  The Mall
  Need HELP to install my other parts WTB Cooling Pipe Bracket Support (Frame Side) (Page 1)
Need HELP to install my other parts WTB Cooling Pipe Bracket Support (Frame Side) by fierogtx
Started on: 06-30-2014 05:17 PM
Replies: 52 (746 views)
Last post by: fierogtx on 07-25-2014 09:57 PM
fierogtx
Report this Post06-30-2014 05:17 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
one of my friend ( Danyel ) will be at frazee this week if anyone can have the brackets floors section . i have paypal ready and you just need to bring it to him so if anyone can cut that part that will be very appreciated
like the title says im looking for (rust free or little rust no hole or big rust one that i will be able to sandblast to remove rust) coolant brackets supports with the floor sheet section that are welded with ( 2 side driver and helper )( the one that have 2 hole for mounting the cooling pipe bracket ) that is welded to the chassis (frame) mine is very rust anbd have a hole . i dont need the smal clamp that you bolt under the cooling pipe just the upper section that are welded to the floor chassis .if someone can cut it at a junkyard or have one fiero for part out and want to cut it with a part of the frame that would be nice . i have paypal ready to pay
here are pictures of how i want it cut and the explanation at the bottom of the pics thanks all
1.
2.
3.
4.
5.
6.
7.
it is from the passenger side but the driver side will be cut like that from all the pic that have above here are the explanation for each side for the rear side like you looked for the pic under the car you need to cut where the other sheet metal contact under the car pics
for the side that goes forward the driver side you cut where the other sheet metal are welded under the car pics 4.5.6
for the front side you looked from the interior pic and you cut where the sheet bracket studs are interior pic 1.2.3
for the side forward the rocker panel you cut with the small sheets that are welded together if possible because i want to tach welded like original the sheet have two tak welded ( if im not wrong there are 2 tach weld on that sheet ) with the bracket pic 4.5.6.7
for the rear side you cut where the other metal sheet are pic 4.5.6.7
thanks a lot all i reallu need this thanks a lot
[This message has been edited by fierogtx (edited 07-20-2014).]
fierogtx
Report this Post06-30-2014 10:42 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Gambit
Report this Post07-01-2014 03:10 PM Click Here to See the Profile for GambitSend a Private Message to GambitEdit/Delete MessageReply w/QuoteDirect Link to This Post
Honestly, is no one in the USA parting out a Fiero? If everything fails and your really in dire need i will hook you up from the NL. You only pay shipping about 22 bucks
fierogtx
Report this Post07-01-2014 08:46 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for your help i hope someone will help me in the usa or canada can you pm me about that because i need one asap because my project is stopped for that reason
fierogtx
Report this Post07-02-2014 08:50 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-03-2014 12:12 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-03-2014 10:16 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
Member since Sep 2011
bump
fierogtx
Report this Post07-05-2014 01:25 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
FieroG97J
Report this Post07-05-2014 10:27 AM Click Here to See the Profile for FieroG97JSend a Private Message to FieroG97JEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
fierogtx
Report this Post07-06-2014 09:45 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-06-2014 07:14 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-06-2014 11:20 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-07-2014 11:00 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-08-2014 01:00 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-08-2014 10:24 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-09-2014 06:27 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
jaskispyder
Total ratings: 205
Report this Post07-09-2014 09:05 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
can't help with the part, but what about welding in a piece of sheet metal? Then weld on a few nuts to hold a pipe bracket?
[This message has been edited by jaskispyder (edited 07-09-2014).]
fierogtx
Report this Post07-09-2014 10:04 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
im not too god in body and prefer to have oem type with welded bracket but i will not have choice if nobody have it or wanted to cut it
fierogtx
Report this Post07-09-2014 11:15 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-11-2014 12:51 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-11-2014 07:03 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump for help needed
fierogtx
Report this Post07-12-2014 10:23 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-12-2014 06:27 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-12-2014 07:21 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-13-2014 09:36 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-13-2014 10:15 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-14-2014 11:07 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-15-2014 09:19 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-16-2014 08:53 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-17-2014 10:51 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-18-2014 06:45 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-18-2014 05:56 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-19-2014 10:32 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-19-2014 01:12 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-19-2014 03:08 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-19-2014 04:24 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-19-2014 06:36 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-19-2014 09:32 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
fierogtx
Report this Post07-20-2014 12:39 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
fierogtx
Report this Post07-20-2014 02:38 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierogtx
bump
