  The Mall
  Parts, Parts and more Parts (Page 1)
Parts, Parts and more Parts by WickedFieroGTP
Started on: 03-20-2014 11:21 PM
Replies: 104 (3915 views)
Last post by: vEnOm on 09-09-2014 02:39 PM
WickedFieroGTP
Report this Post03-20-2014 11:21 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Recently purchased the contents of a 2k square foot storage unit filled with Fiero parts. These parts have been sitting in storage for over ten years. They might be dirty and may have some slight damage. I have separated and disposed of all the non-usable items. Everything I am offering is in serviceable to very good condition. I can email pictures upon request. This is just the beginning of what was in the unit. I will be posting additional items as soon as I get more inventoried so check back if you don't see what you are looking for at this time. Prices do not include s/h.
PART/ QTY/PRICE
Front main window trim with spring 4/ 25
Drivers side fastback window inside trim 1/ 25
4cyl cross over pipe w/ EGR 1/ 25
Rear window w/ defrost 4/ 35
Rear window w/o defrost 2/ 25
Head liner w/o sunroof (Local Pick up) Sold Out
Sunroof Glass 6/ 25
Spare tire tray 2/ 25
LS door glass 12/ 45
RS door glass 9/ 45
Passenger lower quarter pnl w/ grnd effect 4/ 35
Passenger lower quarter pnl w/o grnd effect 4/ 25
Roof (Solid)( Local pick up) 1/ 65
Roof (Sun)(Local Pick up) 3/ 55
Headlight assy. (Left) (No motor) 4/ 25
Headlight assy. (Right) (No motor) 9/ 25
Rear bulkhead pnl. (Tan) 2/ 45
Rear bulkhead pnl. (Grey) 3/ 25
Rear bulkhead pnl. (Light Grey) 3/ 25
Door panels (Drivers Light Grey, Manual mirror) 2/ 25
Door panels (Drivers Light Grey, Power) 1/ 35
Door panels (Drivers Dark Grey, Power) 1/ 35
Door panels (Drivers Dark Grey, Manual mirror) 1/ 25
Door panels (Passenger Light Grey, Power) 3/ 35
Door panels (Passenger Dark Grey, Power) 1/ 35
Door panels (Passenger Tan, Power) 1/ 35
Door skins (Driver) 10/ 25
Door Skin (Pass) 8/ 25
Steering columns (multiple configs) (w/keys) 11/ 75
A pillars (Driver) (Grey) 10/ 20
A pillars (Driver) (Tan) 2/ 20
A pillars (Passenger) (Grey) 9/ 20
A pillars (Passenger) (Tan) 2/ 20
B pillars (Driver) (Grey) (no speaker) 10/ 10
B pillars (Driver) (Tan) (no speaker) 2/ 15
B pillars (Driver) (Grey) (w/ speaker grill) 3/ 20
B pillars (Driver) (Tan) (w/ speaker grill) 1/ 25
B pillars (Passenger) (Grey) (no speaker) 4/ 10
B pillars (Passenger) (Tan) (no speaker) 2/ 15
B pillars (Passenger) (Grey) (w/ speaker grill) 5/ 20
B pillars (Passenger) (Tan) (w/ speaker grill) 2/ 25
Drivers sill panel trim (Grey) 8/ 20
Drivers sill panel trim (Tan) 1/ 20
Center dash console (grey) 11/ 25
Center dash console (Brown) 1/ 35
Center dash console (Tan) 1/ 35
Gauge Cluster (80 MPH) 5/ 55
Gauge Cluster (85 MPH) 12/ 65
Gauge Cluster (85 MPH) (NOS)(zero mile) 1/ 85
Mirror (Power) (Driver) SOLD OUT
Mirror (Power) (Passenger) 2/ 35
Mirror (Non-Power) (Driver) 8/ 25
Mirror (Non-Power) (Passenger) 2/ 25
Lower steering wheel covers (Grey) 11/ 15
Lower steering wheel covers (Brown) 1/ 20
Lower steering wheel covers (Tan) 1/ 20
Notch 1/4 Windows (Driver) 8/ 25
Notch 1/4 Windows (Passenger) 8/ 25
Notch 1/4 Windows (Just Glass) (Set) 1/ 85
Center storage console (Grey) 10/ 40
Center storage console (Tan) 1/ 50
Notchback engine vents (Set) 10/ 40
Starter 5/ 25
Alternator 1/ 25
Upper Intake (Engraved) 2/ 25
Upper Intake (Non-Engraved) 4/ 25
Lower Intake 4/ 25
Master Cylinder 2/ 25
A/C compressor 2/ 50
Valve cover (w/ oil fill) 1/ 25
Valve cover (w/o oil fill) 4/ 2
Fuel Rails (w/ injectors) 4/ 25
Throttle bodies (6cyl) 6/ 45
Distributor (4cyl) 6/ 35
Distributor (6cyl) 4/ 45
Intake manifold (4cyl) 5/ 30
Standard grill 4/ 20
Shift bezel (Auto) 5/ 25
Shift bezel (5spd) 2/ 25
Shift bezel (4spd) 2/ 25
Eng. Compartment blowers 4/ 25
Windshield wiper motor 4/ 10
Seat belt set (gray) 3/ 25
Seat belt set (tan) 1/ 25
Seat belt receptacle set (gray) 6/ 20
Seat belt receptacle set (tan) 1/ 20
Front hood supports 6/ 20
Jack & lug wrench 5/ 20
Steering Column shaft boot 2/ 10
Manifold 4 cyl 4/ 25
Manifold 6 cyl (rear) 4/ 25
Manifold 6 cyl (front) 3/ 25
Reflective "Fiero" skirt trim set 1/ 50
AC lines (86) 1/ 25
AC lines (85) 2/ 25
Dash vents (sets) 4/ 25
Coils 2/ 10
GT Spoiler 2/ 100
Dash Speaker Cover (right) 5/ 10
Dash Speaker Cover (left) 7/ 10
E brake cable (main) 3/ 20
E brake cable (left) 3/ 20
E brake cable (right) 3/ 20
E brake cable (88 right) 1/ 25
E brake handles 2/ 20
5 speed shifter assembly 2/ 25
4 speed shifter assembly 1/ 25
Auto shifter assembly 3/ 25
Brake pedal assembly 1/ 25
Manual pedal assembly 4/ 25
Gas pedal 2/ 10
Clutch Pedal 2/ 10
Brake/Shift safety switch and cable 1/ 25
Heater Controls (tan buttons) 8/ 20
Heater Controls (black buttons) 5/ 20
Heater Controls (slide no AC) 2/ 15
Engine vent bracket sets 15/ 20
Notchback filler panel set 8/ 20
Front turn signals (left) 10/ 5
Front turn signals (right) 13/ 5
Cluster surround (grey) 9/ 25
Cluster surround (tan) 2/ 35
Center console door (grey) 1/ 15
Center console door (tan) 1/ 15
4 cyl front engine cover 1/ 35
Tranny pan 1/ 25
AC bracket (87) 2/ 20
4 cyl dog bone bracket (left) 1/ 20
6 cyl alternator bracket 1/ 50
Strut plates 4/ 5
Clutch Master Cylinder 1/ 20
Fuel Vapor Canister 3/ 10
Heater Core 2/ 10
4 cyl water pump 2/ 20
4 cyl throttle body 5/ 20
Overhead consoles (gray) 13/ 15
Overhead consoles (dark brown) 1/ 15
Overhead consoles (tan) 2/ 15
Arm rests (driver gray) 11/ 10
Arm rests (driver tan) 1/ 15
Arm rests (passenger gray) 8/ 10
Arm rests (passenger tan) 2/ 15
Map pockets (gray) 9/ 10
Map pockets (tan) 1/ 15
Shifter surrounds (gray) 5/ 25
Shifter surrounds (tan) 2/ 30
Ashtrays 23/ 5
"Fiero" ground effect inserts 10/ 5
Radio face plates (gray) 5/ 50
Radio face plates (Dot Matrix) 2/ 65 Sold Out
Dash gauge cluster bezel (gray) 5/ 20
Dash gauge cluster bezel (Dot Matrix) 2/ 30
Fuel door release latch 6/ 10
Door Handle covers (power set) w/switches 1/ 35
Door Handle covers (power set) w/o switches 1/ 25
Door Handle Cover (non-power set) 1/ 25
Light switches with excellent lettering 12/ 25
Power window switch plates (power) 3/ 15
Power window switch plates (non-power) 4/ 10
Trunk release switches (with defrost) 2/ 15
Trunk release switches (without defrost) 5/ 10
Trunk release switches (blank off) 1/ 5
Hood release handle 6/ 10
Dimmer Switch 1/ 5
Cigarette lighter trim 13/ 10
Dash side trim (gray sets) 3/ 10
Dash side trim (tan sets) 1/ 10
3rd brake light cover 4/ 5
E brake boots (gray) 2/ 10
E brake boots (tan) 2/ 15
Pontiac tire center caps 11/ 10
Dog Bones (4 cyl) 6/ 10
Dog Bones (6 cyl) 2/ 10
Engine Coolant fill neck (4cyl) 4/ 25
Engine Coolant fill neck (6cyl) 4/ 25
Fenders (Driver) 8/ 45
Fenders (Passenger) 7/ 45
OEM Speakers 3/ 15
Rear view mirrors 12/ 20
Door hinge (complete set) 2/ 50
Door hinge (left set) 1/ 25
Interior door handles 8/ 5
Air cleaner (6cyl) 3/ 20
Air cleaner (4cyl) 5/ 20
Air cleaner hoses (6cyl) 1/ 25
Air cleaner hoses (4cyl) 3/ 25
Cruise control servo 6/ 10
Cruise control canister 4/ 20
Shift knob (auto) 8/ 10
Shift knob (manual)
Edited to update inventory.
[This message has been edited by WickedFieroGTP (edited 09-09-2014).]
Ang84Indy
Report this Post03-21-2014 12:18 AM Click Here to See the Profile for Ang84IndySend a Private Message to Ang84IndyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a P.M.
WickedFieroGTP
Report this Post03-22-2014 07:07 AM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm replied to.
BabyEating Dingo
Report this Post03-22-2014 10:58 AM Click Here to See the Profile for BabyEating DingoSend a Private Message to BabyEating DingoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent!
dematrix86gt
Report this Post03-22-2014 09:09 PM Click Here to See the Profile for dematrix86gtSend a Private Message to dematrix86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm sent
hnthomps
Total ratings: 51
Report this Post03-23-2014 02:42 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
Nelson
WickedFieroGTP
Report this Post03-23-2014 02:14 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking into shipping for above posts. I will get back to everyone Monday evening.
tshark
Total ratings: 68
Report this Post04-02-2014 07:38 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
oldschoolbilly
Report this Post04-03-2014 03:57 PM Click Here to See the Profile for oldschoolbillySend a Private Message to oldschoolbillyEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
WickedFieroGTP
Report this Post04-08-2014 06:19 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Updated quantities.
fgt1988
Report this Post04-09-2014 08:27 AM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM -
RJS525
Report this Post04-09-2014 03:49 PM Click Here to See the Profile for RJS525Click Here to visit RJS525's HomePageSend a Private Message to RJS525Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM
WickedFieroGTP
Report this Post04-09-2014 10:14 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm's replied to.
Curtisk1060
Report this Post04-10-2014 01:26 AM Click Here to See the Profile for Curtisk1060Send a Private Message to Curtisk1060Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for a "black" trunk release switch in good working condition if you have one. I don't know if my PM worked when I sent it to you..Curtisk1060
RJS525
Report this Post04-12-2014 10:45 AM Click Here to See the Profile for RJS525Click Here to visit RJS525's HomePageSend a Private Message to RJS525Edit/Delete MessageReply w/QuoteDirect Link to This Post
Payment sent
WickedFieroGTP
Report this Post04-12-2014 10:56 AM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RJS525:
Payment sent
Payment received. Will be shipped within an hour.
Ravant
Report this Post04-12-2014 07:35 PM Click Here to See the Profile for RavantSend a Private Message to RavantEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
kyfly727
Report this Post04-13-2014 09:47 AM Click Here to See the Profile for kyfly727Send a Private Message to kyfly727Edit/Delete MessageReply w/QuoteDirect Link to This Post
send pm , you have lots of great stuff
WickedFieroGTP
Report this Post04-13-2014 11:30 AM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
pms replied to.
RJS525
Report this Post04-15-2014 01:12 PM Click Here to See the Profile for RJS525Click Here to visit RJS525's HomePageSend a Private Message to RJS525Edit/Delete MessageReply w/QuoteDirect Link to This Post
Received package today.
Thanks for the quick turnaround. Positive feedback for communication and shipping.
Jimmy2s83
Report this Post04-15-2014 06:22 PM Click Here to See the Profile for Jimmy2s83Send a Private Message to Jimmy2s83Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
Please let me know if you got it.
Thanks!
johnyrottin
Total ratings: 85
Report this Post04-16-2014 09:22 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shift bezel (5spd) 2/ 25....are either of these dot matrix? Can you post a pic of the one or ones that are please? I need one but would like to find a really, really good one.
dajack761
Report this Post04-16-2014 11:33 AM Click Here to See the Profile for dajack761Send a Private Message to dajack761Edit/Delete MessageReply w/QuoteDirect Link to This Post
You have a PM.
WickedFieroGTP
Report this Post04-16-2014 12:43 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pms replied to.
hookdonspeed
Total ratings: 131
Report this Post04-16-2014 01:37 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
the `strut plates` are the they top pieces that hold the springs? if so any chance you have a set for an 88?
WickedFieroGTP
Report this Post04-17-2014 08:11 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent.
maybenot
Report this Post04-17-2014 08:29 PM Click Here to See the Profile for maybenotSend a Private Message to maybenotEdit/Delete MessageReply w/QuoteDirect Link to This Post
guages received. exactly as described. thank you very much!
Lou and Blue
Report this Post04-17-2014 10:07 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't see it on the list but would you happen to have a 3 spoke black steering wheel in really good condition, no center horn cap needed.
Thanks
Louis Duet
Baldwin, Long Island, NY
Where driving hard is SOP.
"Blue" <= '85 Fiero GT
Stock V6---Stock everything. Trying to keep it 'mostly' that way.
"Boo" <= '81 Delorean DMC-12
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
Neiland/Delman Engineered
Carbed and loving it! (Peugot 604 manifold) ---"Sorry purists"
WickedFieroGTP
Report this Post04-17-2014 10:22 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Not in black, but I have a few nice dark grey ones.
Lou and Blue
Report this Post04-17-2014 10:39 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you please email me pics and prices for the dark grey ones? Thanks!
Louis Duet
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
NC&StL
Report this Post04-17-2014 11:00 PM Click Here to See the Profile for NC&StLSend a Private Message to NC&StLEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent - looking for several parts. Thanks.
WickedFieroGTP
Report this Post04-18-2014 05:34 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm's and pics sent.
Luperman
Report this Post04-20-2014 07:22 AM Click Here to See the Profile for LupermanSend a Private Message to LupermanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you still have the E-brake lever/ handle( the one inside the car beside the drivers seat) how is the condition and price to be sent to 22644
Thanks Donald
cptsnoopy
Total ratings: 60
Report this Post04-20-2014 09:04 PM Click Here to See the Profile for cptsnoopySend a Private Message to cptsnoopyEdit/Delete MessageReply w/QuoteDirect Link to This Post
any chance you have a dot-matrix HVAC/radio bezel and an added bonus would be an aux gauge dot-matrix bezel in great shape?
Also looking for left and right inner door panels in grey for power window/power mirror with pocket in great shape.
do your interior plastic parts for the sill, A-pillar and B-pillar (with speakers) have all the mounting tabs and no cracks? I would love to get a whole set. These AZ cars bake in the heat and all the plastic cracks...
Charlie
Lurate
Report this Post04-21-2014 11:07 PM Click Here to See the Profile for LurateClick Here to visit Lurate's HomePageSend a Private Message to LurateEdit/Delete MessageReply w/QuoteDirect Link to This Post
sorry about confusion regarding mirrors. Will PM
[This message has been edited by Lurate (edited 04-25-2014).]
WickedFieroGTP
Report this Post04-21-2014 11:33 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Lurate:
Paypal payment sent last week for mirrors. Any update on when you'll be shipping?
Thanks
I have not received a payment from you. PM sent.
WickedFieroGTP
Report this Post04-21-2014 11:44 PM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
WickedFieroGTP
Member since Jun 2013
Charlie
Pm sent.
cptsnoopy
Total ratings: 60
Report this Post04-21-2014 11:56 PM Click Here to See the Profile for cptsnoopySend a Private Message to cptsnoopyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by WickedFieroGTP:
Pm sent.
Thank you
Replied!
Charlie
WickedFieroGTP
Report this Post04-24-2014 06:50 AM Click Here to See the Profile for WickedFieroGTPSend a Private Message to WickedFieroGTPEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
NC&StL
Report this Post04-26-2014 04:11 PM Click Here to See the Profile for NC&StLSend a Private Message to NC&StLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Received my parts yesterday, well packed and shipped quickly. Thanks!
