  The Mall
  fieroguru 12" C4 Brake Rotor Upgrade for 88 Fieros (Page 1)
fieroguru 12" C4 Brake Rotor Upgrade for 88 Fieros by fieroguru
Started on: 05-18-2014 02:02 PM
Replies: 43 (3018 views)
Last post by: fieroguru on 11-23-2020 08:10 PM
Report this Post05-18-2014 02:02 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieroguru Performance reopened on March 13th, 2016
After the successful launch of my 13” brake kit and feedback from potential customers about additional weight, 17” wheel requirements, and price, I decided to offer this 12” C4 brake kit to give potential customers more options.
Credit must first be given to Fiero Addiction as he came up with the original C4 12” kit that used a dog bone style mount to avoid caliper to upper a-arm interference issues. Unfortunately, Fiero Addiction closed up shop and left the Fiero market several years ago.
Like my 13” kit, I took a clean sheet approach and designed the bracket as I though it should be. As part of the design process I added material around the countersunk bolt holes and the caliper side geometry of the bracket is the same as my 13” kit. As a result of this redesign, my bracket for this 12” C4 kit doesn’t match any caliper bracket ever marketed. So while the concept of this brake upgrade is nothing new, the caliper bracket I designed certainly is.
Some of the key benefits of this kit are:
• Use of stock calipers, brake hoses and parking brake cables keeps cost to a minimum.
• Stock brake bias and parking brake function retained.
• 15% increase in brake rotor diameter for improved visual impact behind 16+” wheels.
• 21% increase in brake system mechanical advantage due to caliper being further from wheel center.
• 12% increase in rotor surface area to increase heat dissipation and reduce potential for brake fade.
• Available in Drilled/Slotted w/Zinc coating to minimize additional weight and improve appearance.
• No interference issues between the caliper and the upper a-arm.
The downsides of this kit are:
• Interference between the nose of the lower a-arm and the backside of the rotor - how to clearance the lower a-arm is shown in the instructions (as well as below).
• Not recommended for use with Lowering ball joints - lowering ball joints will significantly increase the rotor/a-arm interference.
• Weight – this kit will add about 3 lbs per wheel over the stock 88 rotor.
• Wheel requirement – this kit requires 16+ wheels
The Kit consists of the following parts (shipped in 2 boxes):
• 4 - 12” rotors drilled to the 5x100mm pattern
• 4 – steel caliper brackets to relocate the stock brake calipers, painted semi-gloss black
• 4 – plastic expandable concentric rings
• 8 - grade 10.9 M12 bolts
• 1 – set of detailed instructions with pictures
Pricing Summary: All prices shipped for US and Canadian addresses unless noted.
Hardware Kit only – Front:.....................$100
Front Only w/ plain rotors:.....................$200 (+$35 shipping surcharge to Canada)
Front Only w/ Drilled/Slotted/Zinc Rotors:$225 (+$35 to Canada)
Hardware Kit Only – full car:...................$200
Full Kit with Plain Rotors:.......................$400 (+$70 to Canada)
Full Kit with Drilled/Slotted/Zinc Rotors:....$450 (+$70 to Canada)
I will also supply just the rotors drilled to the 5x100 pattern (slight upcharge for other custom patterns)
Rotors - 4 Drilled/Slotted/Zinc Rotors .....$265 (+70 to Canada)
*** NOTE: My rotor supplier changes patterns rather frequently, so I can’t guarantee the exact drilled/slotted pattern you will receive unless I have rotors in stock. I will guarantee that all 4 rotors in your kit will be a matched set.
You can drill the rotors for the 5x100 pattern with a 1/2" drill bit and an old wheel bearing with the instructions in this thread:
https://web.archive.org/web...um2/HTML/120346.html
Inventory:
The initial launch purchase was for 30 brackets and rings (in stock now). As the initial batch is depleted, I will start ordering them in quantities of 100 each and try to never have fewer than 5 full hardware kits in stock and ready to ship.
Rotors will not normally be stocked. They will be ordered as payment is received for the brake kit. It normally takes 2-4 days for the rotors to arrive and 1 day turn around for the drilling and packaging.
Payment:
Payment in full is due at time of order. Your rotors will be ordered the same day and your kit should ship about 5-7 business days from time of order. Payment can be via paypal, postal money order, check (shipment delayed for clearance), or cash. If interested in ordering, please PM me for details.
Here are a few pics to show the change in visual impact of this rotor kit.
Stock size rotor setup:
Caliper bracket, concentric ring, and rotor installed:
New 12" rotor installed:
Interference issue with lower a-arm:
Modification to eliminate the interference:
Why lowering ball joints are not recommended:
http://fieroguruperformance.com/
[This message has been edited by fieroguru (edited 04-07-2016).]
Report this Post05-19-2014 07:50 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Monday Bump!
Steven Snyder
Total ratings: 106
Report this Post05-20-2014 12:11 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks great!
Could you post a photo of the rear caliper with the e-brake cable attached?
My WCF brackets put the e-brake cables at a steep angle and they rub on the bottom of the strut.
Also, how much for front brackets and bolts only? (no rings or rotors)
rourke_87_T-Top
Report this Post05-20-2014 12:52 PM Click Here to See the Profile for rourke_87_T-TopSend a Private Message to rourke_87_T-TopEdit/Delete MessageReply w/QuoteDirect Link to This Post
• Wheel requirement – this kit requires 16+ Wheels
I used the stock '87 crosslace 15" GT wheels front and rear on my '88 Formula during the poor weather season. It just required a slight modification to corner of calipers, a couple mm's and careful wheel weight placement.
Edit, I have original Fieroaddiction brackets, they're slightly different and also rotate the calliper.
[This message has been edited by rourke_87_T-Top (edited 05-20-2014).]
Report this Post05-20-2014 06:27 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Steven Snyder:
Looks great!
PM sent
I would rather have fewer sales by not marketing the kit to fit 15" wheels than to have a single kit returned because it didn't fit and the customer wasn't willing to do the mods to "Make it fit".
My brackets were designed to place the edge of the pad very close to the edge of the rotor to maximize braking potential vs. being as tight as possible to the rotor in an attempt to fit smaller wheels.
[This message has been edited by fieroguru (edited 05-20-2014).]
rourke_87_T-Top
Report this Post05-20-2014 11:00 PM Click Here to See the Profile for rourke_87_T-TopSend a Private Message to rourke_87_T-TopEdit/Delete MessageReply w/QuoteDirect Link to This Post
15's are outdated but some like the look of stock, or they're cheap, lol, so I only mentioned it because it is a very simple slight modification to the outer edge of the calipers, FieroAddiction also stated that it required or suggested 16" or larger. I was curious if your kit may fit with a slight mod, maybe without knowing or intending.
Report this Post05-26-2014 07:44 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Monday Bump!
Report this Post06-02-2014 07:50 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
jsmorter
Report this Post06-07-2014 12:38 PM Click Here to See the Profile for jsmorterSend a Private Message to jsmorterEdit/Delete MessageReply w/QuoteDirect Link to This Post
What pad would you recommend be used with this kit?
Report this Post06-07-2014 01:04 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Brake pads are really a personal preference and depend on how the car is going to be use. Wagner Thermoquiets are quite popular for most daily drivers and greenstuff pads for more performance oriented driving. Once you start road racing, then you want a dedicated race pad.
jsmorter
Report this Post06-07-2014 02:45 PM Click Here to See the Profile for jsmorterSend a Private Message to jsmorterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had my 88 the last 150,000 miles on it. It tends to warp rotors. Is that less a problem with this kit since you have a larger surface area that allows for better cooling?
Report this Post06-07-2014 03:25 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The larger rotors will dissipate more heat at a faster rate and make it much harder for the brakes to reach the point of fading.
Rotors can warp for various reasons and some of them have nothing to do with the rotors. For example, it you have a sticking/dragging caliper you will overheat any rotor to the point of warping it. Automatic cars also tend to warp rotors more than manual transmission cars. After an aggressive stop, the rotor is very, very hot. To stay stopped, the automatic car has to keep some significant pressure applied to the caliper/rotor (to overcome the vehicle push from the torque converter) and the exposed portions of the rotor cool faster than the portion clamped in the caliper. After an aggressive stop, it is important to keep rotating the rotor, even slowly, to help it cool more evenly.
Before you do a brake upgrade it is important to check the current brake hardware to make sure it is performing as it should.
[This message has been edited by fieroguru (edited 06-07-2014).]
Report this Post06-09-2014 07:47 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Luke
Report this Post06-16-2014 12:32 AM Click Here to See the Profile for LukeClick Here to visit Luke's HomePageSend a Private Message to LukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
Report this Post06-23-2014 07:47 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
kennn
Report this Post06-26-2014 10:26 PM Click Here to See the Profile for kennnSend a Private Message to kennnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieroguru,
Did you consider 13" C4 brake rotors for the brake conversion?
Ken
'88 Formula V6
'88 GT TPI V8
Report this Post06-27-2014 06:36 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by kennn:
Fieroguru,
Ken
I have considered hundreds of rotors for brake kits, but very few have the right rotor thickness to allow reuse of the 88 calipers (about .75" to .81" - the C4 13" rotors are 1.1" BTW) and proper depth to allow room for the needed caliper bracket.
The rotor I use for my 13" brake kit for the 88 is thin enough (20mm) to work with the stock 88 calipers and about 2.5 lbs lighter per rotor than the C4 13" rotor.
Report this Post07-28-2014 07:49 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
Report this Post08-11-2014 07:59 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
GodSend
Report this Post08-11-2014 09:26 AM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
Purchased a set of these a while back (hardware only) and have yet to install. Looking at the pictures I am not sure I ever received the countersunk bolts (I will have to check though, its been awhile). Should they have been included with the brackets?
Report this Post08-11-2014 12:50 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
All my kits ship with the brackets, rings, bolts and instructions, but other people have sold a similar version of this kit before and only supplied the steel brackets (no rings or bolts). So I guess it depends on who you purchased them from on whether the bolts (and concentric rings) should have been included.
If you purchased the kit from me, I will gladly send the parts that were not shipped, but I am pretty sure you didn't buy the hardware kit from me (I have only sold one hardware kit to a Canadian customer since I started offering this kit in May).
If you purchased the kit from someone else, I can sell you whatever parts you are missing (+ my instruction sheet).
GodSend
Report this Post08-12-2014 11:36 AM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is most likely the case.. Ive had these for a few years. If the bolts and rings are useable, lets chat over PM.
kennn
Report this Post08-12-2014 11:59 AM Click Here to See the Profile for kennnSend a Private Message to kennnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieroguru,
I've got 1 1/2" 'lowering spindles' on the front of my '88 GT that I purchased from Ryane Motorsports (nee Held Motorsports). They are not lowering ball joints. Do you have a sense if there would be the same clearance issues with the rotor/control arm as with the lowering ball joints? It seems, if I am seeing it properly, that it would be similar to the stock ball joint situation since I am employing a stock ball joint.
Ken
Report this Post08-12-2014 02:27 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieroguru,
Ken
I have never tested a kit with lowering spindles, but do not expect that setup to cause any interference issues (assuming stock lower control arms).
jsmorter
Report this Post08-14-2014 05:26 PM Click Here to See the Profile for jsmorterSend a Private Message to jsmorterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you PM me a phone number so I can order a full set?
Steelsoul
Report this Post08-15-2014 03:00 PM Click Here to See the Profile for SteelsoulSend a Private Message to SteelsoulEdit/Delete MessageReply w/QuoteDirect Link to This Post
No way to modify the lower a-arm if you have the 1 inch lower ball joints?
I ordered these when I was getting all of my suspension parts.
Guess I will have a new set to sell soon.
Report this Post08-15-2014 09:12 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have never mocked the rotors up with the lowering ball joints to see exactly how much needs to be removed (depends on how low you want the car), but it will be significant and likely will be to the point that the lower ball joint pocket in the lower a-arm will be compromised.
Report this Post08-25-2014 07:40 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post09-15-2014 07:56 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
johnyrottin
Total ratings: 85
Report this Post09-15-2014 09:56 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
And they are sexy as hell...drilled and slotted ones. Not that they perform better just love the look.
[This message has been edited by johnyrottin (edited 09-15-2014).]
Report this Post10-13-2014 07:59 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
DKcustoms
Report this Post10-13-2014 05:24 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
$450 for the full kit?
That's a great packaged deal and I'd love this upgrade
Does this not work on the 84-87s?
My 86 SE is gonna need brakes soon, and as I'm doing the whole suspension at the momemt, I'd love some fresh brakes too
Report this Post10-13-2014 08:55 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct.
Sorry, it does not. This kit is only for the 88's. The rear rotors, front concentric rings, and all the caliper mounting brackets and bolts would be different for an 84-87 kit (plus you would have to buy the 88 Fiero calipers).
[This message has been edited by fieroguru (edited 03-05-2016).]
FieroJuice
Report this Post12-12-2015 02:00 PM Click Here to See the Profile for FieroJuiceSend a Private Message to FieroJuiceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump even if it's not active for awhile longer. Great stuff.
Fierofreak00
Total ratings: 170
Report this Post01-27-2016 07:19 PM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for a complete set if your up to getting your shop back together. -Jason
Report this Post03-05-2016 01:43 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieroguru Performance reopened March 13th, 2016
[This message has been edited by fieroguru (edited 03-28-2016).]
Report this Post04-25-2016 08:16 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
yellow fever
Report this Post04-28-2016 01:00 PM Click Here to See the Profile for yellow feverSend a Private Message to yellow feverEdit/Delete MessageReply w/QuoteDirect Link to This Post
With some modifying, would these work on the 84 -87 cars?
Report this Post04-28-2016 04:19 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope.
See sluppy123 for the 84-87 version of this kit.
flimbob
Report this Post11-09-2020 11:16 AM Click Here to See the Profile for flimbobSend a Private Message to flimbobEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
