Parting out almost complete 85 gt by 86Fieroman
Started on | : 04-22-2014 01:28 PM |
Replies | : 62 (1270 views) |
Last post by | : 86Fieroman on 10-01-2014 04:05 PM |
Apr 22nd, 2014
86Fieroman Member Posts: 59 From: Denmark, WI Registered: Jul 2013
I have an 85 gt that is almost complete. I am parting the whole car out. I'm willing to let things go fairly cheap as long as the buyer pays for the shipping. The cradle is out of the car, there is no engine and there are no rims on it anymore. I'll be stealing a few parts off of it yet for my other cars but nearly everything else is for sale. Let me know what you need. Pictures to come soon.
01:28 PM
Midnight Member Posts: 371 From: Ohio Registered: Jun 2010
Got a working temp gauge?  I think it will work in my 87 se.
02:23 PM
I can't promise it works because the car has never ran but it looks good. I guess is prefer to sell the whole gauge cluster instead of only one however maybe I could just take that out.
02:40 PM
Fair enough. If you decided just to sell the gauge let me know.
02:41 PM
Apr 23rd, 2014
Ok, will do.
12:55 PM
May 16th, 2014
Still have tons of parts left. Almost everything is there minus the engine. Let me know what you need.
01:20 PM
Fierotregg Member Posts: 185 From: New Albany, Indiana, USA Registered: Nov 2011
What color interior?
01:45 PM
sniper69 Member Posts: 65 From: OH Registered: Jun 2013
By chance do you have the trim piece that goes on the front passenger quarter panel? It is the piece that is part of the GT trim that is on the bottom of the quarter panel near the door? I'm sure my description probably sucks and there is a name for the piece, but if needed I can take a pic of the piece I'm referring to.
01:46 PM
Robertzep2 Member Posts: 233 From: Akron, Ohio USA Registered: Oct 2012
Do you have the Radiator Splash Shields that are the bottom of the front Fascia(bumper). I really need the plastic pieces that connect the rubber to both wheel wells. Please see the link below for pictures: https://www.fiero.nl/forum/Forum4/HTML/069127.html[This message has been edited by Robertzep2 (edited 05-16-2014).]
01:58 PM
It is the light gray color interior, not the darker one. Sniper69, are you talking about the part of the ground effects. There is the rocker panel and then a small like 8 inch molding above that and that is what you want? And Robertzep2 i will check on that tonight when i get home, i probably do considering the whole radiator is in there.
02:34 PM
| quote | Originally posted by 86Fieroman:
It is the light gray color interior, not the darker one. Sniper69, are you talking about the part of the ground effects. There is the rocker panel and then a small like 8 inch molding above that and that is what you want? And Robertzep2 i will check on that tonight when i get home, i probably do considering the whole radiator is in there. |
Yes that small molding piece that is part of the ground effects above the rocker panel. Also if you have a factory cigarette lighter (not the plug itself but the actual lighter part that inserts in), I'd be interested in that also. And one last question - does the fiero that you are parting out have the performance sound?
02:56 PM
Ill check if i have the cigarette lighter. And no it does not have performance sound or i definitely would have snagged that out of it already.
03:14 PM
Ill check if i have the cigarette lighter. And no it does not have performance sound or i definitely would have snagged that out of it already. |
understandable, mine has performance sound but was looking for a part for it. I'll send a you a PM as well.
03:16 PM
I do have that molding, however I wasn't able to find a cigarette lighter but if you really wanted one I know a junkyard that has about five fieros and I'm sure I could get you one just for whatever he charges me. Also I do believe I have those plastic splash guards that robertzep2 was talking about. I'm assuming however that the only way to get those out would be to pull the whole radiator out?
07:29 PM
I do have that molding, however I wasn't able to find a cigarette lighter but if you really wanted one I know a junkyard that has about five fieros and I'm sure I could get you one just for whatever he charges me. Also I do believe I have those plastic splash guards that robertzep2 was talking about. I'm assuming however that the only way to get those out would be to pull the whole radiator out? |
Let me know what you would like for the molding, Also thanks for checking on the cigarette lighter - I'm not in dire need of one so will hold off on that for now.
08:00 PM
Venomous Member Posts: 65 From: Canton OH Registered: May 2013
Is the engine wiring harness still in the car? I need the engine side C500 and C203 connectors with some length of wiring still attached. Thanks. ------------------
 87 GT: Need to get road worthy first 92 Cutlass Vert: LX9/20s/tons more 01 Impala: Wifes taxi 99 Blazer: Parts hauler/winter beater
08:34 PM
May 17th, 2014
Here is a picture of the plastic pieces from the Radiator Splash Shields with the rubber removed.  Here are two views installed. _1_1.jpg) _2_1.jpg) Here is Rodney Dickman's new rubber pieces I am going to install to them  As for removing them... I have to look under the car, but can't because I am taking it to get new tires and a four wheel alignment this morning. I don't think the radiator needs removed though. If you have them and get them out, let me know what you want for them. -Robert
06:07 AM
cebix Member Posts: 1107 From: Poland Registered: May 2011
What shape are the sun visors in? Drooping a bit or holding fine? I would also need the center mirror and the little trim piece on the front passenger side fender right by the door. Would the rear side markers fit a notchie? Also '85.
Thanks.
07:00 AM
canfirst Member Posts: 641 From: Winnipeg Manitoba Canada Registered: Jul 2011
Would you have a drivers side wing stand and gasket in very good condition? Thanks!
08:38 AM
raysr11 Member Posts: 1254 From: Concrete, WA Registered: Nov 2008
Throttle cable?
02:28 PM
Quad Raider Member Posts: 865 From: Oologah, Oklahoma Registered: Dec 2010
Please pardon my ignorance about GTs, but does it have a sunroof?
08:44 PM
May 18th, 2014
1984whitesc Member Posts: 1043 From: Clayton, WI USA Registered: Jun 2006
What options does this car have? ------------------
 1984 White Fiero Sport Coupe (Juliet) in restoration https://www.fiero.nl/forum/Forum1/HTML/089093.html 1988 Red Fiero Standard Coupe (Bella) in restoration 1990 Black Buick Reatta (Noir) 2002 White Chevy Impala base(Haylie)
12:59 AM
mr-riff Member Posts: 164 From: Whitestown Indiana Registered: Nov 2007
Do you have the front aero nose available? can you provide some pictures?
07:08 PM
Rugger Member Posts: 137 From: Bay City, Michigan, USA Registered: Sep 2012
1) Seat Mechanism Covers? 2) Drivers Side Front Fender? Red Over Silver? 3) Steering Wheel? 4) Black Rain Trough Trim For Above The Driver Side Window? 5) Short Rubber Section That Attaches To Front Passenger Side Under Hood ... 6) WIndshield Washer Nozzles ------------------
08:53 PM
10:38 PM
May 19th, 2014
John W. Tilford Member Posts: 413 From: Bloomington, Indiana, USA Registered: Aug 2005
I need a "PON" (driver's side) GT rear light assembly. Mine has one of the "long shaft vertical attachment screw goes into" tabs broken off. John W. Tilford, johntilford@comcast.net, mobile 812 219 8235
09:50 AM
BabyEating Dingo Member Posts: 132 From: San Antonio, TX Registered: Mar 2014
I need a passenger side "TIAC" tail light. Let me know if you have one.
11:35 AM
Niterrorz Member Posts: 4119 From: Registered: Sep 2010
message sent for trans and other components.
02:46 PM
mrossum Member Posts: 804 From: lake havasu city, az Registered: Oct 2000
i could used the right side engine vent cover is it is there and not cracked ------------------ 87 coupe 4 cyl, 5 speed
04:17 PM
May 27th, 2014
Hello all. I am sorry for not responding for so long, I was out of town all last week and I just got back. I will try to get a response to everyone by tonight at the latest.
12:58 PM
| quote | Originally posted by Venomous:
No I am sorry, I only have the interior side of the wiring harness.
01:05 PM
01:09 PM
| quote | Originally posted by cebix:
Thanks. |
The sunvisors appear to be brand new along with the headliner actually. They are the lighter grey color. I beleive I have the center mirror for you as well. The side markers will fit a notchie, as an 85 gt is actually still a notchie. I could email you pics if you like.
01:12 PM
| quote | Originally posted by canfirst:
Would you have a drivers side wing stand and gasket in very good condition? Thanks! |
I do have it but I am actually looking to keep the spoiler and stands as I have two other gt's and would like a spare in case I ever need a replacement. Sorry.
01:14 PM
| quote | Originally posted by raysr11:
Throttle cable? |
I do have the throttle cable, feel free to pm me about it if you still need it.
01:15 PM
| quote | Originally posted by mr-riff:
Do you have the front aero nose available? can you provide some pictures? |
I do have the front aero nose, I am not really looking to sell it as I would like that as a spare too in case I get in an accident but feel free to pm me if you would like more info. I could email you pics if I do sell it, the pip thing normally gives me problems. Let me know I guess.
01:17 PM
| quote | Originally posted by Rugger:
I do not have any seat mechanism covers. I have a front fender, it is silver and it appears the previous owner sanded on it a little but it is still silver. I do have the steering wheel, however 85 gt steering wheels are different from 86-88 gt steering wheels, but i'm not sure what you are looking for. Yes I do have the rain trough. I believe I have what you are looking for in regards to that rubber piece, I would have to get or send you a picture to make sure though. And I also do have the windshield washer nozzles.
01:21 PM
The sunvisors appear to be brand new along with the headliner actually. They are the lighter grey color. I beleive I have the center mirror for you as well. The side markers will fit a notchie, as an 85 gt is actually still a notchie. I could email you pics if you like. |
Very nice. I would be interested in the headliner but without the "frame", only the bare material if it can be folded because shipping the whole thing I guess would cost me too much. Please send me pics and prices. I PM'ed you me email.
02:12 PM
Does the car have a sunroof? If so, do the metal roof brackets have any rust?
02:19 PM
Playindirty1 Member Posts: 51 From: Omaha, NE, USA Registered: Apr 2014
Radiator fan & assembly? Also center console rubber like shift plate thats under the ash trays and matching rubber like gauge cluster/radio housing? Garrett 4025156498. Ps. not sure if 85gt fan is interchangeable with my 86Gt? 5speed
03:48 PM
