  The Mall
  3.4 Engine Stuff and 4T60-E
3.4 Engine Stuff and 4T60-E by ragging_fiero
Started on: 02-17-2014 09:11 PM
Replies: 14 (689 views)
Last post by: ragging_fiero on 03-29-2014 04:21 PM
ragging_fiero
Report this Post02-17-2014 09:11 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, i'm trying to get a little money for 3.4 project. I have a bunch of stuff from the camaro so the intake the clutch the starter anything you can think of that came off of the motor. I do have the A/C compressor still and the digital EGR i may have other things as well. The 4T60-E came out out of a car that had a 3800. I don't know what car it was. If you need anything just ask!!
ragging_fiero
Report this Post02-18-2014 08:53 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
I have the:
DIS system
Starter
3.4 Flywheel
Clutch System
Wiring Harness-SOLD!!
Upper, Middle, and Lower Intake
Digital EGR
A/C Compressor
Oil Pan
Just ask i may have it! Throw out offers!
Thanks!!
[This message has been edited by ragging_fiero (edited 02-22-2014).]
ragging_fiero
Report this Post02-22-2014 11:12 AM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
ragging_fiero
Report this Post02-25-2014 04:18 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump, I don't need any of this stuff and most of it is still in good shape! Otherwise it will go to scrap or the junkyard
ragging_fiero
Report this Post03-03-2014 06:33 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
1MohrFiero
Total ratings: 157
Report this Post03-03-2014 08:27 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got the harness. Thanks,
1MohrFiero
Total ratings: 157
Report this Post03-03-2014 08:31 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
1MohrFiero
Member since Apr 2003
ragging_fiero
Report this Post03-14-2014 12:36 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
ragging_fiero
Report this Post03-15-2014 10:03 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!! C'mon i know some of this stuff can be sold!
ragging_fiero
Report this Post03-17-2014 10:09 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
josef644
Total ratings: 103
Report this Post03-18-2014 01:02 PM Click Here to See the Profile for josef644Send a Private Message to josef644Edit/Delete MessageReply w/QuoteDirect Link to This Post
There is a metal tag, like this, on the side of the transmission.
Can you take a picture and post it for me? This tag will identify the year of manufiasture, gear artios, and converter stall speed. If it is to dirty to read, just wipe it off with a rag. Don't use carb cleaner of brake cleaner. They will remove the information printed on the tag.
[This message has been edited by josef644 (edited 03-18-2014).]
ragging_fiero
Report this Post03-18-2014 02:53 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heres what you asked for i tried to clean it but it didn't want to come off. If you can't read them here they are otherwise i have some of it down there
6
1
3
Y
U
W
8
9
N
L
josef644
Total ratings: 103
Report this Post03-18-2014 04:02 PM Click Here to See the Profile for josef644Send a Private Message to josef644Edit/Delete MessageReply w/QuoteDirect Link to This Post
3 means 1993
YUW mean's, gear ratio. Y?W's in 92, 93, and 94 were either 2.84 or 3.06 final drive ratios. the 2.84 used a 1420 rpm stall converter. The 3.06 used a 1897 rpm stall converter.
YUW wasn't on the list at Sinister performance. All the Y?W transmissions listed were used with 3800 engines.
Can you PM me, or just post what you are looking to get for this transmission.
Thanks
ragging_fiero
Report this Post03-18-2014 04:18 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
3 means 1993
Thanks
PM sent
ragging_fiero
Report this Post03-29-2014 04:21 PM Click Here to See the Profile for ragging_fieroSend a Private Message to ragging_fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
