Recently purchased the contents of a 2k square foot storage unit filled with Fiero parts. These parts have been sitting in storage for over ten years. They might be dirty and may have some slight damage. I have separated and disposed of all the non-usable items. Everything I am offering is in serviceable to very good condition. I can email pictures upon request. This is just the beginning of what was in the unit. I will be posting additional items as soon as I get more inventoried so check back if you don't see what you are looking for at this time. Prices do not include s/h.
PART/ QTY/PRICE
Front main window trim with spring 4/ 25
Drivers side fastback window inside trim 1/ 25
4cyl cross over pipe w/ EGR 1/ 25
Rear window w/ defrost 4/ 35
Rear window w/o defrost 2/ 25
Head liner w/o sunroof (Local Pick up) Sold OutSunroof Glass 6/ 25
Spare tire tray 2/ 25
LS door glass 12/ 45
RS door glass 9/ 45
Passenger lower quarter pnl w/ grnd effect 4/ 35
Passenger lower quarter pnl w/o grnd effect 4/ 25
Roof (Solid)( Local pick up) 1/ 65
Roof (Sun)(Local Pick up) 3/ 55
Headlight assy. (Left) (No motor) 4/ 25
Headlight assy. (Right) (No motor) 9/ 25
Rear bulkhead pnl. (Tan) 2/ 45
Rear bulkhead pnl. (Grey) 3/ 25
Rear bulkhead pnl. (Light Grey) 3/ 25
Door panels (Drivers Light Grey, Manual mirror) 2/ 25
Door panels (Drivers Light Grey, Power) 1/ 35
Door panels (Drivers Dark Grey, Power) 1/ 35
Door panels (Drivers Dark Grey, Manual mirror) 1/ 25
Door panels (Passenger Light Grey, Power) 3/ 35
Door panels (Passenger Dark Grey, Power) 1/ 35
Door panels (Passenger Tan, Power) 1/ 35
Door skins (Driver) 10/ 25
Door Skin (Pass) 8/ 25
Steering columns (multiple configs) (w/keys) 11/ 75
A pillars (Driver) (Grey) 10/ 20
A pillars (Driver) (Tan) 2/ 20
A pillars (Passenger) (Grey) 9/ 20
A pillars (Passenger) (Tan) 2/ 20
B pillars (Driver) (Grey) (no speaker) 10/ 10
B pillars (Driver) (Tan) (no speaker) 2/ 15
B pillars (Driver) (Grey) (w/ speaker grill) 3/ 20
B pillars (Driver) (Tan) (w/ speaker grill) 1/ 25
B pillars (Passenger) (Grey) (no speaker) 4/ 10
B pillars (Passenger) (Tan) (no speaker) 2/ 15
B pillars (Passenger) (Grey) (w/ speaker grill) 5/ 20
B pillars (Passenger) (Tan) (w/ speaker grill) 2/ 25
Drivers sill panel trim (Grey) 8/ 20
Drivers sill panel trim (Tan) 1/ 20
Center dash console (grey) 11/ 25
Center dash console (Brown) 1/ 35
Center dash console (Tan) 1/ 35
Gauge Cluster (80 MPH) 5/ 55
Gauge Cluster (85 MPH) 12/ 65
Gauge Cluster (85 MPH) (NOS)(zero mile) 1/ 85
Mirror (Power) (Driver) SOLD OUTMirror (Power) (Passenger) 2/ 35
Mirror (Non-Power) (Driver) 8/ 25
Mirror (Non-Power) (Passenger) 2/ 25
Lower steering wheel covers (Grey) 11/ 15
Lower steering wheel covers (Brown) 1/ 20
Lower steering wheel covers (Tan) 1/ 20
Notch 1/4 Windows (Driver) 8/ 25
Notch 1/4 Windows (Passenger) 8/ 25
Notch 1/4 Windows (Just Glass) (Set) 1/ 85
Center storage console (Grey) 10/ 40
Center storage console (Tan) 1/ 50
Notchback engine vents (Set) 10/ 40
Starter 5/ 25
Alternator 1/ 25
Upper Intake (Engraved) 2/ 25
Upper Intake (Non-Engraved) 4/ 25
Lower Intake 4/ 25
Master Cylinder 2/ 25
A/C compressor 2/ 50
Valve cover (w/ oil fill) 1/ 25
Valve cover (w/o oil fill) 4/ 2
Fuel Rails (w/ injectors) 4/ 25
Throttle bodies (6cyl) 6/ 45
Distributor (4cyl) 6/ 35
Distributor (6cyl) 4/ 45
Intake manifold (4cyl) 5/ 30
Standard grill 4/ 20
Shift bezel (Auto) 5/ 25
Shift bezel (5spd) 2/ 25
Shift bezel (4spd) 2/ 25
Eng. Compartment blowers 4/ 25
Windshield wiper motor 4/ 10
Seat belt set (gray) 3/ 25
Seat belt set (tan) 1/ 25
Seat belt receptacle set (gray) 6/ 20
Seat belt receptacle set (tan) 1/ 20
Front hood supports 6/ 20
Jack & lug wrench 5/ 20
Steering Column shaft boot 2/ 10
Manifold 4 cyl 4/ 25
Manifold 6 cyl (rear) 4/ 25
Manifold 6 cyl (front) 3/ 25
Reflective "Fiero" skirt trim set 1/ 50
AC lines (86) 1/ 25
AC lines (85) 2/ 25
Dash vents (sets) 4/ 25
Coils 2/ 10
GT Spoiler 2/ 100
Dash Speaker Cover (right) 5/ 10
Dash Speaker Cover (left) 7/ 10
E brake cable (main) 3/ 20
E brake cable (left) 3/ 20
E brake cable (right) 3/ 20
E brake cable (88 right) 1/ 25
E brake handles 2/ 20
5 speed shifter assembly 2/ 25
4 speed shifter assembly 1/ 25
Auto shifter assembly 3/ 25
Brake pedal assembly 1/ 25
Manual pedal assembly 4/ 25
Gas pedal 2/ 10
Clutch Pedal 2/ 10
Brake/Shift safety switch and cable 1/ 25
Heater Controls (tan buttons) 8/ 20
Heater Controls (black buttons) 5/ 20
Heater Controls (slide no AC) 2/ 15
Engine vent bracket sets 15/ 20
Notchback filler panel set 8/ 20
Front turn signals (left) 10/ 5
Front turn signals (right) 13/ 5
Cluster surround (grey) 9/ 25
Cluster surround (tan) 2/ 35
Center console door (grey) 1/ 15
Center console door (tan) 1/ 15
4 cyl front engine cover 1/ 35
Tranny pan 1/ 25
AC bracket (87) 2/ 20
4 cyl dog bone bracket (left) 1/ 20
6 cyl alternator bracket 1/ 50
Strut plates 4/ 5
Clutch Master Cylinder 1/ 20
Fuel Vapor Canister 3/ 10
Heater Core 2/ 10
4 cyl water pump 2/ 20
4 cyl throttle body 5/ 20
Overhead consoles (gray) 13/ 15
Overhead consoles (dark brown) 1/ 15
Overhead consoles (tan) 2/ 15
Arm rests (driver gray) 11/ 10
Arm rests (driver tan) 1/ 15
Arm rests (passenger gray) 8/ 10
Arm rests (passenger tan) 2/ 15
Map pockets (gray) 9/ 10
Map pockets (tan) 1/ 15
Shifter surrounds (gray) 5/ 25
Shifter surrounds (tan) 2/ 30
Ashtrays 23/ 5
"Fiero" ground effect inserts 10/ 5
Radio face plates (gray) 5/ 50
Radio face plates (Dot Matrix) 2/ 65 Sold OutDash gauge cluster bezel (gray) 5/ 20
Dash gauge cluster bezel (Dot Matrix) 2/ 30
Fuel door release latch 6/ 10
Door Handle covers (power set) w/switches 1/ 35
Door Handle covers (power set) w/o switches 1/ 25
Door Handle Cover (non-power set) 1/ 25
Light switches with excellent lettering 12/ 25
Power window switch plates (power) 3/ 15
Power window switch plates (non-power) 4/ 10
Trunk release switches (with defrost) 2/ 15
Trunk release switches (without defrost) 5/ 10
Trunk release switches (blank off) 1/ 5
Hood release handle 6/ 10
Dimmer Switch 1/ 5
Cigarette lighter trim 13/ 10
Dash side trim (gray sets) 3/ 10
Dash side trim (tan sets) 1/ 10
3rd brake light cover 4/ 5
E brake boots (gray) 2/ 10
E brake boots (tan) 2/ 15
Pontiac tire center caps 11/ 10
Dog Bones (4 cyl) 6/ 10
Dog Bones (6 cyl) 2/ 10
Engine Coolant fill neck (4cyl) 4/ 25
Engine Coolant fill neck (6cyl) 4/ 25
Fenders (Driver) 8/ 45
Fenders (Passenger) 7/ 45
OEM Speakers 3/ 15
Rear view mirrors 12/ 20
Door hinge (complete set) 2/ 50
Door hinge (left set) 1/ 25
Interior door handles 8/ 5
Air cleaner (6cyl) 3/ 20
Air cleaner (4cyl) 5/ 20
Air cleaner hoses (6cyl) 1/ 25
Air cleaner hoses (4cyl) 3/ 25
Cruise control servo 6/ 10
Cruise control canister 4/ 20
Shift knob (auto) 8/ 10
Shift knob (manual)
Edited to update inventory.
[This message has been edited by WickedFieroGTP (edited 09-09-2014).]
