  The Mall
  Custom AC Hoses (Page 4)
Custom AC Hoses by 2002z28ssconv
Started on: 07-15-2014 10:24 PM
Replies: 185 (13218 views)
Last post by: 2002z28ssconv on 02-16-2024 03:17 PM
2002z28ssconv
Total ratings: 51
Report this Post03-06-2018 02:26 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hoses sent
qwikgta
Total ratings: 84
Report this Post03-06-2018 03:49 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for not reading the entire post. So bottom line, we send you the 3800 end and the Fiero end and you send us back a working A/C hose, correct?
Does your price include shipping back to us, or do we pay that too (or is it included in the price).
TIA.
Rob
2002z28ssconv
Total ratings: 51
Report this Post03-06-2018 04:19 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shipping to you in the continental US is included in the price.
Set of hoses with switch port, including core charge for both ends: $180. (125+20+30+5 PayPal)
(This is what you will pay if I haven't received your cores yet... otherwise I wait for your cores.)
Set of hoses with switch port, including core charge for Fiero end: $160. (125+30+5)
Set of hoses with switch port, including core charge for 3800 end: $150. (125+20+5)
Set of hoses with switch port, with no core charge: $129. (125+4)
As always, checks, money orders and such are still an option and you won't pay the $5 PayPal fee.
These are the ends I use.
This is what you'll receive.
[This message has been edited by 2002z28ssconv (edited 03-06-2018).]
Akcraig85
Report this Post04-25-2018 11:10 PM Click Here to See the Profile for Akcraig85Send a Private Message to Akcraig85Edit/Delete MessageReply w/QuoteDirect Link to This Post
I sent you a pm but I’m not 100% sure my pms work. I guess this message is to test that.
2002z28ssconv
Total ratings: 51
Report this Post04-26-2018 07:54 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
replied to PM
Carl Calderone
Report this Post04-26-2018 09:31 PM Click Here to See the Profile for Carl CalderoneSend a Private Message to Carl CalderoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm interested in a set...I believe I already have both ends here. Do you need to know the length ? Or is there a standard configuration that you are making... I'm not sure of the terminology
though... can you explain? switch port???
[This message has been edited by Carl Calderone (edited 04-26-2018).]
2002z28ssconv
Total ratings: 51
Report this Post04-27-2018 10:33 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't need to know the length.
All I really need to know is what compressor you will use. From that, there are a couple of different aluminum ends (known as manifolds) that I can use to build the hoses.
So what is a switch port?
You'd think it was a port for a switch but that's not really true in this case. It's a port with a Schrader valve in it that is built into the hose. A pressure sensor screws onto this port and sends a signal to the PCM telling it what the pressure is inside the hose. From that, the PCM controls the compressor to regulate the optimal pressure in the AC lines.
L.I. Fieros
Report this Post04-29-2018 09:09 AM Click Here to See the Profile for L.I. FierosSend a Private Message to L.I. FierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent about getting a set of hoses!
handymanpat
Report this Post06-15-2018 07:23 PM Click Here to See the Profile for handymanpatSend a Private Message to handymanpatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just got my ac lines today and they are just beautiful!
So professional and clean and they are so well made. Perfect timing also since I will be working on the car this weekend!
Thanks for everything.
Pat Moody
pat moody
KaijuSenso
Report this Post07-06-2018 02:07 PM Click Here to See the Profile for KaijuSensoSend a Private Message to KaijuSensoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you able to make a set for a 3400 swap? I have both ends necessary but now am not sure if the switch port is necessary for an OBD2 LA1? Are the overall hose lengths the same?
2002z28ssconv
Total ratings: 51
Report this Post07-06-2018 02:14 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3400 manifold that bolts to the back of the compressor has longer tubing on it so the rubber sections are shorter.
I can do them as long as you send me the 3400 manifold. If you have the Fiero manifold too, even better.
I'll let you know my address in your PM.
[This message has been edited by 2002z28ssconv (edited 07-06-2018).]
CrazyDragn
Report this Post07-11-2018 04:48 PM Click Here to See the Profile for CrazyDragnSend a Private Message to CrazyDragnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you still making these if so I have the 3800 hoses but I do not have the hoses they connect to the firewall Fiero AC units If you were to supply the port how much would you charge for me to have this done if I send you the core?
Notchie to Fast Back Conversion
After Market Steering Wheel Conversion
2002z28ssconv
Total ratings: 51
Report this Post07-11-2018 07:49 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
155
cam-a-lot
Total ratings: 99
Report this Post07-12-2018 12:27 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it matter which year of 3800 compressor is used? I have seen a few different compressor part numbers on Rock Auto for 3800 motors from 2002-2012,
Not sure if they have the same fittings for the hose? Also, would be great to charge a few bucks more and include the correct seals for the Fiero end and compressor end? just a suggestion
CrazyDragn
Report this Post07-12-2018 09:19 PM Click Here to See the Profile for CrazyDragnSend a Private Message to CrazyDragnEdit/Delete MessageReply w/QuoteDirect Link to This Post
What if I have everything except the fiero core piece? Then how much?
2002z28ssconv
Total ratings: 51
Report this Post07-13-2018 06:50 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
$155.00 (plus $5.00 for paypal if applicable)
2002z28ssconv
Total ratings: 51
Report this Post07-13-2018 02:07 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
2002z28ssconv
Member since Jun 2005
I recommend buying a compressor from a 99 Grand Prix... Or any other mid sized 3800 series 2. Some of the full size cars had compressors with one 1/2" port and one 9/16" port. My car uses this compressor but you have to be careful lining up the hoses on the back of the compressor or they can leak. Series 3 Grand Prix uses another compressor entirely. I have to use the aluminum manifold from that model car because the ports are configured completely different than the series 2 models.
The majority of builds use the standard series 2 compressor. For these I use the manifold from just about any mid sized (2 door) car with a Series 2 3800.
If your donor is a full sized (4 door) car it likely had a larger suction port on the back of the compressor. I still use the same manifold as above but if I know ahead of time I can turn a sleeve on my lathe that goes over the manifold's guide tube so that it fits properly inside the wider port. A wider seal is required but is readily available at most auto stores.
If your donor is a Series 3 Grand Prix, I have to use the manifolds from the S3 Grand Prix. Again, not an issue if I know ahead of time.
I normally quiz people on their setup prior to making their hoses.
As for the seals. I've given the part numbers here but I'd have to charge more to make it worth my time to buy them for you. And we Fiero folk are CHEAP!
[This message has been edited by 2002z28ssconv (edited 07-13-2018).]
2002z28ssconv
Total ratings: 51
Report this Post07-13-2018 02:10 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
2002z28ssconv
Get an assortment from Autozone , Advance or O'Reileys. The packages they have here have the flat washer type for the 3800 end as well as the green O-ring type for the Fiero end.
If your compressor has two different size ports, get this one.
http://www.autozone.com/coo...l-sfi-sc/529591_0_0/
If your compressor has two ports of the same diameters, get this one.
http://www.autozone.com/coo...-sc/529580_912831_0/
cam-a-lot
Total ratings: 99
Report this Post07-13-2018 08:30 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great info, thanks!!
And not ALL Fiero owners are cheap buggers..!!! (just 97.4 %)....
2002z28ssconv
Total ratings: 51
Report this Post07-13-2018 09:28 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately the other 2.6% are broke.
longjonsilver
Report this Post07-14-2018 05:24 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by crashmydaytona:
picture of what I am sending you. Is this correct?
Nope. The left is good (Fiero). The right one came from a full size 3800 car. They point the hoses back in the opposite direction from where they need to go. The midsized 3800 cars usually have the right ones.
Please excuse my ignorance but which cars are the midsized 3800 cars? And did i understand it right that you can make these for 84 Fieros?
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun! 3800 SC swap to come!
2002z28ssconv
Total ratings: 51
Report this Post07-14-2018 06:03 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Regal, Grand Prix, Monte Carlo
Pretty much the 2 door models.
Must be 3800 cars though.
The 4 door and luxury cars won't have the right manifolds, even if they do have 3800s.
And yes, 84 Fiero is no problem.
[This message has been edited by 2002z28ssconv (edited 07-14-2018).]
KaijuSenso
Report this Post07-30-2018 07:08 PM Click Here to See the Profile for KaijuSensoSend a Private Message to KaijuSensoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you post the part number for the hi pressure sensor that fits your switch port?
2002z28ssconv
Total ratings: 51
Report this Post07-31-2018 07:02 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, I normally ask if you need one and throw one in as a courtesy. I can drop one in the mail for you. I usually grab a few while I'm "shopping" for the 3800 manifolds at the salvage yard.
But the part number is 13587697.
Or MT3518 at autozone.
[This message has been edited by 2002z28ssconv (edited 07-31-2018).]
1MohrFiero
Total ratings: 157
Report this Post08-01-2018 07:24 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent
1MohrFiero
Total ratings: 157
Report this Post08-07-2018 04:54 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
New PM sent
1MohrFiero
Total ratings: 157
Report this Post08-07-2018 07:35 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
1MohrFiero
Member since Apr 2003
87 GT 3800SC series 3.
Thanks
1MohrFiero
Total ratings: 157
Report this Post08-08-2018 07:16 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Paypal and reply sent
FieroObsession
Report this Post08-10-2018 08:35 PM Click Here to See the Profile for FieroObsessionSend a Private Message to FieroObsessionEdit/Delete MessageReply w/QuoteDirect Link to This Post
I’d like a set! PM sent!
1MohrFiero
Total ratings: 157
Report this Post08-13-2018 02:56 PM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a PM
Revoevom
Report this Post08-13-2018 05:50 PM Click Here to See the Profile for RevoevomSend a Private Message to RevoevomEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wish I knew I had this option before I had mine done locally for about twice the price.
Bluwolf
Report this Post10-20-2018 08:33 AM Click Here to See the Profile for BluwolfSend a Private Message to BluwolfEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM Sent
ltlgt88
Report this Post01-10-2019 03:14 PM Click Here to See the Profile for ltlgt88Send a Private Message to ltlgt88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you still selling these?
I have nothing for a core and would like to just have a whole set and the sensor provided too.
Does anyone have how to wire this into your pcm to work properly?
[This message has been edited by ltlgt88 (edited 01-10-2019).]
2002z28ssconv
Total ratings: 51
Report this Post01-11-2019 07:23 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes
But I don't have any Fiero cores right now. So I can't make one until I get a core. Someone was supposed to be sending an extra one with theirs but I haven't received them yet. I can let you know if I get one.
As for wiring, yes it has to be part of the engine harness but if it was made by any of the main people in recent history it should be there already.
On a side note, I will be changing prices soon. Making car stuff is becoming more of a business than a hobby and with that I have to start paying taxes and other overheads. It won't happen this month, maybe February. Anybody who had already contacted me will still get today's prices.
PHM1990
Report this Post07-30-2019 09:18 AM Click Here to See the Profile for PHM1990Send a Private Message to PHM1990Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent. Look forward to working with you!
cam-a-lot
Total ratings: 99
Report this Post07-31-2019 07:17 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a review and comment- I have purchased this hose a few months ago and it works great- excellent quality and fit. You can unscrew the sensor from any junk yard 3800 car by hand and thread it into the port that comes on the line.
2002z28ssconv
Total ratings: 51
Report this Post08-01-2019 08:08 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Cam-A-Lot!
I've replied to all the PMs.
For quicker response (I don't get to check here as often as I'd like) email or text is best. My GMAIL account is chjesthe@gm..... From there I'll give out my cell # as well.
I just posted a Youtube video too.
https://youtu.be/Vk9RP7PJyr0
[This message has been edited by 2002z28ssconv (edited 08-01-2019).]
bjc 350
Report this Post08-05-2019 12:48 PM Click Here to See the Profile for bjc 350Send a Private Message to bjc 350Edit/Delete MessageReply w/QuoteDirect Link to This Post
Chuck, You have a PM.
bjc 350
Report this Post08-10-2019 12:59 PM Click Here to See the Profile for bjc 350Send a Private Message to bjc 350Edit/Delete MessageReply w/QuoteDirect Link to This Post
You should be seeing hose ends today. Check your PM for details.
Bryan
Propianoplayer
Report this Post08-25-2019 10:51 PM Click Here to See the Profile for PropianoplayerSend a Private Message to PropianoplayerEdit/Delete MessageReply w/QuoteDirect Link to This Post
sent PM interested in a set of hoses. My 1986 hoses are leaking at the high side crimp. Just looking for a rebuild not conversion.
