBackL67
Report this Post11-01-2015 11:25 AM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump...
Fierorog
Report this Post11-01-2015 11:50 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, I'm sorry, they don't come with bolts.
gtxbullet
Report this Post11-13-2015 01:34 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sent payment on October 28th and haven't got any response to pm or email.
Hopefully you are alive and well.
Fierorog
Report this Post11-14-2015 09:26 AM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sorry, I have been away from my computer for a few days. Yes I'm alive and well. Just been really busy. Your flywheel will be in the mail on Monday. Thanks again. Roger
gtxbullet
Report this Post12-10-2015 02:05 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need to know what bolts I need for the pressure plat. And for the flywheel.
gtxbullet
Report this Post12-10-2015 02:10 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
gtxbullet
Member since Apr 2008
Total ratings: 328
Report this Post12-10-2015 03:35 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The exact GM part number for flywheel bolts is referenced on the Sinister Performance website. If you cannot find it I cann look it up in my own personal file when I get home
AutoMarshal
Report this Post12-10-2015 09:35 PM Click Here to See the Profile for AutoMarshalClick Here to visit AutoMarshal's HomePageSend a Private Message to AutoMarshalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here you go Steve......
I got the clutch and flywheel bolts from the local GM dealership.
Clutch bolts: part# 24571667 $2.60 each times 6= $15.60
Flywheel bolts: part# 24505092 $3.20 each times 8= $25.60
Torque specs:
flywheel: 11 lb/ft + 50* (I like to use a bit of red thread lock on the bolts)
clutch: 15 lb/ft + 45* (I like to use a bit of red thread lock on the bolts)
https://www.fiero.nl/forum/F...2/HTML/000156-4.html
Humungus1138
Report this Post01-26-2016 03:46 PM Click Here to See the Profile for Humungus1138Send a Private Message to Humungus1138Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you still doing these? I am looking for one for a series II 3800 that I want to mate with an F40 transmission. I may have contacted you through eBay as well
Roger
Fierorog
Report this Post01-31-2016 02:28 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ya, That is me on ebay as well. lol
look me up on facebook too.
ignorant prodigy
Report this Post02-02-2016 09:16 AM Click Here to See the Profile for ignorant prodigySend a Private Message to ignorant prodigyEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent
FIER086
Report this Post02-12-2016 03:32 PM Click Here to See the Profile for FIER086Send a Private Message to FIER086Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent to you!
Fierorog
Report this Post02-15-2016 02:43 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
P.M.s replied to.
You can also get me on my cell at 319-939-1285
Thanks, Roger
